Special Variables
W
whburling
Sun, Nov 15, 2015 1:54 AM
i copied and pasted code to reveal my experience from which I shared
interpretations within the code.  the code is a "reply" located at your
original request for code.
View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14496.html
i copied and pasted code to reveal my experience from which I shared interpretations within the code. the code is a "reply" located at your original request for code. -- View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14496.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Nov 15, 2015 11:04 AM
You need to understand the concepts of lexical scope and dynamic scope. To
get something that is global you need to define it at the top level scope.
I.e. file level, outside of any functions, modules. If you assign to it
again at in the same scope it will use the last value assigned everywhere.
If you assign to it in a deeper scope it will simply define a new constant
that hides the original.
A normal variable defined at file scope is visible everywhere later in that
file, but not in modules and functions in other files, called from that
file. They have lexical scope meaning you can see where they are visible
simply by looking at the static program structure. Each module, function
and block enclosed by braces is a new scope. Inside that scope you can
access names defined in scopes that enclose it.
The only difference with $ prefixed  names is they have dynamic scope
meaning they are visible not only in the lexical scope they are defined in
but also in any modules or functions called from that scope, even if they
are in different files. But again if you define a new one in a deeper scope
it hides the original. It doesn't reassign the original. And constants
defined in a deeper scope disappear when that scope ends. They never leak
from an inner scope to an outer one.
You need to understand the concepts of lexical scope and dynamic scope. To get something that is global you need to define it at the top level scope. I.e. file level, outside of any functions, modules. If you assign to it again at in the same scope it will use the last value assigned everywhere. If you assign to it in a deeper scope it will simply define a new constant that hides the original. A normal variable defined at file scope is visible everywhere later in that file, but not in modules and functions in other files, called from that file. They have lexical scope meaning you can see where they are visible simply by looking at the static program structure. Each module, function and block enclosed by braces is a new scope. Inside that scope you can access names defined in scopes that enclose it. The only difference with $ prefixed names is they have dynamic scope meaning they are visible not only in the lexical scope they are defined in but also in any modules or functions called from that scope, even if they are in different files. But again if you define a new one in a deeper scope it hides the original. It doesn't reassign the original. And constants defined in a deeper scope disappear when that scope ends. They never leak from an inner scope to an outer one. On Nov 15, 2015 1:54 AM, "whburling" <whburling@outlook.com> wrote: > i copied and pasted code to reveal my experience from which I shared > interpretations within the code. the code is a "reply" located at your > original request for code. > > > > -- > View this message in context: > http://forum.openscad.org/Special-Variables-tp14477p14496.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
LB
L Boyd
Sun, Nov 15, 2015 3:45 PM
Perhaps this example will help
External file Global Test.scad
module Test1(){
  cube(4);
    echo(" in Test1  x1 = ",x1);
    echo(" in Test1 $y1 = ",$y1);
module Test2(){
  sphere(3);
    echo(" in Test2  x2 = ",x2);
    echo(" in Test2 $y2 = ",$y2);
x1 = 3;
$y1 = 5;
Local file
use<Global Test.scad>;
Test1();
Test2();
Test3();
x1 = 10;
$y1 = 15;
x2 = 20;
$y2 = 27;
x3 = 30;
$y3 = 33;
module Test3(){
  cylinder(10);
    echo(" in Test3  x3 = ",x3);
    echo(" in Test3 $y3 = ",$y3);
Result
ECHO: " in Test1  x1 = ", 3      // Values from Global Test.scad, no
override
ECHO: " in Test1 $y1 = ", 5
ECHO: " in Test2  x2 = ", undef
ECHO: " in Test2 $y2 = ", 27    // local value used in external module
ECHO: " in Test3  x3 = ", 30    // local values used in local moduel
ECHO: " in Test3 $y3 = ", 33
View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14512.html
Perhaps this example will help External file Global Test.scad module Test1(){ cube(4); echo(" in Test1 x1 = ",x1); echo(" in Test1 $y1 = ",$y1); } module Test2(){ sphere(3); echo(" in Test2 x2 = ",x2); echo(" in Test2 $y2 = ",$y2); } x1 = 3; $y1 = 5; Local file use<Global Test.scad>; Test1(); Test2(); Test3(); x1 = 10; $y1 = 15; x2 = 20; $y2 = 27; x3 = 30; $y3 = 33; module Test3(){ cylinder(10); echo(" in Test3 x3 = ",x3); echo(" in Test3 $y3 = ",$y3); } Result ECHO: " in Test1 x1 = ", 3 // Values from Global Test.scad, no override ECHO: " in Test1 $y1 = ", 5 ECHO: " in Test2 x2 = ", undef ECHO: " in Test2 $y2 = ", 27 // local value used in external module ECHO: " in Test3 x3 = ", 30 // local values used in local moduel ECHO: " in Test3 $y3 = ", 33 -- View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14512.html Sent from the OpenSCAD mailing list archive at Nabble.com.
LB
L Boyd
Sun, Nov 15, 2015 6:26 PM
if you replace use<Global Test.scad>; with include<Global Test.scad>; the
results are slightly different.
ECHO: " in Test1  x1 = ", 10
ECHO: " in Test1 $y1 = ", 15
ECHO: " in Test2  x2 = ", 20
Everyone uses the local values, since the included file contents are now
treated as part of the local file.
View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14517.html
if you replace use<Global Test.scad>; with include<Global Test.scad>; the results are slightly different. ECHO: " in Test1 x1 = ", 10 ECHO: " in Test1 $y1 = ", 15 ECHO: " in Test2 x2 = ", 20 ECHO: " in Test2 $y2 = ", 27 ECHO: " in Test3 x3 = ", 30 ECHO: " in Test3 $y3 = ", 33 Everyone uses the local values, since the included file contents are now treated as part of the local file. -- View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14517.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Nov 15, 2015 7:24 PM
The real problem with 'use' is that it doesn't import variable definitions,
only function and module definitions.
The real problem with 'use' is that it doesn't import variable definitions, only function and module definitions. On 15 November 2015 at 13:26, L Boyd <lboyd@frontiernet.net> wrote: > if you replace use<Global Test.scad>; with include<Global Test.scad>; the > results are slightly different. > > ECHO: " in Test1 x1 = ", 10 > ECHO: " in Test1 $y1 = ", 15 > ECHO: " in Test2 x2 = ", 20 > ECHO: " in Test2 $y2 = ", 27 > ECHO: " in Test3 x3 = ", 30 > ECHO: " in Test3 $y3 = ", 33 > > Everyone uses the local values, since the included file contents are now > treated as part of the local file. > > > > -- > View this message in context: > http://forum.openscad.org/Special-Variables-tp14477p14517.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
Sun, Nov 15, 2015 10:38 PM
That is a pro, not a con. Better encapsulation.
That is a pro, not a con. Better encapsulation. On Nov 15, 2015 7:25 PM, "doug moen" <doug@moens.org> wrote: > The real problem with 'use' is that it doesn't import variable > definitions, only function and module definitions. > > On 15 November 2015 at 13:26, L Boyd <lboyd@frontiernet.net> wrote: > >> if you replace use<Global Test.scad>; with include<Global Test.scad>; the >> results are slightly different. >> >> ECHO: " in Test1 x1 = ", 10 >> ECHO: " in Test1 $y1 = ", 15 >> ECHO: " in Test2 x2 = ", 20 >> ECHO: " in Test2 $y2 = ", 27 >> ECHO: " in Test3 x3 = ", 30 >> ECHO: " in Test3 $y3 = ", 33 >> >> Everyone uses the local values, since the included file contents are now >> treated as part of the local file. >> >> >> >> -- >> View this message in context: >> http://forum.openscad.org/Special-Variables-tp14477p14517.html >> Sent from the OpenSCAD mailing list archive at Nabble.com. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
AP
Andrew Plumb
Sun, Nov 15, 2015 11:18 PM
It's definitely a feature. I'm in the habit of coding my utility and library scad files to "self test" when rendered directly or via include, and "use" them across project and variant boundaries. If they depend on top-level variable values then they need rework to be more portable.
Anything that needs to be treated like a global reference or design value shareable across multiple projects, I code as a 0-argument function.
function pi() =3.141592;
It also allowed you do things like incorporate tolerances, design-for-manufacturing rules (min spacing, wall thickness, etc) as arguments to the function-definitions.
Andrew
Sent from myBrain
It's definitely a feature. I'm in the habit of coding my utility and library scad files to "self test" when rendered directly or via include, and "use" them across project and variant boundaries. If they depend on top-level variable values then they need rework to be more portable. Anything that needs to be treated like a global reference or design value shareable across multiple projects, I code as a 0-argument function. function pi() =3.141592; It also allowed you do things like incorporate tolerances, design-for-manufacturing rules (min spacing, wall thickness, etc) as arguments to the function-definitions. Andrew Sent from myBrain > On Nov 15, 2015, at 17:38, nop head <nop.head@gmail.com> wrote: > > That is a pro, not a con. Better encapsulation. > >> On Nov 15, 2015 7:25 PM, "doug moen" <doug@moens.org> wrote: >> The real problem with 'use' is that it doesn't import variable definitions, only function and module definitions. >> >>> On 15 November 2015 at 13:26, L Boyd <lboyd@frontiernet.net> wrote: >>> if you replace use<Global Test.scad>; with include<Global Test.scad>; the >>> results are slightly different. >>> >>> ECHO: " in Test1 x1 = ", 10 >>> ECHO: " in Test1 $y1 = ", 15 >>> ECHO: " in Test2 x2 = ", 20 >>> ECHO: " in Test2 $y2 = ", 27 >>> ECHO: " in Test3 x3 = ", 30 >>> ECHO: " in Test3 $y3 = ", 33 >>> >>> Everyone uses the local values, since the included file contents are now >>> treated as part of the local file. >>> >>> >>> >>> -- >>> View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14517.html >>> Sent from the OpenSCAD mailing list archive at Nabble.com. >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Sun, Nov 15, 2015 11:51 PM
I have difficulty understanding how the current design of 'use' is a "pro",
and I'm skeptical about the claim that it supports "better encapsulation".
If we really want to support better encapsulation in libraries, then we
should provide a way for libraries to control which functions, modules and
variables are exported, and which are private. I'd be happy with something
as simple as a naming convention: names beginning with _ or $ are private.
My current hatred of 'use' comes from my struggles to figure out how to use
the MCAD library. This is the standard library that ships with OpenSCAD.
From the README for MCAD, which is part of the OpenSCAD distro:
You can import these files in your scripts with `use
<MCAD/filename.scad>`,
where 'filename' is one of the files listed below like 'motors' or
'servos'.
This implies that the purpose of 'use' is for importing a library file, but
it's all a big lie.
In order to successfully use an MCAD library file, you must first read the
file, reverse engineer it, and determine whether the author intended it to
be referenced via 'use' or 'include'. Some library files work only with
'use', some work only with 'include'.
  • Some MCAD scripts export mathematical constants as part of their API.
    You must use include. Examples are math.scad and materials.scad.
  • Some MCAD scripts define mathematical constants that are used locally
    within their functions and modules. They won't work with use, you must
    use include. Examples are lego_compatibiity.scad, involute_gears.scad.
  • Some MCAD scripts have top level geometry as example code. They are
    designed to work with use. For example, trochoids.scad contains demo
    code with top level geometry and parameter definitions, including a
    definition of $fn. These parameter definitions are intended to be
    invisible when the script is used.
https://github.com/doug-moen/openscad2/blob/master/rfc/Library_Scripts.md#referencing-a-model-script
I have difficulty understanding how the current design of 'use' is a "pro", and I'm skeptical about the claim that it supports "better encapsulation". If we really want to support better encapsulation in libraries, then we should provide a way for libraries to control which functions, modules and variables are exported, and which are private. I'd be happy with something as simple as a naming convention: names beginning with _ or $ are private. My current hatred of 'use' comes from my struggles to figure out how to use the MCAD library. This is the standard library that ships with OpenSCAD. >From the README for MCAD, which is part of the OpenSCAD distro: You can import these files in your scripts with `use <MCAD/filename.scad>`, where 'filename' is one of the files listed below like 'motors' or 'servos'. This implies that the purpose of 'use' is for importing a library file, but it's all a big lie. In order to successfully use an MCAD library file, you must first read the file, reverse engineer it, and determine whether the author intended it to be referenced via 'use' or 'include'. Some library files work only with 'use', some work only with 'include'. - Some MCAD scripts export mathematical constants as part of their API. You must use include. Examples are math.scad and materials.scad. - Some MCAD scripts define mathematical constants that are used locally within their functions and modules. They won't work with use, you must use include. Examples are lego_compatibiity.scad, involute_gears.scad. - Some MCAD scripts have top level geometry as example code. They are designed to work with use. For example, trochoids.scad contains demo code with top level geometry and parameter definitions, including a definition of $fn. These parameter definitions are intended to be invisible when the script is used. <https://github.com/doug-moen/openscad2/blob/master/rfc/Library_Scripts.md#referencing-a-model-script> On 15 November 2015 at 17:38, nop head <nop.head@gmail.com> wrote: > That is a pro, not a con. Better encapsulation. > On Nov 15, 2015 7:25 PM, "doug moen" <doug@moens.org> wrote: > >> The real problem with 'use' is that it doesn't import variable >> definitions, only function and module definitions. >> >> On 15 November 2015 at 13:26, L Boyd <lboyd@frontiernet.net> wrote: >> >>> if you replace use<Global Test.scad>; with include<Global Test.scad>; the >>> results are slightly different. >>> >>> ECHO: " in Test1 x1 = ", 10 >>> ECHO: " in Test1 $y1 = ", 15 >>> ECHO: " in Test2 x2 = ", 20 >>> ECHO: " in Test2 $y2 = ", 27 >>> ECHO: " in Test3 x3 = ", 30 >>> ECHO: " in Test3 $y3 = ", 33 >>> >>> Everyone uses the local values, since the included file contents are now >>> treated as part of the local file. >>> >>> >>> >>> -- >>> View this message in context: >>> http://forum.openscad.org/Special-Variables-tp14477p14517.html >>> Sent from the OpenSCAD mailing list archive at Nabble.com. >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >>> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Mon, Nov 16, 2015 10:29 AM
I suspect library modules should be implemented as two files, one that you
include to get constants and one that you use to get functions and modules.
Note that even if you use a module you can still override constants in it
by passing them as extra parameters.
encapsulation".
OpenSCAD. From the README for MCAD, which is part of the OpenSCAD distro:
'servos'.
I suspect library modules should be implemented as two files, one that you include to get constants and one that you use to get functions and modules. Note that even if you use a module you can still override constants in it by passing them as extra parameters. On Nov 15, 2015 11:52 PM, "doug moen" <doug@moens.org> wrote: > I have difficulty understanding how the current design of 'use' is a > "pro", and I'm skeptical about the claim that it supports "better > encapsulation". > > If we really want to support better encapsulation in libraries, then we > should provide a way for libraries to control which functions, modules and > variables are exported, and which are private. I'd be happy with something > as simple as a naming convention: names beginning with _ or $ are private. > > My current hatred of 'use' comes from my struggles to figure out how to > use the MCAD library. This is the standard library that ships with > OpenSCAD. From the README for MCAD, which is part of the OpenSCAD distro: > > You can import these files in your scripts with `use > <MCAD/filename.scad>`, > where 'filename' is one of the files listed below like 'motors' or > 'servos'. > > This implies that the purpose of 'use' is for importing a library file, > but it's all a big lie. > > In order to successfully use an MCAD library file, you must first read the > file, reverse engineer it, and determine whether the author intended it to > be referenced via 'use' or 'include'. Some library files work only with > 'use', some work only with 'include'. > > > - Some MCAD scripts export mathematical constants as part of their > API. You must use include. Examples are math.scad and materials.scad. > - Some MCAD scripts define mathematical constants that are used > locally within their functions and modules. They won't work with use, > you must use include. Examples are lego_compatibiity.scad, > involute_gears.scad. > - Some MCAD scripts have top level geometry as example code. They are > designed to work with use. For example, trochoids.scad contains demo > code with top level geometry and parameter definitions, including a > definition of $fn. These parameter definitions are intended to be > invisible when the script is used. > > > <https://github.com/doug-moen/openscad2/blob/master/rfc/Library_Scripts.md#referencing-a-model-script> > > > On 15 November 2015 at 17:38, nop head <nop.head@gmail.com> wrote: > >> That is a pro, not a con. Better encapsulation. >> On Nov 15, 2015 7:25 PM, "doug moen" <doug@moens.org> wrote: >> >>> The real problem with 'use' is that it doesn't import variable >>> definitions, only function and module definitions. >>> >>> On 15 November 2015 at 13:26, L Boyd <lboyd@frontiernet.net> wrote: >>> >>>> if you replace use<Global Test.scad>; with include<Global Test.scad>; >>>> the >>>> results are slightly different. >>>> >>>> ECHO: " in Test1 x1 = ", 10 >>>> ECHO: " in Test1 $y1 = ", 15 >>>> ECHO: " in Test2 x2 = ", 20 >>>> ECHO: " in Test2 $y2 = ", 27 >>>> ECHO: " in Test3 x3 = ", 30 >>>> ECHO: " in Test3 $y3 = ", 33 >>>> >>>> Everyone uses the local values, since the included file contents are now >>>> treated as part of the local file. >>>> >>>> >>>> >>>> -- >>>> View this message in context: >>>> http://forum.openscad.org/Special-Variables-tp14477p14517.html >>>> Sent from the OpenSCAD mailing list archive at Nabble.com. >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>>> >>>> >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
LB
L Boyd
Mon, Nov 16, 2015 12:57 PM
Decided to test this using my example posted earlier.
part of Global Test.scad
module Test1(){
cube(4);
x1 = 3;
$y1 = 5;
Local file
Test1();
Test1(x1=19);
ECHO: " in Test1  x1 = ", 19
Test1(x1=192,$y1=157);
ECHO: " in Test1  x1 = ", 192
ECHO: " in Test1 $y1 = ", 157
Test1();                      // after all of the above
I was able to temporarily override the internal values of x1 and $y1 even
thought they did not appear as parameters in the definition of Test1()!
View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14538.html
nophead wrote > Note that even if you use a module you can still override constants in it > by passing them as extra parameters. Decided to test this using my example posted earlier. part of Global Test.scad module Test1(){ cube(4); echo(" in Test1 x1 = ",x1); echo(" in Test1 $y1 = ",$y1); } x1 = 3; $y1 = 5; Local file use<Global Test.scad>; Test1(); ECHO: " in Test1 x1 = ", 3 ECHO: " in Test1 $y1 = ", 5 Test1(x1=19); ECHO: " in Test1 x1 = ", 19 ECHO: " in Test1 $y1 = ", 5 Test1(x1=192,$y1=157); ECHO: " in Test1 x1 = ", 192 ECHO: " in Test1 $y1 = ", 157 Test1(); // after all of the above ECHO: " in Test1 x1 = ", 3 ECHO: " in Test1 $y1 = ", 5 I was able to temporarily override the internal values of x1 and $y1 even thought they did not appear as parameters in the definition of Test1()! -- View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14538.html Sent from the OpenSCAD mailing list archive at Nabble.com.
