I have tried to take a difference() between a cube and an imported STL,
and it works 2 out of 4 times (with 4 different STLs); the other 2
times, all I get is the cube. The STLs in question are deemed manifold
and OK by netfabb Basic. Is this a known problem? Anythings I can try?
Thanks!
On Dec 3, 2016, at 15:25, jon jon@jonbondy.com wrote:
I have tried to take a difference() between a cube and an imported STL, and it works 2 out of 4 times (with 4 different STLs); the other 2 times, all I get is the cube. The STLs in question are deemed manifold and OK by netfabb Basic. Is this a known problem? Anythings I can try?
This sounds very much like this:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#Why_is_my_imported_STL_file_only_showing_up_with_F5_but_not_F6.3F
We’re discussing way of fixing this in OpenSCAD in a few other threads on this mailing list :)
Also check the STLs with FreeCAD and MeshMixer... they find errors that
NetFabb doesn't.
Thanks. Repeated fixing with various tools has not helped.
that NetFabb doesn't.
On Sun, Dec 4, 2016 at 9:43 AM, Marius Kintel <marius@kintel.net
mailto:marius@kintel.net> wrote:
On Dec 3, 2016, at 15:25, jon <jon@jonbondy.com
<https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#Why_is_my_imported_STL_file_only_showing_up_with_F5_but_not_F6.3F>
Checked by AVG - www.avg.com http://www.avg.com
Version: 2016.0.7924 / Virus Database: 4664/13527 - Release Date: 12/02/16
Do you have a link to your STL?
Turns out that both "problem" STLs appear just fine with F6, but they
still fail to work properly with difference().
http://www.jonbondy.com/ExampleSTL.ZIP
This is a reduced STL (MeshMixer), which still fails to difference()
from a cube with F6 but does with F5.
12/02/16
The file you uploaded is not a ZIP file, but an uncompressed binary STL
file. I was able to read it after guessing that and converting it to
ascii STL using http://www.greentoken.de/onlineconv/ (I need to add
support for reading binary STL).
Below is the log of running it through my healer algorithm. This is the
largest example so far.... and it seems to work after selecting a
slightly higher than default coordinate tolerance (-dtol option)
At bottom you will find the link to the repaired STL .... notice the
download will expire 2 days from now.
Please let us know if you are able to perform the difference operation
after using this repaired version.
polyfix Example_jon.stl -dtol=0.075 -stl
Parameters:
dtol = 0.075
input_file = Example_jon.stl
stl =
polyhedron 0, dtol=0.075, atol=1e-006, maxiter=50
iteration 0: vertices=513834 faces=171278
warning: 1 zero area faces.
warning: nonmanifold edges: uc(1)=513834
merged 428869 vertices
removed 1258 collapsed or zero area faces
removed 69 duplicate faces
removed 19 nonmanifold faces
total changes=430215
warning: nonmanifold edges: uc(1)=12 uc(3)=14 uc(4)=2
iteration 1: vertices=84965 faces=169932
removed 3 unused vertices
merged 34 vertices
removed 66 collapsed or zero area faces
split 3 faces
removed 7 duplicate faces
removed 6 nonmanifold faces
removed 6 zero area faces
total changes=125
warning: nonmanifold edges: uc(1)=2 uc(3)=2
iteration 2: vertices=84928 faces=169850
removed 1 unused vertex
merged 5 vertices
removed 10 collapsed or zero area faces
total changes=16
no warnings
iteration 3: vertices=84922 faces=169840
total changes=0
no warnings
Writing: Example_jon_polyfix.stl
polyhedron 0: vertices=84922 faces=169840 : no warnings
... polyfix finished, time used: 0d 00h 00m 45s
Link to download the resulting Example_jon_polyfix.stl (compressed with
7Zip) below:
https://www.expirebox.com/download/9770d1ed0137913c97b71e25d9ef8327.html
Note the link will expire 2 days from now.
No offence, but you didn't look too hard.
Netfabb basic, when in repair (red cross) use
Repair/Detect_self-intersections.
http://forum.openscad.org/file/n19467/ExampleSTL_si.jpg
Meshlab
http://forum.openscad.org/file/n19467/ExampleSTL_ml.jpg
View this message in context: http://forum.openscad.org/bug-with-difference-tp19439p19467.html
Michael:
Puzzling. I now have about 5 variants of this STL (some with reduced
numbers of triangles, some repaired). When I load any of them into
NetFabb Basic, it does not show up as needing repair. If I repair it
anyway (Automatic repair), I see a few stray bad lines, but the repaired
STL still fails in my program (that is, I can subtract it from a cube
using F5, but not using F6). I can always see the STL if I just view it
with F6 (which is somewhat different than the reported bug).
I do not see a "Repair/Detect_self-intersections" facility. Under
Actions I see a Self-intersections panel. If I click on Detect, it
finds something, but I cannot repair with the freebie version of the
software.
Meshlab
Version: 2016.0.7924 / Virus Database: 4664/13535 - Release Date: 12/04/16
