Tough Nut: How to get text on this ellipse shape.
PYM
Mon, Aug 3, 2015 7:19 PM
Hello,
I successfully created a ellipse shaped profile (thanks to the guys on this
forum helping out!). Now i want to engrave text on the flat outside of this
ring, but i cant figure out how i could do it. Anybody a good idea? Its a
tough one, trust me.
Please help!
requires:
https://github.com/openscad/list-comprehension-demos
https://github.com/OskarLinde/scad-utils
Code
use <list-comprehension-demos/sweep.scad>
use <scad-utils/transformations.scad>
use <scad-utils/shapes.scad>
use <scad-utils/lists.scad>
A=451/2;  //long half-axis of ellipse
B=301/2;  //short half-axis of ellipse
quarter_segments = 4; //Number of displayed quarter segments
Brim cross section parameters
ring_hoehe_ges = 20.00; // Total height of ring
ring_breite_ges = 10.00; // Total width of ring
ring_hoehe_overlap_aussen = 10.00; // Height of outer ring shield
ring_breite_overlap_aussen = 0.90; // Width of outer ring shield
ring_breite_vertiefung = 4.00;
ring_hoehe_vertiefung = 1.00;
step = 0.0005; // Step size for sweep
function e(i) = [
0,
A * cos(6 * 360 * i), //faktor 6?
B * sin(6 * 360 * i)  //faktor 6?
module section(){
polygon( points =  [
[0,0],
[14.59, 0], //15,49 - 0.9 für Vertiefung
[14.59, -0.9],
[-0.9, -0.9],
[-0.9, -3.1],
[4.85, -3.1], //5.75 - 0.9 für Vertiefung
[4.85, -12.80]] //5.75 - 0.9 für Vertiefung
//!section();
module test_bezier(){
polygon( points =  [[0, -12.8], [-0.608, -12.16], [-1.152, -11.52],
[-1.632, -10.88], [-2.048, -10.24], [-2.4, -9.6], [-2.688, -8.96], [-2.912,
-8.32], [-3.072, -7.68], [-3.168, -7.04], [-3.2, -6.4], [-3.168, -5.76],
[-3.072, -5.12], [-2.912, -4.48], [-2.688, -3.84], [-2.4, -3.2], [-2.048,
-2.56], [-1.632, -1.92], [-1.152, -1.28], [-0.608, -0.64]]
//!test_bezier();
function shape() = [
[0,0],
[14.59, -0.9],
[-0.9, -0.9],
[-0.9, -4.1], //Achtung: eigentlich -3.1!!!!!
[4.85, -4.1], //5.75 - 0.9 für Vertiefung
[4.85, -12.80],
[0,-12.80]]; //5.75 - 0.9 für Vertiefung
To avoid degenerate polygon with roundtop
function shape2() = [
[14.59, -0.9],
[-0.9, -0.9],
[-0.9, -3.1],
[4.85, -12.80]]; //5.75 - 0.9 für Vertiefung
Bezier functions
function getpt(n1,n2,i) = n1+((n2-n1)*i);
function bezier(x1,y1,x2,y2,x3,y3,g) = [ for( i= [0:1/g:1+1/g])
[getpt(getpt(x1,x2,i),getpt(x2,x3,i),i),getpt(getpt(y1,y2,i),getpt(y2,y3,i),i)]];
//echo(bezier(0,0,2,12,10,0,30));
Forms a top that seems slim from the outside and broad from the inside
function slimtop(r,g,cs,xs,ys) = [for (i=[0:g-1]) let (a=90+i
90/g) r *
[xs+(cs*cos(a)), ys+sin(a)]];
Forms a quarter top rounded from inside
function quartertop(r,g,cs,xs,ys) = [for (i=[0:g-1]) let (a=180+i
90/g) r *
Forms a circular shaped top
function roundtop(r,g,cs,xs,ys) = [for (i=[0:g-1]) let (a=90+i
180/g) r *
Create variants
function variant_round() =
concat(reverse(shape2()),roundtop(6.4,100,2.0,0,-1));
function variant_thin_outside() =
concat(reverse(shape2()),slimtop(5,20,0.5,0,1));
function variant_quarter_round() =
concat(reverse(shape2()),quartertop(10,20,1.0,0,1));
function variant_bezier() =
concat(shape(),bezier(-3,-12.80,-15.5,-6.4,-3,0.00,100));
//!echo(bezier(0,-12.80,-6.4,-6.4,0,0,20));
module create_ellipse(){
path = [for (i=[0:step:(1*quarter_segments/4)-step]) e(i)];
path_transforms = construct_transform_path(path);
sweep(variant_bezier(), path_transforms);
echo(variant_bezier());
translate([0,0,14.59]){
mirror([1,0,0]){
rotate([180,90,0]){
create_ellipse();
View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430.html
Hello, I successfully created a ellipse shaped profile (thanks to the guys on this forum helping out!). Now i want to engrave text on the flat outside of this ring, but i cant figure out how i could do it. Anybody a good idea? Its a tough one, trust me. Please help! requires: https://github.com/openscad/list-comprehension-demos https://github.com/OskarLinde/scad-utils Code ------ use <list-comprehension-demos/sweep.scad> use <scad-utils/transformations.scad> use <scad-utils/shapes.scad> use <scad-utils/lists.scad> A=451/2; //long half-axis of ellipse B=301/2; //short half-axis of ellipse quarter_segments = 4; //Number of displayed quarter segments /* Brim cross section parameters */ ring_hoehe_ges = 20.00; // Total height of ring ring_breite_ges = 10.00; // Total width of ring ring_hoehe_overlap_aussen = 10.00; // Height of outer ring shield ring_breite_overlap_aussen = 0.90; // Width of outer ring shield ring_breite_vertiefung = 4.00; ring_hoehe_vertiefung = 1.00; step = 0.0005; // Step size for sweep function e(i) = [ 0, A * cos(6 * 360 * i), //faktor 6? B * sin(6 * 360 * i) //faktor 6? ]; module section(){ polygon( points = [ [0,0], [14.59, 0], //15,49 - 0.9 für Vertiefung [14.59, -0.9], [-0.9, -0.9], [-0.9, -3.1], [4.85, -3.1], //5.75 - 0.9 für Vertiefung [4.85, -12.80]] //5.75 - 0.9 für Vertiefung ); } //!section(); module test_bezier(){ polygon( points = [[0, -12.8], [-0.608, -12.16], [-1.152, -11.52], [-1.632, -10.88], [-2.048, -10.24], [-2.4, -9.6], [-2.688, -8.96], [-2.912, -8.32], [-3.072, -7.68], [-3.168, -7.04], [-3.2, -6.4], [-3.168, -5.76], [-3.072, -5.12], [-2.912, -4.48], [-2.688, -3.84], [-2.4, -3.2], [-2.048, -2.56], [-1.632, -1.92], [-1.152, -1.28], [-0.608, -0.64]] ); } //!test_bezier(); function shape() = [ [0,0], [14.59, 0], //15,49 - 0.9 für Vertiefung [14.59, -0.9], [-0.9, -0.9], [-0.9, -4.1], //Achtung: eigentlich -3.1!!!!! [4.85, -4.1], //5.75 - 0.9 für Vertiefung [4.85, -12.80], [0,-12.80]]; //5.75 - 0.9 für Vertiefung /* To avoid degenerate polygon with roundtop */ function shape2() = [ [14.59, 0], //15,49 - 0.9 für Vertiefung [14.59, -0.9], [-0.9, -0.9], [-0.9, -3.1], [4.85, -3.1], //5.75 - 0.9 für Vertiefung [4.85, -12.80]]; //5.75 - 0.9 für Vertiefung /* Bezier functions */ function getpt(n1,n2,i) = n1+((n2-n1)*i); function bezier(x1,y1,x2,y2,x3,y3,g) = [ for( i= [0:1/g:1+1/g]) [getpt(getpt(x1,x2,i),getpt(x2,x3,i),i),getpt(getpt(y1,y2,i),getpt(y2,y3,i),i)]]; //echo(bezier(0,0,2,12,10,0,30)); /* Forms a top that seems slim from the outside and broad from the inside */ function slimtop(r,g,cs,xs,ys) = [for (i=[0:g-1]) let (a=90+i*90/g) r * [xs+(cs*cos(a)), ys+sin(a)]]; /* Forms a quarter top rounded from inside */ function quartertop(r,g,cs,xs,ys) = [for (i=[0:g-1]) let (a=180+i*90/g) r * [xs+(cs*cos(a)), ys+sin(a)]]; /* Forms a circular shaped top */ function roundtop(r,g,cs,xs,ys) = [for (i=[0:g-1]) let (a=90+i*180/g) r * [xs+(cs*cos(a)), ys+sin(a)]]; /* Create variants */ function variant_round() = concat(reverse(shape2()),roundtop(6.4,100,2.0,0,-1)); function variant_thin_outside() = concat(reverse(shape2()),slimtop(5,20,0.5,0,1)); function variant_quarter_round() = concat(reverse(shape2()),quartertop(10,20,1.0,0,1)); function variant_bezier() = concat(shape(),bezier(-3,-12.80,-15.5,-6.4,-3,0.00,100)); //!echo(bezier(0,-12.80,-6.4,-6.4,0,0,20)); module create_ellipse(){ path = [for (i=[0:step:(1*quarter_segments/4)-step]) e(i)]; path_transforms = construct_transform_path(path); sweep(variant_bezier(), path_transforms); echo(variant_bezier()); } translate([0,0,14.59]){ mirror([1,0,0]){ rotate([180,90,0]){ create_ellipse(); } } } -- View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
sgraves
Mon, Aug 3, 2015 11:17 PM
Something like this will give you the "projection" of the text on the
surface.  Bending the text to follow the surface would be very difficult.
I am creating text that goes through the ellipse and intersecting a slightly
larger ellipse with it.  If you want more precise control over the thickness
of the text then do a minkowski with the base ellipse and a
cube([2thickness,2thickness,0.01],center=true).
It will take a long time to compile.
Steve
xy_scale = 1.02;
//Explicit Union, don't really need it
union(){
intersection(){
translate([0,0,5])
rotate([90,0,90])
linear_extrude(height=175)
text("This is your text", halign="center", size = 16);
scale([xy_scale,xy_scale,1])
mirror([1,0,0]){
rotate([180,90,0]){
create_ellipse();
mirror([1,0,0]){
rotate([180,90,0]){
create_ellipse();
PYM wrote
Hello,
Please help!
requires:
Code
function e(i) = [
0,
module section(){
polygon( points =  [
[0,0],
[14.59, -0.9],
[-0.9, -0.9],
[-0.9, -3.1],
//!section();
//!test_bezier();
[0,0],
[14.59, -0.9],
[-0.9, -0.9],
[4.85, -12.80],
[14.59, -0.9],
[-0.9, -0.9],
[-0.9, -3.1],
Bezier functions
90/g) r *
90/g) r
  • [xs+(cs*cos(a)), ys+sin(a)]];
180/g) r *
Create variants
mirror([1,0,0]){
rotate([180,90,0]){
create_ellipse();
View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13433.html
Something like this will give you the "projection" of the text on the surface. Bending the text to follow the surface would be very difficult. I am creating text that goes through the ellipse and intersecting a slightly larger ellipse with it. If you want more precise control over the thickness of the text then do a minkowski with the base ellipse and a cube([2*thickness,2*thickness,0.01],center=true). It will take a long time to compile. Steve xy_scale = 1.02; //Explicit Union, don't really need it union(){ intersection(){ translate([0,0,5]) rotate([90,0,90]) linear_extrude(height=175) text("This is your text", halign="center", size = 16); translate([0,0,14.59]){ scale([xy_scale,xy_scale,1]) mirror([1,0,0]){ rotate([180,90,0]){ create_ellipse(); } } } } translate([0,0,14.59]){ mirror([1,0,0]){ rotate([180,90,0]){ create_ellipse(); } } } } PYM wrote > Hello, > > I successfully created a ellipse shaped profile (thanks to the guys on > this forum helping out!). Now i want to engrave text on the flat outside > of this ring, but i cant figure out how i could do it. Anybody a good > idea? Its a tough one, trust me. > > Please help! > > requires: > > https://github.com/openscad/list-comprehension-demos > https://github.com/OskarLinde/scad-utils > > Code > ------ > > use &lt;list-comprehension-demos/sweep.scad&gt; > use &lt;scad-utils/transformations.scad&gt; > use &lt;scad-utils/shapes.scad&gt; > use &lt;scad-utils/lists.scad&gt; > > A=451/2; //long half-axis of ellipse > B=301/2; //short half-axis of ellipse > > quarter_segments = 4; //Number of displayed quarter segments > > /* > Brim cross section parameters > */ > ring_hoehe_ges = 20.00; // Total height of ring > ring_breite_ges = 10.00; // Total width of ring > ring_hoehe_overlap_aussen = 10.00; // Height of outer ring shield > ring_breite_overlap_aussen = 0.90; // Width of outer ring shield > ring_breite_vertiefung = 4.00; > ring_hoehe_vertiefung = 1.00; > > step = 0.0005; // Step size for sweep > > function e(i) = [ > 0, > A * cos(6 * 360 * i), //faktor 6? > B * sin(6 * 360 * i) //faktor 6? > ]; > > > > module section(){ > polygon( points = [ > [0,0], > [14.59, 0], //15,49 - 0.9 für Vertiefung > [14.59, -0.9], > [-0.9, -0.9], > [-0.9, -3.1], > [4.85, -3.1], //5.75 - 0.9 für Vertiefung > [4.85, -12.80]] //5.75 - 0.9 für Vertiefung > ); > } > //!section(); > > module test_bezier(){ > polygon( points = [[0, -12.8], [-0.608, -12.16], [-1.152, -11.52], > [-1.632, -10.88], [-2.048, -10.24], [-2.4, -9.6], [-2.688, -8.96], > [-2.912, -8.32], [-3.072, -7.68], [-3.168, -7.04], [-3.2, -6.4], [-3.168, > -5.76], [-3.072, -5.12], [-2.912, -4.48], [-2.688, -3.84], [-2.4, -3.2], > [-2.048, -2.56], [-1.632, -1.92], [-1.152, -1.28], [-0.608, -0.64]] > > ); > } > > //!test_bezier(); > > function shape() = [ > [0,0], > [14.59, 0], //15,49 - 0.9 für Vertiefung > [14.59, -0.9], > [-0.9, -0.9], > [-0.9, -4.1], //Achtung: eigentlich -3.1!!!!! > [4.85, -4.1], //5.75 - 0.9 für Vertiefung > [4.85, -12.80], > [0,-12.80]]; //5.75 - 0.9 für Vertiefung > > /* > To avoid degenerate polygon with roundtop > */ > function shape2() = [ > [14.59, 0], //15,49 - 0.9 für Vertiefung > [14.59, -0.9], > [-0.9, -0.9], > [-0.9, -3.1], > [4.85, -3.1], //5.75 - 0.9 für Vertiefung > [4.85, -12.80]]; //5.75 - 0.9 für Vertiefung > > > /* > Bezier functions > */ > > function getpt(n1,n2,i) = n1+((n2-n1)*i); > > function bezier(x1,y1,x2,y2,x3,y3,g) = [ for( i= [0:1/g:1+1/g]) > [getpt(getpt(x1,x2,i),getpt(x2,x3,i),i),getpt(getpt(y1,y2,i),getpt(y2,y3,i),i)]]; > > //echo(bezier(0,0,2,12,10,0,30)); > > /* > Forms a top that seems slim from the outside and broad from the inside > */ > function slimtop(r,g,cs,xs,ys) = [for (i=[0:g-1]) let (a=90+i*90/g) r * > [xs+(cs*cos(a)), ys+sin(a)]]; > > /* > Forms a quarter top rounded from inside > */ > function quartertop(r,g,cs,xs,ys) = [for (i=[0:g-1]) let (a=180+i*90/g) r > * [xs+(cs*cos(a)), ys+sin(a)]]; > > /* > Forms a circular shaped top > */ > function roundtop(r,g,cs,xs,ys) = [for (i=[0:g-1]) let (a=90+i*180/g) r * > [xs+(cs*cos(a)), ys+sin(a)]]; > > /* > Create variants > */ > function variant_round() = > concat(reverse(shape2()),roundtop(6.4,100,2.0,0,-1)); > > function variant_thin_outside() = > concat(reverse(shape2()),slimtop(5,20,0.5,0,1)); > > function variant_quarter_round() = > concat(reverse(shape2()),quartertop(10,20,1.0,0,1)); > > function variant_bezier() = > concat(shape(),bezier(-3,-12.80,-15.5,-6.4,-3,0.00,100)); > > //!echo(bezier(0,-12.80,-6.4,-6.4,0,0,20)); > > > module create_ellipse(){ > path = [for (i=[0:step:(1*quarter_segments/4)-step]) e(i)]; > path_transforms = construct_transform_path(path); > sweep(variant_bezier(), path_transforms); > echo(variant_bezier()); > } > translate([0,0,14.59]){ > mirror([1,0,0]){ > rotate([180,90,0]){ > create_ellipse(); > } > } > } -- View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13433.html Sent from the OpenSCAD mailing list archive at Nabble.com.
PYM
Mon, Aug 3, 2015 11:57 PM
Hi Steve,
thanks for your reply, i will give your idea a shot tomorrow. I think you
are right,doing it accurately is very difficult, but it should be doable. I
saw this code bending text around a parabola, so i think it should be
possible to also bend it on an ellipsoid shape.
https://www.thingiverse.com/thing:210099
Although i dont know how to transfer the code on a generic ellipsoid shape
yet. Can you help?
Patrick
View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13434.html
Hi Steve, thanks for your reply, i will give your idea a shot tomorrow. I think you are right,doing it accurately is very difficult, but it should be doable. I saw this code bending text around a parabola, so i think it should be possible to also bend it on an ellipsoid shape. https://www.thingiverse.com/thing:210099 <https://www.thingiverse.com/thing:210099> Although i dont know how to transfer the code on a generic ellipsoid shape yet. Can you help? Patrick -- View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13434.html Sent from the OpenSCAD mailing list archive at Nabble.com.
N
Neon22
Tue, Aug 4, 2015 2:07 AM
@PYM the scad_utils you reference don't contain shapes.scad, lists.scad and a
few others.
Where did you get those ones from ?
Maybe I should start a request for a sticky thread with the common libs
people include but aren't part of the OpenSCAD distro. We could keep it up
todate as OpenSCAD slowly includes their functionality (possibly).
I'm sure everyone has their favourites... ?
View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13436.html
@PYM the scad_utils you reference don't contain shapes.scad, lists.scad and a few others. Where did you get those ones from ? Maybe I should start a request for a sticky thread with the common libs people include but aren't part of the OpenSCAD distro. We could keep it up todate as OpenSCAD slowly includes their functionality (possibly). I'm sure everyone has their favourites... ? -- View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13436.html Sent from the OpenSCAD mailing list archive at Nabble.com.
rickan
Tue, Aug 4, 2015 2:44 AM
I used this stuff to run PYM's design.
https://github.com/openscad/scad-utils
The other scad-utils has missing functions in addition to the missing files.
I think it must be an older version.
View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13438.html
I used this stuff to run PYM's design. https://github.com/openscad/scad-utils <https://github.com/openscad/scad-utils> The other scad-utils has missing functions in addition to the missing files. I think it must be an older version. -- View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13438.html Sent from the OpenSCAD mailing list archive at Nabble.com.
PYM
Tue, Aug 4, 2015 2:49 PM
Hello,
yeah it is confusing, rickan's link is the correct one. Sorry for mixing up.
Anybody a solution yet? This problem drives me crazy!
Patrick
View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13439.html
Hello, yeah it is confusing, rickan's link is the correct one. Sorry for mixing up. Anybody a solution yet? This problem drives me crazy! Patrick -- View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13439.html Sent from the OpenSCAD mailing list archive at Nabble.com.
PYM
Tue, Aug 4, 2015 7:15 PM
Hi Steve, unfortunately your code gives me an error with CGAL:
WARNING: Ignoring 3D child object for 2D operation
PolySet has nonplanar faces. Attempting alternate construction
ERROR: Alternate construction failed. CGAL error in CGAL_Nef_polyhedron3():
CGAL ERROR: assertion violation! Expr: pe != 0 File:
/data/OpenSCAD/libraries-mingw64-master/mxe-w64/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h
Line: 212
Geometries in cache: 18
Geometry cache size in bytes: 100702352
CGAL Polyhedrons in cache: 170
CGAL cache size in bytes: 104805768
Total rendering time: 0 hours, 0 minutes, 31 seconds
Cheers,
Patrick
View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13443.html
Hi Steve, unfortunately your code gives me an error with CGAL: Rendering Polygon Mesh using CGAL... WARNING: Ignoring 3D child object for 2D operation PolySet has nonplanar faces. Attempting alternate construction ERROR: Alternate construction failed. CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion violation! Expr: pe != 0 File: /data/OpenSCAD/libraries-mingw64-master/mxe-w64/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h Line: 212 Geometries in cache: 18 Geometry cache size in bytes: 100702352 CGAL Polyhedrons in cache: 170 CGAL cache size in bytes: 104805768 Total rendering time: 0 hours, 0 minutes, 31 seconds Cheers, Patrick -- View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13443.html Sent from the OpenSCAD mailing list archive at Nabble.com.
PYM
Wed, Aug 5, 2015 4:28 PM
Bump. Anybody has a solution to that?
View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13453.html
Bump. Anybody has a solution to that? -- View this message in context: http://forum.openscad.org/Tough-Nut-How-to-get-text-on-this-ellipse-shape-tp13430p13453.html Sent from the OpenSCAD mailing list archive at Nabble.com.
CL
Chow Loong Jin
Thu, Aug 6, 2015 1:47 AM
On Mon, Aug 03, 2015 at 12:19:15PM -0700, PYM wrote:
Hello,
Here's a starting point (untested):
for (i = [0:step:(1*quarter_segments/4)-step])
rotate (e_a (i), Z)
translate ([-e_r (i), -e_c (i), 0])
rotate (90, Z)
rotate (90, X)
linear_extrude (height)
text (t, valign = "center");
You'll need to figure out the formula for these functions:
e_r(i) gives you the radius from the center of your ellipse at that specific
point.
e_a(i) gives you the angle from the X axis for that particular point.
You should be able to get the e_r(i) and e_a(i) by converting e(i)'s coordinates
into polar coordinates.
e_c(i) gives you the partial circumference starting from i=0 until current i.
I'm still not sure about the formula for this.
Kind regards,
Loong Jin
On Mon, Aug 03, 2015 at 12:19:15PM -0700, PYM wrote: > Hello, > > I successfully created a ellipse shaped profile (thanks to the guys on this > forum helping out!). Now i want to engrave text on the flat outside of this > ring, but i cant figure out how i could do it. Anybody a good idea? Its a > tough one, trust me. Here's a starting point (untested): for (i = [0:step:(1*quarter_segments/4)-step]) rotate (e_a (i), Z) translate ([-e_r (i), -e_c (i), 0]) rotate (90, Z) rotate (90, X) linear_extrude (height) text (t, valign = "center"); You'll need to figure out the formula for these functions: e_r(i) gives you the radius from the center of your ellipse at that specific point. e_a(i) gives you the angle from the X axis for that particular point. You should be able to get the e_r(i) and e_a(i) by converting e(i)'s coordinates into polar coordinates. e_c(i) gives you the partial circumference starting from i=0 until current i. I'm still not sure about the formula for this. -- Kind regards, Loong Jin
CL
Chow Loong Jin
Thu, Aug 6, 2015 1:49 AM
Hello,
rotate (e_a (i), Z)
rotate (90, Z)
rotate (90, X)
point.
Here's an animation to help you picture what's going on here:
https://cloud.githubusercontent.com/assets/3725313/4020624/8d55c042-2ac3-11e4-82d6-48f3c5a8b15b.gif
Imagine that the red piece is your text. You need to emulate that with an
elliptical path.
Kind regards,
Loong Jin
On Thu, Aug 06, 2015 at 09:47:57AM +0800, Chow Loong Jin wrote: > On Mon, Aug 03, 2015 at 12:19:15PM -0700, PYM wrote: > > Hello, > > > > I successfully created a ellipse shaped profile (thanks to the guys on this > > forum helping out!). Now i want to engrave text on the flat outside of this > > ring, but i cant figure out how i could do it. Anybody a good idea? Its a > > tough one, trust me. > > Here's a starting point (untested): > > for (i = [0:step:(1*quarter_segments/4)-step]) > rotate (e_a (i), Z) > translate ([-e_r (i), -e_c (i), 0]) > rotate (90, Z) > rotate (90, X) > linear_extrude (height) > text (t, valign = "center"); > > > You'll need to figure out the formula for these functions: > > e_r(i) gives you the radius from the center of your ellipse at that specific > point. > > e_a(i) gives you the angle from the X axis for that particular point. > > You should be able to get the e_r(i) and e_a(i) by converting e(i)'s coordinates > into polar coordinates. > > e_c(i) gives you the partial circumference starting from i=0 until current i. > I'm still not sure about the formula for this. Here's an animation to help you picture what's going on here: https://cloud.githubusercontent.com/assets/3725313/4020624/8d55c042-2ac3-11e4-82d6-48f3c5a8b15b.gif Imagine that the red piece is your text. You need to emulate that with an elliptical path. -- Kind regards, Loong Jin
