On Feb 3, 2015, at 12:14 PM, pff pfuhlman@skypoint.com wrote:
Marius, Forgive my laziness, it's been a while since I used OpenSCAD, but does OpenSCAD support a linear sweep / extrude of a solid body (resulting in a new solid that can be subtracted) versus a linear sweep / extrude a 2D profile? Phil(f) in WI
You can only really do linear sweeps of solids if they’re convex, by doing:
hull() {
translate(posA) object();
translate(posB) object();
I tried this example.
I get
Parser error in line 64: syntax error
ERROR: Compilation failed!
line 64 is
pos = position(a);
Please advise
thanks
Stuart
On Tue, Feb 3, 2015 at 11:03 AM, Marius Kintel marius@kintel.net wrote:
On Feb 3, 2015, at 10:27 AM, stustev stustev@gmail.com wrote:
I agree this should be an option.
I like the idea of line by line. That allows finding exactly which line
of code makes which cut. Sometimes, it is clear by just looking but other
times it is not clear which line of code did exactly what. If there is a
way to highlight the cut surfaces/sections and see which line of code cut
it then preprocessing the entire CAM program would be just fine.
There are ways of structuring this in OpenSCAD. You could e.g. describe
all tool locations in a list and let OpenSCAD iterate over that list.
You could even have an animation playing through the list to see the
actual tool movement.
Some of these things are possible in real-time, while others require a lot
of processing.
The best would be to start somewhere and get some experience in terms of
what limitations in OpenSCAD you’ll have to live with.
Perhaps this example could help understand highlighting/animation:
http://files.openscad.org/examples/Advanced/animation.html
Addressee is the intended audience.
If you are not the addressee then my consent is not given for you to read
this email furthermore it is my wish you would close this without saving or
reading, and cease and desist from saving or opening my private
correspondence.
Thank you for honoring my wish.
Your code does not seem to be included. Please post again.
Sincerely,
TakeItAndRun
2015-02-04 16:08 GMT+01:00 Stuart Stevenson stustev@gmail.com:
I get
line 64 is
pos = position(a);
Please advise
thanks
Stuart
lot of processing.
correspondence.
schreiben.
Enjoy!
this is the link Marius provided as an example of animation
It would not run on my computer
I get
line 64 is
pos = position(a);
Please advise
thanks
Stuart
On Wed, Feb 4, 2015 at 12:39 PM, Peter Falke <
Sincerely,
TakeItAndRun
I get
line 64 is
pos = position(a);
Please advise
thanks
Stuart
line of code makes which cut. Sometimes, it is clear by just looking but
other times it is not clear which line of code did exactly what. If there
is a way to highlight the cut surfaces/sections and see which line of code
cut it then preprocessing the entire CAM program would be just fine.
lot of processing.
correspondence.
schreiben.
Enjoy!
correspondence.
You need a development snapshot of OpenSCAD to see that example.
I'm using version = [2014, 6, 29].
The following changes made it work for me:
// posx = position(a);
color("black")
translate([position(a)[0], position(a)[1], -3*r])
cube([0.8, 0.8, 0.2], center = true);
With a newer build the assignment in blocks does work, I believe.
In the code, maybe someone could add a line about what version of OpenSCAD
is required to run it?
Sincerely,
TakeItAndRun
2015-02-04 20:08 GMT+01:00 Marius Kintel marius@kintel.net:
schreiben.
Enjoy!
%for (a = [ 0 : 0.004 : 1]) assign(pos = position(a)){
Is a better fix for older versions to avoid calling position twice.
On 4 February 2015 at 19:43, Peter Falke <
color("black")
Sincerely,
TakeItAndRun
schreiben.
Enjoy!
got it working - thanks
On Wed, Feb 4, 2015 at 1:43 PM, Peter Falke [via OpenSCAD] <
color("black")
Sincerely,
TakeItAndRun
2015-02-04 20:08 GMT+01:00 Marius Kintel <[hidden email]
http:///user/SendEmail.jtp?type=node&node=11452&i=0>:
On Feb 4, 2015, at 13:54 PM, Stuart Stevenson <[hidden email]
[hidden email] http:///user/SendEmail.jtp?type=node&node=11452&i=2
[hidden email] http:///user/SendEmail.jtp?type=node&node=11452&i=3
schreiben.
Enjoy!
[hidden email] http:///user/SendEmail.jtp?type=node&node=11452&i=4
below:
http://forum.openscad.org/nc-code-verification-tp11373p11452.html
To unsubscribe from nc code verification, click here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=11373&code=c3R1c3RldkBnbWFpbC5jb218MTEzNzN8LTEyODc0MzU0ODM=
NAML
correspondence.
View this message in context: http://forum.openscad.org/nc-code-verification-tp11373p11454.html
Does`nt position(a) get cashed(sp?)?
2015-02-04 20:53 GMT+01:00 stustev stustev@gmail.com:
On Wed, Feb 4, 2015 at 1:43 PM, Peter Falke [via OpenSCAD] <[hidden email]
color("black")
OpenSCAD is required to run it?
Sincerely,
TakeItAndRun
schreiben.
Enjoy!
discussion below:
To unsubscribe from nc code verification, click here.
NAML
correspondence.
View this message in context: Re: nc code verification
at Nabble.com.
schreiben.
Enjoy!
There is a new development for FreeCad to generate gcode:
http://yorik.uncreated.net/guestblog.php?2015=22
2015-02-04 22:36 GMT+01:00 Peter Falke stempeldergeschichte@googlemail.com
color("black")
Sincerely,
TakeItAndRun
schreiben.
Enjoy!
discussion below:
NAML
correspondence.
at Nabble.com.
schreiben.
Enjoy!
schreiben.
Enjoy!
