Gene Heskett
Wed, Oct 28, 2026 2:27 PM
Where can I find a recent openscad that will run on an armbian 2404?
2608 is a disaster that found a place to happen, too much stuff does NOT
work so I've reverted to 2404. So I need the appimage to run on that?
Looking at the download page the newest is a 23 something & this is 26.
Help please.
Cheers, Gene
There are 4 boxes to defend liberty
Soap, ballot, Jury, and Ammo.
Please use in that order
Help please.
Cheers, Gene
Wed, Oct 28, 2026 5:26 PM
What might work is using the snap package, which would mean something
like:
sudo apt install snapd
snap install openscad-nightly
Otherwise, I'm not sure what exact Distro that is, Armbian does
not really list much details on the website, but 2404 somehow
sounds like Ubuntu version.
Can you check what the following 3 commands give as output:
uname -a
lsb_release -a
cat /etc/os-release
Maybe that helps to get some more info on the Distro.
like:
uname -a
lsb_release -a
cat /etc/os-release
Wed, Oct 28, 2026 7:25 PM
2404?
like:
Armbian is not just a distro. It's a distro (Debian or derivative, on
an ARM 64 CPU.
uname -a
lsb_release -a
cat /etc/os-release
> > 2404?
> like:
an ARM 64 CPU.
> uname -a
> lsb_release -a
> cat /etc/os-release
> ciao,
> Torsten.
VB
Verachten Bruno
Wed, Oct 28, 2026 7:52 PM
2404?
like:
an ARM 64 CPU.
uname -a
lsb_release -a
cat /etc/os-release
I publish nightly arm64 and riscv64 builds regularly there:
https://github.com/gounthar/openscad/releases/tag/v2026.10.28 .
Bruno Verachten
On Wed, Oct 28, 2026, 20:25 larry via Discuss <discuss@lists.openscad.org>
> > > 2404?
> > like:
> an ARM 64 CPU.
> > uname -a
> > lsb_release -a
> > cat /etc/os-release
> > ciao,
> > Torsten.
Gene Heskett
Wed, Oct 28, 2026 9:18 PM
like:
This worked reasonably well Torsten, runs ok but none of the right hand
menu examples can be found. The gui looks good but I've no starter code
w/o writing my own.
I tried to post a hellphone pix of the stuck synaptic, around 6 megs of
a jpeg which the mail server rejected, and finally used a killall on
synaptic, at which point it fell thru and finished the upgrade. Now I'm
going to try a power cycle reboot. Despite my fstab entry for the raid
ending in 0 0, it insists on fchecking the raid6 & with 20T of SSD's
that takes about half an hour. I did this just to see if I could and am
impressed by the speed of around 600megs a second, read or write. All on
a bpi-m5, which is pretty close to an rpi4, but all 4 usb's are 3.1 speed.
It is, using ubuntu repos for everything it thinks it needs. Which is
NOT everything I need, but you knew that!
Thanks Torsten.
Take good care of you and yours.
Cheers; Gene
uname -a
lsb_release -a
cat /etc/os-release
Soap, ballot, jury, ammo
> like:
w/o writing my own.
Thanks Torsten.
Cheers; Gene
> uname -a
> lsb_release -a
> cat /etc/os-release
> ciao,
> Torsten.
Gene Heskett
Wed, Oct 28, 2026 9:20 PM
2404?
like:
an ARM 64 CPU.
They switched to ubuntu repo's at 2404.
uname -a
lsb_release -a
cat /etc/os-release
>>> 2404?
>> like:
> an ARM 64 CPU.
>> uname -a
>> lsb_release -a
>> cat /etc/os-release
>> ciao,
>> Torsten.
Thu, Oct 29, 2026 10:16 AM
2404?
IIRC I recently tried compiling it on my raspberry (thinking there
were no distro packages). That went smoothly. Then I found out there
was a package after all.
** Verl. Spiegelmakerstraat 37 2645 LZ Delfgauw, The Netherlands.
** KVK: 27239233 **
** 'a' for accelleration.
> 2404?
** KVK: 27239233 **
Gene Heskett
Thu, Oct 29, 2026 1:39 PM
2404?
Except this isn't an rpi Roger, its a bananapi-m5, with all 4 USB ports
rated at 3.1. Rpi4 stuff might run on it, but poorly. SPI stuff won't.
At about the 10th full install, sound suddenly started working. I'm not
100% happy yet, the auto logoff stuff has been turned off, but the
eventual killing of the hdmi output makes the 42" Visio monitor goes
back to being a tv, at which point the sound of the endless pol skits
wakes me back up.
Thanks & Cheers Roger, Gene
There are four boxes to protect liberty
Please use in that order!
>> 2404?
> Roger.
wakes me back up.
Thu, Oct 29, 2026 3:57 PM
I wasn't suggesting you'd get the RPI binary (from me?), but
that just downloading the sources, hit "./confgure;make" and
it might just work. Might take an hour or so to compile, but
you'd have your own binaries, for your machine.
** KVK: 27239233 **
** KVK: 27239233 **
Gene Heskett
Thu, Oct 29, 2026 7:10 PM
2404?
Correction Armbian 26.8.1 uptodate.
I'll have to go check again in a couple days. I've found some u-sd cards
that are around 2x faster than what I have ATM but AZ won't deliver till
tomorrow. And I have a grocry list of stuff to install after those
cards get here.
Thank you Roger
>> 2404?
> Roger.
cards get here.
Thank you Roger
