Fri, Oct 23, 2026 12:37 PM
I have tried BelfrySCAD and it is unlikely that I will return to
OpenSCAD. Bugs that I reported a year ago in OSCAD are already fixed in
BSCAD, and suggestions made are responded to and acted upon in hours or
days, not years. Improvement is significant and rapid.
I highly recommend that people give BelfrySCAD a try.
DP
Dan Perry
Fri, Oct 23, 2026 12:53 PM
Likewise. I've already reported a couple bugs and had them fixed. I like
the out-of-the-box thinking to skip preview and go straight to render. And
BelfrySCAD is much faster than OpenSCAD, especially noticeable when using
path_sweep() and similar compute-intensive modules.
The editor is not for me, but it's easy to use VS Code and BelfrySCAD
together. With OpenSCAD, there are VS Code extensions that can start
OpenSCAD, while with BelfrySCAD there is a small inconvenience that one has
to open the .scad file in both tools manually.
Dan
On Fri, Oct 23, 2026 at 1:38 PM Jon Bondy via Discuss <
Dan
> Jon
> This email has been checked for viruses by AVG antivirus software.
> www.avg.com
GS
Guenther Sohler
Fri, Oct 23, 2026 1:13 PM
Yes, i am also looking into that now.
Did anybody find out, how to use the WYSIFYG Gizmos.
I am trying to trigger a code rewrite by dragging a vertex/edge but did not
succeed yet.
On Fri, Oct 23, 2026 at 2:54 PM Dan Perry via Discuss <
Dan
succeed yet.
> Dan
>> Jon
>> www.avg.com
Fri, Oct 23, 2026 1:31 PM
If you are having problems with BSCAD, I suggest submitting an Issue on
their GitHub rather than asking here.
did not succeed yet.
fixed. I like the out-of-the-box thinking to skip preview and go
straight to render. And BelfrySCAD is much faster than OpenSCAD,
especially noticeable when using path_sweep() and similar
BelfrySCAD together. With OpenSCAD, there are VS Code extensions
that can start OpenSCAD, while with BelfrySCAD there is a small
inconvenience that one has to open the .scad file in both tools
manually.
Dan
already fixed in
hours or
<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.avg.com&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=IGZNEr9s1lb8mLhbXCXXS28cOKXDIkfIRjs9_OSi47LOXp-7YI-qVZvmALteb7Hr&s=1ppcBRsMuP9CvhZFa4JR_LBcVzzx3IlWKlfsxVlgczM&e=>
> manually.
> Dan
> already fixed in
> hours or
> Jon
> www.avg.com
TA
Todd Allen
Fri, Oct 23, 2026 4:41 PM
while with BelfrySCAD there is a small inconvenience that one has to open
I'm using kate under Debian as my external editor for both OpenSCAD and
BelfrySCAD. My workflow is better in BelfrySCAD. I installed BelfrySCAD
from a flatpak and invoke it through a bash script named BelfrySCAD. I
configured ALT-B to run BelfrySCAD --render filename.scad. The first time
I do this BelfrySCAD opens slightly slower than OpenSCAD which I have bound
to ALT-O. But after that successive commands are handled by the BelfrySCAD
instance which opens additional files quickly in new tabs while OpenSCAD
never implemented that requested feature and slowly opens every file in a
separate instance.
Unfortunately in BelfrySCAD as of this morning I get a preview instead of a
render. Yesterday BelfrySCAD did not have a preview mode and I made a
request for a command line option to suppress the '#' modifier which was
always active in renders since there was no preview. Instead, the
desirability of retaining a preview mode was recognized and quickly
implemented and F5 with $preview=true is back and in my mind much better
because it shares the graphics pipeline with render. So one can for
example do a preview to see high contrast colors and use the measure tool
in the preview which can't be done in OpenSCAD and probably take a long
time to iimplement if the feature was requested. I'm fairly certain
--render will work as expected today, perhaps when I get back from lunch.
On Fri, Oct 23, 2026 at 7:54 AM Dan Perry via Discuss <
Dan
separate instance.
> Dan
>> Jon
>> www.avg.com
Fri, Oct 23, 2026 5:50 PM
On Oct 23, 2026, at 6:14 AM, Guenther Sohler via Discuss discuss@lists.openscad.org wrote:
I am trying to trigger a code rewrite by dragging a vertex/edge but did not succeed yet.
While the WYSIWYG editing idea was one of the reasons I started writing BelfrySCAD, it is also one of the least well developed features so far. Mostly because figuring out how the code should be handled is somewhat complicated. You can move, scale, or rotate objects you select, but there is currently no support for doing anything with edges or corners of objects.
If would have ideas on how this interface can be improved, please file a feature request at https://github.com/BelfrySCAD/BelfrySCAD/issues
-Revar
> On Oct 23, 2026, at 6:14 AM, Guenther Sohler via Discuss <discuss@lists.openscad.org> wrote:
-Revar
GS
Guenther Sohler
Fri, Oct 23, 2026 6:06 PM
Hi Revar,
This shows where the real difficulty lies. If you drag a corner of cube(10),
the length, width and height would all have to change together; with
cube([10,11,12]), each coordinate would presumably change on its own. A
model built from many operations brings many parameters into each of those
operations, and a two-dimensional drag on the screen gives the tool very
little to go on. Mapping that movement back onto the model parameters is
close to impossible.
I have implemented a solution for this in PythonSCAD, but I’d like to look
around and see whether there are alternative approaches.
On Fri, Oct 23, 2026 at 7:50 PM Revar Desmera via Discuss <
not succeed yet.
objects.
-Revar
Hi Revar,
> not succeed yet.
> objects.
> -Revar
WF
William F. Adams
Fri, Oct 23, 2026 8:22 PM
The thing which I really want to happen when dragging is for the UI to determine what variable is tied to the feature/object being dragged and then update the value for that variable in the code.
The current BelfrySCAD implementation of wrapping things in scale/transform/translate blocks is an interesting approach, and one which I've found useful for working on the code in projects/modules, but it's not something which I think an end-user would find directly useful --- a mode which identifies all the usages of variables exposed in the Customizer and makes the matching objects/features/points directly draggable would be more useful for most end-users, but I think there's room for both approaches.
I'd be very interested in seeing a tool which could serve both sorts of usages.
-- Sphinx of black quartz, judge my vow.https://designinto3d.com/
On Friday, October 23, 2026 at 02:06:01 PM EDT, OpenSCAD general discussion Mailing-list discuss@lists.openscad.org wrote:
Hi Revar,
This shows where the real difficulty lies. If you drag a corner of cube(10), the length, width and height would all have to change together; with cube([10,11,12]), each coordinate would presumably change on its own. A model built from many operations brings many parameters into each of those operations, and a two-dimensional drag on the screen gives the tool very little to go on. Mapping that movement back onto the model parameters is close to impossible.
I have implemented a solution for this in PythonSCAD, but I’d like to look around and see whether there are alternative approaches.
On Fri, Oct 23, 2026 at 7:50 PM Revar Desmera via Discuss discuss@lists.openscad.org wrote:
-Revar
On Friday, October 23, 2026 at 02:06:01 PM EDT, OpenSCAD general discussion Mailing-list <discuss@lists.openscad.org> wrote:
Hi Revar,
On Fri, Oct 23, 2026 at 7:50 PM Revar Desmera via Discuss <discuss@lists.openscad.org> wrote:
-Revar
Fri, Oct 23, 2026 8:58 PM
I don't think such a thing is possible, in anything like the general case.
The problem is that it's only possible if you can some how reverse the
position of the point that you're trying to modify, back to a single value.
cube(10); // easy
a = 5; cube(a); // fairly easy
b = 5; cube(b + 1); // possible
c = 5; d = 3; cube(c + d); // impossible
And then there's the question of what to do when the value that's at the
root of the thing being modified is the basis for another thing entirely.
x = 5; cube(x); sphere(x);
When you drag the corner of the cube and x changes, the sphere will
change too. Is that what you wanted? Maybe yes, maybe no, depending on
the intent of the change.
My guess is that in my models fewer than half of the resulting
coordinates would make it past the first problem. There's way too many
"width of the box minus two times the thickness of the sides" kinds of
patterns.
cube(10); // easy
patterns.
TA
Todd Allen
Fri, Oct 23, 2026 10:10 PM
I like the way dragging stuff works in Freecad's sketcher. It's not
perfect and it has taken a long time to get as good as it is although the
pace of improvement has accelerated, perhaps from AI assisted coding. The
sketcher is based on defining constraints and a constraint solver engine
that determines what can move and how things can move when a point is
dragged or a constraint such as a distance between points or an angle or
radius is modified. I think a constraint system could be a great addition
to SCAD either with or without a GUI.
On Fri, Oct 23, 2026, 3:59 PM Jordan Brown via Discuss <
cube(10); // easy
When you drag the corner of the cube and x changes, the sphere will change
too. Is that what you wanted? Maybe yes, maybe no, depending on the
My guess is that in my models fewer than half of the resulting coordinates
would make it past the first problem. There's way too many "width of the
box minus two times the thickness of the sides" kinds of patterns.
> cube(10); // easy
