Sun, Jun 30, 2019 6:27 AM
I'm playing with Linux again.
Got Debian Stretch installed and using it to RDP into my Windows VM until I
transition.
It's a bit flaky ATM but that may be my RAID1 NVME 'creative' solution...
Anyway, Synaptic installs OpenSCAD 2015.03.
Can I have multiple versions installed like on Windows (via zip)?
How do I get the 2019.05 release?
I take it if I follow the instructions re "openscad-nightly", that can
co-exist.
- click on my MichaelAtOz label, there is a link to email me.
transition.
co-exist.
* click on my MichaelAtOz label, there is a link to email me.
Sun, Jun 30, 2019 11:23 AM
co-exist.
Yes, the nightlies are packaged to go into separate folders so they
can installed in parallel.
> co-exist.
Sun, Jul 7, 2019 4:46 AM
More Linux adoption issues.
What's going on here? 'Can't open library...'
http://forum.openscad.org/file/t359/Screenshot_use_error.png
The source file is in ~/openscad which also contains the library folders
'use<>'ed in the source.
It finds the first two, what's different with 'scad-utils'?
2015.03 if that matters.
<http://forum.openscad.org/file/t359/Screenshot_use_error.png>
Sun, Jul 7, 2019 8:02 AM
ahh, it was use<> inside skin.scad.
Must setup library folder...
Mon, Jul 15, 2019 7:03 AM
Next step - openscad-nightly
Debian / Ubuntu packages built on OpenSUSE build service
To install the packages, the release key must be added with apt-key to the
key-ring to allow apt-get / aptitude to validate the packages.
Key ID: 75F3214F30EB8E08 (valid till 2021-04-18)
Key UID: home:t-paul OBS Project
home:t-paul@build.opensuse.org
Well apt-key help is not particularly helpful.
So how does a Debian beginner do this?
I tried 'wget -qO - https://files.openscad.org/OBS-Repository-Key.pub | sudo
apt-key add -'
gpg: WARNING: nothing exported
gpg: no valid OpenPGP data found.
gpg: Total number processed: 0
apt-key add -'
Mon, Jul 15, 2019 6:48 PM
> apt-key add -'
I've never seen that fail really, I suspect that maybe wget is
just not installed?
Does it work separately?
wget https://files.openscad.org/OBS-Repository-Key.pub
apt-key add OBS-Repository-Key.pub
BL
Bryan Lee
Mon, Jul 15, 2019 7:05 PM
Try it as:
sudo ls
then wget -qO - https://files.openscad.org/OBS-Repository-Key.pub | sudo apt-key add -
I have had problems before because sudo needs you to authenticate, but piping
into sudo redirects stdin and stdout, making authentication impossible.
Thus Torsten Paul hast written on Mon, Jul 15, 2019 at 08:48:08PM +0200, and, according to prophecy, it shall come to pass that:
Try it as:
sudo ls
> > apt-key add -'
> just not installed?
AC
A. Craig West
Mon, Jul 15, 2019 7:11 PM
This is where 'sudo bash' is your friend...
On Mon, 15 Jul 2019, 15:05 Bryan Lee, leebc11@acm.org wrote:
Try it as:
sudo ls
sudo apt-key add -
piping
apt-key add -'
On Mon, 15 Jul 2019, 15:05 Bryan Lee, <leebc11@acm.org> wrote:
> Try it as:
> sudo ls
> sudo apt-key add -
> piping
> | sudo
> > > apt-key add -'
> > just not installed?
BL
Bryan Lee
Mon, Jul 15, 2019 7:37 PM
Yeah.. Don't.... Dont' do it like that. That makes the privledge
seperation pointless and you may as well run everything as root.
Thus A. Craig West hast written on Mon, Jul 15, 2019 at 03:11:23PM -0400, and, according to prophecy, it shall come to pass that:
Try it as:
sudo ls
sudo apt-key add -
piping
apt-key add -'
> > Try it as:
> > sudo ls
> > sudo apt-key add -
> > piping
> > | sudo
> > > > apt-key add -'
> > > just not installed?
AC
A. Craig West
Mon, Jul 15, 2019 7:40 PM
When you are doing system management tasks that all need to be performed as
root, it's pretty pointless to sudo each particular command. When i am
doing this type of thing, I either run commands that don't need root in a
different prompt, or su them to the user
Try it as:
sudo ls
sudo apt-key add -
piping
apt-key add -'
> > > Try it as:
> > > sudo ls
> > > sudo apt-key add -
> > > piping
> +0200,
> > > > > I tried 'wget -qO -
> > > | sudo
> > > > > apt-key add -'
> > > > just not installed?
