How to create an cylindrical arc?
adrian
Thu, Jan 29, 2015 3:03 AM
Well that's less blocky but its too big and I also want a circle extruded
along an arc.  I've been looking around and it looks like sweep() is what
I'm looking for, but I need to figure out how it works and where all the
modules are to use it.  I see it  here
https://github.com/openscad/list-comprehension-demos  , but some of the
modules it includes are not there.
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11280.html
Well that's less blocky but its too big and I also want a circle extruded along an arc. I've been looking around and it looks like sweep() is what I'm looking for, but I need to figure out how it works and where all the modules are to use it. I see it here <https://github.com/openscad/list-comprehension-demos> , but some of the modules it includes are not there. A -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11280.html Sent from the OpenSCAD mailing list archive at Nabble.com.
adrian
Thu, Jan 29, 2015 3:08 AM
Thanks Ian!  That has good possibilities. :)
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11281.html
Thanks Ian! That has good possibilities. :) A -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11281.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Jan 29, 2015 3:22 AM
You need the development version to use it.
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11283.html
adrian wrote > but some of the modules it includes are not there. You need the development version to use it. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11283.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Jan 29, 2015 3:38 AM
IOW a curved tube??
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11284.html
> too big and I also want a circle extruded along an arc. IOW a curved tube?? ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11284.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Jan 29, 2015 4:48 AM
I'm looking for, […]
Sweep is a bit general and probably requires too much configuration to fit your needs perfectly.
Currently, the best solution I can think of is to just intersect your 360 degree rotation volume with a wedge.
Here’s a quick starting point:
module rotate_extrude_angle(angle, size) {
module pie(a) {
r=sqrt(2);
hull() polyhedron(points=[[0,0,-r], [r,0,-r], [rcos(a),rsin(a),-r],[0,0,r], [r,0,r], [rcos(a),rsin(a),r]], faces=[[0,1,2,3,4,5]]);
scale(size) pie(angle);
rotate_extrude() children();
rotate_extrude_angle(45, 13) translate([8,0]) circle(5);
On Jan 28, 2015, at 22:03 PM, adrian <adrianh.bsc@gmail.com> wrote: > Well that's less blocky but its too big and I also want a circle extruded > along an arc. I've been looking around and it looks like sweep() is what > I'm looking for, […] Sweep is a bit general and probably requires too much configuration to fit your needs perfectly. Currently, the best solution I can think of is to just intersect your 360 degree rotation volume with a wedge. Here’s a quick starting point: module rotate_extrude_angle(angle, size) { module pie(a) { r=sqrt(2); hull() polyhedron(points=[[0,0,-r], [r,0,-r], [r*cos(a),r*sin(a),-r],[0,0,r], [r,0,r], [r*cos(a),r*sin(a),r]], faces=[[0,1,2,3,4,5]]); } intersection() { scale(size) pie(angle); rotate_extrude() children(); } } rotate_extrude_angle(45, 13) translate([8,0]) circle(5); -Marius
Thu, Jan 29, 2015 5:04 AM
OpenCSG doesn't like that
http://forum.openscad.org/file/n11286/pire_circle.jpg
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11286.html
OpenCSG doesn't like that <http://forum.openscad.org/file/n11286/pire_circle.jpg> ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11286.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Jan 29, 2015 5:08 AM
Yep, quick and dirty. the rotate_extrude() needs a convexity parameter to render correctly. I guess we could be helpful and automatically set it higher for rotate_extrude as it tends to always have a depth complexity of minimum 2..
On Jan 29, 2015, at 00:04 AM, MichaelAtOz <oz.at.michael@gmail.com> wrote: > OpenCSG doesn't like that > Yep, quick and dirty. the rotate_extrude() needs a convexity parameter to render correctly. I guess we could be helpful and automatically set it higher for rotate_extrude as it tends to always have a depth complexity of minimum 2.. -Marius
Thu, Jan 29, 2015 5:12 AM
Fixed in latest master ;)
On Jan 29, 2015, at 00:08 AM, Marius Kintel <marius@kintel.net> wrote: > I guess we could be helpful and automatically set it higher for rotate_extrude as it tends to always have a depth complexity of minimum 2.. > Fixed in latest master ;) -Marius
GW
Glenn West
Thu, Jan 29, 2015 5:18 AM
Ive done a few like theses, I use a pie library.
It can slide up a circle easy enough, and then a difference of a another
pie. Pretty easy.
On Wed, Jan 28, 2015 at 8:30 AM, adrian adrianh.bsc@gmail.com wrote:
I need to make an cylindrical arc given 3 points: start, middle and end.
It's been a while since I've done vector algebra, but I'm guessing I'll
have
to find the centre point which I would use to translate from the origin,
find the plane, which I would use to rotate from the x,y plane to the
actual
plane, find the radius and extrude several linear segments of a circle and
then rotate and translate it into position.
Does that sound reasonable?  Is there another way to do this?  A prefabbed
lib maybe?
http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257.html
Ive done a few like theses, I use a pie library. It can slide up a circle easy enough, and then a difference of a another pie. Pretty easy. On Wed, Jan 28, 2015 at 8:30 AM, adrian <adrianh.bsc@gmail.com> wrote: > I need to make an cylindrical arc given 3 points: start, middle and end. > It's been a while since I've done vector algebra, but I'm guessing I'll > have > to find the centre point which I would use to translate from the origin, > find the plane, which I would use to rotate from the x,y plane to the > actual > plane, find the radius and extrude several linear segments of a circle and > then rotate and translate it into position. > > Does that sound reasonable? Is there another way to do this? A prefabbed > lib maybe? > > > A > > > > -- > View this message in context: > http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
adrian
Thu, Jan 29, 2015 6:01 AM
And where do I get that?  I have the 2015.01.23.  Isn't that development?
IOW a curved tube??
Yes.
View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11291.html
You need the development version to use it. And where do I get that? I have the 2015.01.23. Isn't that development? > too big and I also want a circle extruded along an arc. IOW a curved tube?? Yes. -- View this message in context: http://forum.openscad.org/How-to-create-an-cylindrical-arc-tp11257p11291.html Sent from the OpenSCAD mailing list archive at Nabble.com.
