Hello,
Any chance rotate_extrude might be extended with vertical motion, in order
to make helixes?
I can imagine something workable with the following parameters:
So if you start with a circle of diameter 1 (like for a donut) but move 2
units upwards per rotation, you get a helix with a "fill factor" of 0.5.
Implementation can be done with 2 triangular polygon per area where normally
(on a donut or so) would be 1 trapezoid polygon. I'm sorry if I don't use
the proper terms exactly, I'm not an expert in this field.
Joris
View this message in context: http://forum.openscad.org/building-screw-threads-tp3280p14223.html
On Tue, Oct 27, 2015 at 01:44:44AM -0700, robijn wrote:
Hello,
to make helixes?
There's linear_extrude with the twist parameter, and then there's sweep() which
gives you generalized extrusion with certain transformations. If you look at the
commit log of github.com/openscad/MCAD's fasteners/threads.scad library, you'll
see an implementation I did using linear_extrude with twist, and the current one
that uses sweep.
linear_extrude with twist generated okay meshes as long as you lined up your
facets with the twist slice back in an older version of OpenSCAD, but looks
terrible now. See https://github.com/openscad/openscad/issues/901.
Kind regards,
Loong Jin
Hello,
to make helixes?
that uses sweep.
Sorry, forgot to mention that it's in the dev branch, so
https://github.com/openscad/MCAD/tree/dev/fasteners
Kind regards,
Loong Jin
Hello,
to make helixes?
that uses sweep.
Umm, I mean https://github.com/openscad/MCAD/blob/dev/fasteners/threads.scad
Kind regards,
Loong Jin
I understand you can make similar things with linear_extrude. But the polygons will be
completely different and it will not look nearly as good. If you use linear_extrude with a lot of
rotations, the polygons will be very long stretched. You don't want this on threads. Many more
polygons are then needed to create something that looks reasonable acceptable. Rendering
times are 10 times what is actually be needed. And still it's not really good.
Also, conceptually, it is a different way of creating things. In the real world, extrusion
machines don't make threads, and there's a good reason for it: the angle cannot be that
great. To make a thread, you would place a shape at 90 degrees onto the work, like a cutter
on a lathe. You are shaping from a different angle.
The thread library is very nice, but the library could also be a lot easier if this type of rotating
extrusion would be natively supported. You would only need to use the following code to
make a nearly perfect thread:
module metric_thread( diameter, length, pitch );
translate( [0, 0, -pitch] )
// create a thread from a polygon
rotate_extrude( pitch=pitch, rotations=length/pitch+2 )
polygon( points=[
[0,0],
[diameter,0],
[diameter, pitch1/16],
[diameter-5/16sqrt(3)pitch, pitch6/16],
[diameter-5/16sqrt(3)pitch, pitch10/16],
[diameter, pitch15/16],
[diameter, pitch],
[0, pitch], ] );
// cut off the thread at top and bottom by intersecting with this cube
translate( [-diameter/2, -diameter/2,0] )
cube( [diameter,diameter,length] );
Hello,
motion, in order
to make helixes?
parameters:
you look at the
library, you'll
the current one
that uses sweep.
lined up your
OpenSCAD, but looks
terrible now. See
Umm, I mean
Kind regards,
Loong Jin
[hidden email]
http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.or
g
signature.asc (836 bytes) Download Attachment
If you reply to this email, your message will be added to the
discussion below:
http://forum.openscad.org/building-screw-threads-tp3280p14226.html
To unsubscribe from building screw threads, click here.
NAML
polygon( points=[
[0,0],
[diameter,0],
[diameter, pitch],
[0, pitch], ] );
This snippet could possibly be abstracted out into a module to do what you want.
https://github.com/openscad/MCAD/blob/dev/fasteners/threads.scad#L202
Kind regards,
Loong Jin
to make helixes?
I like the idea of modifying rotate_extrude to allow for building helixes, although it’s a step backwards from providing more general extrusion functionality..
Any chance this might make it in a future release? I'm running into this again now, and I don't like to the use libraries for this
basic lathe functionality.
Would it be easy for me (having some C++ experience) to add it myself?
Best regards,
Joris
On 27 Oct 2015 at 6:42, kintel [via OpenSCAD] wrote:
to make helixes?
I like the idea of modifying rotate_extrude to allow for building helixes, although it's a step backwards from providing more
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://forum.openscad.org/building-screw-threads-tp3280p14230.html
NAML
Joris Robijn joris@rubytech.nl
www.rubytech.nl
www.videoregie.nl
Eindhoven, The Netherlands
Phone: +31 6 288 41 964
View this message in context: http://forum.openscad.org/building-screw-threads-tp3280p18704.html
Best regards,
Joris
to make helixes?
[hidden email]
NAML
www.rubytech.nl
www.videoregie.nl
On Oct 14, 2016, at 06:15, Joris Robijn joris@robijn.net wrote:
Any chance this might make it in a future release? I'm running into this again now, and I don't like to the use libraries for this basic lathe functionality.
It’s trivial to add the basic functionality.
Dealing with the public interface, corner cases and testing to get it accepted into OpenSCAD takes a bit more effort.
One idea could be to introduce a new built-in module for this; lathe() or helix() or smth.. That way we can leave rotate_extrude() alone. We still need to be careful as we have to maintain this function in the future.
Hopefully, in the future it would be possible to implement such a module in pure openscad.
