Mon, Jul 15, 2019 7:42 PM
Yes we used to be able to do su root, before unix became a nany like
thieving else these days.
On Mon, 15 Jul 2019 at 20:38, Bryan Lee leebc11@acm.org wrote:
Yeah.. Don't.... Dont' do it like that. That makes the privledge
seperation pointless and you may as well run everything as root.
Thus A. Craig West hast written on Mon, Jul 15, 2019 at 03:11:23PM -0400,
and, according to prophecy, it shall come to pass that:
This is where 'sudo bash' is your friend...
On Mon, 15 Jul 2019, 15:05 Bryan Lee, leebc11@acm.org wrote:
Try it as:
sudo ls
then wget -qO - https://files.openscad.org/OBS-Repository-Key.pub |
sudo apt-key add -
I have had problems before because sudo needs you to authenticate, but
piping
into sudo redirects stdin and stdout, making authentication impossible.
Thus Torsten Paul hast written on Mon, Jul 15, 2019 at 08:48:08PM
On 15.07.19 09:03, MichaelAtOz wrote:
apt-key add -'
gpg: WARNING: nothing exported
gpg: no valid OpenPGP data found.
gpg: Total number processed: 0
> > On Mon, 15 Jul 2019, 15:05 Bryan Lee, <leebc11@acm.org> wrote:
> > > Try it as:
> > > sudo ls
> > > sudo apt-key add -
> > > piping
> +0200,
> > > > > I tried 'wget -qO -
> > > | sudo
> > > > > apt-key add -'
> > > > I've never seen that fail really, I suspect that maybe wget is
> > > > just not installed?
> > > > Does it work separately?
> > > > wget https://files.openscad.org/OBS-Repository-Key.pub
> > > > apt-key add OBS-Repository-Key.pub
> > > _______________________________________________
> > > OpenSCAD mailing list
> > > Discuss@lists.openscad.org
> > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
AC
A. Craig West
Mon, Jul 15, 2019 7:51 PM
I mean sudo bash, if you are doing a lot of root tasks, and then if one of
the tasks doesn't need root, su -c "do unprivileged command" username
sudo apt-key add -
piping
apt-key add -'
>> > > Try it as:
>> > > sudo ls
>> > > sudo apt-key add -
>> > > piping
>> impossible.
>> +0200,
>> > > > > I tried 'wget -qO -
>> > > | sudo
>> > > > > apt-key add -'
>> > > > just not installed?
Mon, Jul 15, 2019 11:17 PM
I'm currently sudo with ALL=(ALL) NOPASSWD:ALL so it isn't password
related.(Yes I know...)
mebd@mebd:~$ wget https://files.openscad.org/OBS-Repository-Key.pub
--2019-07-16 09:02:56-- https://files.openscad.org/OBS-Repository-Key.pub
Resolving files.openscad.org (files.openscad.org)... 104.236.249.91
Connecting to files.openscad.org (files.openscad.org)|104.236.249.91|:443...
connected.
HTTP request sent, awaiting response... 200 OK
Length: 1093 (1.1K) [application/octet-stream]
Saving to: ‘OBS-Repository-Key.pub’
100%[
---============================>] 1.07K
--.-KB/s in 0s
2019-07-16 09:02:57 (14.8 MB/s) - ‘OBS-Repository-Key.pub’ saved [1093/1093]
mebd@mebd:~$ sudo apt-key add OBS-Repository-Key.pub
mebd@mebd:~$ cat OBS-Repository-Key.pub
-----BEGIN PGP PUBLIC KEY BLOCK-----
Version: GnuPG v1.4.5 (GNU/Linux)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=KL4Z
-----END PGP PUBLIC KEY BLOCK-----
mebd@mebd:~$
- click on my MichaelAtOz label, there is a link to email me.
0
*mebd@mebd:~$ wget https://files.openscad.org/OBS-Repository-Key.pub*
connected.
100%[=============================================================>] 1.07K
--.-KB/s in 0s
*mebd@mebd:~$ sudo apt-key add OBS-Repository-Key.pub*
*mebd@mebd:~$ cat OBS-Repository-Key.pub*
iMnK
=KL4Z
mebd@mebd:~$
* click on my MichaelAtOz label, there is a link to email me.
Mon, Jul 15, 2019 11:26 PM
Note, this is the bit I need help with, am I meant to do something with gpg?
(Google is not my friend ATM)
added with apt-key to the key-ring to allow apt-get / aptitude to validate
the packages.
Key ID: 75F3214F30EB8E08 (valid till 2021-04-18)
Key UID: home:t-paul OBS Project home:t-paul@build.opensuse.org
the packages.
Key UID: home:t-paul OBS Project <home:t-paul@build.opensuse.org>
Mon, Jul 15, 2019 11:34 PM
I found some references that could be caused by a corrupted
/etc/apt/trusted.gpg file.
What happens with
gpg --list-keys --no-default-keyring --keyring /etc/apt/trusted.gpg
That should list some keys in format
pub rsa2048 2014-09-20 [SC] [expires: 2021-04-18]
5F4A8A2C8BB11716F29482BB75F3214F30EB8E08
uid [ unknown] home:t-paul OBS Project home:t-paul@build.opensuse.org
If that gives an error maybe backup that file by renaming
it and retry with apt-key.
What happens with
uid [ unknown] home:t-paul OBS Project <home:t-paul@build.opensuse.org>
Mon, Jul 15, 2019 11:54 PM
That did it, thanks.
Now I need to resolve 30 odd dependencies...
Tue, Jul 16, 2019 12:21 AM
I stopped checking after the first 7 were installed, so I presume it is
something else.
This was via Synaptic. Why not installable?
openscad-nightly:arm64: Installed version
Depends: libboost-filesystem1.62.0 but it is not installable
1.62.0+dfsg-4
Depends: libboost-program-options1.62.0 but it is not installable "
Depends: libboost-regex1.62.0 but it is not installable "
Depends: libboost-system1.62.0 but it is not installable "
Depends: libboost-thread1.62.0 but it is not installable "
Depends: libc6 (>=2.17) but it is not installable 2.24-11-deb94
Depends: libcgal12 but it is not installable 4.9-1+b2
Depends: libdouble-conversion1 (>=2.0.0) but it is not installable
Depends: libfontconfig1 (>=2.11) but it is not installable
Depends: libfreetype6 (>=2.2.1) but it is not installable
Depends: libgcc1 (>=1:4.2) but it is not installable
Depends: libgl1-mesa-glx but it is not installable or
libgl1 but it is not installable
Depends: libglew2.0 (>=1.12.0) but it is not installable
Depends: libglib2.0-0 (>=2.12.0) but it is not installable
Depends: libglu1-mesa but it is not installable or
libglu1 but it is not installable
Depends: libgmp10 but it is not installable
Depends: libharfbuzz0b (>=0.9.9) but it is not installable
Depends: libmpfr4 (>=3.1.3) but it is not installable
Depends: libopencsg1 but it is not installable
Depends: libqt5concurrent5 (>=5.0.2) but it is not installable
Depends: libqt5core5a (>=5.7.0) but it is not installable
Depends: libqt5dbus5 (>=5.0.2) but it is not installable
Depends: libqt5gui5 (>=5.7.0) but it is not installable
Depends: libqt5multimedia5 (>=5.6.0~beta) but it is not installable
Depends: libqt5network5 (>=5.0.2) but it is not installable
Depends: libqt5printsupport5 (>=5.0.2) but it is not installable
Depends: libqt5scintilla2-12v5 (>=2.8.4) but it is not installable
Depends: libqt5widgets5 (>=5.4.0) but it is not installable
Depends: libstdc++6 (>=5.2) but it is not installable
Depends: libx11-6 but it is not installable
Depends: libxml2 (>=2.7.4) but it is not installable
something else.
1.62.0+dfsg-4
Tue, Jul 16, 2019 12:24 AM
Reformatted
Installed version
1.62.0+dfsg-4
2.24-11-deb94
4.9-1+b2
Reformatted
Installed version
1.62.0+dfsg-4
2.24-11-deb94
4.9-1+b2
Tue, Jul 16, 2019 12:52 AM
That seems old, so maybe you picked a version that is not
matching the Debian release?
Which Debian version is that?
cat /etc/os-release
And which of the repos did you give as apt source?
apt-cache policy openscad-nightly
cat /etc/os-release
Tue, Jul 16, 2019 1:13 AM
Nabble keeps stuffing up the format. The " ditto means they are the same as
above.
Am I right that 'Depends: libboost-regex1.62.0' means it wants that version?
Because all those libboost-* are installed with version 1.62.0+dfsg-4.
And 'Depends: libc6 (>=2.17) but it is not installable' is installed v
2.24-11-deb94.
maybe you picked a version that is not matching the Debian release?
Debian Stretch was installed from a dvd.iso downloaded a few months ago.
mebd@mebd:~$ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 9 (stretch)"
NAME="Debian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
mebd@mebd:~$ apt-cache policy openscad-nightly
openscad-nightly:
Installed: (none)
Candidate: 20190715T105013.git6cc7e911f+3106.1
Version table:
20190715T105013.git6cc7e911f+3106.1 500
500
https://download.opensuse.org/repositories/home:/t-paul/Debian_9.0 ./
Packages
mebd@mebd:~$ cat /etc/apt/sources.list.d/openscad.list
deb https://download.opensuse.org/repositories/home:/t-paul/Debian_9.0/ ./
> That seems old,
above.
2.24-11-deb94.
VERSION_ID="9"
ID=debian
openscad-nightly:
Installed: (none)
Version table:
500
Packages
