thehans wrote
Here is a quick implementation of the rounded cube concept which I
made as a module, since this version does still require one hull
operation.
https://gist.github.com/thehans/2c96601af4e5c8c2d232e50252dd37b1
let me annote that hull() itself is not the problem. To avoid a time
consuming CGAL round trip, don't use (implicit) unions inside a hull(). If
you implement rounded_cube() more explicitely, rendering is fast (seconds).
$fa = 0.1;
$fs = 0.1;
rounded_cube_([4, 20, 5], r=1, center=[1,1,1]);
module rounded_cube_(size, r=0, center=false)
sz = size[0]==undef?[size, size, size]:size;
ce = center[0]==undef?[center, center, center]:center;
r_ = min(abs(r), abs(size.x/2), abs(size.y/2), abs(size.z/2)); // correct
r
translate([ce.x?-sz.x/2:0,ce.y?-sz.y/2:0, ce.z?-sz.z/2:0])
if(r)
hull()
translate([r_, r_, r_]) sphere(r_);
translate([r_, r_, sz.z-r_]) sphere(r_);
translate([r_, sz.y-r_, r_]) sphere(r_);
translate([r_, sz.y-r_, sz.z-r_]) sphere(r_);
translate([sz.x-r_, r_, r_]) sphere(r_);
translate([sz.x-r_, r_, sz.z-r_]) sphere(r_);
translate([sz.x-r_, sz.y-r_, r_]) sphere(r_);
translate([sz.x-r_, sz.y-r_, sz.z-r_]) sphere(r_);
else
cube(size);
in contrast the following call of hull will take minutes.
hull()
for(x=[r_,size.x-r_], y=[r_,size.y-r_], z=[r_,size.z-r_])
translate([x,y,z]) sphere(r_);
However, rounded_cube_ is currently a typical libary module. I wouldn't add
it to the core language unless cylinder(), linear_extrude() and maybe hull()
also get a r parameter.
Sorry to be clueless, but why is it faster to enumerate the explicit
locations of the spheres vs having them in a loop?
operation.
$fa = 0.1;
$fs = 0.1;
r
if(r)
hull()
else
cube(size);
hull()
Sent from my desktop computer.
I do not receive emails while away from my desk,
nor do I receive texts on my main phone number
(which is a land line).
If you know that I am on the road, please text me.
If you know that I am home, please email me.
as I wrote, it avoids CGAL.
hull(). If you implement rounded_cube() more explicitely, rendering is
fast (seconds).
So you're saying it's better if the objects are simple and direct
children of the hull, rather than being a union (through whatever
mechanism) of those same objects?
$fa = 0.1;
$fs = 0.1;
r
if(r)
hull()
else
cube(size);
hull()
Exactly. Have a look at the CSG structures. Results of a for loop are
represented as group node and processed as (implicit) union. And this needs
to be done by CGAL.
Thank you Parkinbot!
This is an excellent example of how a user new to OpenSCAD could spin
their wheels "needlessly". I know nothing about the internals of
OpenSCAD. I imagine that most C programmers do not wish to have to
understand the details of the parser or the code generator. I hope that
we can eventually have a tool where two seemingly identical structures
take roughly the same time to calculate. I imagine there are good (and
subtle) reasons why this objective is difficult to achieve
to be done by CGAL.
Oh, wow. I guess I had always assumed that hull was a CGAL operation.
You say this belongs in a library, but is there a single library that
has a properly implemented rounded cube? Everyone's implementation is
different and 99.9% of them are slow and/or poduce ugly geometry.
This is why It should be standardized from the source.
I guess what I'm saying is at the very least MCAD should get updated
with an efficient module like you wrote here, because I think its
currently using what is more-or-less the same implementation as that
example006.scad I mentioned.
Also I should just say that my attention was originally drawn to
example006.scad a while ago when I was looking at improving OpenSCAD's
Travis build times, particularly in the execution time of individual
tests. And example006.scad was one of the longest running tests.
Hans
operation.
$fa = 0.1;
$fs = 0.1;
r
if(r)
hull()
else
cube(size);
hull()
to be done by CGAL.
Not knowing how hull( ) works, I wouldn't have expected there to be a
difference.
Good information, thanks.
I wonder if we could alleviate most of the slowdown of implicit union
by having group nodes do a simple bounding box check before passing to
CGAL, if no bounding boxes overlap then just skip it?
On Tue, Jan 30, 2018 at 10:49 AM, Jordan Brown
to be done by CGAL.
difference.
Well I prefer libraries, which I write on my own, because they let me define
my own parameters and defaults and I can refer to the implementation. I
never understood why cube(), cylinder() and linear_extrude() are not
centered by default. And to be honest, I still don't know which prototypes
and defaults they exactly have. OK, this could be fixed by a proper
documentation ...
We have discussed it before several times that OpenSCAD is missing a
(standard) library concept. Have a look at the libraries folder shipped with
OpenSCAD and you will discover pretty old stuff that hasn't been maintained
for years.
See my implementation of a rounded_cylinder() and how it deals with
conflicts between diameters and radii. It is pretty fast, but I have no way
to figure out, whether it is semantically equivalent with cylinder,
therefore I can't call cylinder() with all its parameters in case r_ is 0.
$fa=.2;
$fs=.2;
CyR(r1=1, r2=6, h=7, r_=1.4, center = false);
//CyR(h=12, r_=1, r1=6, d2=1);
module CyR(r = 10, h=10, r_=1, d = undef, r1=undef, r2=undef, d1 = undef, d2
= undef, center=false)
r1 = r1==undef?d1==undef?d==undef?r:d/2:d1/2:r1;
r2 = r2==undef?d2==undef?d==undef?r:d/2:d2/2:r2;
r1_=min(abs(h/4), abs(r1), abs(r_));
r2_=min(abs(h/4), abs(r2), abs(r_));
echo(r1, r2, r1_, r2_);
h=abs(h);
translate([0,0,(center?-h/2:0)])
rotate_extrude()
intersection()
hull()
translate([r1-r1_, r1_]) circle(r1_);
translate([r2-r2_, h-r2_]) circle(r2_);
polygon([[0,0], [r1-r1_, r1_], [r2-r2_, h-r2_], [0,h]] );
square([max(r1,r2), h]);
