Is there a "best practices" to speed up some operations?
I
infocean
Fri, Mar 19, 2021 4:30 AM
I have this little program:
// Some parameters
pmpgap = 0.2;
sposstart1 = 0;
intakel = 2;
intakew = 0.5;
indist = 4;
intakeholer = 0.2;
nintakeholes = 40;
pintake1 = sposstart1+1.5;
pintake2 = sposstart1+11.8;
// Module of the intake
module intake(){
/rotate([0,90,0])/
rotate_extrude(convexity=10)
translate([indist,0,0])
rotate(45)
square([intakel,intakew],true);
for(i=[1:nintakeholes])
rotate([0,0,i*360/nintakeholes])
translate([indist-0.5,0,-0.5])
    rotate([0,135,0])
    linear_extrude(height=intakew+0.5,center = true, convexity = 10,
twist = 50)
circle(r=intakeholer);
// Draw the intakes
color("SlateBlue",0.4) render()
translate([pintake1,0,0])
intake();
When nintakeholes =3,5,20,40. the execution time is: 0:00:28.891,
0:01:57.659, 0:12:25.321, 0:34:03.133.  Looks to me time goes up faster than
linear.  So, the question is how can the rendering time be reduced.  I am a
newbie, so I am just putting constructs one after another and do not know
what coding technics here would give the fastest, or minimum faster
execution.
I am trying to code an intake cover, "covered" by holes all over.  I coded
here just one circle of holes, but I need to add 4-5 more, so air can go in
freely.  That might take a whole day to render.
My machine has 12 cores.  Only one is working.  I also have 3 graphics card
for computation.  None of them is working.  If OpenSCAD could have been
parallelized on the cores for geometry and the math and vector computation
outscored to the GPUs, the speed increase could be minimum 10 fold.
If it is a big work to rewrite, then maybe another language can be put into
slave service - like Julia which has built in parallelism and can handle the
GPUs easily -, and pass to that language all parallelizable  computation.
Julia although it is an interpreted language has a speed very close to C++
if the coding done right.
Maybe the Google summer code camp can be a good occasion to go over the
OpenSCAD code and see what portions can be passed to the multicore CPU for
parallelization and what portions can passed to the GPUs for heavy lifting.
Additional quick questions:
  1. When I highlight something in the Console window and select copy and
    then I try to paste it into another program's document - like right here -,
    Console gives me nothing.  What is the trick to be able to copy and paste
    just as I can do in any other programs?  I am on a Mac with OS X 10.15.7.
  2. I changed the cache sizes to 200MB from the default 100MB, but I see that
    even when I render the nintakeholes =20 case Console says: CGAL cache size
    in bytes: 199228304, so very close to 200MB.  What is the recommended CGal
    and PolySet cache sizes to get the fastest rendering speed possible?  I have
    48GB in this machine and 23GB or so was not even touched.
  3. It would be nice if after a coding error and OpenSCAd hang, the program
    would not want to F5 the crashed code.  Actually it would be nice if at
    start when I open an scad file the rendering would not happen, so I can edit
    it before any rendering, let say to correct a bug in the code and render
    only if I hit <cmd>+<s>.  I am not seeing anything in Preferences to help me
    out in this regard.
Thanks ahead,
infocean
Hi, I have this little program: // Some parameters pmpgap = 0.2; sposstart1 = 0; intakel = 2; intakew = 0.5; indist = 4; intakeholer = 0.2; nintakeholes = 40; pintake1 = sposstart1+1.5; pintake2 = sposstart1+11.8; // Module of the intake module intake(){ /*rotate([0,90,0])*/ difference(){ rotate_extrude(convexity=10) translate([indist,0,0]) rotate(45) square([intakel,intakew],true); for(i=[1:nintakeholes]) rotate([0,0,i*360/nintakeholes]) translate([indist-0.5,0,-0.5]) rotate([0,135,0]) linear_extrude(height=intakew+0.5,center = true, convexity = 10, twist = 50) circle(r=intakeholer); } } // Draw the intakes color("SlateBlue",0.4) render() translate([pintake1,0,0]) intake(); When nintakeholes =3,5,20,40. the execution time is: 0:00:28.891, 0:01:57.659, 0:12:25.321, 0:34:03.133. Looks to me time goes up faster than linear. So, the question is how can the rendering time be reduced. I am a newbie, so I am just putting constructs one after another and do not know what coding technics here would give the fastest, or minimum faster execution. I am trying to code an intake cover, "covered" by holes all over. I coded here just one circle of holes, but I need to add 4-5 more, so air can go in freely. That might take a whole day to render. My machine has 12 cores. Only one is working. I also have 3 graphics card for computation. None of them is working. If OpenSCAD could have been parallelized on the cores for geometry and the math and vector computation outscored to the GPUs, the speed increase could be minimum 10 fold. If it is a big work to rewrite, then maybe another language can be put into slave service - like Julia which has built in parallelism and can handle the GPUs easily -, and pass to that language all parallelizable computation. Julia although it is an interpreted language has a speed very close to C++ if the coding done right. Maybe the Google summer code camp can be a good occasion to go over the OpenSCAD code and see what portions can be passed to the multicore CPU for parallelization and what portions can passed to the GPUs for heavy lifting. Additional quick questions: 1. When I highlight something in the Console window and select copy and then I try to paste it into another program's document - like right here -, Console gives me nothing. What is the trick to be able to copy and paste just as I can do in any other programs? I am on a Mac with OS X 10.15.7. 2. I changed the cache sizes to 200MB from the default 100MB, but I see that even when I render the nintakeholes =20 case Console says: CGAL cache size in bytes: 199228304, so very close to 200MB. What is the recommended CGal and PolySet cache sizes to get the fastest rendering speed possible? I have 48GB in this machine and 23GB or so was not even touched. 3. It would be nice if after a coding error and OpenSCAd hang, the program would not want to F5 the crashed code. Actually it would be nice if at start when I open an scad file the rendering would not happen, so I can edit it before any rendering, let say to correct a bug in the code and render only if I hit <cmd>+<s>. I am not seeing anything in Preferences to help me out in this regard. Thanks ahead, infocean -- Sent from: http://forum.openscad.org/
HJ
Hugo Jackson
Fri, Mar 19, 2021 4:46 AM
In response to your additional quick question 1:
The openSCAD window is not context aware for keyboard shortcuts in the console window. You can still copy, you have to select the text you want to copy and but then right(alternate)-click at which point a window will appear and you can select “copy”. Cmd-C doesn’t work.
On Mar 18, 2021, at 9:30 PM, infocean via Discuss discuss@lists.openscad.org wrote:
// Some parameters
pmpgap = 0.2;
sposstart1 = 0;
intakel = 2;
intakew = 0.5;
indist = 4;
intakeholer = 0.2;
nintakeholes = 40;
module intake(){
/rotate([0,90,0])/
rotate(45)
     rotate([0,135,0])
// Draw the intakes
intake();
Thanks ahead,
infocean
Sent from the OpenSCAD mailing list archive http://forum.openscad.org/ at Nabble.com.
In response to your additional quick question 1: The openSCAD window is not context aware for keyboard shortcuts in the console window. You can still copy, you have to select the text you want to copy and but then right(alternate)-click at which point a window will appear and you can select “copy”. Cmd-C doesn’t work. > On Mar 18, 2021, at 9:30 PM, infocean via Discuss <discuss@lists.openscad.org> wrote: > > Hi, > > I have this little program: > > // Some parameters > pmpgap = 0.2; > sposstart1 = 0; > intakel = 2; > intakew = 0.5; > indist = 4; > intakeholer = 0.2; > nintakeholes = 40; > pintake1 = sposstart1+1.5; > pintake2 = sposstart1+11.8; > > // Module of the intake > module intake(){ > /*rotate([0,90,0])*/ > difference(){ > rotate_extrude(convexity=10) > translate([indist,0,0]) > rotate(45) > square([intakel,intakew],true); > > for(i=[1:nintakeholes]) > rotate([0,0,i*360/nintakeholes]) > translate([indist-0.5,0,-0.5]) > rotate([0,135,0]) > linear_extrude(height=intakew+0.5,center = true, convexity = 10, twist = 50) > circle(r=intakeholer); > } > } > > // Draw the intakes > color("SlateBlue",0.4) render() > translate([pintake1,0,0]) > intake(); > > > When nintakeholes =3,5,20,40. the execution time is: 0:00:28.891, 0:01:57.659, 0:12:25.321, 0:34:03.133. Looks to me time goes up faster than linear. So, the question is how can the rendering time be reduced. I am a newbie, so I am just putting constructs one after another and do not know what coding technics here would give the fastest, or minimum faster execution. > I am trying to code an intake cover, "covered" by holes all over. I coded here just one circle of holes, but I need to add 4-5 more, so air can go in freely. That might take a whole day to render. > > My machine has 12 cores. Only one is working. I also have 3 graphics card for computation. None of them is working. If OpenSCAD could have been parallelized on the cores for geometry and the math and vector computation outscored to the GPUs, the speed increase could be minimum 10 fold. > > If it is a big work to rewrite, then maybe another language can be put into slave service - like Julia which has built in parallelism and can handle the GPUs easily -, and pass to that language all parallelizable computation. Julia although it is an interpreted language has a speed very close to C++ if the coding done right. > Maybe the Google summer code camp can be a good occasion to go over the OpenSCAD code and see what portions can be passed to the multicore CPU for parallelization and what portions can passed to the GPUs for heavy lifting. > > Additional quick questions: > 1. When I highlight something in the Console window and select copy and then I try to paste it into another program's document - like right here -, Console gives me nothing. What is the trick to be able to copy and paste just as I can do in any other programs? I am on a Mac with OS X 10.15.7. > 2. I changed the cache sizes to 200MB from the default 100MB, but I see that even when I render the nintakeholes =20 case Console says: CGAL cache size in bytes: 199228304, so very close to 200MB. What is the recommended CGal and PolySet cache sizes to get the fastest rendering speed possible? I have 48GB in this machine and 23GB or so was not even touched. > 3. It would be nice if after a coding error and OpenSCAd hang, the program would not want to F5 the crashed code. Actually it would be nice if at start when I open an scad file the rendering would not happen, so I can edit it before any rendering, let say to correct a bug in the code and render only if I hit <cmd>+<s>. I am not seeing anything in Preferences to help me out in this regard. > > Thanks ahead, > infocean > > > > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> at Nabble.com. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Fri, Mar 19, 2021 6:50 AM
40 holes F6 render took me
Total rendering time: 0:00:04.877
Removing 'render()' (which is equivalent to F6 render) F5 preview took
Compile and preview finished.
Total rendering time: 0:00:00.068
render() is an acquired taste, needed for some preview anomalies, best left alone until you gain
experience.
Some people like using it on small chunks so they cache.
Are you using $fn, $fa or $fs?
We are working on climate-change :-) don't want to use too much power...
History https://github.com/openscad/openscad/issues/391 .
OpenSCAD uses some complex libraries. OpenGL & CGAL being the main ones. Lookup CGAL.
On my 8GB (+SSD Swap) VM I have, 8000MB each, make yours bigger, 23000? It only gets used on
complex models.
  1. It would be nice if after a coding error and OpenSCAd hang, the program would not want to F5
the crashed code.
What error & what hang?
Uncheck Design/Automatic-preview&render. And don't use render().
From: infocean via Discuss [mailto:discuss@lists.openscad.org]
Sent: Fri, 19 Mar 2021 15:30
Cc: infocean
Subject: [OpenSCAD] Is there a "best practices" to speed up some operations?
// Some parameters
pmpgap = 0.2;
sposstart1 = 0;
intakel = 2;
intakew = 0.5;
indist = 4;
intakeholer = 0.2;
nintakeholes = 40;
module intake(){
/rotate([0,90,0])/
rotate(45)
    rotate([0,135,0])
// Draw the intakes
intake();
    10.15.7.
    regard.
Thanks ahead,
infocean
Sent from the OpenSCAD mailing http://forum.openscad.org/  list archive at Nabble.com.
> So, the question is how can the rendering time be reduced. 40 holes F6 render took me Total rendering time: 0:00:04.877 Removing 'render()' (which is equivalent to F6 render) F5 preview took Compile and preview finished. Total rendering time: 0:00:00.068 render() is an acquired taste, needed for some preview anomalies, best left alone until you gain experience. Some people like using it on small chunks so they cache. Are you using $fn, $fa or $fs? > My machine has 12 cores. Only one is working We are working on climate-change :-) don't want to use too much power... History <https://github.com/openscad/openscad/issues/391> . > If it is a big work to rewrite, then maybe another language OpenSCAD uses some complex libraries. OpenGL & CGAL being the main ones. Lookup CGAL. > I changed the cache sizes to 200MB from the default 100MB On my 8GB (+SSD Swap) VM I have, 8000MB each, make yours bigger, 23000? It only gets used on complex models. > 3. It would be nice if after a coding error and OpenSCAd hang, the program would not want to F5 the crashed code. What error & what hang? > Actually it would be nice if at start when I open an scad file the rendering would not happen, so I can edit it before any rendering Uncheck Design/Automatic-preview&render. And don't use render(). _____ From: infocean via Discuss [mailto:discuss@lists.openscad.org] Sent: Fri, 19 Mar 2021 15:30 To: discuss@lists.openscad.org Cc: infocean Subject: [OpenSCAD] Is there a "best practices" to speed up some operations? Hi, I have this little program: // Some parameters pmpgap = 0.2; sposstart1 = 0; intakel = 2; intakew = 0.5; indist = 4; intakeholer = 0.2; nintakeholes = 40; pintake1 = sposstart1+1.5; pintake2 = sposstart1+11.8; // Module of the intake module intake(){ /*rotate([0,90,0])*/ difference(){ rotate_extrude(convexity=10) translate([indist,0,0]) rotate(45) square([intakel,intakew],true); for(i=[1:nintakeholes]) rotate([0,0,i*360/nintakeholes]) translate([indist-0.5,0,-0.5]) rotate([0,135,0]) linear_extrude(height=intakew+0.5,center = true, convexity = 10, twist = 50) circle(r=intakeholer); } } // Draw the intakes color("SlateBlue",0.4) render() translate([pintake1,0,0]) intake(); When nintakeholes =3,5,20,40. the execution time is: 0:00:28.891, 0:01:57.659, 0:12:25.321, 0:34:03.133. Looks to me time goes up faster than linear. So, the question is how can the rendering time be reduced. I am a newbie, so I am just putting constructs one after another and do not know what coding technics here would give the fastest, or minimum faster execution. I am trying to code an intake cover, "covered" by holes all over. I coded here just one circle of holes, but I need to add 4-5 more, so air can go in freely. That might take a whole day to render. My machine has 12 cores. Only one is working. I also have 3 graphics card for computation. None of them is working. If OpenSCAD could have been parallelized on the cores for geometry and the math and vector computation outscored to the GPUs, the speed increase could be minimum 10 fold. If it is a big work to rewrite, then maybe another language can be put into slave service - like Julia which has built in parallelism and can handle the GPUs easily -, and pass to that language all parallelizable computation. Julia although it is an interpreted language has a speed very close to C++ if the coding done right. Maybe the Google summer code camp can be a good occasion to go over the OpenSCAD code and see what portions can be passed to the multicore CPU for parallelization and what portions can passed to the GPUs for heavy lifting. Additional quick questions: 1. When I highlight something in the Console window and select copy and then I try to paste it into another program's document - like right here -, Console gives me nothing. What is the trick to be able to copy and paste just as I can do in any other programs? I am on a Mac with OS X 10.15.7. 2. I changed the cache sizes to 200MB from the default 100MB, but I see that even when I render the nintakeholes =20 case Console says: CGAL cache size in bytes: 199228304, so very close to 200MB. What is the recommended CGal and PolySet cache sizes to get the fastest rendering speed possible? I have 48GB in this machine and 23GB or so was not even touched. 3. It would be nice if after a coding error and OpenSCAd hang, the program would not want to F5 the crashed code. Actually it would be nice if at start when I open an scad file the rendering would not happen, so I can edit it before any rendering, let say to correct a bug in the code and render only if I hit <cmd>+<s>. I am not seeing anything in Preferences to help me out in this regard. Thanks ahead, infocean _____ Sent from the OpenSCAD mailing <http://forum.openscad.org/> list archive at Nabble.com. -- This email has been checked for viruses by AVG. https://www.avg.com
Fri, Mar 19, 2021 7:23 AM
That would be Automatic-reload&preview...
MichaelAtOz wrote > Uncheck Design/Automatic-preview&render. And don't use render(). That would be Automatic-reload&preview... ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
Rob Ward
Fri, Mar 19, 2021 9:54 AM
Welcome to the 1980s.
Cheers, RobW
On 19 March 2021 3:30:01 pm AEDT, infocean via Discuss discuss@lists.openscad.org wrote:
// Some parameters
pmpgap = 0.2;
sposstart1 = 0;
intakel = 2;
intakew = 0.5;
indist = 4;
intakeholer = 0.2;
nintakeholes = 40;
module intake(){
/rotate([0,90,0])/
rotate(45)
    rotate([0,135,0])
twist = 50)
// Draw the intakes
intake();
than
am a
know
execution.
coded
go in
card
computation
into
handle the
computation.
C++
for
lifting.
    and
    here -,
    paste
    10.15.7.
    that
    size
    CGal
    have
    program
    edit
    render
    help me
    out in this regard.
Thanks ahead,
infocean
Welcome to the 1980s. Cheers, RobW On 19 March 2021 3:30:01 pm AEDT, infocean via Discuss <discuss@lists.openscad.org> wrote: >Hi, > >I have this little program: > >// Some parameters >pmpgap = 0.2; >sposstart1 = 0; >intakel = 2; >intakew = 0.5; >indist = 4; >intakeholer = 0.2; >nintakeholes = 40; >pintake1 = sposstart1+1.5; >pintake2 = sposstart1+11.8; > >// Module of the intake >module intake(){ > /*rotate([0,90,0])*/ > difference(){ > rotate_extrude(convexity=10) > translate([indist,0,0]) > rotate(45) > square([intakel,intakew],true); > > for(i=[1:nintakeholes]) > rotate([0,0,i*360/nintakeholes]) > translate([indist-0.5,0,-0.5]) > rotate([0,135,0]) > linear_extrude(height=intakew+0.5,center = true, convexity = 10, >twist = 50) > circle(r=intakeholer); > } >} > >// Draw the intakes > color("SlateBlue",0.4) render() > translate([pintake1,0,0]) > intake(); > > >When nintakeholes =3,5,20,40. the execution time is: 0:00:28.891, >0:01:57.659, 0:12:25.321, 0:34:03.133. Looks to me time goes up faster >than >linear. So, the question is how can the rendering time be reduced. I >am a >newbie, so I am just putting constructs one after another and do not >know >what coding technics here would give the fastest, or minimum faster >execution. >I am trying to code an intake cover, "covered" by holes all over. I >coded >here just one circle of holes, but I need to add 4-5 more, so air can >go in >freely. That might take a whole day to render. > >My machine has 12 cores. Only one is working. I also have 3 graphics >card >for computation. None of them is working. If OpenSCAD could have been >parallelized on the cores for geometry and the math and vector >computation >outscored to the GPUs, the speed increase could be minimum 10 fold. > >If it is a big work to rewrite, then maybe another language can be put >into >slave service - like Julia which has built in parallelism and can >handle the >GPUs easily -, and pass to that language all parallelizable >computation. >Julia although it is an interpreted language has a speed very close to >C++ >if the coding done right. >Maybe the Google summer code camp can be a good occasion to go over the >OpenSCAD code and see what portions can be passed to the multicore CPU >for >parallelization and what portions can passed to the GPUs for heavy >lifting. > >Additional quick questions: >1. When I highlight something in the Console window and select copy >and >then I try to paste it into another program's document - like right >here -, >Console gives me nothing. What is the trick to be able to copy and >paste >just as I can do in any other programs? I am on a Mac with OS X >10.15.7. >2. I changed the cache sizes to 200MB from the default 100MB, but I see >that >even when I render the nintakeholes =20 case Console says: CGAL cache >size >in bytes: 199228304, so very close to 200MB. What is the recommended >CGal >and PolySet cache sizes to get the fastest rendering speed possible? I >have >48GB in this machine and 23GB or so was not even touched. >3. It would be nice if after a coding error and OpenSCAd hang, the >program >would not want to F5 the crashed code. Actually it would be nice if at >start when I open an scad file the rendering would not happen, so I can >edit >it before any rendering, let say to correct a bug in the code and >render >only if I hit <cmd>+<s>. I am not seeing anything in Preferences to >help me >out in this regard. > >Thanks ahead, >infocean > > > > > > >-- >Sent from: http://forum.openscad.org/
CA
Fri, Mar 19, 2021 12:02 PM
10 fold.
In many cases you can run OpenSCAD scripts in AngelCAD and enjoy use of
multiple cores that way https://arnholm.github.io/angelcad-docs/
Yes you can get a 10 fold increase in speed.
However, for this particular example it does not work properly, since
you don't get an equivalent result. I have not researched why that is
so. But many other examples work fine.
On 19.03.2021 05:30, infocean via Discuss wrote: > My machine has 12 cores.  Only one is working.  I also have 3 graphics > card for computation.  None of them is working.  If OpenSCAD could have > been parallelized on the cores for geometry and the math and vector > computation outscored to the GPUs, the speed increase could be minimum > 10 fold. In many cases you can run OpenSCAD scripts in AngelCAD and enjoy use of multiple cores that way https://arnholm.github.io/angelcad-docs/ Yes you can get a 10 fold increase in speed. However, for this particular example it does not work properly, since you don't get an equivalent result. I have not researched why that is so. But many other examples work fine. Carsten Arnholm
Fri, Mar 19, 2021 4:14 PM
This has nothing to do with the language. The slow part
is the geometry engine which also had no easy way to run
threaded.
Using a different language would achieve exactly nothing.
The approach to increase speed is moving to a different
geometry calculation, which is done in
https://github.com/openscad/openscad/pull/3641
and may also open up the possibility to easier go multi
threaded, where earlier attempts struggle due to the
underlying library.
Google Summer of Code is now just about 180h of coding,
so there's essentially no way to have any of that as
topic, unless someone with lots of experience in that
area comes around and proposes this as project with a
very clear plan (which would be awesome!).
On 19.03.21 05:30, infocean via Discuss wrote: > If it is a big work to rewrite, then maybe another language This has nothing to do with the language. The slow part is the geometry engine which also had no easy way to run threaded. Using a different language would achieve exactly nothing. The approach to increase speed is moving to a different geometry calculation, which is done in https://github.com/openscad/openscad/pull/3641 and may also open up the possibility to easier go multi threaded, where earlier attempts struggle due to the underlying library. Google Summer of Code is now just about 180h of coding, so there's essentially no way to have any of that as topic, unless someone with lots of experience in that area comes around and proposes this as project with a very clear plan (which would be awesome!). ciao, Torsten.
Fri, Mar 19, 2021 5:57 PM
There must be something else going on here.
My PC is something like eight years old, and was not quite
bottom-of-the-line when I bought it.
With nintakeholes=40, a render takes about ten seconds.
With nintakeholes=3, a render takes under a second.
On 3/18/2021 9:30 PM, infocean via Discuss wrote: > When nintakeholes =3,5,20,40. the execution time is: 0:00:28.891, > 0:01:57.659, 0:12:25.321, 0:34:03.133. There must be something else going on here. My PC is something like eight years old, and was not quite bottom-of-the-line when I bought it. With nintakeholes=40, a render takes about ten seconds. With nintakeholes=3, a render takes under a second.
(null) (null)
Sat, Mar 20, 2021 12:11 AM
HI, All,
By taking out render() made the difference.
With render() :Total rendering time: 9:23:59.954
Without render() : Total rendering time: 0:00:00.449
Amazing! /Even as I added four more circles of holes/  My motivation to use render() was from some posts on the forum suggesting to be able to see the colors after F5.  But now looks like it is not needed for this purpose.  It would be great if F6 would also retain the color info.  More and more 3D printers are using multiple colors and I think I saw one which is using even millions of colors.
Yes, now I am able to “cut & paste”. Thanks for the info.
I looked over the History link.  Hmm… The team needs someone with parallelization experience to minimum distribute the computations among the available processors and cores.  Unfortunately I have no C++ experience, so I cannot volunteer.
Regarding the hanging and the “crash” I found out that they were not real crashes.  OpenSCAD just stopped communicating to the OS, so Activity Monitor reported it as “not responding”, but ultimately after some time the program finished the job.  Maybe in a future version OpenSCAD can communicate to the OS more frequently, so the watchdog like programs as Activity Monitor would not be confused regarding the true status of the program.
Yes I use some $ variables.  Here they are:
echo(version=version());
$fa=0.4;
$fs=0.4;
$fn=60;
Are they optimal for middle-complex jobs?
Thank you all,
Infocean
On Mar 19, 2021, at 1:57 PM, Jordan Brown openscad@jordan.maileater.net wrote:
HI, All, By taking out render() made the difference. With render() :Total rendering time: 9:23:59.954 Without render() : Total rendering time: 0:00:00.449 Amazing! /Even as I added four more circles of holes/ My motivation to use render() was from some posts on the forum suggesting to be able to see the colors after F5. But now looks like it is not needed for this purpose. It would be great if F6 would also retain the color info. More and more 3D printers are using multiple colors and I think I saw one which is using even millions of colors. Yes, now I am able to “cut & paste”. Thanks for the info. I looked over the History link. Hmm… The team needs someone with parallelization experience to minimum distribute the computations among the available processors and cores. Unfortunately I have no C++ experience, so I cannot volunteer. Regarding the hanging and the “crash” I found out that they were not real crashes. OpenSCAD just stopped communicating to the OS, so Activity Monitor reported it as “not responding”, but ultimately after some time the program finished the job. Maybe in a future version OpenSCAD can communicate to the OS more frequently, so the watchdog like programs as Activity Monitor would not be confused regarding the true status of the program. Yes I use some $ variables. Here they are: echo(version=version()); $fa=0.4; $fs=0.4; $fn=60; Are they optimal for middle-complex jobs? Thank you all, Infocean > On Mar 19, 2021, at 1:57 PM, Jordan Brown <openscad@jordan.maileater.net> wrote: > > On 3/18/2021 9:30 PM, infocean via Discuss wrote: >> When nintakeholes =3,5,20,40. the execution time is: 0:00:28.891, 0:01:57.659, 0:12:25.321, 0:34:03.133. > > There must be something else going on here. > > My PC is something like eight years old, and was not quite bottom-of-the-line when I bought it. > > With nintakeholes=40, a render takes about ten seconds. > With nintakeholes=3, a render takes under a second. > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Sat, Mar 20, 2021 1:19 AM
Are your values in inches or millimeters?  OpenSCAD doesn't care, but
most slicers default to millimeters.  Your part looks really small in
millimeters, and the holes are tiny.
The difference between your performance and the performance other people
are seeing on your model is the settings of $fa/$fs/$fn. Your settings
of 0.4/0.4/60 took a sub-second render with the default values to a
minute and a half for me, with three holes.  Just that $fn setting
accounts for most of it.  Assuming you're using inches, your "intake
holes" have a diameter of 0.4in; you're forcing them to each have 60
sides so each side is about 0.02in, below the resolution of a
conventional 3D printer.  If you're in mm, they'd be even tinier.
Mostly, don't mess with render() unless you're having problems with
preview artifacts.  But not messing with render() doesn't save you;
you'll need to do a full F6 render if you want to export to STL.
On Windows, F6 render runs in a different thread from the UI, so the UI
remains live.  Unfortunately, F5 preview, even if it's doing a render(),
runs in the same thread as the UI and so the UI freezes while it runs.
$fa=0.4;
$fs=0.4;
$fn=60;
Note that these weren't in the sample you posted.  They can make a huge
difference in performance.
Mostly, I suggest that you don't mess with $fn unless you need to force
a particular number of sides because you want a hexagon or whatever.
$fa=0.4 is really small.  Looking only at the effect of $fa, if you set
it to 2 it is hard to see the polgon-ness of the result unless you look
really closely.  Larger numbers are more visible but still probably fine
for 3D printing.
$fs=0.4 is really small.  It's saying that you want the polygon sides to
be 0.4 units or less - typically, 0.4mm or less.  Unless your circles
are down in the couple-of-millimeter range, that's more precise than you
need.
These two parameters work together to keep your circles from having a
uselessly large number of sides.  One way to look at it is that $fa
controls the behavior of large circles and $fs controls the behavior of
small circles.
You can probably pick values for $fa and $fs that will make both small
circles and big circles look good, without making either have an
unreasonable number of sides.  Try $fa=5 and $fs=1 and see how it works
for you.  Actually print some models; the sides are more visible on the
screen than they are in plastic.
Are your values in inches or millimeters?  OpenSCAD doesn't care, but most slicers default to millimeters.  Your part looks really small in millimeters, and the holes are tiny. On 3/19/2021 5:11 PM, (null) (null) via Discuss wrote: > By taking out render() made the difference. > > With render() :Total rendering time: 9:23:59.954 > > Without render() : Total rendering time: 0:00:00.449 The difference between your performance and the performance other people are seeing on your model is the settings of $fa/$fs/$fn. Your settings of 0.4/0.4/60 took a sub-second render with the default values to a minute and a half for me, with three holes.  Just that $fn setting accounts for most of it.  Assuming you're using inches, your "intake holes" have a diameter of 0.4in; you're forcing them to each have 60 sides so each side is about 0.02in, below the resolution of a conventional 3D printer.  If you're in mm, they'd be even tinier. Mostly, don't mess with render() unless you're having problems with preview artifacts.  But not messing with render() doesn't save you; you'll need to do a full F6 render if you want to export to STL. > It would be great if F6 would also retain the color info. Yes.  https://github.com/openscad/openscad/issues/1608 > Regarding the hanging and the “crash” I found out that they were not real crashes. OpenSCAD just stopped communicating to the OS, so Activity Monitor reported it as “not responding”, but ultimately after some time the program finished the job. Maybe in a future version OpenSCAD can communicate to the OS more frequently, so the watchdog like programs as Activity Monitor would not be confused regarding the true status of the program. On Windows, F6 render runs in a different thread from the UI, so the UI remains live.  Unfortunately, F5 preview, even if it's doing a render(), runs in the same thread as the UI and so the UI freezes while it runs. > Yes I use some $ variables. Here they are: > echo(version=version()); > $fa=0.4; > $fs=0.4; > $fn=60; > > Are they optimal for middle-complex jobs? Note that these weren't in the sample you posted.  They can make a huge difference in performance. Mostly, I suggest that you don't mess with $fn unless you need to force a particular number of sides because you want a hexagon or whatever. $fa=0.4 is really small.  Looking only at the effect of $fa, if you set it to 2 it is hard to see the polgon-ness of the result unless you look really closely.  Larger numbers are more visible but still probably fine for 3D printing. $fs=0.4 is really small.  It's saying that you want the polygon sides to be 0.4 units or less - typically, 0.4mm or less.  Unless your circles are down in the couple-of-millimeter range, that's more precise than you need. These two parameters work together to keep your circles from having a uselessly large number of sides.  One way to look at it is that $fa controls the behavior of large circles and $fs controls the behavior of small circles. You can probably pick values for $fa and $fs that will make both small circles and big circles look good, without making either have an unreasonable number of sides.  Try $fa=5 and $fs=1 and see how it works for you.  Actually print some models; the sides are more visible on the screen than they are in plastic.
