On 10/29/26 11:58, Rogier Wolff via Discuss wrote:
On Thu, Oct 29, 2026 at 09:39:32AM -0400, Gene Heskett wrote:
Except this isn't an rpi Roger, its a bananapi-m5, with all 4 USB ports
rated at 3.1. Rpi4 stuff might run on it, but poorly. SPI stuff won't.
I wasn't suggesting you'd get the RPI binary (from me?), but
that just downloading the sources, hit "./confgure;make" and
it might just work. Might take an hour or so to compile, but
you'd have your own binaries, for your machine.
I've considered that too, and if I build it on the raid6, faster than
stink. Thanks for the reminder.
Cheers, Gene
There are four boxes to protect liberty
Soap, ballot, jury, ammo
Please use in that order!
On 10/28/26 10:27, Gene Heskett via Discuss wrote:
Where can I find a recent openscad that will run on an armbian 2404?
2608 is a disaster that found a place to happen, too much stuff does
NOT work so I've reverted to 2404. So I need the appimage to run on
that?
Looking at the download page the newest is a 23 something & this is
26.
Help please. Cheers, Gene
I need to correct the distro I'm using, saying above that 2608 was a
disaster, I think I was pulling the usbkey before the sync was
completed. So the image that got to the u-sd card was incomplete. So I
waited another 5 minutes and issued a sync,which took several seconds
after dd wrote the card and its worked very well for about 12 days now.
So I'm running the latest armbian version of 2608.1 which now reports:
Linux bananapim5 6.18.44-current-meson64 #1 SMP PREEMPT Sun Aug 9
18:25:30 UTC 2026 aarch64 GNU/Linux
aka from /etc/issue:
Armbian 26.8.14 resolute \l
copy
