nc code verification
SS
Stuart Stevenson
Tue, Feb 17, 2015 5:16 PM
I can generate the nc code without a problem. I want to then use openSCAD
to verify the code cuts the part correct.
I will need to set up openSCAD with a set of matrices to simulate the
machine motion and position the tool.
Create/import geometry to simulate material to be cut.
Define geometry to use for the tool.
Use the nc code positions to simulate cutting the part.
There is a new development for FreeCad to generate gcode:
http://yorik.uncreated.net/guestblog.php?2015=22
2015-02-04 22:36 GMT+01:00 Peter Falke <[hidden email]
http:///user/SendEmail.jtp?type=node&node=11659&i=0>:
Does`nt  position(a) get cashed(sp?)?
2015-02-04 20:53 GMT+01:00 stustev <[hidden email]
http:///user/SendEmail.jtp?type=node&node=11659&i=1>:
got it working - thanks
On Wed, Feb 4, 2015 at 1:43 PM, Peter Falke [via OpenSCAD] <[hidden
email] http:///user/SendEmail.jtp?type=node&node=11454&i=0> wrote:
I'm using version = [2014, 6, 29].
The following changes made it work for me:
// posx = position(a);
color("black")
translate([position(a)[0], position(a)[1], -3*r])
cube([0.8, 0.8, 0.2], center = true);
With a newer build the assignment in blocks does work, I believe.
In the code, maybe someone could add a line about what version of
OpenSCAD is required to run it?
Sincerely,
TakeItAndRun
2015-02-04 20:08 GMT+01:00 Marius Kintel <[hidden email]
http:///user/SendEmail.jtp?type=node&node=11452&i=0>:
On Feb 4, 2015, at 13:54 PM, Stuart Stevenson <[hidden email]
http:///user/SendEmail.jtp?type=node&node=11452&i=1> wrote:
http://files.openscad.org/examples/Advanced/animation.html
this is the link Marius provided as an example of animation
It would not run on my computer
You need a development snapshot of OpenSCAD to see that example.
[hidden email] http:///user/SendEmail.jtp?type=node&node=11452&i=2
[hidden email] http:///user/SendEmail.jtp?type=node&node=11452&i=3
schreiben.
Enjoy!
[hidden email] http:///user/SendEmail.jtp?type=node&node=11452&i=4
If you reply to this email, your message will be added to the
discussion below:
http://forum.openscad.org/nc-code-verification-tp11373p11452.html
To unsubscribe from nc code verification, click here.
NAML
Addressee is the intended audience.
If you are not the addressee then my consent is not given for you to read
this email furthermore it is my wish you would close this without saving or
reading, and cease and desist from saving or opening my private
correspondence.
Thank you for honoring my wish.
View this message in context: Re: nc code verification
http://forum.openscad.org/nc-code-verification-tp11373p11454.html
at Nabble.com.
[hidden email] http:///user/SendEmail.jtp?type=node&node=11659&i=2
[hidden email] http:///user/SendEmail.jtp?type=node&node=11659&i=3
schreiben.
Enjoy!
[hidden email] http:///user/SendEmail.jtp?type=node&node=11659&i=4
schreiben.
Enjoy!
[hidden email] http:///user/SendEmail.jtp?type=node&node=11659&i=5
below:
http://forum.openscad.org/nc-code-verification-tp11373p11659.html
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=11373&code=c3R1c3RldkBnbWFpbC5jb218MTEzNzN8LTEyODc0MzU0ODM=
NAML
I can generate the nc code without a problem. I want to then use openSCAD to verify the code cuts the part correct. I will need to set up openSCAD with a set of matrices to simulate the machine motion and position the tool. Create/import geometry to simulate material to be cut. Define geometry to use for the tool. Use the nc code positions to simulate cutting the part. There is a new development for FreeCad to generate gcode: http://yorik.uncreated.net/guestblog.php?2015=22 2015-02-04 22:36 GMT+01:00 Peter Falke <[hidden email] <http:///user/SendEmail.jtp?type=node&node=11659&i=0>>: > Does`nt position(a) get cashed(sp?)? > > 2015-02-04 20:53 GMT+01:00 stustev <[hidden email] > <http:///user/SendEmail.jtp?type=node&node=11659&i=1>>: > >> got it working - thanks >> >> On Wed, Feb 4, 2015 at 1:43 PM, Peter Falke [via OpenSCAD] <[hidden >> email] <http:///user/SendEmail.jtp?type=node&node=11454&i=0>> wrote: >> >>> I'm using version = [2014, 6, 29]. >>> The following changes made it work for me: >>> >>> // posx = position(a); >>> >>> color("black") >>> >>> translate([position(a)[0], position(a)[1], -3*r]) >>> >>> cube([0.8, 0.8, 0.2], center = true); >>> >>> >>> With a newer build the assignment in blocks does work, I believe. >>> >>> >>> In the code, maybe someone could add a line about what version of >>> OpenSCAD is required to run it? >>> >>> >>> Sincerely, >>> >>> >>> TakeItAndRun >>> >>> >>> >>> >>> 2015-02-04 20:08 GMT+01:00 Marius Kintel <[hidden email] >>> <http:///user/SendEmail.jtp?type=node&node=11452&i=0>>: >>> >>>> On Feb 4, 2015, at 13:54 PM, Stuart Stevenson <[hidden email] >>>> <http:///user/SendEmail.jtp?type=node&node=11452&i=1>> wrote: >>>> >>>> > http://files.openscad.org/examples/Advanced/animation.html >>>> > >>>> > this is the link Marius provided as an example of animation >>>> > >>>> > It would not run on my computer >>>> > >>>> You need a development snapshot of OpenSCAD to see that example. >>>> >>>> -Marius >>>> >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=11452&i=2> >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>> >>> >>> >>> -- >>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=11452&i=3> >>> >>> P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: >>> Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu >>> schreiben. >>> Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. >>> >>> P.S. In case my e-mail is shorter than you enjoy: >>> I am currently trying short replies instead of no replies at all. >>> Please let me know, if you like to read more. >>> >>> Enjoy! >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=11452&i=4> >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >>> ------------------------------ >>> If you reply to this email, your message will be added to the >>> discussion below: >>> http://forum.openscad.org/nc-code-verification-tp11373p11452.html >>> To unsubscribe from nc code verification, click here. >>> NAML >>> <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> >>> >> >> >> >> -- >> Addressee is the intended audience. >> If you are not the addressee then my consent is not given for you to read >> this email furthermore it is my wish you would close this without saving or >> reading, and cease and desist from saving or opening my private >> correspondence. >> Thank you for honoring my wish. >> >> >> ------------------------------ >> View this message in context: Re: nc code verification >> <http://forum.openscad.org/nc-code-verification-tp11373p11454.html> >> Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> >> at Nabble.com. >> >> _______________________________________________ >> OpenSCAD mailing list >> [hidden email] <http:///user/SendEmail.jtp?type=node&node=11659&i=2> >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > > -- > [hidden email] <http:///user/SendEmail.jtp?type=node&node=11659&i=3> > > P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: > Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu > schreiben. > Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. > > P.S. In case my e-mail is shorter than you enjoy: > I am currently trying short replies instead of no replies at all. > Please let me know, if you like to read more. > > Enjoy! > -- [hidden email] <http:///user/SendEmail.jtp?type=node&node=11659&i=4> P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu schreiben. Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. P.S. In case my e-mail is shorter than you enjoy: I am currently trying short replies instead of no replies at all. Please let me know, if you like to read more. Enjoy! _______________________________________________ OpenSCAD mailing list [hidden email] <http:///user/SendEmail.jtp?type=node&node=11659&i=5> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org ------------------------------ If you reply to this email, your message will be added to the discussion below: http://forum.openscad.org/nc-code-verification-tp11373p11659.html To unsubscribe from nc code verification, click here <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=11373&code=c3R1c3RldkBnbWFpbC5jb218MTEzNzN8LTEyODc0MzU0ODM=> . NAML <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
