Mark,
Thanks for the reply. As per the other posts, I think I will be able to do
this all in OpenSCAD, and not have to use multiple applications. But it is
good to know of those resources.
Thanks!
Kevin
On Sat, Dec 22, 2018 at 1:48 PM Mark Schafer mschafer@wireframe.biz wrote:
Hi Kevin,
As others have pointed out Circular pitch means something slightly
different and direct measurement is difficult (also pressure angle)..
I suggest looking at the links in this reference:
This plugin will draw gears in Inkscape ( a free OS vector drawing
program).
This might help you to match the gear you have by direct comparison with a
2D drawing.
You can also export to openSCAD directly but this will only make simple
gears with no 3D profiling but you can use it to learn about these
parameters and make direct 2D comparisons. Then create gears that match in
Greg's library.
Cheers, Mark...
On 12/23/2018 2:14 AM, Kevin Toppenberg wrote:
I am trying to model a gear for an Atlas metal lathe. I have some
original (real-life) gears, but want to print one with a different number
of teeth.
I have found this gear library by GregFrost:
https://www.thingiverse.com/thing:3575/files
I know that this list is not responsible for the library, but it seems to
be a good one, and I am hoping someone here can help.
My question is about the units of the input parameters. For example, in
the file parametric_involute_gear_v5.0.scad there are some example gears.
I modified one slightly as follows:
gear (number_of_teeth=64,
circular_pitch=285.0,
circles=0);
I chose the value for circular_pitch experimentally. First I put an
Echo() statement in the gear_shape module such that it reports the minor
diameter, pitch diameter, and major diameter (in mm). I then slowly
modified the circular_pitch value until it matched the measurements of my
actual real-life gear, taken with my micrometer.
I am confused about what circular_pitch is supposed to represent. I
reviewed standard gear terms from here:
https://en.wikipedia.org/wiki/List_of_gear_nomenclature#Circular_Pitch
Circular pitch should be the distance (in mm) from tooth to tooth. In my
actual real-life gear, the value is about 5 mm.
On a slightly different tact, I am also confused about gear terminology
used for my lathe. The gears are typically described using inches and
diametral pitch (which is supposed to be 1/circular_pitch). According to
this site:
https://www.practicalmachinist.com/vb/general/need-atlas-lathe-gear-208658/
(which references here: http://www.lathes.co.uk/atlas/), Atlas gears use
a 16DP, which I think means 16 diametral pitch or 16 teeth per inch. I'm
not sure I believe this number, because my real-life gear with 20 teeth has
a diameter of 1.475 inches, circumference of ~4.3 inches, and thus 20/4.3 =
~4.6 teeth/inch.
Summary:
1. Can anyone help me understand the units for the circular_pitch
parameter in the gear() module as described above?
2. Can anyone see the source of my confusion about the 16DP
Thanks in advance,
Kevin T
kdtop wrote
Instead, lathes have a secondary
drive rod that moves the carriage along slowly, and these can be plastic.
In fact many of the smaller bench-top lathes use plastic gears for this.
I have a metal lathe on my own and know exactly what you want ... and what
forces are involved. However, plastic gears and 3D printed gears are not the
same. At least you should use PETG or Nylon. ABS and PLA will not do the job
(for long) as a 1.75 module is not very strong. You can't use normal grease
lube for plastic gears. Rather use silicone grease.
But try, and have fun.
Parkinbot,
Fingers crossed that they don't break soon! I have nylon (Taulman 680, I
think) and can print them in that if they do.
Thanks again
Kevin
job
