Tue, Jan 30, 2018 6:34 PM
I wonder if we could alleviate most of the slowdown of implicit union
by having group nodes do a simple bounding box check before passing to
CGAL, if no bounding boxes overlap then just skip it?
This issue has also been discussed many times, in the context of
multithreading and also in the context with a lazy_union() operator.
Tue, Jan 30, 2018 7:00 PM
See my implementation of a rounded_cylinder() and how it deals with
conflicts between diameters and radii. It is pretty fast, but I have no
way
to figure out, whether it is semantically equivalent with cylinder,
therefore I can't call cylinder() with all its parameters in case r_ is 0.
Sorry, here is my latest implementation:
$fa=.2;
$fs=.2;
module CyR(r = 10, h=10, r_=1, d = undef, r1=undef, r2=undef, d1 = undef, d2
= undef, center=false)
r1 = r1==undef?d1==undef?d==undef?r:d/2:d1/2:r1;
r2 = r2==undef?d2==undef?d==undef?r:d/2:d2/2:r2;
r_=min(abs(h/4), abs(r1), abs(r2), abs(r_));
h=abs(h);
translate([0,0,center?-h/2:0])
rotate_extrude()
intersection()
offset(r_)offset(-r_) polygon([[-2r_,0], [r1, 0], [r2, h], [0,h],
[-2r_,h]] );
square(max(r1,r2), h);
> way
$fa=.2;
$fs=.2;
h=abs(h);
rotate_extrude()
intersection()
offset(r_)offset(-r_) polygon([[-2*r_,0], [r1, 0], [r2, h], [0,h],
[-2*r_,h]] );
CA
Tue, Jan 30, 2018 7:05 PM
On 30. jan. 2018 17:49, Jordan Brown wrote:
Not knowing how hull( ) works, I wouldn't have expected there to be a
difference.
Good information, thanks.
The problem is not hull(), but implicit union. Hull only needs the
points in the input mesh(es). Applying [implicit] union() before
applying hull() to the result is like unknowingly driving with the hand
brake engaged. You perform a potentially costly computation (union())
only to immediately throw away the result.
One idea would be to provide an option to switch off implicit union, and
such issues will go away.
> difference.
Tue, Jan 30, 2018 7:25 PM
I would welcome a switch that turned off implicit union, if the result
was better performance. I understand that I would need to alter my
source code, and that I might need to modify library source code.
difference.
hand brake engaged. You perform a potentially costly computation
(union()) only to immediately throw away the result.
and such issues will go away.
Sent from my desktop computer.
I do not receive emails while away from my desk,
nor do I receive texts on my main phone number
(which is a land line).
If you know that I am on the road, please text me.
If you know that I am home, please email me.
>> difference.
> Carsten Arnholm
HL
Hans L
Tue, Jan 30, 2018 7:35 PM
I would welcome a switch that turned off implicit union, if the result was
better performance. I understand that I would need to alter my source code,
difference.
The problem is not hull(), but implicit union. Hull only needs the points
in the input mesh(es). Applying [implicit] union() before applying hull() to
the result is like unknowingly driving with the hand brake engaged. You
perform a potentially costly computation (union()) only to immediately throw
away the result.
By the way, here is a relevant issue that looks like had a lot of work
done towards it but never completely finalized.
Lazy union (aka. no implicit union):
https://github.com/openscad/openscad/issues/350
> Jon
>>> difference.
>> away the result.
>> Carsten Arnholm
AB
Antonio Bueno
Any insight in why the first hull() (the one with explicit union()) is
faster (16s*) than the second one (26s)?
(*) These times are with version 2018.01.06, Windows 10 x64, i5-4570S @
2.90GHz and 32 GB of RAM
size=30;
radius=1;
$fn=60;
// 16s if $fn=60
hull() {
union() translate([size/2, size/2]) {
translate([0, 0, -size/2]) sphere(radius);
translate([0, 0, size/2]) sphere(radius);
cylinder(radius, h=size, center=true);
rotate(90) union() translate([size/2, size/2]) {
rotate(180) union() translate([size/2, size/2]) {
rotate(270) union() translate([size/2, size/2]) {
// 26s if $fn=60
hull() {
rotate(90) translate([size/2, size/2]) {
rotate(180) translate([size/2, size/2]) {
rotate(270) translate([size/2, size/2]) {
(I know there are faster methods to do that, but they are a couple of
samples from an speed test I did some time ago and illustrate well my doubt)
2018-01-30 20:05 GMT+01:00 Carsten Arnholm arnholm@arnholm.org:
difference.
to the result is like unknowingly driving with the hand brake engaged. You
size=30;
radius=1;
$fn=60;
// 16s if $fn=60
hull() {
// 26s if $fn=60
hull() {
2018-01-30 20:05 GMT+01:00 Carsten Arnholm <arnholm@arnholm.org>:
>> difference.
> Carsten Arnholm
Saludos,
Antonio
CA
Tue, Jan 30, 2018 8:07 PM
Implicit or explicit union takes time. You are doing both in this case.
Why not simplify. Shorter, easier code. And faster.
size=30;
radius=1;
$fn=60;
hull() {
translate([-size/2, -size/2, -size/2]) sphere(radius);
translate([+size/2, -size/2, -size/2]) sphere(radius);
translate([+size/2, +size/2, -size/2]) sphere(radius);
translate([-size/2, +size/2, -size/2]) sphere(radius);
translate([-size/2, -size/2, +size/2]) sphere(radius);
translate([+size/2, -size/2, +size/2]) sphere(radius);
translate([+size/2, +size/2, +size/2]) sphere(radius);
translate([-size/2, +size/2, +size/2]) sphere(radius);
size=30;
radius=1;
$fn=60;
hull() {
HL
Hans L
Tue, Jan 30, 2018 8:12 PM
Its basically just easier for CGAL to handle a bunch of smaller unions
than one big one.
size=30;
radius=1;
$fn=60;
hull() {
than one big one.
On Tue, Jan 30, 2018 at 2:07 PM, Carsten Arnholm <arnholm@arnholm.org> wrote:
> size=30;
> radius=1;
> $fn=60;
> hull() {
> Carsten Arnholm
N
NateTG
Wed, Jan 31, 2018 2:40 PM
than one big one.
If that's true, then can OpenSCAD get a performance improvement with divide
and conquer?
than one big one.
and conquer?
N
NateTG
Thu, Feb 8, 2018 2:33 AM
As an attempt to attack the problem of booleans, I wrote an octree voxelizer
- that would make the boolean operations trivial, but it seems too slow to
be viable.
octree.scad http://forum.openscad.org/file/t2140/octree.scad
be viable.
octree.scad <http://forum.openscad.org/file/t2140/octree.scad>
