How to create an cylindrical arc?
adrian
Wed, Jan 28, 2015 12:30 AM
I need to make an cylindrical arc given 3 points: start, middle and end.
It's been a while since I've done vector algebra, but I'm guessing I'll have
to find the centre point which I would use to translate from the origin,
find the plane, which I would use to rotate from the x,y plane to the actual
plane, find the radius and extrude several linear segments of a circle and
then rotate and translate it into position.
Does that sound reasonable?  Is there another way to do this?  A prefabbed
lib maybe?
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257.html
I need to make an cylindrical arc given 3 points: start, middle and end. It's been a while since I've done vector algebra, but I'm guessing I'll have to find the centre point which I would use to translate from the origin, find the plane, which I would use to rotate from the x,y plane to the actual plane, find the radius and extrude several linear segments of a circle and then rotate and translate it into position. Does that sound reasonable? Is there another way to do this? A prefabbed lib maybe? A -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257.html Sent from the OpenSCAD mailing list archive at Nabble.com.
adrian
Wed, Jan 28, 2015 12:48 AM
Oh, I can use the rotate_extrude().  But everything else should be good
right?
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11258.html
Oh, I can use the rotate_extrude(). But everything else should be good right? A -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11258.html Sent from the OpenSCAD mailing list archive at Nabble.com.
adrian
Wed, Jan 28, 2015 1:58 AM
Actually, is it "cheaper" to make a bunch of segments and subtract the
sections I don't want?  Or is it better to use a bunch of linearly extruded
segments?
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11259.html
Actually, is it "cheaper" to make a bunch of segments and subtract the sections I don't want? Or is it better to use a bunch of linearly extruded segments? A -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11259.html Sent from the OpenSCAD mailing list archive at Nabble.com.
adrian
Wed, Jan 28, 2015 2:33 AM
Actually, I think that doing a bunch of segments wouldn't work since every
time I add a new segment, it would not properly intersect with the last one.
I would need some type of function to "round the corner" between one segment
and the next. :(
So I guess that answers my question.  Unless there is some other way to make
an arc.  Unfortunately, it looks like rotate_extrude() is limited to only
doing a full 360 degrees and no partial.  At least the documentation doesn't
seem to indicate that it is possible...
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11261.html
Actually, I think that doing a bunch of segments wouldn't work since every time I add a new segment, it would not properly intersect with the last one. I would need some type of function to "round the corner" between one segment and the next. :( So I guess that answers my question. Unless there is some other way to make an arc. Unfortunately, it looks like rotate_extrude() is limited to only doing a full 360 degrees and no partial. At least the documentation doesn't seem to indicate that it is possible... A -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11261.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Jan 28, 2015 2:59 AM
Nice little conversation you're having with yourself ;)
Try donutslice() from MCAD/2Dshapes.scad, in libraries under your OpenSCAD
program installation directory. You'll need to extrude it.
You should checkout all the MCAD libraries too.
Cheers.
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11263.html
Nice little conversation you're having with yourself ;) Try donutslice() from MCAD/2Dshapes.scad, in libraries under your OpenSCAD program installation directory. You'll need to extrude it. You should checkout all the MCAD libraries too. Cheers. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11263.html Sent from the OpenSCAD mailing list archive at Nabble.com.
adrian
Wed, Jan 28, 2015 3:44 AM
Well, had to talk to someone intelligent around here. ;)
Oh, that's good to know.  Didn't look around the file system for that.
Thanks,
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11268.html
MichaelAtOz wrote > Nice little conversation you're having with yourself ;) Well, had to talk to someone intelligent around here. ;) MichaelAtOz wrote > Try donutslice() from MCAD/2Dshapes.scad, in libraries under your OpenSCAD > program installation directory. You'll need to extrude it. > > You should checkout all the MCAD libraries too. Oh, that's good to know. Didn't look around the file system for that. Thanks, A -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11268.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Jan 28, 2015 3:51 AM
You should also do a search for OpenSCAD on thingiverse.com, there are some
good libraries there.
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11270.html
You should also do a search for OpenSCAD on thingiverse.com, there are some good libraries there. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11270.html Sent from the OpenSCAD mailing list archive at Nabble.com.
adrian
Wed, Jan 28, 2015 4:24 AM
Documentation is sparse on donutSlice().  From what I can see, it makes a
blocky donut slice.  Not very useful. :/
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11273.html
Documentation is sparse on donutSlice(). From what I can see, it makes a blocky donut slice. Not very useful. :/ A -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11273.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Jan 28, 2015 4:34 AM
If you mean the line segments, try
donutSlice(30,50,190,270,$fn=64);
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11274.html
If you mean the line segments, try donutSlice(30,50,190,270,$fn=64); ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11274.html Sent from the OpenSCAD mailing list archive at Nabble.com.
IN
Ian Nichols
Wed, Jan 28, 2015 10:34 AM
one.
segment
and the next. :(
make
doesn't
I've done things like this in the past (to make a tubular arc in the case
below) by doing a rotate_extrude (to make a torus) and finding the
intersection of that and a wedge shape made by linear_extruding a sort of
fanning polygon that starts at the centre of the rotation and expands
around the outside of  the torus.  You could probably adapt that to your
needs.
$fn=64;
pipebend (4,3,20,135);
module pipebend (thickness, id, od, ang)
intersection (){
torus (thickness, od);
torus (id,od);
wedge (thickness, (od+thickness)/1.7,ang);
// ********************** End of Module ******************
module torus (thickness, dia,)
rotate_extrude(convexity = 10) translate([dia/2, 0, 0]) circle(r =
thickness/2) ;
module wedge (thickness, rad, ang)
translate ([0,0,-(thickness/2)-1]) {
linear_extrude (height = thickness+2) {
polygon(points=[
[radcos(ang/2),-radsin(ang/2)],
[0,0],
[radcos(ang/2),radsin(ang/2)],
[radcos(ang/3),radsin(ang/3)],
[radcos(ang/6),radsin(ang/6)],
[rad,0],
[radcos(ang/6),-radsin(ang/6)],
[radcos(ang/3),-radsin(ang/3)]],
paths=[[0,1,2,3,4,5,6,7]]);}
Stand firm for what you believe in, until and unless logic and experience
prove you wrong.  Remember: when the emperor looks naked, the emperor is
naked, the truth and a lie are not "sort-of the same thing" and there is
no aspect, no facet, no moment of life that can't be improved with pizza.
-Daria Morgendorffer
On 28 January 2015 at 02:33, adrian <adrianh.bsc@gmail.com> wrote: > Actually, I think that doing a bunch of segments wouldn't work since every > time I add a new segment, it would not properly intersect with the last > one. > I would need some type of function to "round the corner" between one > segment > and the next. :( > > So I guess that answers my question. Unless there is some other way to > make > an arc. Unfortunately, it looks like rotate_extrude() is limited to only > doing a full 360 degrees and no partial. At least the documentation > doesn't > seem to indicate that it is possible... > I've done things like this in the past (to make a tubular arc in the case below) by doing a rotate_extrude (to make a torus) and finding the intersection of that and a wedge shape made by linear_extruding a sort of fanning polygon that starts at the centre of the rotation and expands around the outside of the torus. You could probably adapt that to your needs. $fn=64; pipebend (4,3,20,135); module pipebend (thickness, id, od, ang) intersection (){ difference(){ torus (thickness, od); torus (id,od); } wedge (thickness, (od+thickness)/1.7,ang); } // ********************** End of Module ****************** module torus (thickness, dia,) rotate_extrude(convexity = 10) translate([dia/2, 0, 0]) circle(r = thickness/2) ; // ********************** End of Module ****************** module wedge (thickness, rad, ang) translate ([0,0,-(thickness/2)-1]) { linear_extrude (height = thickness+2) { polygon(points=[ [rad*cos(ang/2),-rad*sin(ang/2)], [0,0], [rad*cos(ang/2),rad*sin(ang/2)], [rad*cos(ang/3),rad*sin(ang/3)], [rad*cos(ang/6),rad*sin(ang/6)], [rad,0], [rad*cos(ang/6),-rad*sin(ang/6)], [rad*cos(ang/3),-rad*sin(ang/3)]], paths=[[0,1,2,3,4,5,6,7]]);} } // ********************** End of Module ****************** -- Stand firm for what you believe in, until and unless logic and experience prove you wrong. Remember: when the emperor looks naked, the emperor *is* naked, the truth and a lie are not "sort-of the same thing" and there is no aspect, no facet, no moment of life that can't be improved with pizza. -Daria Morgendorffer
