rendering problem
D
dpa
Mon, May 25, 2020 9:08 PM
Hey,
I was using OpenSCAD because it's so reliable, but yesterday I was very
disappointed. I researched the frequing same problem for almost exactly one
day now and just couldn't get any further. There are probably several in
one.
For this question mail I didn't use my own polygons, just circle,
rotate_extrude and minkowski with a sphere.
The preview is fine, the rendering doesn't say enything but stays empty.
Thats my first question: why is there no error AND no output?
It brings an error when you change the "add_rotate" in cutomizer. What
brings me to the 2nd question: why does a rotation bring different errors?
And last but not least: how can I bring this object to render with a
"add_rotate"=7 at all? Where is the error / what I'm doing wrong?
best
Dietrich
Hey, I was using OpenSCAD because it's so reliable, but yesterday I was very disappointed. I researched the frequing same problem for almost exactly one day now and just couldn't get any further. There are probably several in one. For this question mail I didn't use my own polygons, just circle, rotate_extrude and minkowski with a sphere. The preview is fine, the rendering doesn't say enything but stays empty. Thats my first question: why is there no error AND no output? It brings an error when you change the "add_rotate" in cutomizer. What brings me to the 2nd question: why does a rotation bring different errors? And last but not least: how can I bring this object to render with a "add_rotate"=7 at all? Where is the error / what I'm doing wrong? best Dietrich
D
dpa
Mon, May 25, 2020 9:10 PM
here is the file...
Am Mo., 25. Mai 2020 um 23:08 Uhr schrieb dpa sc@pankd.de:
Hey,
one.
best
Dietrich
here is the file... Am Mo., 25. Mai 2020 um 23:08 Uhr schrieb dpa <sc@pankd.de>: > Hey, > I was using OpenSCAD because it's so reliable, but yesterday I was very > disappointed. I researched the frequing same problem for almost exactly one > day now and just couldn't get any further. There are probably several in > one. > > For this question mail I didn't use my own polygons, just circle, > rotate_extrude and minkowski with a sphere. > The preview is fine, the rendering doesn't say enything but stays empty. > Thats my first question: why is there no error AND no output? > It brings an error when you change the "add_rotate" in cutomizer. What > brings me to the 2nd question: why does a rotation bring different errors? > And last but not least: how can I bring this object to render with a > "add_rotate"=7 at all? Where is the error / what I'm doing wrong? > > best > Dietrich >
Mon, May 25, 2020 10:06 PM
Congratulations! You have found a bug in the minkowski operator. That is
what I get with Thrown Together:
Yes, there is some reversed face in the minkowski! Just the minkowsky
renders fine but CGAL finds an error when it is boolean operated with the
connector. That face seems to be the cause.
I have never seen that bug before. The bug seems to be related to the
number of faces in the sphere and edges in the extrusion circle. Something
odd happens when both $fn are equal to 6.
Em seg., 25 de mai. de 2020 às 22:10, dpa sc@pankd.de escreveu:
here is the file...
Hey,
one.
best
Dietrich
Congratulations! You have found a bug in the minkowski operator. That is what I get with Thrown Together: [image: image.png] Yes, there is some reversed face in the minkowski! Just the minkowsky renders fine but CGAL finds an error when it is boolean operated with the connector. That face seems to be the cause. I have never seen that bug before. The bug seems to be related to the number of faces in the sphere and edges in the extrusion circle. Something odd happens when both $fn are equal to 6. Em seg., 25 de mai. de 2020 às 22:10, dpa <sc@pankd.de> escreveu: > here is the file... > > > Am Mo., 25. Mai 2020 um 23:08 Uhr schrieb dpa <sc@pankd.de>: > >> Hey, >> I was using OpenSCAD because it's so reliable, but yesterday I was very >> disappointed. I researched the frequing same problem for almost exactly one >> day now and just couldn't get any further. There are probably several in >> one. >> >> For this question mail I didn't use my own polygons, just circle, >> rotate_extrude and minkowski with a sphere. >> The preview is fine, the rendering doesn't say enything but stays empty. >> Thats my first question: why is there no error AND no output? >> It brings an error when you change the "add_rotate" in cutomizer. What >> brings me to the 2nd question: why does a rotation bring different errors? >> And last but not least: how can I bring this object to render with a >> "add_rotate"=7 at all? Where is the error / what I'm doing wrong? >> >> best >> Dietrich >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
O
OzAtMichael
Tue, May 26, 2020 2:30 AM
I get a CGAL error,
ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion violation! Expr:
e->incident_sface() != SFace_const_handle() File:
/mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_const_decorator.h Line: 329
Geometries in cache: 8
Geometry cache size in bytes: 80896
CGAL Polyhedrons in cache: 1
CGAL cache size in bytes: 0
Total rendering time: 0 hours, 0 minutes, 0 seconds
Rendering finished.
If you missed that and tried F6 again, you don't get the error as the geometry is cached.
Whenever you have strange things like that it is good to try Design/Flush-cache.
Thank you, you have found a simple example of a bug I have seen hiding, where F5 then F6 has a CGAL
error, but F6 alone (fresh run or flush cache) does not, but the exported STL is bad.
A change in rotation will produce different angles where faces meet, sometimes they meet in a way
that is non-manifold, like an edge or point meeting exactly in the middle of a face.
But in this case I suspect a bug.
Interesting what I found inside (with add_rotate=7):
From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of dpa
Sent: Tue, 26 May 2020 07:09
Subject: [OpenSCAD] rendering problem
Hey,
a sphere.
best
Dietrich
> The preview is fine, the rendering doesn't say enything but stays empty. Thats my first question: why is there no error AND no output? I get a CGAL error, Rendering Polygon Mesh using CGAL... ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion violation! Expr: e->incident_sface() != SFace_const_handle() File: /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_const_decorator.h Line: 329 Geometries in cache: 8 Geometry cache size in bytes: 80896 CGAL Polyhedrons in cache: 1 CGAL cache size in bytes: 0 Total rendering time: 0 hours, 0 minutes, 0 seconds Rendering finished. If you missed that and tried F6 again, you don't get the error as the geometry is cached. Whenever you have strange things like that it is good to try Design/Flush-cache. Thank you, you have found a simple example of a bug I have seen hiding, where F5 then F6 has a CGAL error, but F6 alone (fresh run or flush cache) does not, but the exported STL is bad. > What brings me to the 2nd question: why does a rotation bring different errors? A change in rotation will produce different angles where faces meet, sometimes they meet in a way that is non-manifold, like an edge or point meeting exactly in the middle of a face. But in this case I suspect a bug. Interesting what I found inside (with add_rotate=7): _____ From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of dpa Sent: Tue, 26 May 2020 07:09 To: discuss@lists.openscad.org Subject: [OpenSCAD] rendering problem Hey, I was using OpenSCAD because it's so reliable, but yesterday I was very disappointed. I researched the frequing same problem for almost exactly one day now and just couldn't get any further. There are probably several in one. For this question mail I didn't use my own polygons, just circle, rotate_extrude and minkowski with a sphere. The preview is fine, the rendering doesn't say enything but stays empty. Thats my first question: why is there no error AND no output? It brings an error when you change the "add_rotate" in cutomizer. What brings me to the 2nd question: why does a rotation bring different errors? And last but not least: how can I bring this object to render with a "add_rotate"=7 at all? Where is the error / what I'm doing wrong? best Dietrich -- This email has been checked for viruses by AVG. https://www.avg.com
O
OzAtMichael
Tue, May 26, 2020 3:14 AM
BTW those inverted triangle z-fight when it is moved. I presume that means it is duplicated, one
correct, the other inverse.
From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of OzAtMichael
Sent: Tue, 26 May 2020 12:31
Subject: Re: [OpenSCAD] rendering problem
I get a CGAL error,
Rendering finished.
Hey,
a sphere.
best
Dietrich
tent=emailclient>
Virus-free.
tent=emailclient> www.avg.com
BTW those inverted triangle z-fight when it is moved. I presume that means it is duplicated, one correct, the other inverse. _____ From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of OzAtMichael Sent: Tue, 26 May 2020 12:31 To: 'OpenSCAD general discussion' Subject: Re: [OpenSCAD] rendering problem > The preview is fine, the rendering doesn't say enything but stays empty. Thats my first question: why is there no error AND no output? I get a CGAL error, Rendering Polygon Mesh using CGAL... ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion violation! Expr: e->incident_sface() != SFace_const_handle() File: /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_const_decorator.h Line: 329 Geometries in cache: 8 Geometry cache size in bytes: 80896 CGAL Polyhedrons in cache: 1 CGAL cache size in bytes: 0 Total rendering time: 0 hours, 0 minutes, 0 seconds Rendering finished. If you missed that and tried F6 again, you don't get the error as the geometry is cached. Whenever you have strange things like that it is good to try Design/Flush-cache. Thank you, you have found a simple example of a bug I have seen hiding, where F5 then F6 has a CGAL error, but F6 alone (fresh run or flush cache) does not, but the exported STL is bad. > What brings me to the 2nd question: why does a rotation bring different errors? A change in rotation will produce different angles where faces meet, sometimes they meet in a way that is non-manifold, like an edge or point meeting exactly in the middle of a face. But in this case I suspect a bug. Interesting what I found inside (with add_rotate=7): _____ From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of dpa Sent: Tue, 26 May 2020 07:09 To: discuss@lists.openscad.org Subject: [OpenSCAD] rendering problem Hey, I was using OpenSCAD because it's so reliable, but yesterday I was very disappointed. I researched the frequing same problem for almost exactly one day now and just couldn't get any further. There are probably several in one. For this question mail I didn't use my own polygons, just circle, rotate_extrude and minkowski with a sphere. The preview is fine, the rendering doesn't say enything but stays empty. Thats my first question: why is there no error AND no output? It brings an error when you change the "add_rotate" in cutomizer. What brings me to the 2nd question: why does a rotation bring different errors? And last but not least: how can I bring this object to render with a "add_rotate"=7 at all? Where is the error / what I'm doing wrong? best Dietrich <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_con tent=emailclient> Virus-free. <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_con tent=emailclient> www.avg.com -- This email has been checked for viruses by AVG. https://www.avg.com
Tue, May 26, 2020 8:41 AM
It works fine for me if I flush the cache before F6 but not if I do F5, F6.
So it is not a bug in Minkowski, it is just the normal PolySet grid snap
bug that breaks topology and caches it.
*OzAtMichael
I get a CGAL error,
Line: 329
Rendering finished.
geometry is cached.
Design/Flush-cache.
errors?
*dpa
Hey,
one.
best
Dietrich
Virus-free. www.avg.com
<#m_-7215788200432690012_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
It works fine for me if I flush the cache before F6 but not if I do F5, F6. So it is not a bug in Minkowski, it is just the normal PolySet grid snap bug that breaks topology and caches it. On Tue, 26 May 2020 at 04:15, OzAtMichael <oz.at.michael@gmail.com> wrote: > BTW those inverted triangle z-fight when it is moved. I presume that means > it is duplicated, one correct, the other inverse. > > > ------------------------------ > > *From:* Discuss [mailto:discuss-bounces@lists.openscad.org] *On Behalf Of > *OzAtMichael > *Sent:* Tue, 26 May 2020 12:31 > *To:* 'OpenSCAD general discussion' > *Subject:* Re: [OpenSCAD] rendering problem > > > > > The preview is fine, the rendering doesn't say enything but stays > empty. Thats my first question: why is there no error AND no output? > > I get a CGAL error, > > > > Rendering Polygon Mesh using CGAL... > > ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion > violation! Expr: e->incident_sface() != SFace_const_handle() File: > /mxe/usr/x86_64-w64-mingw32.static.posix/include/CGAL/Nef_S2/SM_const_decorator.h > Line: 329 > > Geometries in cache: 8 > > Geometry cache size in bytes: 80896 > > CGAL Polyhedrons in cache: 1 > > CGAL cache size in bytes: 0 > > Total rendering time: 0 hours, 0 minutes, 0 seconds > > Rendering finished. > > > > If you missed that and tried F6 again, you don't get the error as the > geometry is cached. > > Whenever you have strange things like that it is good to try > Design/Flush-cache. > > > > Thank you, you have found a simple example of a bug I have seen hiding, > where F5 then F6 has a CGAL error, but F6 alone (fresh run or flush cache) > does not, but the exported STL is bad. > > > > > What brings me to the 2nd question: why does a rotation bring different > errors? > > > > A change in rotation will produce different angles where faces meet, > sometimes they meet in a way that is non-manifold, like an edge or point > meeting exactly in the middle of a face. > > But in this case I suspect a bug. > > > > Interesting what I found inside (with add_rotate=7): > > > > > > > ------------------------------ > > *From:* Discuss [mailto:discuss-bounces@lists.openscad.org] *On Behalf Of > *dpa > *Sent:* Tue, 26 May 2020 07:09 > *To:* discuss@lists.openscad.org > *Subject:* [OpenSCAD] rendering problem > > > > Hey, > > I was using OpenSCAD because it's so reliable, but yesterday I was very > disappointed. I researched the frequing same problem for almost exactly one > day now and just couldn't get any further. There are probably several in > one. > > > > For this question mail I didn't use my own polygons, just circle, > rotate_extrude and minkowski with a sphere. > The preview is fine, the rendering doesn't say enything but stays empty. > Thats my first question: why is there no error AND no output? > It brings an error when you change the "add_rotate" in cutomizer. What > brings me to the 2nd question: why does a rotation bring different errors? > And last but not least: how can I bring this object to render with a > "add_rotate"=7 at all? Where is the error / what I'm doing wrong? > > > > best > > Dietrich > > > > > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > > Virus-free. www.avg.com > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > > <#m_-7215788200432690012_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Tue, May 26, 2020 10:40 AM
F6.
I'm not so sure.
As I said, z-fighting outside-face & inside-face.
In Netfabb I was able to delete the wrong face, and the right one was then
exposed.
I'm still looking, but it does look like duplicated faces.
nophead wrote > It works fine for me if I flush the cache before F6 but not if I do F5, > F6. > So it is not a bug in Minkowski, it is just the normal PolySet grid snap > bug that breaks topology and caches it. I'm not so sure. As I said, z-fighting outside-face & inside-face. In Netfabb I was able to delete the wrong face, and the right one was then exposed. I'm still looking, but it does look like duplicated faces. ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
Tue, May 26, 2020 11:02 AM
As long as I flush the cache and do F6 it all looks fine to me and I can
export the STL to Netfabb and that says it's fine as well.
On Tue, 26 May 2020 at 11:41, MichaelAtOz oz.at.michael@gmail.com wrote:
F6.
I'm not so sure.
exposed.
stupid...
As long as I flush the cache and do F6 it all looks fine to me and I can export the STL to Netfabb and that says it's fine as well. On Tue, 26 May 2020 at 11:41, MichaelAtOz <oz.at.michael@gmail.com> wrote: > nophead wrote > > It works fine for me if I flush the cache before F6 but not if I do F5, > > F6. > > So it is not a bug in Minkowski, it is just the normal PolySet grid snap > > bug that breaks topology and caches it. > > I'm not so sure. > As I said, z-fighting outside-face & inside-face. > In Netfabb I was able to delete the wrong face, and the right one was then > exposed. > I'm still looking, but it does look like duplicated faces. > > > > ----- > Admin - email* me if you need anything, or if I've done something > stupid... > > * click on my MichaelAtOz label, there is a link to email me. > > Unless specifically shown otherwise above, my contribution is in the > Public Domain; to the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. Obviously > inclusion of works of previous authors is not included in the above. > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
arnholm@arnholm.org
Tue, May 26, 2020 11:38 AM
Could be an intermittent problem, or behaviour depends on version of
OpenSCAD and/or operating system. It is not necessarily minkowski that
fails, since difference is the final operation.
I tried with OpenSCAD 2017.01.20 under Win10 and it shows no obvious
problems (but see below), it is reported as
Total rendering time: 0 hours, 0 minutes, 10 seconds
Simple:        yes
Vertices:      369
Halfedges:    1556
Edges:        778
Halffacets:    826
Facets:        413
Volumes:        3
Rendering finished.
STL export finished.
However, testing the exported STL in polyfix reveals a higher number of
faces (628) compared to what OpenSCAD reports (413), which is kind of
strange.
polyhedron 0 ================= volume=1469.81, dtol=0.01, atol=1e-06,
maxiter=10
iteration 0: vertices=1884 faces=628
warning: 4 zero area faces.
warning: nonmanifold edges: uc(1)=1884
merged 1574 vertices
removed 16 collapsed or zero area faces
removed 2 duplicate faces
removed 2 nonmanifold faces
total changes=1594
no warnings
iteration 1: vertices=310 faces=608
removed 2 unused vertices
total changes=2
no warnings
iteration 2: vertices=308 faces=608
total changes=0
no warnings
Summary:
polyhedron 0: vertices=308 faces=608 : no warnings
When instead exporting the same model from OpenSCAD to OFF format, it
showed an even higher number of faces (710):
maxiter=10
iteration 0: vertices=359 faces=710
warning: 86 zero area faces.
merged 49 vertices
removed 98 collapsed or zero area faces
total changes=151
no warnings
total changes=2
no warnings
total changes=0
no warnings
Summary:
As you can see, polyfix resolved both of the above to vertices=308
faces=608, even if the starting points were different. I think this
shows that at least part of the problems lie in file export code.
It does not make sense that the number of faces exported depends on the
file format chosen. Clearly, there is no check for zero area faces on
file export in OpenSCAD.
I also tried this, which seemed to work
https://gist.github.com/arnholm/de50168cd1a477be1de116e100a8066a
On 2020-05-26 00:06, Ronaldo Persiano wrote: > Congratulations! You have found a bug in the minkowski operator. That > is what I get with Thrown Together: Could be an intermittent problem, or behaviour depends on version of OpenSCAD and/or operating system. It is not necessarily minkowski that fails, since difference is the final operation. I tried with OpenSCAD 2017.01.20 under Win10 and it shows no obvious problems (but see below), it is reported as Total rendering time: 0 hours, 0 minutes, 10 seconds Top level object is a 3D object: Simple: yes Vertices: 369 Halfedges: 1556 Edges: 778 Halffacets: 826 Facets: 413 Volumes: 3 Rendering finished. STL export finished. However, testing the exported STL in polyfix reveals a higher number of faces (628) compared to what OpenSCAD reports (413), which is kind of strange. polyhedron 0 ================= volume=1469.81, dtol=0.01, atol=1e-06, maxiter=10 iteration 0: vertices=1884 faces=628 warning: 4 zero area faces. warning: nonmanifold edges: uc(1)=1884 merged 1574 vertices removed 16 collapsed or zero area faces removed 2 duplicate faces removed 2 nonmanifold faces total changes=1594 no warnings iteration 1: vertices=310 faces=608 removed 2 unused vertices total changes=2 no warnings iteration 2: vertices=308 faces=608 total changes=0 no warnings Summary: polyhedron 0: vertices=308 faces=608 : no warnings When instead exporting the same model from OpenSCAD to OFF format, it showed an even higher number of faces (710): polyhedron 0 ================= volume=1469.81, dtol=0.01, atol=1e-06, maxiter=10 iteration 0: vertices=359 faces=710 warning: 86 zero area faces. merged 49 vertices removed 98 collapsed or zero area faces removed 2 duplicate faces removed 2 nonmanifold faces total changes=151 no warnings iteration 1: vertices=310 faces=608 removed 2 unused vertices total changes=2 no warnings iteration 2: vertices=308 faces=608 total changes=0 no warnings Summary: polyhedron 0: vertices=308 faces=608 : no warnings As you can see, polyfix resolved both of the above to vertices=308 faces=608, even if the starting points were different. I think this shows that at least part of the problems lie in file export code. It does not make sense that the number of faces exported depends on the file format chosen. Clearly, there is no check for zero area faces on file export in OpenSCAD. I also tried this, which seemed to work https://gist.github.com/arnholm/de50168cd1a477be1de116e100a8066a Carsten Arnholm
Michael Marx
Tue, May 26, 2020 11:52 AM
All well & good, but F5+F6 should work.
It needs to be fixed.
Your render() based designs are probably prone to this issue.
In this specific case, Flush Cache & F6 & Export STL, produced a broken STL, that one on the
Netfabb images above.
From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of nop head
Sent: Tue, 26 May 2020 21:03
F6.
I'm not so sure.
exposed.
All well & good, but F5+F6 should work. It needs to be fixed. Your render() based designs are probably prone to this issue. In this specific case, Flush Cache & F6 & Export STL, produced a broken STL, that one on the Netfabb images above. _____ From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of nop head Sent: Tue, 26 May 2020 21:03 To: OpenSCAD general discussion Subject: Re: [OpenSCAD] rendering problem As long as I flush the cache and do F6 it all looks fine to me and I can export the STL to Netfabb and that says it's fine as well. On Tue, 26 May 2020 at 11:41, MichaelAtOz <oz.at.michael@gmail.com> wrote: nophead wrote > It works fine for me if I flush the cache before F6 but not if I do F5, > F6. > So it is not a bug in Minkowski, it is just the normal PolySet grid snap > bug that breaks topology and caches it. I'm not so sure. As I said, z-fighting outside-face & inside-face. In Netfabb I was able to delete the wrong face, and the right one was then exposed. I'm still looking, but it does look like duplicated faces. ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/ _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- This email has been checked for viruses by AVG. https://www.avg.com
