MacOS Universal Build - Call for testing
Thu, Jan 20, 2022 1:41 PM
Hi!
Marius has put in quite some work to get the MacOS version
ready as universal build for both Intel and M1 system.
It would be great if that could get some wider testing on
both platforms so it can be published with confidence:
See the github issue for the download link:
https://github.com/openscad/openscad/issues/4036
Hi! Marius has put in quite some work to get the MacOS version ready as universal build for both Intel and M1 system. It would be great if that could get some wider testing on both platforms so it can be published with confidence: See the github issue for the download link: https://github.com/openscad/openscad/issues/4036 ciao, Torsten.
BC
Bob Carter
Thu, Jan 20, 2022 2:11 PM
A quick run over 3 of my more complex models shows that F5 and F6 readers are typically half that of Rosetta with the latest MC build with no problems.
I will keep using it and report any problems I run into.
thanks
Bob.C
On 20 Jan 2022, at 13:41, Torsten Paul Torsten.Paul@gmx.de wrote:
Hi!
A quick run over 3 of my more complex models shows that F5 and F6 readers are typically half that of Rosetta with the latest MC build with no problems. I will keep using it and report any problems I run into. thanks Bob.C > On 20 Jan 2022, at 13:41, Torsten Paul <Torsten.Paul@gmx.de> wrote: > > Hi! > > Marius has put in quite some work to get the MacOS version > ready as universal build for both Intel and M1 system. > > It would be great if that could get some wider testing on > both platforms so it can be published with confidence: > > See the github issue for the download link: > https://github.com/openscad/openscad/issues/4036 > > ciao, > Torsten. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
DS
David Schooley
Thu, Jan 20, 2022 4:25 PM
Thank you Marius!
I’m getting repeated requests to give OpenSCAD access to the Documents folder. Normally this happens only once, but now it happens every time I start OpenSCAD and tell it to open an recent file. The dialog even pops up more than once. Normally you see this once and then everything is taken care of after that. It’s possible that my Mac is just confused.
On Jan 20, 2022, at 7:41 AM, Torsten Paul Torsten.Paul@gmx.de wrote:
Hi!
Thank you Marius! I’m getting repeated requests to give OpenSCAD access to the Documents folder. Normally this happens only once, but now it happens every time I start OpenSCAD and tell it to open an recent file. The dialog even pops up more than once. Normally you see this once and then everything is taken care of after that. It’s possible that my Mac is just confused. > On Jan 20, 2022, at 7:41 AM, Torsten Paul <Torsten.Paul@gmx.de> wrote: > > Hi! > > Marius has put in quite some work to get the MacOS version > ready as universal build for both Intel and M1 system. > > It would be great if that could get some wider testing on > both platforms so it can be published with confidence: > > See the github issue for the download link: > https://github.com/openscad/openscad/issues/4036 > > ciao, > Torsten. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
BC
Bob Carter
Thu, Jan 20, 2022 4:30 PM
Yes I am getting that as well - It also happens when I revert to Rosetta which was behaving well yesterday
Big Sur 11.6.2
OpenScad 211020 Rosetta
On 20 Jan 2022, at 16:25, David Schooley dcschooley@gmail.com wrote:
Thank you Marius!
Hi!
Yes I am getting that as well - It also happens when I revert to Rosetta which was behaving well yesterday Big Sur 11.6.2 OpenScad 211020 Rosetta > On 20 Jan 2022, at 16:25, David Schooley <dcschooley@gmail.com> wrote: > > Thank you Marius! > > I’m getting repeated requests to give OpenSCAD access to the Documents folder. Normally this happens only once, but now it happens every time I start OpenSCAD and tell it to open an recent file. The dialog even pops up more than once. Normally you see this once and then everything is taken care of after that. It’s possible that my Mac is just confused. > > > >> On Jan 20, 2022, at 7:41 AM, Torsten Paul <Torsten.Paul@gmx.de> wrote: >> >> Hi! >> >> Marius has put in quite some work to get the MacOS version >> ready as universal build for both Intel and M1 system. >> >> It would be great if that could get some wider testing on >> both platforms so it can be published with confidence: >> >> See the github issue for the download link: >> https://github.com/openscad/openscad/issues/4036 >> >> ciao, >> Torsten. >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
DS
David Schooley
Thu, Jan 20, 2022 4:53 PM
I’m glad it’s not just me. I haven’t seen this before either with the Intel release or with the Apple Silicon version that I built myself. Something is confusing MacOS.
Big Sur 11.6.2
Thank you Marius!
Hi!
I’m glad it’s not just me. I haven’t seen this before either with the Intel release or with the Apple Silicon version that I built myself. Something is confusing MacOS. > On Jan 20, 2022, at 10:30 AM, Bob Carter <caggius@gmail.com> wrote: > > Yes I am getting that as well - It also happens when I revert to Rosetta which was behaving well yesterday > > Big Sur 11.6.2 > OpenScad 211020 Rosetta > > >> On 20 Jan 2022, at 16:25, David Schooley <dcschooley@gmail.com> wrote: >> >> Thank you Marius! >> >> I’m getting repeated requests to give OpenSCAD access to the Documents folder. Normally this happens only once, but now it happens every time I start OpenSCAD and tell it to open an recent file. The dialog even pops up more than once. Normally you see this once and then everything is taken care of after that. It’s possible that my Mac is just confused. >> >> >> >>> On Jan 20, 2022, at 7:41 AM, Torsten Paul <Torsten.Paul@gmx.de> wrote: >>> >>> Hi! >>> >>> Marius has put in quite some work to get the MacOS version >>> ready as universal build for both Intel and M1 system. >>> >>> It would be great if that could get some wider testing on >>> both platforms so it can be published with confidence: >>> >>> See the github issue for the download link: >>> https://github.com/openscad/openscad/issues/4036 >>> >>> ciao, >>> Torsten. >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
BC
Bob Carter
Thu, Jan 20, 2022 5:09 PM
I normally have multiple releases of OpenScad in my App folder and I have not seen this behaviour when switching between those - they obviously share some things as they will always offer me recent files that have been opened by a different version.
I wondered if it was the M1 & Rosetta pairing confusing the OS
So I deleted the M1 version out of Apps and then 211020 asked for permission the first time but not the second - back to normal.
Delete all my Rosetta versions and reinstate the M1 version on its own and it gets stuck in the permissions loop.
So not sure if that helps, but it is all grist for the mill….
Cheers
Bob.C
Big Sur 11.6.2
Thank you Marius!
Hi!
I normally have multiple releases of OpenScad in my App folder and I have not seen this behaviour when switching between those - they obviously share some things as they will always offer me recent files that have been opened by a different version. I wondered if it was the M1 & Rosetta pairing confusing the OS So I deleted the M1 version out of Apps and then 211020 asked for permission the first time but not the second - back to normal. Delete all my Rosetta versions and reinstate the M1 version on its own and it gets stuck in the permissions loop. So not sure if that helps, but it is all grist for the mill…. Cheers Bob.C > On 20 Jan 2022, at 16:53, David Schooley <dcschooley@gmail.com> wrote: > > I’m glad it’s not just me. I haven’t seen this before either with the Intel release or with the Apple Silicon version that I built myself. Something is confusing MacOS. > >> On Jan 20, 2022, at 10:30 AM, Bob Carter <caggius@gmail.com> wrote: >> >> Yes I am getting that as well - It also happens when I revert to Rosetta which was behaving well yesterday >> >> Big Sur 11.6.2 >> OpenScad 211020 Rosetta >> >> >>> On 20 Jan 2022, at 16:25, David Schooley <dcschooley@gmail.com> wrote: >>> >>> Thank you Marius! >>> >>> I’m getting repeated requests to give OpenSCAD access to the Documents folder. Normally this happens only once, but now it happens every time I start OpenSCAD and tell it to open an recent file. The dialog even pops up more than once. Normally you see this once and then everything is taken care of after that. It’s possible that my Mac is just confused. >>> >>> >>> >>>> On Jan 20, 2022, at 7:41 AM, Torsten Paul <Torsten.Paul@gmx.de> wrote: >>>> >>>> Hi! >>>> >>>> Marius has put in quite some work to get the MacOS version >>>> ready as universal build for both Intel and M1 system. >>>> >>>> It would be great if that could get some wider testing on >>>> both platforms so it can be published with confidence: >>>> >>>> See the github issue for the download link: >>>> https://github.com/openscad/openscad/issues/4036 >>>> >>>> ciao, >>>> Torsten. >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
D
dpa
Thu, Jan 20, 2022 5:29 PM
I got the question "access to the Documents?" for every scad file + every
Preset!
wrote a bug report https://github.com/openscad/openscad/issues/4059
Am Do., 20. Jan. 2022 um 18:11 Uhr schrieb Bob Carter caggius@gmail.com:
Cheers
Bob.C
Big Sur 11.6.2
Thank you Marius!
Hi!
I got the question "access to the Documents?" for every scad file *+ every Preset!* wrote a bug report <https://github.com/openscad/openscad/issues/4059> Am Do., 20. Jan. 2022 um 18:11 Uhr schrieb Bob Carter <caggius@gmail.com>: > I normally have multiple releases of OpenScad in my App folder and I have > not seen this behaviour when switching between those - they obviously share > some things as they will always offer me recent files that have been opened > by a different version. > > I wondered if it was the M1 & Rosetta pairing confusing the OS > > So I deleted the M1 version out of Apps and then 211020 asked for > permission the first time but not the second - back to normal. > > Delete all my Rosetta versions and reinstate the M1 version on its own and > it gets stuck in the permissions loop. > > So not sure if that helps, but it is all grist for the mill…. > > Cheers > Bob.C > > > > On 20 Jan 2022, at 16:53, David Schooley <dcschooley@gmail.com> wrote: > > > > I’m glad it’s not just me. I haven’t seen this before either with the > Intel release or with the Apple Silicon version that I built myself. > Something is confusing MacOS. > > > >> On Jan 20, 2022, at 10:30 AM, Bob Carter <caggius@gmail.com> wrote: > >> > >> Yes I am getting that as well - It also happens when I revert to > Rosetta which was behaving well yesterday > >> > >> Big Sur 11.6.2 > >> OpenScad 211020 Rosetta > >> > >> > >>> On 20 Jan 2022, at 16:25, David Schooley <dcschooley@gmail.com> wrote: > >>> > >>> Thank you Marius! > >>> > >>> I’m getting repeated requests to give OpenSCAD access to the Documents > folder. Normally this happens only once, but now it happens every time I > start OpenSCAD and tell it to open an recent file. The dialog even pops up > more than once. Normally you see this once and then everything is taken > care of after that. It’s possible that my Mac is just confused. > >>> > >>> > >>> > >>>> On Jan 20, 2022, at 7:41 AM, Torsten Paul <Torsten.Paul@gmx.de> > wrote: > >>>> > >>>> Hi! > >>>> > >>>> Marius has put in quite some work to get the MacOS version > >>>> ready as universal build for both Intel and M1 system. > >>>> > >>>> It would be great if that could get some wider testing on > >>>> both platforms so it can be published with confidence: > >>>> > >>>> See the github issue for the download link: > >>>> https://github.com/openscad/openscad/issues/4036 > >>>> > >>>> ciao, > >>>> Torsten. > >>>> _______________________________________________ > >>>> OpenSCAD mailing list > >>>> To unsubscribe send an email to discuss-leave@lists.openscad.org > >>> _______________________________________________ > >>> OpenSCAD mailing list > >>> To unsubscribe send an email to discuss-leave@lists.openscad.org > >> _______________________________________________ > >> OpenSCAD mailing list > >> To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
DS
David Schooley
Thu, Jan 20, 2022 8:33 PM
There is something about the universal version that is confusing MacOS. I have an inkling of what it might be, but I’m not capable of explaining it. The combination of M1 and Intel binaries should not be a problem. Lot’s of applications are set up that way. I got the same behavior you did when switching to a different version but with my homemade M1 version instead of the Intel binary. The universal binary asks permission every time it wants to access a file. When I go back to the M1-only version, it asks once and never again. If my inkling is correct, then this should be an easy fix.
Cheers
Bob.C
Big Sur 11.6.2
Thank you Marius!
Hi!
There is something about the universal version that is confusing MacOS. I have an inkling of what it might be, but I’m not capable of explaining it. The combination of M1 and Intel binaries should not be a problem. Lot’s of applications are set up that way. I got the same behavior you did when switching to a different version but with my homemade M1 version instead of the Intel binary. The universal binary asks permission every time it wants to access a file. When I go back to the M1-only version, it asks once and never again. If my inkling is correct, then this should be an easy fix. > On Jan 20, 2022, at 11:09 AM, Bob Carter <caggius@gmail.com> wrote: > > I normally have multiple releases of OpenScad in my App folder and I have not seen this behaviour when switching between those - they obviously share some things as they will always offer me recent files that have been opened by a different version. > > I wondered if it was the M1 & Rosetta pairing confusing the OS > > So I deleted the M1 version out of Apps and then 211020 asked for permission the first time but not the second - back to normal. > > Delete all my Rosetta versions and reinstate the M1 version on its own and it gets stuck in the permissions loop. > > So not sure if that helps, but it is all grist for the mill…. > > Cheers > Bob.C > > >> On 20 Jan 2022, at 16:53, David Schooley <dcschooley@gmail.com> wrote: >> >> I’m glad it’s not just me. I haven’t seen this before either with the Intel release or with the Apple Silicon version that I built myself. Something is confusing MacOS. >> >>> On Jan 20, 2022, at 10:30 AM, Bob Carter <caggius@gmail.com> wrote: >>> >>> Yes I am getting that as well - It also happens when I revert to Rosetta which was behaving well yesterday >>> >>> Big Sur 11.6.2 >>> OpenScad 211020 Rosetta >>> >>> >>>> On 20 Jan 2022, at 16:25, David Schooley <dcschooley@gmail.com> wrote: >>>> >>>> Thank you Marius! >>>> >>>> I’m getting repeated requests to give OpenSCAD access to the Documents folder. Normally this happens only once, but now it happens every time I start OpenSCAD and tell it to open an recent file. The dialog even pops up more than once. Normally you see this once and then everything is taken care of after that. It’s possible that my Mac is just confused. >>>> >>>> >>>> >>>>> On Jan 20, 2022, at 7:41 AM, Torsten Paul <Torsten.Paul@gmx.de> wrote: >>>>> >>>>> Hi! >>>>> >>>>> Marius has put in quite some work to get the MacOS version >>>>> ready as universal build for both Intel and M1 system. >>>>> >>>>> It would be great if that could get some wider testing on >>>>> both platforms so it can be published with confidence: >>>>> >>>>> See the github issue for the download link: >>>>> https://github.com/openscad/openscad/issues/4036 >>>>> >>>>> ciao, >>>>> Torsten. >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Fri, Jan 21, 2022 12:59 AM
I also have the same issue of repeated requests for folder access.
M1 macbook air
On Thu, 20 Jan 2022, 21:55 David Schooley, dcschooley@gmail.com wrote:
Thank you Marius!
Hi!
I also have the same issue of repeated requests for folder access. M1 macbook air On Thu, 20 Jan 2022, 21:55 David Schooley, <dcschooley@gmail.com> wrote: > Thank you Marius! > > I’m getting repeated requests to give OpenSCAD access to the Documents > folder. Normally this happens only once, but now it happens every time I > start OpenSCAD and tell it to open an recent file. The dialog even pops up > more than once. Normally you see this once and then everything is taken > care of after that. It’s possible that my Mac is just confused. > > > > > On Jan 20, 2022, at 7:41 AM, Torsten Paul <Torsten.Paul@gmx.de> wrote: > > > > Hi! > > > > Marius has put in quite some work to get the MacOS version > > ready as universal build for both Intel and M1 system. > > > > It would be great if that could get some wider testing on > > both platforms so it can be published with confidence: > > > > See the github issue for the download link: > > https://github.com/openscad/openscad/issues/4036 > > > > ciao, > > Torsten. > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
DP
David Phillip Oster
Wed, Feb 9, 2022 5:13 AM
Any chance,  on Mac, of adding a preference for where the library folder
search path? So it would be stored like other preferences of the app in the
existing  ~/Library/Preferences/org.openscad.OpenSCAD.plist
This issue of repeated requests for folder access would vanish if OpenSCAD
looked in ~/Library/Application Support/OpenSCAD/library which is where a
Mac application should be putting its libraries.
And since Macs don't provide an easy way to set environment variables, the
suggested way of changing OPENSCADPATH (the list of paths) given in
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Libraries
hasn't
worked in years. (Reference:
https://stackoverflow.com/questions/25385934/setting-environment-variables-via-launchd-conf-no-longer-works-in-os-x-yosemite
So, change the location, change the documentation, and document the change
in the release notes.
On Thu, Jan 20, 2022 at 5:00 PM Sanjeev Prabhakar sprabhakar2006@gmail.com
M1 macbook air
Any chance, on Mac, of adding a preference for where the library folder search path? So it would be stored like other preferences of the app in the existing ~/Library/Preferences/org.openscad.OpenSCAD.plist This issue of repeated requests for folder access would vanish if OpenSCAD looked in *~/Library/Application Support/OpenSCAD/library* which is where a Mac application *should* be putting its libraries. And since Macs don't provide an easy way to set environment variables, the suggested way of changing OPENSCADPATH (the list of paths) given in *https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Libraries <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Libraries>* hasn't worked in years. (Reference: https://stackoverflow.com/questions/25385934/setting-environment-variables-via-launchd-conf-no-longer-works-in-os-x-yosemite ) So, change the location, change the documentation, and document the change in the release notes. On Thu, Jan 20, 2022 at 5:00 PM Sanjeev Prabhakar <sprabhakar2006@gmail.com> wrote: > I also have the same issue of repeated requests for folder access. > M1 macbook air >
