I am not sure how useful it is for unit testing as it is a very crude
measure of correctness. The OpenSCAD automatic tests generate images or STL
files, etc and compare them with what is expected.
On Tue, 14 May 2019 at 20:46, AdrianSchlatter ad@tambora.ch wrote:
That clearly means it cannot be done with today’s openscad. It can be done
by
changing openscad (as you outlined) or by using third party tools (as
outlined by Carsten). If this would be an urgent problem, I’d go for
Carsten’s AngelCAD. It’s not urgent, therefore I’ll avoid that extra
dependency for now.
Am I the only one interested in that feature? Or is this a use case others
have as well? Should the suggested command line option provide additional
information to be more useful for unit testing?
Regards, Adrian
nophead wrote
The code that prints the volumes is part of the GUI so it doesn't happen
when running without a GUI. It is here:
https://github.com/openscad/openscad/blob/master/src/mainwin.cc#L2276
I don't think it would be a big job to move it to openscad.cc and call it
from mainwin.cc. Perhaps a command line option to enable it as most
people
probably don't want the extra noise.
