Special Variables
W
whburling
Mon, Nov 16, 2015 4:59 PM
Thank you for replying. Very much appreciated.
So if I understand you…. Special variables do not have global scope.
If they did then when I created a special variable within a module, it would
not go out of scope when the module was left.
What I thought I heard you say was that if I created a special variable it
could be seen by all modules regardless of scope but that it could not be
changed. I thought I heard an implication that just being see by all made it
global.
To allow a special variable to be changed locally and not be visible outside
of the module where it is changed seems to be illogical (maybe I am not
logical), because it is supposed to be seen by all.
So, unfortunately, I am still grappling with what a special variable is
bil
[mailto:ml-node+s1091067n14491h37@n5.nabble.com]
Sent: Saturday, November 14, 2015 6:32 PM
To: whburling whburling@outlook.com
Subject: Re: Special Variables
To explain the original post. If you set a special variable at the file
scope it will be visible in every thing you call but if you try to assign to
it in a deeper scope you simply get a new one with the same name that hides
the original until it goes out of scope. Just the same as the normal lexical
scope variables in that respect.
On Nov 14, 2015 11:23 PM, "runsun" <[hidden email]> wrote:
copy and paste ?
$  Runsun Pan, PhD
$ libs: doctest , faces ( git ), offline doc ( git ),runscad.py( 1 , 2 , git
View this message in context:
http://forum.openscad.org/Special-Variables-tp14477p14489.html
[hidden email]
[hidden email]
below:
http://forum.openscad.org/Special-Variables-tp14477p14491.html
To unsubscribe from Special Variables, click here
<http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_cod
e&node=14477&code=d2hidXJsaW5nQG91dGxvb2suY29tfDE0NDc3fDU4Njc0MDk4NA==> .
<http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=in
stant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-
nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamesp
ace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21na
bble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> NAML
View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14544.html
Thank you for replying. Very much appreciated. So if I understand you…. Special variables do not have global scope. If they did then when I created a special variable within a module, it would not go out of scope when the module was left. What I thought I heard you say was that if I created a special variable it could be seen by all modules regardless of scope but that it could not be changed. I thought I heard an implication that just being see by all made it global. To allow a special variable to be changed locally and not be visible outside of the module where it is changed seems to be illogical (maybe I am not logical), because it is supposed to be seen by all. So, unfortunately, I am still grappling with what a special variable is bil From: nophead [via OpenSCAD] [mailto:ml-node+s1091067n14491h37@n5.nabble.com] Sent: Saturday, November 14, 2015 6:32 PM To: whburling <whburling@outlook.com> Subject: Re: Special Variables To explain the original post. If you set a special variable at the file scope it will be visible in every thing you call but if you try to assign to it in a deeper scope you simply get a new one with the same name that hides the original until it goes out of scope. Just the same as the normal lexical scope variables in that respect. On Nov 14, 2015 11:23 PM, "runsun" <[hidden email]> wrote: copy and paste ? ----- $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ),runscad.py( 1 , 2 , git );  $ tips: hash( 1 , 2 ), sweep , var , lerp , animGif -- View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14489.html Sent from the OpenSCAD mailing list archive at Nabble.com. _______________________________________________ OpenSCAD mailing list [hidden email] http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org _______________________________________________ OpenSCAD mailing list [hidden email] http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org _____ If you reply to this email, your message will be added to the discussion below: http://forum.openscad.org/Special-Variables-tp14477p14491.html To unsubscribe from Special Variables, click here <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_cod e&node=14477&code=d2hidXJsaW5nQG91dGxvb2suY29tfDE0NDc3fDU4Njc0MDk4NA==> . <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=in stant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace- nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamesp ace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21na bble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> NAML -- View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14544.html Sent from the OpenSCAD mailing list archive at Nabble.com.
W
whburling
Mon, Nov 16, 2015 5:31 PM
just discsovered your reply.  Let me digest it.  play with simple examples.
You were careful wtih your wording...and so i suspect i will be able to
recreate your views and thus appreciate what you are saying.
please be patient with me.
View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14547.html
just discsovered your reply. Let me digest it. play with simple examples. You were careful wtih your wording...and so i suspect i will be able to recreate your views and thus appreciate what you are saying. please be patient with me. -- View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14547.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Nov 16, 2015 8:19 PM
The only thing special about them is they have dynamic scope. If you place
them at the file level they do have a global effect. For example setting
$fn at the top of file affects all cylinders, except those that specify it
themselves or those in modules that set it locally. If you have it set to
1000 to get really smooth cylinders but you want some hexagonal prisms you
wouldn't expect setting it locally to six to make all your cylinders
hexagonal.
So special variables have the intended behavior appropriate to settings
like fn. Also if you created you own variable and called a library module
that by coincidence used a variable with the same name you wouldn't want
the surprise of it affecting your variable.
The only thing special about them is they have dynamic scope. If you place them at the file level they do have a global effect. For example setting $fn at the top of file affects all cylinders, except those that specify it themselves or those in modules that set it locally. If you have it set to 1000 to get really smooth cylinders but you want some hexagonal prisms you wouldn't expect setting it locally to six to make all your cylinders hexagonal. So special variables have the intended behavior appropriate to settings like fn. Also if you created you own variable and called a library module that by coincidence used a variable with the same name you wouldn't want the surprise of it affecting your variable.
LB
L Boyd
Mon, Nov 16, 2015 8:35 PM
Getting back to the original question, the poster was expecting special
variables to be an exception to the scope rules of regular variables. See
Variable scope
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General#Scope_of_variables
Variables defined in an outer scope are visible within inner scopes. They
can be given new values within the inner scope, but that new value does not
leak out to an outer scope. This is true for both regular and special
variables.
Regular variables are visible inside modules defined in, or included into,
the local file. They are not visible inside modules loaded with run.
Special variables are also visible inside modules loaded with run.
View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14574.html
Getting back to the original question, the poster was expecting special variables to be an exception to the scope rules of regular variables. See Variable scope <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/General#Scope_of_variables> . Variables defined in an outer scope are visible within inner scopes. They can be given new values within the inner scope, but that new value does not leak out to an outer scope. This is true for both regular and special variables. Regular variables are visible inside modules defined in, or included into, the local file. They are not visible inside modules loaded with run. Special variables are also visible inside modules loaded with run. -- View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14574.html Sent from the OpenSCAD mailing list archive at Nabble.com.
W
whburling
Tue, Nov 17, 2015 8:29 PM
ok.....after reading your comments and trying out code offered in this thread
and in writing my own code I came to conclude the following. If i have
incorrect understanding, please correct.
(1)  there are no variables in openSCAD
(2)  there are only constants.
(3)  constants have two scopes
(a) if standard constant, the constant value is local to a given
module or function
(b) if special constants, the value is observable by all called
modules and functions, regardless of  whether they were defined in the same
file as called or in some external file that was "included" or referenced
through "use"
(4)  the constants are defined at compile time.  there is no "dynamic"
aspect in that they can be redefined at run time.
(5) there is no way to extract data local to modules as they have no return
value and openSCAD does not have global values
(6) I am uncertain if functions can be written exactly as modules with the
ability to return a value unrelated to any passed parameter or any special
variable.  I am finding out that I do not understand how to "return" an
arbitrary value.
View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14601.html
ok.....after reading your comments and trying out code offered in this thread and in writing my own code I came to conclude the following. If i have incorrect understanding, please correct. (1) there are no variables in openSCAD (2) there are only constants. (3) constants have two scopes (a) if standard constant, the constant value is local to a given module or function (b) if special constants, the value is observable by all called modules and functions, regardless of whether they were defined in the same file as called or in some external file that was "included" or referenced through "use" (4) the constants are defined at compile time. there is no "dynamic" aspect in that they can be redefined at run time. (5) there is no way to extract data local to modules as they have no return value and openSCAD does not have global values (6) I am uncertain if functions can be written exactly as modules with the ability to return a value unrelated to any passed parameter or any special variable. I am finding out that I do not understand how to "return" an arbitrary value. -- View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14601.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Nov 17, 2015 9:46 PM
All pretty much true except the is no run time in OpenSCAD. The source code
is compiled into geometry, not executable code that runs.
Functions are simply reusable expressions that yield a value. It can be as
arbitrary as you want or it can depend on passed parameters or any named
constants that are in scope.
function fred() = 42;
The are not like modules with return values at all.
thread
module or function
through "use"
arbitrary value.
All pretty much true except the is no run time in OpenSCAD. The source code is compiled into geometry, not executable code that runs. Functions are simply reusable expressions that yield a value. It can be as arbitrary as you want or it can depend on passed parameters or any named constants that are in scope. function fred() = 42; The are not like modules with return values at all. On Nov 17, 2015 8:30 PM, "whburling" <whburling@outlook.com> wrote: > ok.....after reading your comments and trying out code offered in this > thread > and in writing my own code I came to conclude the following. If i have > incorrect understanding, please correct. > > (1) there are no variables in openSCAD > (2) there are only constants. > (3) constants have two scopes > (a) if standard constant, the constant value is local to a given > module or function > (b) if special constants, the value is observable by all called > modules and functions, regardless of whether they were defined in the same > file as called or in some external file that was "included" or referenced > through "use" > (4) the constants are defined at compile time. there is no "dynamic" > aspect in that they can be redefined at run time. > (5) there is no way to extract data local to modules as they have no return > value and openSCAD does not have global values > (6) I am uncertain if functions can be written exactly as modules with the > ability to return a value unrelated to any passed parameter or any special > variable. I am finding out that I do not understand how to "return" an > arbitrary value. > > > > > -- > View this message in context: > http://forum.openscad.org/Special-Variables-tp14477p14601.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Wed, Nov 18, 2015 2:31 AM
Everything you say is correct (although different people use different
terminology for the same things). As for point #6, the answer is no,
functions don't do that. The value returned by a function is a mathematical
function of its arguments (hence the name*), but functions can also depend
on special variables, as you say.
(*) It might be fair to say that OpenSCAD is executable mathematics for
describing geometry, rather than a conventional programming language.
Mathematics has things called 'variables' which resemble the things we call
variables in OpenSCAD. You prefer to use the term 'constant', and I
understand why.
thread
module or function
through "use"
arbitrary value.
Everything you say is correct (although different people use different terminology for the same things). As for point #6, the answer is no, functions don't do that. The value returned by a function is a mathematical function of its arguments (hence the name*), but functions can also depend on special variables, as you say. (*) It might be fair to say that OpenSCAD is executable mathematics for describing geometry, rather than a conventional programming language. Mathematics has things called 'variables' which resemble the things we call variables in OpenSCAD. You prefer to use the term 'constant', and I understand why. On 17 November 2015 at 15:29, whburling <whburling@outlook.com> wrote: > ok.....after reading your comments and trying out code offered in this > thread > and in writing my own code I came to conclude the following. If i have > incorrect understanding, please correct. > > (1) there are no variables in openSCAD > (2) there are only constants. > (3) constants have two scopes > (a) if standard constant, the constant value is local to a given > module or function > (b) if special constants, the value is observable by all called > modules and functions, regardless of whether they were defined in the same > file as called or in some external file that was "included" or referenced > through "use" > (4) the constants are defined at compile time. there is no "dynamic" > aspect in that they can be redefined at run time. > (5) there is no way to extract data local to modules as they have no return > value and openSCAD does not have global values > (6) I am uncertain if functions can be written exactly as modules with the > ability to return a value unrelated to any passed parameter or any special > variable. I am finding out that I do not understand how to "return" an > arbitrary value. > > > > > -- > View this message in context: > http://forum.openscad.org/Special-Variables-tp14477p14601.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
LB
L Boyd
Wed, Nov 18, 2015 4:40 PM
The following is based on testing using OpenSCAD version 2015.03-1.
Inside functions and modules, special variables behave differently than
normal variables.
User-Defined Functions and Modules are defined at the outer most scope of
the script.
They see and use the values of regular variables in effect at this outer
scope. New values assigned within inner scopes, from which they are called,
are not seen by the functions and modules.
When external files are loaded with include they are treated as if they were
internal, using the same values of regular variables as if locally defined.
When run is used to load only the functions and modules from an external
file, they use the values of regular variables from their external file,
rather than the local values.
Variables inside a single instance of a function or module can be overridden
by passing as parameters in the call.
For example
var = 5;
module showvar() echo(var);
showvar();         // ECHO: 5
showvar(var = 10); // ECHO: 10
showvar(var = 10); is equivalent to:
module showvar(){ var = 10; echo(var); }
showvar();
With special variables, the functions and modules DO see new values
assigned within the inner scope from which they were called. This includes
functions and modules loaded with run as well as those included and locally
defined.
View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14622.html
The following is based on testing using OpenSCAD version 2015.03-1. Inside functions and modules, special variables behave differently than normal variables. User-Defined Functions and Modules are defined at the outer most scope of the script. They see and use the values of regular variables in effect at this outer scope. New values assigned within inner scopes, from which they are called, are *not seen* by the functions and modules. When external files are loaded with include they are treated as if they were internal, using the same values of regular variables as if locally defined. When run is used to load only the functions and modules from an external file, they use the values of regular variables from their external file, rather than the local values. Variables inside a single instance of a function or module can be overridden by passing as parameters in the call. For example var = 5; module showvar() echo(var); showvar(); // ECHO: 5 showvar(var = 10); // ECHO: 10 showvar(var = 10); is equivalent to: module showvar(){ var = 10; echo(var); } showvar(); With special variables, the functions and modules *DO* see new values assigned within the inner scope from which they were called. This includes functions and modules loaded with run as well as those included and locally defined. -- View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14622.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Nov 18, 2015 4:46 PM
Note that functions and modules don't have to defined at file scope. You
can define them in modules as well.
normal variables.
the script.
were
overridden
For example
var = 5;
showvar();
defined.
Note that functions and modules don't have to defined at file scope. You can define them in modules as well. On Nov 18, 2015 4:41 PM, "L Boyd" <lboyd@frontiernet.net> wrote: > The following is based on testing using OpenSCAD version 2015.03-1. > > Inside functions and modules, special variables behave differently than > normal variables. > > User-Defined Functions and Modules are defined at the outer most scope of > the script. > They see and use the values of regular variables in effect at this outer > scope. New values assigned within inner scopes, from which they are called, > are *not seen* by the functions and modules. > > When external files are loaded with include they are treated as if they > were > internal, using the same values of regular variables as if locally defined. > > When run is used to load only the functions and modules from an external > file, they use the values of regular variables from their external file, > rather than the local values. > > Variables inside a single instance of a function or module can be > overridden > by passing as parameters in the call. > > For example > var = 5; > module showvar() echo(var); > showvar(); // ECHO: 5 > showvar(var = 10); // ECHO: 10 > > showvar(var = 10); is equivalent to: > module showvar(){ var = 10; echo(var); } > showvar(); > > With special variables, the functions and modules *DO* see new values > assigned within the inner scope from which they were called. This includes > functions and modules loaded with run as well as those included and locally > defined. > > > > > -- > View this message in context: > http://forum.openscad.org/Special-Variables-tp14477p14622.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
LB
L Boyd
Wed, Nov 18, 2015 9:00 PM
Learn something new every day!
Have not tried yet, but I assume this means the universe for these functions
and modules are the scope within which they were defined. This would mean:
  1. Regular variables have the value in effect at this scope, which may be
    different than the value at file scope.
  2. Functions and modules thus defined are undefined outside of this
    universe.
  3. The value of a special variable is still dependent on the call hierarchy,
    not where the function or module was defined.
Not sure how to use this knowledge, but  it means some rewording where I
said "outer most scope".
Do you have some ideas where they might be useful?
normal variables.
the script.
called,
were
defined.
overridden
For example
var = 5;
showvar();
includes
locally
defined.
Larry
View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14628.html
nophead wrote > Note that functions and modules don't have to defined at file scope. You > can define them in modules as well. Learn something new every day! Have not tried yet, but I assume this means the universe for these functions and modules are the scope within which they were defined. This would mean: 1. Regular variables have the value in effect at this scope, which may be different than the value at file scope. 2. Functions and modules thus defined are undefined outside of this universe. 3. The value of a special variable is still dependent on the call hierarchy, not where the function or module was defined. Not sure how to use this knowledge, but it means some rewording where I said "outer most scope". Do you have some ideas where they might be useful? L Boyd wrote >> The following is based on testing using OpenSCAD version 2015.03-1. >> >> Inside functions and modules, special variables behave differently than >> normal variables. >> >> User-Defined Functions and Modules are defined at the outer most scope of >> the script. >> They see and use the values of regular variables in effect at this outer >> scope. New values assigned within inner scopes, from which they are >> called, >> are *not seen* by the functions and modules. >> >> When external files are loaded with include they are treated as if they >> were >> internal, using the same values of regular variables as if locally >> defined. >> >> When run is used to load only the functions and modules from an external >> file, they use the values of regular variables from their external file, >> rather than the local values. >> >> Variables inside a single instance of a function or module can be >> overridden >> by passing as parameters in the call. >> >> For example >> var = 5; >> module showvar() echo(var); >> showvar(); // ECHO: 5 >> showvar(var = 10); // ECHO: 10 >> >> showvar(var = 10); is equivalent to: >> module showvar(){ var = 10; echo(var); } >> showvar(); >> >> With special variables, the functions and modules *DO* see new values >> assigned within the inner scope from which they were called. This >> includes >> functions and modules loaded with run as well as those included and >> locally >> defined. ----- Larry -- View this message in context: http://forum.openscad.org/Special-Variables-tp14477p14628.html Sent from the OpenSCAD mailing list archive at Nabble.com.
