bug with difference?
Mon, Dec 5, 2016 12:36 AM
Carsten:
Your repaired STL works fine!  Thank you very much!
What language did you use to implement this tool?  Is this technology
available without having to pass STL files through you? I have one more
that is troublesome.
On 12/4/2016 1:56 PM, Carsten Arnholm wrote:
The file you uploaded is not a ZIP file, but an uncompressed binary
STL file. I was able to read it after guessing that and converting it
to ascii STL using http://www.greentoken.de/onlineconv/ (I need to add
support for reading binary STL).
Below is the log of running it through my healer algorithm. This is
the largest example so far.... and it seems to work after selecting a
slightly higher than default coordinate tolerance (-dtol option)
At bottom you will find the link to the repaired STL .... notice the
download will expire 2 days from now.
Please let us know if you are able to perform the difference operation
after using this repaired version.
polyfix Example_jon.stl -dtol=0.075 -stl
Parameters:
dtol = 0.075
input_file = Example_jon.stl
stl =
polyhedron 0, dtol=0.075, atol=1e-006, maxiter=50
iteration 0: vertices=513834 faces=171278
warning: 1 zero area faces.
warning: nonmanifold edges: uc(1)=513834
merged 428869 vertices
removed 1258 collapsed or zero area faces
removed 69 duplicate faces
removed 19 nonmanifold faces
total changes=430215
warning: nonmanifold edges: uc(1)=12 uc(3)=14 uc(4)=2
iteration 1: vertices=84965 faces=169932
removed 3 unused vertices
merged 34 vertices
removed 66 collapsed or zero area faces
split 3 faces
removed 7 duplicate faces
removed 6 nonmanifold faces
removed 6 zero area faces
total changes=125
warning: nonmanifold edges: uc(1)=2 uc(3)=2
iteration 2: vertices=84928 faces=169850
removed 1 unused vertex
merged 5 vertices
removed 10 collapsed or zero area faces
total changes=16
no warnings
iteration 3: vertices=84922 faces=169840
total changes=0
no warnings
Writing: Example_jon_polyfix.stl
polyhedron 0: vertices=84922 faces=169840 : no warnings
... polyfix finished, time used: 0d 00h 00m 45s
Link to download the resulting Example_jon_polyfix.stl (compressed
with 7Zip) below:
https://www.expirebox.com/download/9770d1ed0137913c97b71e25d9ef8327.html
Note the link will expire 2 days from now.
On 04. des. 2016 14:24, jon wrote:
http://www.jonbondy.com/ExampleSTL.ZIP
This is a reduced STL (MeshMixer), which still fails to difference()
from a cube with F6 but does with F5.
On 12/3/2016 6:09 PM, Carsten Arnholm wrote:
On 03. des. 2016 22:54, jon wrote:
Thanks.  Repeated fixing with various tools has not helped.
Do you have a link to your STL?
Checked by AVG - www.avg.com
Version: 2016.0.7924 / Virus Database: 4664/13535 - Release Date:
12/04/16
Carsten: Your repaired STL works fine! Thank you very much! What language did you use to implement this tool? Is this technology available without having to pass STL files through you? I have one more that is troublesome. Jon On 12/4/2016 1:56 PM, Carsten Arnholm wrote: > The file you uploaded is not a ZIP file, but an uncompressed binary > STL file. I was able to read it after guessing that and converting it > to ascii STL using http://www.greentoken.de/onlineconv/ (I need to add > support for reading binary STL). > > Below is the log of running it through my healer algorithm. This is > the largest example so far.... and it seems to work after selecting a > slightly higher than default coordinate tolerance (-dtol option) > > At bottom you will find the link to the repaired STL .... notice the > download will expire 2 days from now. > > Please let us know if you are able to perform the difference operation > after using this repaired version. > > >polyfix Example_jon.stl -dtol=0.075 -stl > > Parameters: > dtol = 0.075 > input_file = Example_jon.stl > stl = > > polyhedron 0, dtol=0.075, atol=1e-006, maxiter=50 > > iteration 0: vertices=513834 faces=171278 > warning: 1 zero area faces. > warning: nonmanifold edges: uc(1)=513834 > merged 428869 vertices > removed 1258 collapsed or zero area faces > removed 69 duplicate faces > removed 19 nonmanifold faces > total changes=430215 > warning: nonmanifold edges: uc(1)=12 uc(3)=14 uc(4)=2 > > iteration 1: vertices=84965 faces=169932 > warning: nonmanifold edges: uc(1)=12 uc(3)=14 uc(4)=2 > removed 3 unused vertices > merged 34 vertices > removed 66 collapsed or zero area faces > split 3 faces > removed 7 duplicate faces > removed 6 nonmanifold faces > removed 6 zero area faces > total changes=125 > warning: nonmanifold edges: uc(1)=2 uc(3)=2 > > iteration 2: vertices=84928 faces=169850 > warning: nonmanifold edges: uc(1)=2 uc(3)=2 > removed 1 unused vertex > merged 5 vertices > removed 10 collapsed or zero area faces > total changes=16 > no warnings > > iteration 3: vertices=84922 faces=169840 > total changes=0 > no warnings > > Writing: Example_jon_polyfix.stl > polyhedron 0: vertices=84922 faces=169840 : no warnings > > ... polyfix finished, time used: 0d 00h 00m 45s > > > Link to download the resulting Example_jon_polyfix.stl (compressed > with 7Zip) below: > > https://www.expirebox.com/download/9770d1ed0137913c97b71e25d9ef8327.html > Note the link will expire 2 days from now. > > Carsten Arnholm > > > On 04. des. 2016 14:24, jon wrote: >> http://www.jonbondy.com/ExampleSTL.ZIP >> >> This is a reduced STL (MeshMixer), which still fails to difference() >> from a cube with F6 but does with F5. >> >> Jon >> >> >> On 12/3/2016 6:09 PM, Carsten Arnholm wrote: >>> On 03. des. 2016 22:54, jon wrote: >>>> Thanks. Repeated fixing with various tools has not helped. >>>> >>>> Jon >>> >>> Do you have a link to your STL? >>> >>> Carsten Arnholm > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2016.0.7924 / Virus Database: 4664/13535 - Release Date: > 12/04/16 > >
Mon, Dec 5, 2016 1:10 AM
jon_bondy wrote
it does not show up as needing repair.
I does not automatically check for self-intersections.
If I repair it anyway (Automatic repair), I see a few stray bad lines, but
the repaired
STL still fails in my program
Bad lines = broken
(that is, I can subtract it from a cube
using F5, but not using F6).  I can always see the STL if I just view it
with F6 (which is somewhat different than the reported bug).
F5 doesn't actually generate real geometry, so you wont get such problems
with F5.
F6 will process the geometry if it needs to do union() difference() etc, so
wont always get the error, but of you use such operations it gets the error
because it is processing a broken STL.
I do not see a "Repair/Detect_self-intersections" facility. Under
Actions I see a Self-intersections panel.  If I click on Detect, it
finds something, but I cannot repair with the freebie version of the
software.
"Repair/Detect_self-intersections" is a menu.
If Netfabb doesn't fix it, it is almost certain OpenSCAD wont like it.
Trouble is garbage in - garbage out.
In Netfabb you also see black marks, these also are likely to be problems.
Such as;
http://forum.openscad.org/file/n19477/ExampleSTL_marks.jpg
This is the one under the right armpit;
http://forum.openscad.org/file/n19477/ExampleSTL_marks_closeup.jpg
Did you create the STLs? They look like scans of a plaster model taken from
a mould, I presume the arm/neck area are saw marks, where the scanner had
problems. It is better to try to fix the source than repair something with
missing information.
View this message in context: http://forum.openscad.org/bug-with-difference-tp19439p19477.html
jon_bondy wrote > it does not show up as needing repair. I does not automatically check for self-intersections. > If I repair it anyway (Automatic repair), I see a few stray bad lines, but > the repaired > STL still fails in my program Bad lines = broken > (that is, I can subtract it from a cube > using F5, but not using F6). I can always see the STL if I just view it > with F6 (which is somewhat different than the reported bug). F5 doesn't actually generate real geometry, so you wont get such problems with F5. F6 will process the geometry if it needs to do union() difference() etc, so wont always get the error, but of you use such operations it gets the error because it is processing a broken STL. > I do not see a "Repair/Detect_self-intersections" facility. Under > Actions I see a Self-intersections panel. If I click on Detect, it > finds something, but I cannot repair with the freebie version of the > software. "Repair/Detect_self-intersections" is a menu. If Netfabb doesn't fix it, it is almost certain OpenSCAD wont like it. Trouble is garbage in - garbage out. In Netfabb you also see black marks, these also are likely to be problems. Such as; <http://forum.openscad.org/file/n19477/ExampleSTL_marks.jpg> This is the one under the right armpit; <http://forum.openscad.org/file/n19477/ExampleSTL_marks_closeup.jpg> Did you create the STLs? They look like scans of a plaster model taken from a mould, I presume the arm/neck area are saw marks, where the scanner had problems. It is better to try to fix the source than repair something with missing information. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/bug-with-difference-tp19439p19477.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Dec 5, 2016 1:17 AM
I grabbed the original STL from Thingiverse.  No idea if it was
scanned.  I see no "Repair/Detect_self-intersections" in netfabb Basic
5.2 (and it claims that no updates are available).  I guess I need
better error detection-and-repair tools.  Carsten's tool seems to have
done a fine job!
I grabbed the original STL from Thingiverse. No idea if it was scanned. I see no "Repair/Detect_self-intersections" in netfabb Basic 5.2 (and it claims that no updates are available). I guess I need better error detection-and-repair tools. Carsten's tool seems to have done a fine job! Jon
Mon, Dec 5, 2016 1:24 AM
fine job!
Newer versions are a bit more confusing to get. No idea if
it's worth it. For some reason they dropped the support for
non-Windows platforms :(.
See "Guide: How to get the new, free Autodesk Netfabb Basic!"
https://www.youtube.com/watch?v=2QRvS9xdNzw
On 12/05/2016 02:17 AM, jon wrote: > I grabbed the original STL from Thingiverse. No idea if it was scanned. > I see no "Repair/Detect_self-intersections" in netfabb Basic 5.2 > (and it claims that no updates are available). I guess I need better > error detection-and-repair tools. Carsten's tool seems to have done a > fine job! > Newer versions are a bit more confusing to get. No idea if it's worth it. For some reason they dropped the support for non-Windows platforms :(. See "Guide: How to get the new, free Autodesk Netfabb Basic!" https://www.youtube.com/watch?v=2QRvS9xdNzw ciao, Torsten.
Mon, Dec 5, 2016 3:00 AM
Torsten:
Thanks for the tip.  I am now using the correct/current Netfabb Basic!
Now I understand Michael's otherwise cryptic comments about
self-intersection!
fine job!
Torsten: Thanks for the tip. I am now using the correct/current Netfabb Basic! Now I understand Michael's otherwise cryptic comments about self-intersection! Jon On 12/4/2016 8:24 PM, Torsten Paul wrote: > On 12/05/2016 02:17 AM, jon wrote: >> I grabbed the original STL from Thingiverse. No idea if it was scanned. >> I see no "Repair/Detect_self-intersections" in netfabb Basic 5.2 >> (and it claims that no updates are available). I guess I need better >> error detection-and-repair tools. Carsten's tool seems to have done a >> fine job! >> > Newer versions are a bit more confusing to get. No idea if > it's worth it. For some reason they dropped the support for > non-Windows platforms :(. > > See "Guide: How to get the new, free Autodesk Netfabb Basic!" > https://www.youtube.com/watch?v=2QRvS9xdNzw > > ciao, > Torsten. > >
arnholm@arnholm.org
Mon, Dec 5, 2016 8:40 AM
On 2016-12-05 01:36, jon wrote:
Carsten:
You are welcome. Thanks for the opportunity to test with our model.
It is written in ISO C++
Is this technology
Right now, no. I am considering some kind of free service for this but
this is very early days and more testing is required to confirm the
methods are sufficiently stable. To help this happen you (and others on
this list) may email me off list with links to models in need of repair.
Please do not send the files as attachments (I will not reply if you
do so), but instead provide links to your own site or alternatively a
free temporary file storage service like e.g. https://www.expirebox.com/
. I will then process and reply. No guarantees for success, but I will
try to solve solvable problems.
On 2016-12-05 01:36, jon wrote: > Carsten: > > Your repaired STL works fine! Thank you very much! You are welcome. Thanks for the opportunity to test with our model. > What language did you use to implement this tool? It is written in ISO C++ > Is this technology > available without having to pass STL files through you? I have one > more that is troublesome. Right now, no. I am considering some kind of free service for this but this is very early days and more testing is required to confirm the methods are sufficiently stable. To help this happen you (and others on this list) may email me off list with links to models in need of repair. Please do *not* send the files as attachments (I will not reply if you do so), but instead provide links to your own site or alternatively a free temporary file storage service like e.g. https://www.expirebox.com/ . I will then process and reply. No guarantees for success, but I will try to solve solvable problems. Carsten Arnholm
Mon, Dec 5, 2016 3:26 PM
Jon,
We’re also working on an open source implementation of such repair functionality. Some of that is collected in this work-in-progress issue: https://github.com/openscad/openscad/issues/1580
Any help is welcome, right now we mostly need dev resources and low-level test cases.
Jon, We’re also working on an open source implementation of such repair functionality. Some of that is collected in this work-in-progress issue: https://github.com/openscad/openscad/issues/1580 Any help is welcome, right now we mostly need dev resources and low-level test cases. -Marius
CA
Sun, Jan 15, 2017 6:37 PM
I just happened to see the following on the forum (Jan 03)
http://forum.openscad.org/bug-with-difference-tp19439p19889.html
Since it did not appear on the mailing list, I didn't see it until now,
sorry.
Here is the reply to the query
https://www.expirebox.com/download/af79793020a059ca5fa992d496de4b9c.html
(2 faces removed)
I just happened to see the following on the forum (Jan 03) http://forum.openscad.org/bug-with-difference-tp19439p19889.html Since it did not appear on the mailing list, I didn't see it until now, sorry. Here is the reply to the query https://www.expirebox.com/download/af79793020a059ca5fa992d496de4b9c.html (2 faces removed) Carsten Arnholm
