On 10/23/2026 3:10 PM, Todd Allen wrote:
I like the way dragging stuff works in Freecad's sketcher. It's not
perfect and it has taken a long time to get as good as it is although
the pace of improvement has accelerated, perhaps from AI assisted
coding. The sketcher is based on defining constraints and a
constraint solver engine that determines what can move and how things
can move when a point is dragged or a constraint such as a distance
between points or an angle or radius is modified. I think a
constraint system could be a great addition to SCAD either with or
without a GUI.
There are such systems, but they are very different in style from OpenSCAD.
I don't know how they handle the cube(a+b) case, though. My guess is
that they apparently-randomly pick one or the other variable to change,
as long as all of the rest of the constraints are still satisfied.
Things only move or change as needed to satisfy constraints. If you don't
like how something responds you add or change constraints. The goal is to
reach a fully constrained design with a single solution. For a cube each
of x, y, z, width, height and depth could be constrained by assigning a
value. Or any of the corner points might be constrained by assigning their
positions or binding them to something else. As you go the system gives
feedback on what elements are fully constrained, partially constrained,
unconstrained or over constrained.
On Fri, Oct 23, 2026, 5:23 PM Jordan Brown openscad@jordan.maileater.net
perfect and it has taken a long time to get as good as it is although the
pace of improvement has accelerated, perhaps from AI assisted coding. The
sketcher is based on defining constraints and a constraint solver engine
that determines what can move and how things can move when a point is
dragged or a constraint such as a distance between points or an angle or
radius is modified. I think a constraint system could be a great addition
to SCAD either with or without a GUI.
I don't know how they handle the cube(a+b) case, though. My guess is that
they apparently-randomly pick one or the other variable to change, as long
Constraint-based systems are clearly not BelfrySCAD, so I changed the
subject.
Moreover, while I agree that constraint-based systems are interesting...
OpenSCAD isn't one of them, so much more than a reference to "go look
over there for more information" is probably off topic.
But if people still want to talk about this, well, at least now the
subject is sort of appropriate.
OpenSCAD doesn't have a constraint system but there is nothing preventing
it but lack of developer capacity. Imagine existing language primitives
taking a ??? instead of a floating point value. And ways to specify
constraints. The constraint solver keeps you informed of which ??? are
constrained and solvable or when constraints conflict. If there is a GUI
things unconstrained can be dragged and then their distance or angle to
something else can be captured as a constraint.
BelfrySCAD could very likely leverage the Freecad sketcher into an
additional way to create 2d geometry in a couple weeks and expand it to 3d
quickly after that. For OpenSCAD I think you would be right to say it is
impossible.
On Fri, Oct 23, 2026, 6:34 PM Jordan Brown via Discuss <
subject.
OpenSCAD isn't one of them, so much more than a reference to "go look over
On Oct 23, 2026, at 6:50 PM, Todd Allen via Discuss discuss@lists.openscad.org wrote:
OpenSCAD doesn't have a constraint system but there is nothing preventing it but lack of developer capacity. Imagine existing language primitives taking a ??? instead of a floating point value. And ways to specify constraints. The constraint solver keeps you informed of which ??? are constrained and solvable or when constraints conflict. If there is a GUI things unconstrained can be dragged and then their distance or angle to something else can be captured as a constraint.
While I know how to make a constraints solver, it is far less clear how to integrate the necessary concepts into OpenSCAD syntax.
This is one area where the OpenSCAD Language's parent-child structure and implicit union-ing syntax makes things difficult.
You could do:
constraint_tangent() {
circle(20);
square([25,30]);
But that's insufficient constraints for that geometry. What side of the square is it tangent to? Which position coordinates are locked down? And there's no clear way to specify multiple constraints for any one object. If we had module literals, like PR #4478, we could theoretically add multiple constraints by referring to the shapes by variables, but even that gets muddied by the immutable "variables" Functional Programming. Maybe something like:
a = module() square([25,30]);
b = module() circle(20);
a2 = add_constraint(a,"position",[0,0]);
b2 = add_constraint(b,"x>=",25);
b3 = add_constraint(b2,"y",0);
c = add_joint_constraint(a,b,"tangent");
c(); // instantiate!
You'll end up with a bunch of constraint types, and joint constraint types.
I'm not sure I want to really think about how to write the solver Jacobians for 3D tangents of irregular polyhedrons, though.
And about the second after I hit send on this, it occurs to be that a pure-data constraints system is perfectly possible without module literals.
You could do:
circle(20);
square([25,30]);
Could one design a constraint-based language and fit it into the
OpenSCAD UI and geometry engines? Definitely. Am I interested in
working on such a project? No.
Could one augment the OpenSCAD language with constraint mechanisms, so
that they would somehow play nice together? Maybe. I'm dubious.
Probably depends on what kind of integration you would expect. Am I
interested in working on such a project? No.
Okay, it looks like it is possible to make a pure user-space OpenSCAD constraints system. Not sure how fast it'd be.
It'd look something like this:
res = constraint_solve(
object( // Initial guesses
cp=[4,3], // center point of circle
r=2, // radius of circle
a=[0,0], // Point A of triangle
b=[1,0], // Point B of triangle
c=[0,1] // Point C of triangle
function(o) [ // Constraints
// A.y == B.y
constraint_horizontal(o.a, o.b),
// norm(A-B) == 20
constraint_length(o.a, o.b, 20),
// norm(C-midpt(B,C)) == 15
constraint_length(o.c, (o.a+o.b)/2, 15),
// norm(A-C) == norm(B-C)
constraint_equal_length(o.a, o.c, o.b, o.c),
// Circle is tangent to AB
constraint_circle_tangent_to_line(o.cp, o.r, o.a, o.b),
// Circle is tangent to AC
constraint_circle_tangent_to_line(o.cp, o.r, o.a, o.c),
// Circle is tangent to BC
constraint_circle_tangent_to_line(o.cp, o.r, o.b, o.c),
// Circle is centered at [0,1]
constraint_coincident(o.cp, [0,1])
draw_line(res.a, res.b);
draw_line(res.b, res.c);
draw_line(res.c, res.a);
translate(rec.cp) circle(r=rec.r);
Kind of ugly, and unnecessarily verbose. I have got all the functions undefined above written out, but it's a few hundred lines long.
Honestly, I don't really know how often I'd want to go to all the trouble of formalizing constraints like this.
That actually ran a lot faster than I thought it would. Converged in 7 iterations, in 0.012 seconds. Maybe I should consider this for BOSL2.
// A.y == B.y
// norm(A-B) == 20
"Honestly, I don't really know how often I'd want to go to all the
trouble of formalizing constraints like this."
That.
// A.y == B.y
// norm(A-B) == 20
