Hi Everyone! I'm writing to You to get a little helping hand on the project
I'm involved with right now.
I'll briefly try to sum up what I'm trying to achieve and what did I manage
to do until now. First of all I'm new to openscad. I grasp the basics of it
and see its huge potential but I don't have enough knowledge to perfectly
get the result I'm looking for.
The project is about reversing gcode generated for 3d printing to get a
solid 3d model of the object passed through the slicing process. I want to
do it to perform FEM structural analysis on specimens that will be printed
in plastic and to determine the mechanical characteristics of the different
types of Infill pattern available for slicing.
So, I managed to find an openscad script which served my purpose: a
polyline3d module with hull function to simulate the linear extrusion of a
sphere through consecutive X,Y,Z points. And it works. The problem is that
the real world extrusion on a plane is not spherical but looks a bit more
like a little tiny "sausage". For this reason I've tried to modify the
polyline 3d module by substituting the sphere geometry with a sausage-like
one.
I obtained the sausage-like geometry in two ways. By adding two spheres at
the ends of a cylindrical shape or by "hulling" a sphere to the desired
length. Both ways seem to kind work out. In fact they really only work when
the hull goes the opposite direction (i.e. X axis) than the direction of
construction (i.e. Y axis) of the sausage-like geometry. If the direction of
hull (i.e. Y axis) is the same as the direction of construction (i.e. Y
axis) of the sausage-like geometry the result is no more a sausage but a
sphere. This is because i couldn't find the command or the way to tell the
program which one is normal direction of hull/extrusion from the base
geometry allowing me to obtain a consistent extrusion in all the directions,
diagonals included.
The only way to by-pass this that came to my mind was to make a double
extrusion by hulling a sausage built on the X axis and one built on the Y
axis. This way the problem is kinda solved but other problems are generated:
the calculation takes double the time (in my case is a very long time) and I
don't really know whether or how the 3d solid model generated by this two
overlapping CSGs can be affected by this ploy.
layer_height = .2;
layer_width = .4;
module hull_polyline3d(points, layer_height) {
leng = len(points);
module hull_extrusion_unit1(layer_height){
// hull method for generating the sausage geometry
hull()
sphere(r=layer_height);
translate([layer_width,0,0])sphere(r=layer_height);
module hull_extrusion_unit2(layer_height){
hull()
translate([0,layer_width,0])sphere(r=layer_height);
module hull_line3d(index) {
point1 = points[index - 1];
point2 = points[index];
hull() {
translate(point1)
hull_extrusion_unit1(layer_height);
translate(point2)
hull() {
translate(point1)
hull_extrusion_unit2(layer_height);
translate(point2)
// hook for testing
test_hull_polyline3d_line_segment(index, point1, point2);
module polyline3d_inner(index) {
if(index < leng) {
hull_line3d(index);
polyline3d_inner(index + 1);
polyline3d_inner(1);
// override it to test
module test_hull_polyline3d_line_segment(index, point1, point2) {
echo("This is an Extrusion Unit with LAYER_HEIGHT=", layer_height, " and
LAYER_WIDTH=", layer_width);
echo(layer_height=layer_height,layer_width=layer_width); // shortcut
The last image show the hull issue mitigated by doubling the hull with the
geometry built on the other axis.
I hope the explanation was not too confusing.
Thanks so much for your priceless help.
Bless You all.
Leo
http://forum.openscad.org/file/t2859/Modulo_ExtrusionUnit_con_angolo_dritto_ma_pesante3.png
http://forum.openscad.org/file/t2859/Modulo_ExtrusionUnit_con_angolo_dritto_ma_pesante1.png
http://forum.openscad.org/file/t2859/Hull_issue_.png
http://forum.openscad.org/file/t2859/Hull_issue_mitigated_by_double_hull.png
I'm not really following your description of your problem, but...
Very small gcode files have thousands of individual instructions, most
of which are extrusions. (My 1cm test cube has >500 extrusions.) Even
modest sized objects often have hundreds of thousands of individual
instructions. I would be very doubtful that OpenSCAD could handle that
kind of scale.
Maybe I'm just not understanding the problem, or maybe my imagination is
lacking, but I'm not coming up with any kind of "orientation" for hull
operations. A hull operation stretches a rubber balloon around the
objects, so that the result is entirely concave. I don't think there
are ever multiple solutions for how to do that.
I'm not sure if I understand your question, but I have two thoughts.
Would it work to simply apply scale([1,1,layerheight/layerwidth]) or
something like that to the original program? That's going to be the
simplest way to get a squished look like a 3d printed extrusion.
If you want to do this directly it sounds like the problem you're having
is that you are using two spheres to define the "sausage" geometry. Would
it work to use one squished sphere? So for example,
module squished() { scale([.4,.4,.2]) sphere(d=1);}
hull(){
squished();
translate([3,4]) squished();
Thank You so much for your kind hints. Actually I managed to achieve what I
was trying to do by choosing a smarter geometry to hull: a torus! It took me
a while to realize this very simple fact. Amazing!
Nice approach and good solution.
this will work for a couple of paths quite well. But when it comes to a
union of hundreds of extrusion paths, an F6 build will be extremely slow in
OpenSCAD. So better keep your model simple.
That is true. Why not sweep an appropriate section along all the filament
paths for each layer? As each layer has a planar path, it would not be so
hard to detect possible path self intersections, chopping the path
accordingly. That would be a very big change in your project, increasing
its complexity but rewarded by a huge gain in run time. I don't think non
planar layers, as in spiral extrusions, would be hard to deal with.
Hmm, I also considered, whether some sweep() operations could be at least
helpful. But to my understanding two adjacent paths in a layer are usually
meant to melt together. So, they'll have to intersect more or less and a
union is unavoidable, unless you calculate the intersection which could be a
possible option.
They don't intersect because one is solid and the other liquid. What
happens is the liquid filament gets deformed by being squished between the
nozzle, the layer below and the adjacent filament. So you would need a
sweep with different profiles depending on what is on each side and below
the extrusion path and a model that caters for several possibilities.
E.g.
An outline on the bed.
An outline on a layer below.
An outline that overhangs the layer below.
An outline that spans a bridge.
Infill on the bed bounded on no sides, one side and two sides.
Infil over a layer below bounded on no sides, one side and two sides.
Infil over a bridge bounded on no sides, one side and two sides.
These all give different shaped extrusions.
a
possible option.
a
possible option.
I didn't mean to avoid all unions, just to reduce their number. Each layer
would be the union of non self-intersecting sweeps and their union would be
the final object. That is better than the union of each elementary
linear_extrude. In a simple print without infill, we will have the union of
2 times the number of layers.
To have a comparison I have done a lazy simulation of both ways:
fh = 1; // filament section height
lh = 1.05; // layer height
nl = 3; // number of layers
rad = 10; // radius of the circular layers
module section() { circle(d=fh,$fn=20); }
module fake_sweep(rad, angle) {
rotate_extrude(angle=angle,$fn=36)
translate([rad,0])
children() ;
module with_sweep() {
union(){
for(h=[0:lh:lh*(nl-1)])
translate([0,0,h])
union(){
fake_sweep(rad,180) section() ;
rotate(180)
module without_sweep() {
union(){
for(h=[0:lh:lh*(nl-1)]) {
translate([0,0,h])
for(ang=[0:10:360]) {
rotate(ang)
rotate_extrude(angle=10,$fn=1)
translate([rad,0])
section() ;
Module fake_sweep simulates a sweep of section() along a half circular path
with radius rad. In my computer, module with_sweep() runs in 16 sec. while
without_sweep() requires 50 sec. It is not a huge gain as I expected. We
can estimate the gain of disjoint layers by setting lh greater than the
filament height lh. With lh=1.05, the module with_sweep() runs in 13 sec.
It is not unthinkable to generate one huge-sized polyhedron representing
the whole print. It would be a very hard work to write a code to slice the
layers in finer ones to melt them but that is all we need.
Am Tue, 23 Jun 2020 19:47:55 +0100
schrieb Ronaldo Persiano rcmpersiano@gmail.com:
least helpful. But to my understanding two adjacent paths in a
layer are usually meant to melt together. So, they'll have to
intersect more or less and a union is unavoidable, unless you
possible option.
layer would be the union of non self-intersecting sweeps and their
union would be the final object. That is better than the union of
each elementary linear_extrude. In a simple print without infill, we
will have the union of 2 times the number of layers.
translate([rad,0])
children() ;
union(){
translate([0,0,h])
union(){
rotate(180)
union(){
translate([0,0,h])
rotate(ang)
translate([rad,0])
section() ;
circular path with radius rad. In my computer, module with_sweep()
runs in 16 sec. while without_sweep() requires 50 sec. It is not a
huge gain as I expected. We can estimate the gain of disjoint layers
by setting lh greater than the filament height lh. With lh=1.05, the
representing the whole print. It would be a very hard work to write a
code to slice the layers in finer ones to melt them but that is all
we need.
Just for comparison ....
with_sweep();
Geometries in cache: 3
Geometry cache size in bytes: 55384
CGAL Polyhedrons in cache: 0
CGAL cache size in bytes: 0
Normalized CSG tree has 6 elements
Compile and preview finished.
Total rendering time: 0:00:00.052
Geometries in cache: 4
Geometry cache size in bytes: 109968
CGAL Polyhedrons in cache: 5
CGAL cache size in bytes: 12487024
Total rendering time: 0:00:03.283 <--------
Simple: yes
Vertices: 2160
Halfedges: 12480
Edges: 6240
Halffacets: 8160
Facets: 4080
Volumes: 4
Rendering finished.
without_sweep();
Saved design '/home/peter/Dokumente/work/openscad/sweep_w_wo.scad'.
Loaded design '/home/peter/Dokumente/work/openscad/sweep_w_wo.scad'.
Geometries in cache: 6
Geometry cache size in bytes: 115592
Normalized CSG tree has 111 elements
Total rendering time: 0:00:00.083
Geometries in cache: 42
Geometry cache size in bytes: 318056
CGAL Polyhedrons in cache: 9
CGAL cache size in bytes: 31551664
Total rendering time: 0:00:28.405 <------
Simple: yes
Vertices: 4482
Halfedges: 22044
Edges: 11022
Halffacets: 13080
Facets: 6540
Volumes: 4
Rendering finished.
OpenSCAD 2020.06.14.nightly (git be16bd8)
Mit freundlichen Grüßen
Best Regards
Peter Ragosch
