Question about gear library
KT
Kevin Toppenberg
Sat, Dec 22, 2018 1:14 PM
I am trying to model a gear for an Atlas metal lathe.  I have some original
(real-life) gears, but want to print one with a different number of teeth.
I have found this gear library by GregFrost:
https://www.thingiverse.com/thing:3575/files
I know that this list is not responsible for the library, but it seems to
be a good one, and I am hoping someone here can help.
My question is about the units of the input parameters.  For example, in
the file parametric_involute_gear_v5.0.scad there are some example gears.
I modified one slightly as follows:
gear (number_of_teeth=64,
circular_pitch=285.0,
circles=0);
I chose the value for circular_pitch experimentally.  First I put an Echo()
statement in the gear_shape module such that it reports the minor diameter,
pitch diameter, and major diameter (in mm).  I then slowly modified the
circular_pitch value until it matched the measurements of my actual
real-life gear, taken with my micrometer.
I am confused about what circular_pitch is supposed to represent.  I
reviewed standard gear terms from here:
https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch
Circular pitch should be the distance (in mm) from tooth to tooth.  In my
actual real-life gear, the value is about 5 mm.
On a slightly different tact, I am also confused about gear terminology
used for my lathe.  The gears are typically described using inches and
diametral pitch (which is supposed to be 1/circular_pitch).  According to
this site:
https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/
(which references here: http://www.lathes.co.uk/atlas/), Atlas gears use a
16DP, which I think means 16 diametral pitch or 16 teeth per inch.  I'm not
sure I believe this number, because my real-life gear with 20 teeth has a
diameter of 1.475 inches, circumference of ~4.3 inches, and thus 20/4.3 =
~4.6 teeth/inch.
Summary:
  1. Can anyone help me understand the units for the circular_pitch
    parameter in the gear() module as described above?
  2. Can anyone see the source of my confusion about the 16DP
Thanks in advance,
Kevin T
I am trying to model a gear for an Atlas metal lathe. I have some original (real-life) gears, but want to print one with a different number of teeth. I have found this gear library by GregFrost: https://www.thingiverse.com/thing:3575/files I know that this list is not responsible for the library, but it seems to be a good one, and I am hoping someone here can help. My question is about the units of the input parameters. For example, in the file parametric_involute_gear_v5.0.scad there are some example gears. I modified one slightly as follows: gear (number_of_teeth=64, circular_pitch=285.0, circles=0); I chose the value for circular_pitch experimentally. First I put an Echo() statement in the gear_shape module such that it reports the minor diameter, pitch diameter, and major diameter (in mm). I then slowly modified the circular_pitch value until it matched the measurements of my actual real-life gear, taken with my micrometer. I am confused about what circular_pitch is supposed to represent. I reviewed standard gear terms from here: https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch Circular pitch should be the distance (in mm) from tooth to tooth. In my actual real-life gear, the value is about 5 mm. On a slightly different tact, I am also confused about gear terminology used for my lathe. The gears are typically described using inches and diametral pitch (which is supposed to be 1/circular_pitch). According to this site: https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ (which references here: http://www.lathes.co.uk/atlas/), Atlas gears use a 16DP, which I think means 16 diametral pitch or 16 teeth per inch. I'm not sure I believe this number, because my real-life gear with 20 teeth has a diameter of 1.475 inches, circumference of ~4.3 inches, and thus 20/4.3 = ~4.6 teeth/inch. Summary: 1. Can anyone help me understand the units for the circular_pitch parameter in the gear() module as described above? 2. Can anyone see the source of my confusion about the 16DP Thanks in advance, Kevin T
Sat, Dec 22, 2018 1:52 PM
I am not familiar with Greg's library but DP is not about circumference. It
is the number of teeth per inch of its pitch diameter, an odd measure that
doesn't really have a physical meaning because the teeth go around the
circumference, not across the diameter.
Also the pitch diameter is not the outside diameter, it is the diameter
where the teeth mesh, sort of half way down the tooth. So you can mesh two
gears if they have the same DP and you space them apart by half the sum of
the pitch diameters.
I have a vague memory that Greg's library has a bug in the way
circular_pitch is used.
of teeth.
circles=0);
this site:
~4.6 teeth/inch.
Summary:
Thanks in advance,
Kevin T
I am not familiar with Greg's library but DP is not about circumference. It is the number of teeth per inch of its pitch diameter, an odd measure that doesn't really have a physical meaning because the teeth go around the circumference, not across the diameter. Also the pitch diameter is not the outside diameter, it is the diameter where the teeth mesh, sort of half way down the tooth. So you can mesh two gears if they have the same DP and you space them apart by half the sum of the pitch diameters. I have a vague memory that Greg's library has a bug in the way circular_pitch is used. On Sat, 22 Dec 2018 at 13:16, Kevin Toppenberg <kdtop3@gmail.com> wrote: > I am trying to model a gear for an Atlas metal lathe. I have some > original (real-life) gears, but want to print one with a different number > of teeth. > > I have found this gear library by GregFrost: > https://www.thingiverse.com/thing:3575/files > I know that this list is not responsible for the library, but it seems to > be a good one, and I am hoping someone here can help. > > My question is about the units of the input parameters. For example, in > the file parametric_involute_gear_v5.0.scad there are some example gears. > I modified one slightly as follows: > > gear (number_of_teeth=64, > circular_pitch=285.0, > circles=0); > > I chose the value for circular_pitch experimentally. First I put an > Echo() statement in the gear_shape module such that it reports the minor > diameter, pitch diameter, and major diameter (in mm). I then slowly > modified the circular_pitch value until it matched the measurements of my > actual real-life gear, taken with my micrometer. > > I am confused about what circular_pitch is supposed to represent. I > reviewed standard gear terms from here: > https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch > Circular pitch should be the distance (in mm) from tooth to tooth. In my > actual real-life gear, the value is about 5 mm. > > On a slightly different tact, I am also confused about gear terminology > used for my lathe. The gears are typically described using inches and > diametral pitch (which is supposed to be 1/circular_pitch). According to > this site: > https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ > (which references here: http://www.lathes.co.uk/atlas/), Atlas gears use > a 16DP, which I think means 16 diametral pitch or 16 teeth per inch. I'm > not sure I believe this number, because my real-life gear with 20 teeth has > a diameter of 1.475 inches, circumference of ~4.3 inches, and thus 20/4.3 = > ~4.6 teeth/inch. > > Summary: > > 1. Can anyone help me understand the units for the circular_pitch > parameter in the gear() module as described above? > 2. Can anyone see the source of my confusion about the 16DP > > > Thanks in advance, > Kevin T > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
AG
Alex Gibson
Sat, Dec 22, 2018 2:34 PM
Hi, I’ve used Greg’s excellent library a lot without ever getting into the fine detail of this – I’m wondering why you actually need to?
My assumption is that you might be trying to change only one gear of a pair?
If you can change both gears, then you don’t need to worry much about the pitches – simply specify the distance between shafts and the gear ratio, and Greg’s library will take care of it all very nicely.
If you’re hoping to keep using one of the gears, you will need to much more deeply understand the pitches, or if your main motivation is to understand how Greg’s library is doing its job, please ignore this useless intervention!
Cheers,
Alex Gibson
admg consulting
edumaker limited
·        Project management
·        Operations & Process improvement
·        3D Printing
From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of nop head
Sent: 22 December 2018 13:52
Subject: Re: [OpenSCAD] Question about gear library
  circles=0);
Summary:
Thanks in advance,
Kevin T
Hi, I’ve used Greg’s excellent library a lot without ever getting into the fine detail of this – I’m wondering why you actually need to? My assumption is that you might be trying to change only one gear of a pair? If you can change both gears, then you don’t need to worry much about the pitches – simply specify the distance between shafts and the gear ratio, and Greg’s library will take care of it all very nicely. If you’re hoping to keep using one of the gears, you will need to much more deeply understand the pitches, or if your main motivation is to understand how Greg’s library is doing its job, please ignore this useless intervention! Cheers, Alex Gibson admg consulting edumaker limited · Project management · Operations & Process improvement · 3D Printing From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of nop head Sent: 22 December 2018 13:52 To: OpenSCAD general discussion Subject: Re: [OpenSCAD] Question about gear library I am not familiar with Greg's library but DP is not about circumference. It is the number of teeth per inch of its pitch diameter, an odd measure that doesn't really have a physical meaning because the teeth go around the circumference, not across the diameter. Also the pitch diameter is not the outside diameter, it is the diameter where the teeth mesh, sort of half way down the tooth. So you can mesh two gears if they have the same DP and you space them apart by half the sum of the pitch diameters. I have a vague memory that Greg's library has a bug in the way circular_pitch is used. On Sat, 22 Dec 2018 at 13:16, Kevin Toppenberg <kdtop3@gmail.com> wrote: I am trying to model a gear for an Atlas metal lathe. I have some original (real-life) gears, but want to print one with a different number of teeth. I have found this gear library by GregFrost: https://www.thingiverse.com/thing:3575/files I know that this list is not responsible for the library, but it seems to be a good one, and I am hoping someone here can help. My question is about the units of the input parameters. For example, in the file parametric_involute_gear_v5.0.scad there are some example gears. I modified one slightly as follows: gear (number_of_teeth=64, circular_pitch=285.0, circles=0); I chose the value for circular_pitch experimentally. First I put an Echo() statement in the gear_shape module such that it reports the minor diameter, pitch diameter, and major diameter (in mm). I then slowly modified the circular_pitch value until it matched the measurements of my actual real-life gear, taken with my micrometer. I am confused about what circular_pitch is supposed to represent. I reviewed standard gear terms from here: https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch Circular pitch should be the distance (in mm) from tooth to tooth. In my actual real-life gear, the value is about 5 mm. On a slightly different tact, I am also confused about gear terminology used for my lathe. The gears are typically described using inches and diametral pitch (which is supposed to be 1/circular_pitch). According to this site: https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ (which references here: http://www.lathes.co.uk/atlas/), Atlas gears use a 16DP, which I think means 16 diametral pitch or 16 teeth per inch. I'm not sure I believe this number, because my real-life gear with 20 teeth has a diameter of 1.475 inches, circumference of ~4.3 inches, and thus 20/4.3 = ~4.6 teeth/inch. Summary: 1. Can anyone help me understand the units for the circular_pitch parameter in the gear() module as described above? 2. Can anyone see the source of my confusion about the 16DP Thanks in advance, Kevin T _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
HJ
Hugo Jackson
Sat, Dec 22, 2018 3:51 PM
If you know the diametral pitch of a gear train you should be in pretty good shape as you can work backwards to determining the pitch diameter and other necessary dimensions.
As others have noted, diametral pitch is the distance between gear teeth, but this is not measured at the outer diameter of the gear but at a calculated point between the outer diameter of the gear teeth and the diameter of the base of the teeth, and this is know as the pitch circle or reference diameter.
pitchDiameter = numberOfTeeth / diametralPitch;
So if you want to calculate the pitch diameter for Greg’s routines you can just count the teeth on the gear you are trying to copy and plug that into the formula above. If Atlas gears do have a diametral pitch of 16 and you count the number of teeth accurately :) then you’re gonna end up with a gear the correct size.
If you want to check that against what you’ve measured as the outside diameter of your gear you can do the following, noting that the dimension between the pitchDiameter and the outside diameter is called the addendum
addendum = 1 / diametralPitch;
outsideDiameter = pitchDiameter + (2 * addendum);
Looking at the link you posted (https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ ) it mentions that atlas gears use a 14.5 degree pressure angle so in addition to the routine in Greg’s library you’re already calling you’ll want to include the pressure_angle parameter as well, as the default of 20 is not what you want., e.g.
//      circular_pitch=285.0, // call greg’s routine with the diametral pitch parameter.. not circular pitch
diametral_pitch = 16,
pressure_angle = 14.5,
   circles=0);
Hope this is helpful.
On Sat, 22 Dec 2018 at 13:16, Kevin Toppenberg <kdtop3@gmail.com mailto:kdtop3@gmail.com> wrote:
I have found this gear library by GregFrost:  https://www.thingiverse.com/thing:3575/files https://www.thingiverse.com/thing:3575/files
circles=0);
I am confused about what circular_pitch is supposed to represent.  I reviewed standard gear terms from here:  https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch
On a slightly different tact, I am also confused about gear terminology used for my lathe.  The gears are typically described using inches and diametral pitch (which is supposed to be 1/circular_pitch).  According to this site: https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ (which references here: http://www.lathes.co.uk/atlas/ http://www.lathes.co.uk/atlas/), Atlas gears use a 16DP, which I think means 16 diametral pitch or 16 teeth per inch.  I'm not sure I believe this number, because my real-life gear with 20 teeth has a diameter of 1.475 inches, circumference of ~4.3 inches, and thus 20/4.3 = ~4.6 teeth/inch.
Summary:
Thanks in advance,
Kevin T
If you know the diametral pitch of a gear train you should be in pretty good shape as you can work backwards to determining the pitch diameter and other necessary dimensions. As others have noted, diametral pitch is the distance between gear teeth, but this is not measured at the outer diameter of the gear but at a calculated point between the outer diameter of the gear teeth and the diameter of the base of the teeth, and this is know as the pitch circle or reference diameter. pitchDiameter = numberOfTeeth / diametralPitch; So if you want to calculate the pitch diameter for Greg’s routines you can just count the teeth on the gear you are trying to copy and plug that into the formula above. If Atlas gears do have a diametral pitch of 16 and you count the number of teeth accurately :) then you’re gonna end up with a gear the correct size. If you want to check that against what you’ve measured as the outside diameter of your gear you can do the following, noting that the dimension between the pitchDiameter and the outside diameter is called the addendum addendum = 1 / diametralPitch; outsideDiameter = pitchDiameter + (2 * addendum); Looking at the link you posted (https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ <https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/> ) it mentions that atlas gears use a 14.5 degree pressure angle so in addition to the routine in Greg’s library you’re already calling you’ll want to include the pressure_angle parameter as well, as the default of 20 is not what you want., e.g. > gear (number_of_teeth=64, // circular_pitch=285.0, // call greg’s routine with the diametral pitch parameter.. not circular pitch diametral_pitch = 16, pressure_angle = 14.5, > circles=0); Hope this is helpful. > On Dec 22, 2018, at 1:52 PM, nop head <nop.head@gmail.com> wrote: > > I am not familiar with Greg's library but DP is not about circumference. It is the number of teeth per inch of its pitch diameter, an odd measure that doesn't really have a physical meaning because the teeth go around the circumference, not across the diameter. > > Also the pitch diameter is not the outside diameter, it is the diameter where the teeth mesh, sort of half way down the tooth. So you can mesh two gears if they have the same DP and you space them apart by half the sum of the pitch diameters. > > I have a vague memory that Greg's library has a bug in the way circular_pitch is used. > > On Sat, 22 Dec 2018 at 13:16, Kevin Toppenberg <kdtop3@gmail.com <mailto:kdtop3@gmail.com>> wrote: > I am trying to model a gear for an Atlas metal lathe. I have some original (real-life) gears, but want to print one with a different number of teeth. > > I have found this gear library by GregFrost: https://www.thingiverse.com/thing:3575/files <https://www.thingiverse.com/thing:3575/files> > I know that this list is not responsible for the library, but it seems to be a good one, and I am hoping someone here can help. > > My question is about the units of the input parameters. For example, in the file parametric_involute_gear_v5.0.scad there are some example gears. I modified one slightly as follows: > > gear (number_of_teeth=64, > circular_pitch=285.0, > circles=0); > > I chose the value for circular_pitch experimentally. First I put an Echo() statement in the gear_shape module such that it reports the minor diameter, pitch diameter, and major diameter (in mm). I then slowly modified the circular_pitch value until it matched the measurements of my actual real-life gear, taken with my micrometer. > > I am confused about what circular_pitch is supposed to represent. I reviewed standard gear terms from here: https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch <https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch> > Circular pitch should be the distance (in mm) from tooth to tooth. In my actual real-life gear, the value is about 5 mm. > > On a slightly different tact, I am also confused about gear terminology used for my lathe. The gears are typically described using inches and diametral pitch (which is supposed to be 1/circular_pitch). According to this site: https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ <https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/> (which references here: http://www.lathes.co.uk/atlas/ <http://www.lathes.co.uk/atlas/>), Atlas gears use a 16DP, which I think means 16 diametral pitch or 16 teeth per inch. I'm not sure I believe this number, because my real-life gear with 20 teeth has a diameter of 1.475 inches, circumference of ~4.3 inches, and thus 20/4.3 = ~4.6 teeth/inch. > > Summary: > Can anyone help me understand the units for the circular_pitch parameter in the gear() module as described above? > Can anyone see the source of my confusion about the 16DP > > Thanks in advance, > Kevin T > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
MS
Mark Schafer
Sat, Dec 22, 2018 6:47 PM
Hi Kevin,
As others have pointed out Circular pitch means something slightly different and direct measurement is difficult (also pressure angle)..
I suggest looking at the links in this reference:
- https://github.com/jnweiger/inkscape-gears-dev
This plugin will draw gears in Inkscape ( a free OS vector drawing program).
This might help you to match the gear you have by direct comparison with a 2D drawing.
You can also export to openSCAD directly but this will only make simple gears with no 3D profiling but you can use it to learn about these parameters and make direct 2D comparisons. Then create gears that match in Greg's library.
Cheers, Mark...
circles=0);
Summary:
Thanks in advance,
Kevin T
<pre class="moz-quote-pre" wrap="">_______________________________________________
<a class="moz-txt-link-abbreviated" href="mailto:Discuss@lists.openscad.org">Discuss@lists.openscad.org</a>
<a class="moz-txt-link-freetext" href="http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org">http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org</a>
Sat, Dec 22, 2018 10:43 PM
Kevin,
having programmed, designed and printed a lot of gears and gear types, the
last I would recommend you is to use a 3D-printed gear in a metal lathe.
Even if you have a SLM printer at hand, the result won't be usable on the
long run in a production machine. You risk a lot when putting a minor
quality gear into such a device.
Gears used in lathes are usually of standard pitch und can be bought from
the manufacturer even for old machines. Did you do an Ebay search?
But to answer your question and to complete your information about gears. DP
is a kind of a crook to be able to measure gears somehow in inch. Using it
is somehow magic and not very intuitive.
The metric system is more clear. You have a modulus m and a number z of
theeth. With this your pitch diameter d=mz. The outer diameter of a gear is
usually od=d+addendum, with addendum < 2
m.
So, starting with addendum = 2*m, od=1.475 inches = 37.47 mm and z=20 will
give you a modulus of 1.70xx, which is uncommon. A common module is m=1.75.
Why? because you can buy cutting tools for this module, and many lathes use
it. This will result in a pitch diameter of 35mm or 1.378 inch. Further you
must know the pressure angle w, which you can't measure. 20° is normal, but
there are other systems. Maybe it its 14.5°, as was mentioned before. And
last but not least many gears have a profile shift to further adapt the
pitch diameter.
If you want to check all this with your given gear set, you can see my post:
https://www.thingiverse.com/thing:636119 and download my library gears.scad.
It will prompt you the pitch and the outer diameter and some other useful
information to the console. However it uses millimeters. It also provides a
help function. This is your gear:
use<gears.scad>
help(); // see what the lib contains and the prototypes of the modules
gear(m=1.75, z=20, w=14.5);
and your new gear will simply be:
gear(m=1.75, z=64, w=14.5);
Kevin, having programmed, designed and printed a lot of gears and gear types, the last I would recommend you is to use a 3D-printed gear in a metal lathe. Even if you have a SLM printer at hand, the result won't be usable on the long run in a production machine. You risk a lot when putting a minor quality gear into such a device. Gears used in lathes are usually of standard pitch und can be bought from the manufacturer even for old machines. Did you do an Ebay search? But to answer your question and to complete your information about gears. DP is a kind of a crook to be able to measure gears somehow in inch. Using it is somehow magic and not very intuitive. The metric system is more clear. You have a modulus m and a number z of theeth. With this your pitch diameter d=m*z. The outer diameter of a gear is usually od=d+addendum, with addendum < 2*m. So, starting with addendum = 2*m, od=1.475 inches = 37.47 mm and z=20 will give you a modulus of 1.70xx, which is uncommon. A common module is m=1.75. Why? because you can buy cutting tools for this module, and many lathes use it. This will result in a pitch diameter of 35mm or 1.378 inch. Further you must know the pressure angle w, which you can't measure. 20° is normal, but there are other systems. Maybe it its 14.5°, as was mentioned before. And last but not least many gears have a profile shift to further adapt the pitch diameter. If you want to check all this with your given gear set, you can see my post: https://www.thingiverse.com/thing:636119 and download my library gears.scad. It will prompt you the pitch and the outer diameter and some other useful information to the console. However it uses millimeters. It also provides a help function. This is your gear: use<gears.scad> help(); // see what the lib contains and the prototypes of the modules gear(m=1.75, z=20, w=14.5); and your new gear will simply be: gear(m=1.75, z=64, w=14.5); -- Sent from: http://forum.openscad.org/
KT
Kevin Toppenberg
Sun, Dec 23, 2018 12:41 AM
Nop head,
Thank you for your reply.  The reason I was talking about circumference is
because I was calculating the actual number of teeth per inch on my actual
gear.  To calculate that, I had to know the distance along the surface to
divide the 20 teeth between.  That involves the circumference.
I'll keep my eyes out for a bug in the library.
Thanks.
of teeth.
circles=0);
this site:
~4.6 teeth/inch.
Summary:
Thanks in advance,
Kevin T
Nop head, Thank you for your reply. The reason I was talking about circumference is because I was calculating the actual number of teeth per inch on my actual gear. To calculate that, I had to know the distance along the surface to divide the 20 teeth between. That involves the circumference. I'll keep my eyes out for a bug in the library. Thanks. On Sat, Dec 22, 2018 at 8:53 AM nop head <nop.head@gmail.com> wrote: > I am not familiar with Greg's library but DP is not about circumference. > It is the number of teeth per inch of its pitch diameter, an odd measure > that doesn't really have a physical meaning because the teeth go around the > circumference, not across the diameter. > > Also the pitch diameter is not the outside diameter, it is the diameter > where the teeth mesh, sort of half way down the tooth. So you can mesh two > gears if they have the same DP and you space them apart by half the sum of > the pitch diameters. > > I have a vague memory that Greg's library has a bug in the way > circular_pitch is used. > > On Sat, 22 Dec 2018 at 13:16, Kevin Toppenberg <kdtop3@gmail.com> wrote: > >> I am trying to model a gear for an Atlas metal lathe. I have some >> original (real-life) gears, but want to print one with a different number >> of teeth. >> >> I have found this gear library by GregFrost: >> https://www.thingiverse.com/thing:3575/files >> I know that this list is not responsible for the library, but it seems to >> be a good one, and I am hoping someone here can help. >> >> My question is about the units of the input parameters. For example, in >> the file parametric_involute_gear_v5.0.scad there are some example gears. >> I modified one slightly as follows: >> >> gear (number_of_teeth=64, >> circular_pitch=285.0, >> circles=0); >> >> I chose the value for circular_pitch experimentally. First I put an >> Echo() statement in the gear_shape module such that it reports the minor >> diameter, pitch diameter, and major diameter (in mm). I then slowly >> modified the circular_pitch value until it matched the measurements of my >> actual real-life gear, taken with my micrometer. >> >> I am confused about what circular_pitch is supposed to represent. I >> reviewed standard gear terms from here: >> https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch >> Circular pitch should be the distance (in mm) from tooth to tooth. In my >> actual real-life gear, the value is about 5 mm. >> >> On a slightly different tact, I am also confused about gear terminology >> used for my lathe. The gears are typically described using inches and >> diametral pitch (which is supposed to be 1/circular_pitch). According to >> this site: >> https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ >> (which references here: http://www.lathes.co.uk/atlas/), Atlas gears use >> a 16DP, which I think means 16 diametral pitch or 16 teeth per inch. I'm >> not sure I believe this number, because my real-life gear with 20 teeth has >> a diameter of 1.475 inches, circumference of ~4.3 inches, and thus 20/4.3 = >> ~4.6 teeth/inch. >> >> Summary: >> >> 1. Can anyone help me understand the units for the circular_pitch >> parameter in the gear() module as described above? >> 2. Can anyone see the source of my confusion about the 16DP >> >> >> Thanks in advance, >> Kevin T >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
KT
Kevin Toppenberg
Sun, Dec 23, 2018 12:42 AM
Alex,
Yes, I am trying to add a gear into an existing gear train.  So I have to
exactly match the pitch of the others.
Thanks!
Kevin
pair?
intervention!
Cheers,
Alex Gibson
admg consulting
edumaker limited
·        3D Printing
*nop head
of teeth.
   circles=0);
this site:
~4.6 teeth/inch.
Summary:
Thanks in advance,
Kevin T
Alex, Yes, I am trying to add a gear into an existing gear train. So I have to exactly match the pitch of the others. Thanks! Kevin On Sat, Dec 22, 2018 at 9:36 AM Alex Gibson <alex@alexgibson.net> wrote: > Hi, I’ve used Greg’s excellent library a lot without ever getting into the > fine detail of this – I’m wondering why you actually need to? > > > > My assumption is that you might be trying to change only one gear of a > pair? > > > > If you can change both gears, then you don’t need to worry much about the > pitches – simply specify the distance between shafts and the gear ratio, > and Greg’s library will take care of it all very nicely. > > > > If you’re hoping to keep using one of the gears, you will need to much > more deeply understand the pitches, or if your main motivation is to > understand how Greg’s library is doing its job, please ignore this useless > intervention! > > > > Cheers, > > > > Alex Gibson > > > > admg consulting > > > > edumaker limited > > > > · Project management > > · Operations & Process improvement > > · 3D Printing > > > > *From:* Discuss [mailto:discuss-bounces@lists.openscad.org] *On Behalf Of > *nop head > *Sent:* 22 December 2018 13:52 > *To:* OpenSCAD general discussion > *Subject:* Re: [OpenSCAD] Question about gear library > > > > I am not familiar with Greg's library but DP is not about circumference. > It is the number of teeth per inch of its pitch diameter, an odd measure > that doesn't really have a physical meaning because the teeth go around the > circumference, not across the diameter. > > > > Also the pitch diameter is not the outside diameter, it is the diameter > where the teeth mesh, sort of half way down the tooth. So you can mesh two > gears if they have the same DP and you space them apart by half the sum of > the pitch diameters. > > > > I have a vague memory that Greg's library has a bug in the way > circular_pitch is used. > > > > On Sat, 22 Dec 2018 at 13:16, Kevin Toppenberg <kdtop3@gmail.com> wrote: > > I am trying to model a gear for an Atlas metal lathe. I have some > original (real-life) gears, but want to print one with a different number > of teeth. > > > > I have found this gear library by GregFrost: > https://www.thingiverse.com/thing:3575/files > > I know that this list is not responsible for the library, but it seems to > be a good one, and I am hoping someone here can help. > > > > My question is about the units of the input parameters. For example, in > the file parametric_involute_gear_v5.0.scad there are some example gears. > I modified one slightly as follows: > > > > gear (number_of_teeth=64, > > circular_pitch=285.0, > > circles=0); > > > > I chose the value for circular_pitch experimentally. First I put an > Echo() statement in the gear_shape module such that it reports the minor > diameter, pitch diameter, and major diameter (in mm). I then slowly > modified the circular_pitch value until it matched the measurements of my > actual real-life gear, taken with my micrometer. > > > > I am confused about what circular_pitch is supposed to represent. I > reviewed standard gear terms from here: > https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch > > Circular pitch should be the distance (in mm) from tooth to tooth. In my > actual real-life gear, the value is about 5 mm. > > > > On a slightly different tact, I am also confused about gear terminology > used for my lathe. The gears are typically described using inches and > diametral pitch (which is supposed to be 1/circular_pitch). According to > this site: > https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ > (which references here: http://www.lathes.co.uk/atlas/), Atlas gears use > a 16DP, which I think means 16 diametral pitch or 16 teeth per inch. I'm > not sure I believe this number, because my real-life gear with 20 teeth has > a diameter of 1.475 inches, circumference of ~4.3 inches, and thus 20/4.3 = > ~4.6 teeth/inch. > > > > Summary: > > 1. Can anyone help me understand the units for the circular_pitch > parameter in the gear() module as described above? > 2. Can anyone see the source of my confusion about the 16DP > > > Thanks in advance, > > Kevin T > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
KT
Kevin Toppenberg
Sun, Dec 23, 2018 1:13 AM
Hugo,
Thank you for this helpful reply.  See comments below
I think your definition is not quite right.  The units for diametral pitch
are teeth/distance, not distance/tooth.  But I get what you mean.
reference diameter.
This formula helped me quite a bit.  I think I might have been conflating
the two different terms: diametral pitch and pitch diameter.  But I see now
that they are clearly different.
So this worked:
pitch_diameter (inches) = 20 teeth / 16 teeth/inch  = 1.25 inches  <---
matches my actual gear.
So the gear() module accepts either circular_pitch OR diametral_pitch as
inputs.  In a bit of a gotcha, however, the units for the diametral_pitch
module have to be in mm, not inches -- even though diametral pitch is
typically only makes sense in inches.  E.g. 16 teeth/inch makes sense to
talk about.  The equivalent value, 0.63 teeth/mm seems crazy.
So I mentioned before that I carefully adjusted the circular_pitch until I
got values that matched my real gear.  Well, I then made another gear
using the diametral_pitch, and they exactly matched.  Hurrah!
I STILL would like to know the units for the circular_pitch Greg is using.
Wikipedia (
https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch)
says circular pitch is the inverse of diametral_pitch, e.g.
circular_pitch = 1/ diametral_pitch.
But in the gear() module, this conversion is made
circular_pitch = 180/diametral_pitch.  <--- what's that 180??
   circles=0);
This was very helpful. I put in the correct pressure_angle and it now looks
just like my actual gear.
Thanks so much!!
Kevin
of teeth.
circles=0);
this site:
~4.6 teeth/inch.
Summary:
Thanks in advance,
Kevin T
Hugo, Thank you for this helpful reply. See comments below On Sat, Dec 22, 2018 at 10:52 AM Hugo Jackson <hugo@apres.net> wrote: > If you know the diametral pitch of a gear train you should be in pretty > good shape as you can work backwards to determining the pitch diameter and > other necessary dimensions. > As others have noted, diametral pitch is the distance between gear teeth, > I think your definition is not quite right. The units for diametral pitch are teeth/distance, not distance/tooth. But I get what you mean. > but this is not measured at the outer diameter of the gear but at a > calculated point between the outer diameter of the gear teeth and the > diameter of the base of the teeth, and this is know as the pitch circle or > reference diameter. > > pitchDiameter = numberOfTeeth / diametralPitch; > This formula helped me quite a bit. I think I might have been conflating the two different terms: diametral pitch and pitch diameter. But I see now that they are clearly different. > So if you want to calculate the pitch diameter for Greg’s routines you can > just count the teeth on the gear you are trying to copy and plug that into > the formula above. If Atlas gears do have a diametral pitch of 16 and you > count the number of teeth accurately :) then you’re gonna end up with a > gear the correct size. > So this worked: pitch_diameter (inches) = 20 teeth / 16 teeth/inch = 1.25 inches <--- matches my actual gear. So the gear() module accepts either circular_pitch OR diametral_pitch as inputs. In a bit of a gotcha, however, the units for the diametral_pitch module have to be in *mm*, not inches -- even though diametral pitch is typically only makes sense in inches. E.g. 16 teeth/inch makes sense to talk about. The equivalent value, 0.63 teeth/mm seems crazy. So I mentioned before that I carefully adjusted the circular_pitch until I got values that matched my real gear. Well, I then made another gear using the diametral_pitch, and they exactly matched. Hurrah! I STILL would like to know the units for the circular_pitch Greg is using. Wikipedia ( https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch) says circular pitch is the inverse of diametral_pitch, e.g. circular_pitch = 1/ diametral_pitch. But in the gear() module, this conversion is made circular_pitch = 180/diametral_pitch. <--- what's that 180?? > If you want to check that against what you’ve measured as the outside > diameter of your gear you can do the following, noting that the dimension > between the pitchDiameter and the outside diameter is called the addendum > > addendum = 1 / diametralPitch; > > outsideDiameter = pitchDiameter + (2 * addendum); > > Looking at the link you posted ( > https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ ) > it mentions that atlas gears use a 14.5 degree pressure angle so in > addition to the routine in Greg’s library you’re already calling you’ll > want to include the pressure_angle parameter as well, as the default of 20 > is not what you want., e.g. > > gear (number_of_teeth=64, >> > // circular_pitch=285.0, // call greg’s routine with the diametral > pitch parameter.. not circular pitch > diametral_pitch = 16, > pressure_angle = 14.5, > > circles=0); >> > >> > Hope this is helpful. > This was very helpful. I put in the correct pressure_angle and it now looks just like my actual gear. Thanks so much!! Kevin > > > > On Dec 22, 2018, at 1:52 PM, nop head <nop.head@gmail.com> wrote: > > I am not familiar with Greg's library but DP is not about circumference. > It is the number of teeth per inch of its pitch diameter, an odd measure > that doesn't really have a physical meaning because the teeth go around the > circumference, not across the diameter. > > Also the pitch diameter is not the outside diameter, it is the diameter > where the teeth mesh, sort of half way down the tooth. So you can mesh two > gears if they have the same DP and you space them apart by half the sum of > the pitch diameters. > > I have a vague memory that Greg's library has a bug in the way > circular_pitch is used. > > On Sat, 22 Dec 2018 at 13:16, Kevin Toppenberg <kdtop3@gmail.com> wrote: > >> I am trying to model a gear for an Atlas metal lathe. I have some >> original (real-life) gears, but want to print one with a different number >> of teeth. >> >> I have found this gear library by GregFrost: >> https://www.thingiverse.com/thing:3575/files >> I know that this list is not responsible for the library, but it seems to >> be a good one, and I am hoping someone here can help. >> >> My question is about the units of the input parameters. For example, in >> the file parametric_involute_gear_v5.0.scad there are some example gears. >> I modified one slightly as follows: >> >> gear (number_of_teeth=64, >> circular_pitch=285.0, >> circles=0); >> >> I chose the value for circular_pitch experimentally. First I put an >> Echo() statement in the gear_shape module such that it reports the minor >> diameter, pitch diameter, and major diameter (in mm). I then slowly >> modified the circular_pitch value until it matched the measurements of my >> actual real-life gear, taken with my micrometer. >> >> I am confused about what circular_pitch is supposed to represent. I >> reviewed standard gear terms from here: >> https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch >> Circular pitch should be the distance (in mm) from tooth to tooth. In my >> actual real-life gear, the value is about 5 mm. >> >> On a slightly different tact, I am also confused about gear terminology >> used for my lathe. The gears are typically described using inches and >> diametral pitch (which is supposed to be 1/circular_pitch). According to >> this site: >> https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/ >> (which references here: http://www.lathes.co.uk/atlas/), Atlas gears use >> a 16DP, which I think means 16 diametral pitch or 16 teeth per inch. I'm >> not sure I believe this number, because my real-life gear with 20 teeth has >> a diameter of 1.475 inches, circumference of ~4.3 inches, and thus 20/4.3 = >> ~4.6 teeth/inch. >> >> Summary: >> >> 1. Can anyone help me understand the units for the circular_pitch >> parameter in the gear() module as described above? >> 2. Can anyone see the source of my confusion about the 16DP >> >> >> Thanks in advance, >> Kevin T >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
KT
Kevin Toppenberg
Sun, Dec 23, 2018 1:24 AM
Parkinbot,
Thanks for the replay.  See comments below.
On Sat, Dec 22, 2018 at 5:44 PM Parkinbot rudolf@digitaldocument.de wrote:
Kevin,
There are different types of gears used on metal lathes.  You are probably
thinking about gears that are directly connected to the motor and turn the
spindle.  That is not what I am doing.  Instead, lathes have a secondary
drive rod that moves the carriage along slowly, and these can be plastic.
In fact many of the smaller bench-top lathes use plastic gears for this.
The gears are combined in various combinations to get the drive gear to
move at different speeds compared to the spindle, and this allows creating
threads when making screws etc.  These are called "change gears."  There
is a great Youtube creator named TubalCain (https://youtu.be/V6Aq0d1070I)
that did a great video on this topic showing that the plastic change gears
work fine.  Furthermore, I have printed out a set already (
https://www.thingiverse.com/thing:143893) and they seem to be working OK.
But I just need a size not provided there.
I have looked on Ebay for the gear sets, but they are typically expensive,
i.e. about $150 for a set.  Also, I want to make a larger gear than is
usually provided, so that I can slow down my carriage travel even slower.
That gives a better surface finish.
DP
Yes, I agree that the metric system is better.  Ten thousand times better.
But I have to work with the information I have.  And the gear
specifications for this lathe use the imperial system.  :-(
is
m.
pitch diameter.
post:
gears.scad.
use<gears.scad>
This library looks great.  I'll check it out.
Thanks so much for your help.
Kevin T
Parkinbot, Thanks for the replay. See comments below. On Sat, Dec 22, 2018 at 5:44 PM Parkinbot <rudolf@digitaldocument.de> wrote: > Kevin, > > having programmed, designed and printed a lot of gears and gear types, the > last I would recommend you is to use a 3D-printed gear in a metal lathe. > Even if you have a SLM printer at hand, the result won't be usable on the > long run in a production machine. You risk a lot when putting a minor > quality gear into such a device. > Gears used in lathes are usually of standard pitch und can be bought from > the manufacturer even for old machines. Did you do an Ebay search? > There are different types of gears used on metal lathes. You are probably thinking about gears that are directly connected to the motor and turn the spindle. That is not what I am doing. Instead, lathes have a secondary drive rod that moves the carriage along slowly, and these can be plastic. In fact many of the smaller bench-top lathes use plastic gears for this. The gears are combined in various combinations to get the drive gear to move at different speeds compared to the spindle, and this allows creating threads when making screws etc. These are called "change gears." There is a great Youtube creator named TubalCain (https://youtu.be/V6Aq0d1070I) that did a great video on this topic showing that the plastic change gears work fine. Furthermore, I have printed out a set already ( https://www.thingiverse.com/thing:143893) and they seem to be working OK. But I just need a size not provided there. I have looked on Ebay for the gear sets, but they are typically expensive, i.e. about $150 for a set. Also, I want to make a larger gear than is usually provided, so that I can slow down my carriage travel even slower. That gives a better surface finish. > > But to answer your question and to complete your information about gears. > DP > is a kind of a crook to be able to measure gears somehow in inch. Using it > is somehow magic and not very intuitive. > > The metric system is more clear. Yes, I agree that the metric system is better. Ten thousand times better. But I have to work with the information I have. And the gear specifications for this lathe use the imperial system. :-( > You have a modulus m and a number z of > theeth. With this your pitch diameter d=m*z. The outer diameter of a gear > is > usually od=d+addendum, with addendum < 2*m. > > So, starting with addendum = 2*m, od=1.475 inches = 37.47 mm and z=20 will > give you a modulus of 1.70xx, which is uncommon. A common module is m=1.75. > Why? because you can buy cutting tools for this module, and many lathes use > it. This will result in a pitch diameter of 35mm or 1.378 inch. Further you > must know the pressure angle w, which you can't measure. 20° is normal, but > there are other systems. Maybe it its 14.5°, as was mentioned before. And > last but not least many gears have a profile shift to further adapt the > pitch diameter. > > If you want to check all this with your given gear set, you can see my > post: > https://www.thingiverse.com/thing:636119 and download my library > gears.scad. > It will prompt you the pitch and the outer diameter and some other useful > information to the console. However it uses millimeters. It also provides a > help function. This is your gear: > > use<gears.scad> > help(); // see what the lib contains and the prototypes of the modules > gear(m=1.75, z=20, w=14.5); > > and your new gear will simply be: > > gear(m=1.75, z=64, w=14.5); > > > This library looks great. I'll check it out. Thanks so much for your help. Kevin T > > > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
