The 2021 release allows the insertion of code snippets. I can't find any
information in the docs about this other that to use alt-ins to insert a
snippet. Some questions.
-Bob
On 18.05.21 03:14, rjcarlson49 wrote:
No idea where that key is on Mac, but the code snippets can
be also inserted via context menu (normally right click in
the editor, wherever that is on Mac, probably CTRL+Click?)
There's no GUI for that yet. Maybe that will happen at some
point but right now it's all manual work.
The folder name can be found in Help->Library Info->User
Config Path
Create a subfolder called "templates"
Create a text file with extension .json, for example:
File name: points.json
Content:
"key" : "points",
"content" : "points = [ for (a = [0:5:359]) 1^~^ * [ -sin(x), cos(x) ] ]"
The 3 chars ^~^ indicate where the cursor will end up
after the text was inserted at the current cursor location.
Those are stored in the Application Bundle, so it might be
possible to edit those by "Show Package Content" and going
into the Contents/Resources/templates folder. I'm not sure
if that's a good option though.
For reference the files shipped in the application are:
https://github.com/openscad/openscad/tree/master/templates
Sent: Sun, 23 May 2021 10:45
Subject: [OpenSCAD] Re: How do I edit/create code snippets?
Config Path
Content:
"key" : "points",
Thanks. That should be documented somewhere.
I would suggest first of all, that all templates include vectors with numbers. This is much quicker in the long run. Even when typing I do that. I type translate([0, 0, 0]), then edit. For multmatrix I would make it multmatrix([[1, 0, 0, 0], [0, 1, 0, 0], [0, 0, 1, 0]]). That’s a good starting point for that function.
Second, perhaps this is already how it works, but allow templates in the library to replace the built in ones. It would make for less confusion.
Also, in the Mac editor UI, option-leftarrow should go left one word, but it does not. This is basic mac text editing. And option-rightarrow does the “right” thing.
-Bob
Tucson AZ
Config Path
Content:
"key" : "points",
The OpenSCAD Manual Wiki
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual#The_OpenSCAD_User_Manual
is editable by anyone ;)
There doesn't seem to be a section this info would slot into, so if anyone
wants to add this info,
I'd do it in FAQ for now. There is a bunch of similar config details that
need documenting, color schemes, registry (and *nix equiv.) etc.
This is a very personal matter of taste, I would (and have in Notepad++) use
<KeyWord name="translate (["/>
So from there I just type e,g, "somevar.x, somevar.y, -1] ) " then follow on
e.g. "cu" for a cube.
+1, if it doesn't now, they are in the template subdir where the .exe lives
(e.g. 'My programs' for Windows).
the “right” thing.
Bob, would you be able to check the Keyboard info on GitHub
https://github.com/openscad/openscad/wiki/Keyboard-Shortcuts from a Mac
users perspective?
No need to edit it, just note anything here and I'll update it.
I looked at it, but it will take some time to do it right.
First thing I noticed though is that on a Mac, there is a control key. ctrl should equal control not command. When the semantics exist on a mac like undo, cut, copy, paste the Mac shortcuts should always be used. So those four are command-z, -x, -c, -v, even though those use control- on the PC. Perhaps the problem is just the presentation. Better I think would be a table with rows consisting of <action> <pc shortcut> <mac shortcut> <linux shortcut>. Is there a Linux version?
Second, the entire "Mac only navigation shortcuts” should probably be eliminated. AFAIK these are in no way mac standard and no one would use them.
-Bob
Tucson AZ
Bob, would you be able to check the Keyboard info on GitHub https://github.com/openscad/openscad/wiki/Keyboard-Shortcuts from a Mac users perspective?
Unless specifically shown otherwise above, my contribution is in the Public Domain;
to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work.
Sent from the OpenSCAD mailing list archive http://forum.openscad.org/ at Nabble.com.
Sorry Bob, I wrote the first bits, where I included this at the top,
'C - Ctrl (Cmd on Mac) '
'M - Ctrl on Mac (Windows/Meta key on others) '
I should have mentioned that.
I did that as the GitHub Wiki is written from a developer's perspective, and so in Qt context https://doc.qt.io/qt-5/qkeysequence.html#details , where:
'Each key code consists of a single Qt::Key https://doc.qt.io/qt-5/qt.html#Key-enum value and zero or more modifiers, such as Qt::SHIFT https://doc.qt.io/qt-5/qt.html#Modifier-enum , Qt::CTRL https://doc.qt.io/qt-5/qt.html#Modifier-enum , Qt::ALT https://doc.qt.io/qt-5/qt.html#Modifier-enum and Qt::META https://doc.qt.io/qt-5/qt.html#Modifier-enum .'
'On macOS, the appropriate symbols are used to describe keyboard shortcuts using special keys on the Macintosh keyboard.'
'Note: On macOS, references to "Ctrl", Qt::CTRL https://doc.qt.io/qt-5/qt.html#Modifier-enum , Qt::Key_Control https://doc.qt.io/qt-5/qt.html#Key-enum and Qt::ControlModifier https://doc.qt.io/qt-5/qt.html#KeyboardModifier-enum correspond to the Command keys on the Macintosh keyboard, and references to "Meta", Qt::META https://doc.qt.io/qt-5/qt.html#Modifier-enum , Qt::Key_Meta https://doc.qt.io/qt-5/qt.html#Key-enum and Qt::MetaModifier https://doc.qt.io/qt-5/qt.html#KeyboardModifier-enum correspond to the Control keys. Developers on macOS can use the same shortcut descriptions across all platforms, and their applications will automatically work as expected on macOS.'
So in Function Shortcuts
Key Modifier Function Notes
C C Copy selection
V C Paste
X C Cut selection
Modifier 'C' means Command on Mac, but is technically in Qt is CTRL, and 'M' Meta means Control on Mac. [I didn't write it]
In that context, I think the functions match.
Don't worry about it if you don't want to do that mental translation.
Re 'the entire "Mac only navigation shortcuts” should probably be eliminated. AFAIK these are in no way mac standard' they
are listed in https://support.apple.com/en-us/HT201236, is that out of date?
Michael.
Sent: Tue, 25 May 2021 04:03
-Bob
Tucson AZ
Sent from the OpenSCAD mailing http://forum.openscad.org/ list archive at Nabble.com.
I have a bunch of templates set up now. They work fine. (For clarification, I’m talking MAC here.)
I can’t set up a keyboard shortcut for Insert Template because that command does not exist in the menu tree. Apparently context menu items cannot be keyboard shortcutted. I verified this by tying the key to another command in the Edit menu and it works perfectly. Please just put Insert Template somewhere in the menu tree.
It would be WAY easier to maintain if you allowed an array of templates in a single file instead of requiring a single file for each template.
User templates do not replace the built in templates. Just the opposite. If I create a transfer template, it does not appear at all and the built in template is the only one available. I believe it would be better to reverse that.
I notice that option-left and option-right now work. Maybe I was mistaken before. However, shift-option-left and shift-option-right are supposed to extend the selection one word to the left or right. That is NOT working.
There was no OpenSCAD folder in …/Library/Application Support/. I had to create OpenSCAD/ and OpenSCAD/templates/.
-Bob
Tucson AZ
Config Path
Content:
"key" : "points",
Dear friends
I found many libraries for modelling srews and bolts. As my requirements
are really very low and as I am not a screw specialist who is willing to
re-invent the circle Iḿ looking for a small library only for modelling
M2-M6 threads/bolts...
any recommendations?
BR
Karl
Not really a small library but you can use a small part of it:
https://github.com/nophead/NopSCADlib#screws
On Tue, 8 Jun 2021 at 09:26, Karl Exler karl.exler@meinklang.cc wrote:
Dear friends
BR
Karl
