AdrianSchlatter
Wed, May 8, 2019 5:01 PM
I‘m looking for a way to render a .scad file and get the number of rendered
volumes in a machine-readable way - i.e. on the cmdline. Purpose: unit
testing. I‘m creating a library of threads (hundreds) and want to verify
that nuts and bolts are created as exactly one part each, and that a bolt
does not collide with its mating nut. Idea: render nut + bolt. Check number
of volumes:
1: what the Heck?!
2: collision
3: ok
=4: Something is detached (e.g. thread not attached to bolt)
My problem: OpenSCAD prints the number of volumes when run in GUI. I have
not found a way to make it print that info on cmd line. Any ideas?
Best regards, Adrian
of volumes:
1: what the Heck?!
2: collision
3: ok
CA
Wed, May 8, 2019 7:51 PM
The first problem seems to be that the number of volumes OpenSCAD prints
is incorrect. For example
cubes.scad
n=5;
for(i=[1:n]) {
echo(i);
translate([i*20,0,0])cube(10);
You get 5 echoes, but in the GUI console it says
Simple: yes
Vertices: 40
Halfedges: 120
Edges: 60
Halffacets: 60
Facets: 30
Volumes: 6
Rendering finished.
So the number of volumes reported by OpenSCAD is off by one. Aside from
that minor issue, you can use an external program to count the volumes
in a machine-readable way if OpenSCAD can not do it.
Here is one way to do it:
Assuming the OS is Linux (similar for Windows), prepare 2 files in the
same folder, a bash script and a minimal .as file.
Note that the term 'lump' below is equivalent to OpenSCAD 'volume'.
count_lumps.sh
#!/bin/bash
openscad -o temp_file.off $1
as_csg ./count_lumps.as > /dev/null
xcsg --stl temp_file.xcsg | grep lump
rm temp_file.*
count_lumps.as
void main() {
polyhedron("temp_file.off").write_xcsg("temp_file");
Run count_lumps.sh with OpenSCAD input
$ ./count_lumps.sh cubes.scad
ECHO: 1
ECHO: 2
ECHO: 3
ECHO: 4
ECHO: 5
...result model contains 5 lumps.
...lump 1: 8 vertices, 12 polygon faces.
...lump 2: 8 vertices, 12 polygon faces.
...lump 3: 8 vertices, 12 polygon faces.
...lump 4: 8 vertices, 12 polygon faces.
...lump 5: 8 vertices, 12 polygon faces.
What happens in the script is
- openscad generates .off file from .scad
- as_csg converts .off to .xcsg (silently)
- xcsg reads .xcsg and prints (filtered with grep here)
- Temporary files are removed (silently)
If you skip piping to grep you get more detailed information. If you
instead replace 'grep lump' with 'grep lumps' you get only the
information you asked for:
as_csg and xcsg are installed with AngelCAD
https://github.com/arnholm/angelcad/releases
Kind Regards
cubes.scad
n=5;
for(i=[1:n]) {
echo(i);
Simple: yes
Vertices: 40
Halfedges: 120
Edges: 60
Halffacets: 60
Facets: 30
Volumes: 6
Rendering finished.
count_lumps.sh
#!/bin/bash
rm temp_file.*
count_lumps.as
void main() {
ECHO: 1
ECHO: 2
ECHO: 3
ECHO: 4
ECHO: 5
1. openscad generates .off file from .scad
2. as_csg converts .off to .xcsg (silently)
3. xcsg reads .xcsg and prints (filtered with grep here)
4. Temporary files are removed (silently)
Kind Regards
Wed, May 8, 2019 11:06 PM
I believe the extra volume is that which is NOT bound by the part. The perimeter of the part divides all space into 2 separate volumes.
The first problem seems to be that the number of volumes OpenSCAD prints is incorrect. For example
cubes.scad
n=5;
for(i=[1:n]) {
echo(i);
Simple: yes
Vertices: 40
Halfedges: 120
Edges: 60
Halffacets: 60
Facets: 30
Volumes: 6
Rendering finished.
So the number of volumes reported by OpenSCAD is off by one. Aside from that minor issue, you can use an external program to count the volumes in a machine-readable way if OpenSCAD can not do it.
Assuming the OS is Linux (similar for Windows), prepare 2 files in the same folder, a bash script and a minimal .as file.
count_lumps.sh
#!/bin/bash
rm temp_file.*
count_lumps.as
void main() {
ECHO: 1
ECHO: 2
ECHO: 3
ECHO: 4
ECHO: 5
If you skip piping to grep you get more detailed information. If you instead replace 'grep lump' with 'grep lumps' you get only the information you asked for:
Kind Regards
- Revar
> cubes.scad
> n=5;
> for(i=[1:n]) {
> echo(i);
> Simple: yes
> Vertices: 40
> Halfedges: 120
> Edges: 60
> Halffacets: 60
> Facets: 30
> Volumes: 6
> Rendering finished.
> count_lumps.sh
> #!/bin/bash
> rm temp_file.*
> count_lumps.as
> void main() {
> ECHO: 1
> ECHO: 2
> ECHO: 3
> ECHO: 4
> ECHO: 5
> Kind Regards
> Carsten Arnholm
Wed, May 8, 2019 11:09 PM
Have you tried adding --render to the command-line?
of volumes:
1: what the Heck?!
2: collision
3: ok
Have you tried adding `--render` to the command-line?
- Revar
> of volumes:
> 1: what the Heck?!
> 2: collision
> 3: ok
AdrianSchlatter
Thu, May 9, 2019 6:39 PM
Yep, tried that. OpenSCAD remains silent.
AdrianSchlatter
Thu, May 9, 2019 6:53 PM
Carsten,
Sounds good to me, thanks for the help. Can I compile AngelCAD on MacOS?
Linux is ok for CI server, of course, but it would be nice to run the tests
locally as well.
Best regards,
Adrian
Carsten,
locally as well.
Best regards,
Adrian
CA
Thu, May 9, 2019 7:22 PM
On 09.05.2019 20:53, AdrianSchlatter wrote:
Carsten,
locally as well.
I don't see anything in principle for it not to work, but I have no
particular interest in or experience with MacOS, so I have done 'only'
Windows and Linux. It is possible on the Mac with some dedication, but
it would be a new os port. All the tools & components are available I think.
Alternatively install a virtual machine with Ubuntu on the Mac, or
simply get OpenSCAD to report to the console :-)
Regards
> Carsten,
> locally as well.
Regards
Thu, May 9, 2019 7:26 PM
The code that prints the volumes is part of the GUI so it doesn't happen
when running without a GUI. It is here:
https://github.com/openscad/openscad/blob/master/src/mainwin.cc#L2276
I don't think it would be a big job to move it to openscad.cc and call it
from mainwin.cc. Perhaps a command line option to enable it as most people
probably don't want the extra noise.
On Thu, 9 May 2019 at 19:54, AdrianSchlatter <ad@tambora.ch> wrote:
> Carsten,
> locally as well.
> Best regards,
> Adrian
HL
Hans L
Thu, May 9, 2019 10:42 PM
Yep. The inside of your geometries define one volume each, and infinite
void outside the geometry is the other volume. That's just how CGAL
represents volumes. In other words, "It's not a bug, its a feature" ;)
Hans
cubes.scad
n=5;
for(i=[1:n]) {
echo(i);
Simple: yes
Vertices: 40
Halfedges: 120
Edges: 60
Halffacets: 60
Facets: 30
Volumes: 6
Rendering finished.
count_lumps.sh
#!/bin/bash
rm temp_file.*
count_lumps.as
void main() {
ECHO: 1
ECHO: 2
ECHO: 3
ECHO: 4
ECHO: 5
you asked for:
Hans
> - Revar
> have
> > cubes.scad
> > n=5;
> > for(i=[1:n]) {
> > echo(i);
> > Simple: yes
> > Vertices: 40
> > Halfedges: 120
> > Edges: 60
> > Halffacets: 60
> > Facets: 30
> > Volumes: 6
> > Rendering finished.
> > count_lumps.sh
> > #!/bin/bash
> > rm temp_file.*
> > count_lumps.as
> > void main() {
> > ECHO: 1
> > ECHO: 2
> > ECHO: 3
> > ECHO: 4
> > ECHO: 5
> you asked for:
> > Kind Regards
> > Carsten Arnholm
AdrianSchlatter
Tue, May 14, 2019 7:45 PM
That clearly means it cannot be done with today’s openscad. It can be done by
changing openscad (as you outlined) or by using third party tools (as
outlined by Carsten). If this would be an urgent problem, I’d go for
Carsten’s AngelCAD. It’s not urgent, therefore I’ll avoid that extra
dependency for now.
Am I the only one interested in that feature? Or is this a use case others
have as well? Should the suggested command line option provide additional
information to be more useful for unit testing?
Regards, Adrian
people
dependency for now.
Regards, Adrian
> people
