Ronaldo wrote
To have a comparison I have done a lazy simulation of both ways:
You are right, of course, but you will have a hard time to properly
implement sweep() for this kind of extrusion with arbitrary paths (and with
a couple of shapes, as mophead mentioned), because you need some means to
avoid self intersections. Leo's approach made me think of code like:
R=5; // nozzle width
r = 2.5; // layer height
$fn=10;
P = [[0,0, 0], [50, 10, 0], [50, 50, 0], [170, -150, 0], [170, 150, 0]];
multiline(P);
module multiline(P) for(i=[0:len(P)-2]) line(P[i], P[i+1]);
module line(p1, p2)
hull()
translate(p1)torus();
translate(p2)torus();
module torus(R=R, r=r)
rotate_extrude() translate([R, 0, 0])circle(r);
So, some appropriate sweep() operation can save time and will obviously be
faster than multiline() in my code example. However, the implemenation is
demanding and if you have to union a significant number of such paths,
OpenSCAD again will make you cry. So better use multiline() right away,
spare the programming time and give your machine the time it needs, while
you are on your sommer leave.
@Leo, Maybe you can give us some hint about the complexity of the FEM
analysis you are planning to do. Is it just some layers with, say, a hundred
strokes all together, or are you planning to analyse more complex prints?
mophead? I could have been called that a few weeks ago as I last went to
the barbers in December but I managed to buy some clippers and my wife cut
my hair, so back to nophead.
$fn=10;
multiline(P);
module line(p1, p2)
hull()
hundred
g, sorry for the typo
