Tough Nut: How to get text on this ellipse shape.
PF
Peter Falke
Sat, Aug 8, 2015 10:39 PM
There is an older but nice way to get text on cubes, cylinders, and
spheres:  http://www.thingiverse.com/thing:16193
This utility should probably be re-writen with text().
2015-08-06 3:49 GMT+02:00 Chow Loong Jin hyperair@debian.org:
On Thu, Aug 06, 2015 at 09:47:57AM +0800, Chow Loong Jin wrote:
On Mon, Aug 03, 2015 at 12:19:15PM -0700, PYM wrote:
Hello,
I successfully created a ellipse shaped profile (thanks to the guys on
this
forum helping out!). Now i want to engrave text on the flat outside of
this
ring, but i cant figure out how i could do it. Anybody a good idea?
Its a
tough one, trust me.
Here's a starting point (untested):
for (i = [0:step:(1*quarter_segments/4)-step])
rotate (e_a (i), Z)
translate ([-e_r (i), -e_c (i), 0])
rotate (90, Z)
rotate (90, X)
linear_extrude (height)
text (t, valign = "center");
You'll need to figure out the formula for these functions:
e_r(i) gives you the radius from the center of your ellipse at that
specific
point.
e_a(i) gives you the angle from the X axis for that particular point.
You should be able to get the e_r(i) and e_a(i) by converting e(i)'s
coordinates
into polar coordinates.
e_c(i) gives you the partial circumference starting from i=0 until
current i.
I'm still not sure about the formula for this.
Here's an animation to help you picture what's going on here:
https://cloud.githubusercontent.com/assets/3725313/4020624/8d55c042-2ac3-11e4-82d6-48f3c5a8b15b.gif
Imagine that the red piece is your text. You need to emulate that with an
elliptical path.
Kind regards,
Loong Jin
schreiben.
Enjoy!
There is an older but nice way to get text on cubes, cylinders, and spheres: http://www.thingiverse.com/thing:16193 This utility should probably be re-writen with text(). 2015-08-06 3:49 GMT+02:00 Chow Loong Jin <hyperair@debian.org>: > On Thu, Aug 06, 2015 at 09:47:57AM +0800, Chow Loong Jin wrote: > > On Mon, Aug 03, 2015 at 12:19:15PM -0700, PYM wrote: > > > Hello, > > > > > > I successfully created a ellipse shaped profile (thanks to the guys on > this > > > forum helping out!). Now i want to engrave text on the flat outside of > this > > > ring, but i cant figure out how i could do it. Anybody a good idea? > Its a > > > tough one, trust me. > > > > Here's a starting point (untested): > > > > for (i = [0:step:(1*quarter_segments/4)-step]) > > rotate (e_a (i), Z) > > translate ([-e_r (i), -e_c (i), 0]) > > rotate (90, Z) > > rotate (90, X) > > linear_extrude (height) > > text (t, valign = "center"); > > > > > > You'll need to figure out the formula for these functions: > > > > e_r(i) gives you the radius from the center of your ellipse at that > specific > > point. > > > > e_a(i) gives you the angle from the X axis for that particular point. > > > > You should be able to get the e_r(i) and e_a(i) by converting e(i)'s > coordinates > > into polar coordinates. > > > > e_c(i) gives you the partial circumference starting from i=0 until > current i. > > I'm still not sure about the formula for this. > > Here's an animation to help you picture what's going on here: > > https://cloud.githubusercontent.com/assets/3725313/4020624/8d55c042-2ac3-11e4-82d6-48f3c5a8b15b.gif > > Imagine that the red piece is your text. You need to emulate that with an > elliptical path. > > -- > Kind regards, > Loong Jin > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > -- stempeldergeschichte@googlemail.com <karsten@rohrbach.de> P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu schreiben. Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. P.S. In case my e-mail is shorter than you enjoy: I am currently trying short replies instead of no replies at all. Please let me know, if you like to read more. Enjoy!
Sat, Aug 8, 2015 10:42 PM
On 08/09/2015 12:39 AM, Peter Falke wrote: > There is an older but nice way to get text on cubes, cylinders, and > spheres: http://www.thingiverse.com/thing:16193 > > This utility should probably be re-writen with text(). > It already is: https://github.com/brodykenrick/text_on_OpenSCAD ciao, Torsten.
