Re: [OpenSCAD] Access violation on starting OpenSCAD (Win8)
D
donbright
Mon, Oct 26, 2015 11:41 PM
My first question would be, can the user run "openscad --info" from the
command line?
View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14219.html
My first question would be, can the user run "openscad --info" from the command line? -- View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14219.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
spinorkit
Tue, Oct 27, 2015 7:27 AM
On my Win8.0 machine, the 2015.10.17 build returns after a few seconds with
no output. The 2014 build on the same machine returns:
C:\Program Files\OpenSCAD>openscad.exe --info
C:\Program Files\OpenSCAD>openscad --info
OpenSCAD Version: 2014.03
Compiler, build date: GCC "4.8.1", Mar  9 2014
Boost version: 1_53
Eigen version: 3.1.3
CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>,
Epeck
OpenCSG version: OpenCSG 1.3.2
Qt version: 4.8.5
MingW build: MingW64
GLib version: 2.36.3
OPENSCADPATH: <not set>
OpenSCAD library path:
GLEW version: 1.9.0
OpenGL Version: 4.3.0 - Build 10.18.14.4264
GL Renderer: Intel(R) HD Graphics 4600
GL Vendor: Intel
RGBA(8888), depth(24), stencil(8)
GL_ARB_framebuffer_object: yes
GL_EXT_framebuffer_object: yes
GL_EXT_packed_depth_stencil: yes
GL context creator: WGL
PNG generator: lodepng
OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x1eaec74 amd64
Machine: 8664
Running openscad.exe --info crashes without output. The access violation is
Unhandled exception at 0x0000000000FF7A04 in openscad.exe: 0xC0000005:
Access violation reading location 0x0000000000000000.
Thanks,
Kit
On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] <
ml-node+s1091067n14219h34@n5.nabble.com> wrote:
View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14220.html
On my Win8.0 machine, the 2015.10.17 build returns after a few seconds with no output. The 2014 build on the same machine returns: C:\Program Files\OpenSCAD>openscad.exe --info C:\Program Files\OpenSCAD>openscad --info OpenSCAD Version: 2014.03 Compiler, build date: GCC "4.8.1", Mar 9 2014 Boost version: 1_53 Eigen version: 3.1.3 CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, Epeck OpenCSG version: OpenCSG 1.3.2 Qt version: 4.8.5 MingW build: MingW64 GLib version: 2.36.3 OPENSCADPATH: <not set> OpenSCAD library path: GLEW version: 1.9.0 OpenGL Version: 4.3.0 - Build 10.18.14.4264 GL Renderer: Intel(R) HD Graphics 4600 GL Vendor: Intel RGBA(8888), depth(24), stencil(8) GL_ARB_framebuffer_object: yes GL_EXT_framebuffer_object: yes GL_EXT_packed_depth_stencil: yes GL context creator: WGL PNG generator: lodepng OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x1eaec74 amd64 Machine: 8664 C:\Program Files\OpenSCAD> Running openscad.exe --info crashes without output. The access violation is : Unhandled exception at 0x0000000000FF7A04 in openscad.exe: 0xC0000005: Access violation reading location 0x0000000000000000. Thanks, Kit On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] < ml-node+s1091067n14219h34@n5.nabble.com> wrote: > > My first question would be, can the user run "openscad --info" from the > command line? > > ------------------------------ > If you reply to this email, your message will be added to the discussion > below: > > http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14219.html > To unsubscribe from Access violation on starting OpenSCAD (Win8), click > here > <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=14201&code=a2l0LmFkYW1zQGdtYWlsLmNvbXwxNDIwMXwtMTM1NzI4MDMyMQ==> > . > NAML > <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> > -- View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14220.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
spinorkit
Tue, Oct 27, 2015 7:36 AM
In case it helps, the disassembly around the crash is:
0000000000FF79B5  call        0000000001001D10
0000000000FF79BA  mov        r12,rax
0000000000FF79BD  mov        rbp,qword ptr [rsi+30h]
0000000000FF79C1  test        rbp,rbp
0000000000FF79C4  je          0000000000FF7A60
0000000000FF79CA  cmp        byte ptr [rsi+0D5h],0
0000000000FF79D1  jne        0000000000FF7A60
0000000000FF79D7  test        r12,r12
0000000000FF79DA  jle        0000000000FF7B00
0000000000FF79E0  mov        rax,qword ptr [rsi+88h]
0000000000FF79E7  mov        rdx,qword ptr [rsi+30h]
0000000000FF79EB  lea        rbx,[rsp+30h]
0000000000FF79F0  lea        rcx,[rsi+38h]
0000000000FF79F4  mov        r9d,r12d
0000000000FF79F7  lea        r12,[rsi+88h]
0000000000FF79FE  mov        r8,rdi
0000000000FF7A01  mov        ebp,dword ptr [rax+4]
Null deference [rdx] here ->0000000000FF7A04  mov        rax,qword ptr
[rdx]
0000000000FF7A07  mov        qword ptr [rsp+20h],rcx
0000000000FF7A0C  mov        rcx,rbx
0000000000FF7A0F  call        qword ptr [rax+18h]
0000000000FF7A12  mov        rdx,rbx
0000000000FF7A15  mov        rcx,r12
0000000000FF7A18  call        00000000010440F0
0000000000FF7A1D  mov        rcx,qword ptr [rsp+30h]
0000000000FF7A22  mov        eax,dword ptr [rcx]
0000000000FF7A24  test        eax,eax
0000000000FF7A26  jne        0000000000FF7AC3
0000000000FF7A2C  mov        r8d,8
0000000000FF7A32  mov        edx,2
0000000000FF7A37  call        00000000010BE1A0
0000000000FF7A3C  test        r13b,r13b
0000000000FF7A3F  jne        0000000000FF7B90
0000000000FF7A45  mov        eax,1
0000000000FF7A4A  add        rsp,4048h
0000000000FF7A51  pop        rbx
0000000000FF7A52  pop        rsi
0000000000FF7A53  pop        rdi
0000000000FF7A54  pop        rbp
0000000000FF7A55  pop        r12
0000000000FF7A57  pop        r13
0000000000FF7A59  ret
0000000000FF7A5A  nop        word ptr [rax+rax]
Boost version: 1_53
Epeck
Qt version: 4.8.5
GLEW version: 1.9.0
GL Vendor: Intel
Machine: 8664
is :
Thanks,
Kit
View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14221.html
In case it helps, the disassembly around the crash is: 0000000000FF79B5 call 0000000001001D10 0000000000FF79BA mov r12,rax 0000000000FF79BD mov rbp,qword ptr [rsi+30h] 0000000000FF79C1 test rbp,rbp 0000000000FF79C4 je 0000000000FF7A60 0000000000FF79CA cmp byte ptr [rsi+0D5h],0 0000000000FF79D1 jne 0000000000FF7A60 0000000000FF79D7 test r12,r12 0000000000FF79DA jle 0000000000FF7B00 0000000000FF79E0 mov rax,qword ptr [rsi+88h] 0000000000FF79E7 mov rdx,qword ptr [rsi+30h] 0000000000FF79EB lea rbx,[rsp+30h] 0000000000FF79F0 lea rcx,[rsi+38h] 0000000000FF79F4 mov r9d,r12d 0000000000FF79F7 lea r12,[rsi+88h] 0000000000FF79FE mov r8,rdi 0000000000FF7A01 mov ebp,dword ptr [rax+4] Null deference [rdx] here ->0000000000FF7A04 mov rax,qword ptr [rdx] 0000000000FF7A07 mov qword ptr [rsp+20h],rcx 0000000000FF7A0C mov rcx,rbx 0000000000FF7A0F call qword ptr [rax+18h] 0000000000FF7A12 mov rdx,rbx 0000000000FF7A15 mov rcx,r12 0000000000FF7A18 call 00000000010440F0 0000000000FF7A1D mov rcx,qword ptr [rsp+30h] 0000000000FF7A22 mov eax,dword ptr [rcx] 0000000000FF7A24 test eax,eax 0000000000FF7A26 jne 0000000000FF7AC3 0000000000FF7A2C mov r8d,8 0000000000FF7A32 mov edx,2 0000000000FF7A37 call 00000000010BE1A0 0000000000FF7A3C test r13b,r13b 0000000000FF7A3F jne 0000000000FF7B90 0000000000FF7A45 mov eax,1 0000000000FF7A4A add rsp,4048h 0000000000FF7A51 pop rbx 0000000000FF7A52 pop rsi 0000000000FF7A53 pop rdi 0000000000FF7A54 pop rbp 0000000000FF7A55 pop r12 0000000000FF7A57 pop r13 0000000000FF7A59 ret 0000000000FF7A5A nop word ptr [rax+rax] On Tue, Oct 27, 2015 at 8:26 PM, Kit Adams <kit.adams@gmail.com> wrote: > On my Win8.0 machine, the 2015.10.17 build returns after a few seconds > with no output. The 2014 build on the same machine returns: > > C:\Program Files\OpenSCAD>openscad.exe --info > > C:\Program Files\OpenSCAD>openscad --info > OpenSCAD Version: 2014.03 > Compiler, build date: GCC "4.8.1", Mar 9 2014 > Boost version: 1_53 > Eigen version: 3.1.3 > CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, > Epeck > OpenCSG version: OpenCSG 1.3.2 > Qt version: 4.8.5 > MingW build: MingW64 > GLib version: 2.36.3 > OPENSCADPATH: <not set> > OpenSCAD library path: > > > GLEW version: 1.9.0 > OpenGL Version: 4.3.0 - Build 10.18.14.4264 > GL Renderer: Intel(R) HD Graphics 4600 > GL Vendor: Intel > RGBA(8888), depth(24), stencil(8) > GL_ARB_framebuffer_object: yes > GL_EXT_framebuffer_object: yes > GL_EXT_packed_depth_stencil: yes > GL context creator: WGL > PNG generator: lodepng > OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x1eaec74 amd64 > Machine: 8664 > > C:\Program Files\OpenSCAD> > > Running openscad.exe --info crashes without output. The access violation > is : > Unhandled exception at 0x0000000000FF7A04 in openscad.exe: 0xC0000005: > Access violation reading location 0x0000000000000000. > > > Thanks, > Kit > > On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] < > ml-node+s1091067n14219h34@n5.nabble.com> wrote: > >> >> My first question would be, can the user run "openscad --info" from the >> command line? >> >> ------------------------------ >> If you reply to this email, your message will be added to the discussion >> below: >> >> http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14219.html >> To unsubscribe from Access violation on starting OpenSCAD (Win8), click >> here >> <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=14201&code=a2l0LmFkYW1zQGdtYWlsLmNvbXwxNDIwMXwtMTM1NzI4MDMyMQ==> >> . >> NAML >> <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> >> > > -- View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14221.html Sent from the OpenSCAD mailing list archive at Nabble.com.
S
spinorkit
Tue, Oct 27, 2015 7:38 AM
and the stack:
openscad.exe!0000000000ff7a04() Unknown
openscad.exe!0000000000ff867e() Unknown
openscad.exe!0000000000ff9087() Unknown
openscad.exe!0000000000fd3be3() Unknown
openscad.exe!0000000000fd5ad9() Unknown
openscad.exe!0000000000f9d6e5() Unknown
openscad.exe!0000000000f9d9fd() Unknown
openscad.exe!00000000004e8817() Unknown
openscad.exe!00000000004edec1() Unknown
openscad.exe!0000000000557eff() Unknown
openscad.exe!00000000004013e8() Unknown
openscad.exe!00000000004014eb() Unknown
[rdx]
Boost version: 1_53
Epeck
Qt version: 4.8.5
GLEW version: 1.9.0
GL Vendor: Intel
Machine: 8664
is :
Thanks,
Kit
View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14222.html
and the stack: > openscad.exe!0000000000ff7a04() Unknown openscad.exe!0000000000ff867e() Unknown openscad.exe!0000000000ff9087() Unknown openscad.exe!0000000000fd3be3() Unknown openscad.exe!0000000000fd5ad9() Unknown openscad.exe!0000000000f9d6e5() Unknown openscad.exe!0000000000f9d9fd() Unknown openscad.exe!00000000004e8817() Unknown openscad.exe!00000000004edec1() Unknown openscad.exe!0000000000557eff() Unknown openscad.exe!00000000004013e8() Unknown openscad.exe!00000000004014eb() Unknown On Tue, Oct 27, 2015 at 8:36 PM, Kit Adams <kit.adams@gmail.com> wrote: > In case it helps, the disassembly around the crash is: > 0000000000FF79B5 call 0000000001001D10 > 0000000000FF79BA mov r12,rax > 0000000000FF79BD mov rbp,qword ptr [rsi+30h] > 0000000000FF79C1 test rbp,rbp > 0000000000FF79C4 je 0000000000FF7A60 > 0000000000FF79CA cmp byte ptr [rsi+0D5h],0 > 0000000000FF79D1 jne 0000000000FF7A60 > 0000000000FF79D7 test r12,r12 > 0000000000FF79DA jle 0000000000FF7B00 > 0000000000FF79E0 mov rax,qword ptr [rsi+88h] > 0000000000FF79E7 mov rdx,qword ptr [rsi+30h] > 0000000000FF79EB lea rbx,[rsp+30h] > 0000000000FF79F0 lea rcx,[rsi+38h] > 0000000000FF79F4 mov r9d,r12d > 0000000000FF79F7 lea r12,[rsi+88h] > 0000000000FF79FE mov r8,rdi > 0000000000FF7A01 mov ebp,dword ptr [rax+4] > Null deference [rdx] here ->0000000000FF7A04 mov rax,qword ptr > [rdx] > 0000000000FF7A07 mov qword ptr [rsp+20h],rcx > 0000000000FF7A0C mov rcx,rbx > 0000000000FF7A0F call qword ptr [rax+18h] > 0000000000FF7A12 mov rdx,rbx > 0000000000FF7A15 mov rcx,r12 > 0000000000FF7A18 call 00000000010440F0 > 0000000000FF7A1D mov rcx,qword ptr [rsp+30h] > 0000000000FF7A22 mov eax,dword ptr [rcx] > 0000000000FF7A24 test eax,eax > 0000000000FF7A26 jne 0000000000FF7AC3 > 0000000000FF7A2C mov r8d,8 > 0000000000FF7A32 mov edx,2 > 0000000000FF7A37 call 00000000010BE1A0 > 0000000000FF7A3C test r13b,r13b > 0000000000FF7A3F jne 0000000000FF7B90 > 0000000000FF7A45 mov eax,1 > 0000000000FF7A4A add rsp,4048h > 0000000000FF7A51 pop rbx > 0000000000FF7A52 pop rsi > 0000000000FF7A53 pop rdi > 0000000000FF7A54 pop rbp > 0000000000FF7A55 pop r12 > 0000000000FF7A57 pop r13 > 0000000000FF7A59 ret > 0000000000FF7A5A nop word ptr [rax+rax] > > > On Tue, Oct 27, 2015 at 8:26 PM, Kit Adams <kit.adams@gmail.com> wrote: > >> On my Win8.0 machine, the 2015.10.17 build returns after a few seconds >> with no output. The 2014 build on the same machine returns: >> >> C:\Program Files\OpenSCAD>openscad.exe --info >> >> C:\Program Files\OpenSCAD>openscad --info >> OpenSCAD Version: 2014.03 >> Compiler, build date: GCC "4.8.1", Mar 9 2014 >> Boost version: 1_53 >> Eigen version: 3.1.3 >> CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, >> Epeck >> OpenCSG version: OpenCSG 1.3.2 >> Qt version: 4.8.5 >> MingW build: MingW64 >> GLib version: 2.36.3 >> OPENSCADPATH: <not set> >> OpenSCAD library path: >> >> >> GLEW version: 1.9.0 >> OpenGL Version: 4.3.0 - Build 10.18.14.4264 >> GL Renderer: Intel(R) HD Graphics 4600 >> GL Vendor: Intel >> RGBA(8888), depth(24), stencil(8) >> GL_ARB_framebuffer_object: yes >> GL_EXT_framebuffer_object: yes >> GL_EXT_packed_depth_stencil: yes >> GL context creator: WGL >> PNG generator: lodepng >> OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x1eaec74 amd64 >> Machine: 8664 >> >> C:\Program Files\OpenSCAD> >> >> Running openscad.exe --info crashes without output. The access violation >> is : >> Unhandled exception at 0x0000000000FF7A04 in openscad.exe: 0xC0000005: >> Access violation reading location 0x0000000000000000. >> >> >> Thanks, >> Kit >> >> On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] < >> ml-node+s1091067n14219h34@n5.nabble.com> wrote: >> >>> >>> My first question would be, can the user run "openscad --info" from the >>> command line? >>> >>> ------------------------------ >>> If you reply to this email, your message will be added to the discussion >>> below: >>> >>> http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14219.html >>> To unsubscribe from Access violation on starting OpenSCAD (Win8), click >>> here >>> <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=14201&code=a2l0LmFkYW1zQGdtYWlsLmNvbXwxNDIwMXwtMTM1NzI4MDMyMQ==> >>> . >>> NAML >>> <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> >>> >> >> > -- View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14222.html Sent from the OpenSCAD mailing list archive at Nabble.com.
KA
Kit Adams
Tue, Oct 27, 2015 9:46 AM
Actually, that dis-assembly and stack is for the 2015.03-1 build. The
2015.10.17 version crashes in similar code at address 0000000000F903F4 :
mov        rax,qword ptr [rdx] .
On Tue, Oct 27, 2015 at 8:38 PM, spinorkit kit.adams@gmail.com wrote:
and the stack:
On Tue, Oct 27, 2015 at 8:36 PM, Kit Adams <[hidden email]
[rdx]
On Tue, Oct 27, 2015 at 8:26 PM, Kit Adams <[hidden email]
Boost version: 1_53
Epeck
Qt version: 4.8.5
GLEW version: 1.9.0
GL Vendor: Intel
Machine: 8664
is :
Thanks,
Kit
On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] <[hidden
email] http:///user/SendEmail.jtp?type=node&node=14222&i=2> wrote:
View this message in context: Re: Access violation on starting OpenSCAD
(Win8)
at Nabble.com.
Actually, that dis-assembly and stack is for the 2015.03-1 build. The 2015.10.17 version crashes in similar code at address 0000000000F903F4 : mov rax,qword ptr [rdx] . On Tue, Oct 27, 2015 at 8:38 PM, spinorkit <kit.adams@gmail.com> wrote: > and the stack: > > openscad.exe!0000000000ff7a04() Unknown > openscad.exe!0000000000ff867e() Unknown > openscad.exe!0000000000ff9087() Unknown > openscad.exe!0000000000fd3be3() Unknown > openscad.exe!0000000000fd5ad9() Unknown > openscad.exe!0000000000f9d6e5() Unknown > openscad.exe!0000000000f9d9fd() Unknown > openscad.exe!00000000004e8817() Unknown > openscad.exe!00000000004edec1() Unknown > openscad.exe!0000000000557eff() Unknown > openscad.exe!00000000004013e8() Unknown > openscad.exe!00000000004014eb() Unknown > > > On Tue, Oct 27, 2015 at 8:36 PM, Kit Adams <[hidden email] > <http:///user/SendEmail.jtp?type=node&node=14222&i=0>> wrote: > >> In case it helps, the disassembly around the crash is: >> 0000000000FF79B5 call 0000000001001D10 >> 0000000000FF79BA mov r12,rax >> 0000000000FF79BD mov rbp,qword ptr [rsi+30h] >> 0000000000FF79C1 test rbp,rbp >> 0000000000FF79C4 je 0000000000FF7A60 >> 0000000000FF79CA cmp byte ptr [rsi+0D5h],0 >> 0000000000FF79D1 jne 0000000000FF7A60 >> 0000000000FF79D7 test r12,r12 >> 0000000000FF79DA jle 0000000000FF7B00 >> 0000000000FF79E0 mov rax,qword ptr [rsi+88h] >> 0000000000FF79E7 mov rdx,qword ptr [rsi+30h] >> 0000000000FF79EB lea rbx,[rsp+30h] >> 0000000000FF79F0 lea rcx,[rsi+38h] >> 0000000000FF79F4 mov r9d,r12d >> 0000000000FF79F7 lea r12,[rsi+88h] >> 0000000000FF79FE mov r8,rdi >> 0000000000FF7A01 mov ebp,dword ptr [rax+4] >> Null deference [rdx] here ->0000000000FF7A04 mov rax,qword ptr >> [rdx] >> 0000000000FF7A07 mov qword ptr [rsp+20h],rcx >> 0000000000FF7A0C mov rcx,rbx >> 0000000000FF7A0F call qword ptr [rax+18h] >> 0000000000FF7A12 mov rdx,rbx >> 0000000000FF7A15 mov rcx,r12 >> 0000000000FF7A18 call 00000000010440F0 >> 0000000000FF7A1D mov rcx,qword ptr [rsp+30h] >> 0000000000FF7A22 mov eax,dword ptr [rcx] >> 0000000000FF7A24 test eax,eax >> 0000000000FF7A26 jne 0000000000FF7AC3 >> 0000000000FF7A2C mov r8d,8 >> 0000000000FF7A32 mov edx,2 >> 0000000000FF7A37 call 00000000010BE1A0 >> 0000000000FF7A3C test r13b,r13b >> 0000000000FF7A3F jne 0000000000FF7B90 >> 0000000000FF7A45 mov eax,1 >> 0000000000FF7A4A add rsp,4048h >> 0000000000FF7A51 pop rbx >> 0000000000FF7A52 pop rsi >> 0000000000FF7A53 pop rdi >> 0000000000FF7A54 pop rbp >> 0000000000FF7A55 pop r12 >> 0000000000FF7A57 pop r13 >> 0000000000FF7A59 ret >> 0000000000FF7A5A nop word ptr [rax+rax] >> >> >> On Tue, Oct 27, 2015 at 8:26 PM, Kit Adams <[hidden email] >> <http:///user/SendEmail.jtp?type=node&node=14222&i=1>> wrote: >> >>> On my Win8.0 machine, the 2015.10.17 build returns after a few seconds >>> with no output. The 2014 build on the same machine returns: >>> >>> C:\Program Files\OpenSCAD>openscad.exe --info >>> >>> C:\Program Files\OpenSCAD>openscad --info >>> OpenSCAD Version: 2014.03 >>> Compiler, build date: GCC "4.8.1", Mar 9 2014 >>> Boost version: 1_53 >>> Eigen version: 3.1.3 >>> CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, >>> Epeck >>> OpenCSG version: OpenCSG 1.3.2 >>> Qt version: 4.8.5 >>> MingW build: MingW64 >>> GLib version: 2.36.3 >>> OPENSCADPATH: <not set> >>> OpenSCAD library path: >>> >>> >>> GLEW version: 1.9.0 >>> OpenGL Version: 4.3.0 - Build 10.18.14.4264 >>> GL Renderer: Intel(R) HD Graphics 4600 >>> GL Vendor: Intel >>> RGBA(8888), depth(24), stencil(8) >>> GL_ARB_framebuffer_object: yes >>> GL_EXT_framebuffer_object: yes >>> GL_EXT_packed_depth_stencil: yes >>> GL context creator: WGL >>> PNG generator: lodepng >>> OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x1eaec74 amd64 >>> Machine: 8664 >>> >>> C:\Program Files\OpenSCAD> >>> >>> Running openscad.exe --info crashes without output. The access violation >>> is : >>> Unhandled exception at 0x0000000000FF7A04 in openscad.exe: 0xC0000005: >>> Access violation reading location 0x0000000000000000. >>> >>> >>> Thanks, >>> Kit >>> >>> On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] <[hidden >>> email] <http:///user/SendEmail.jtp?type=node&node=14222&i=2>> wrote: >>> >>>> >>>> My first question would be, can the user run "openscad --info" from the >>>> command line? >>>> >>>> ------------------------------ >>>> If you reply to this email, your message will be added to the >>>> discussion below: >>>> >>>> http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14219.html >>>> To unsubscribe from Access violation on starting OpenSCAD (Win8), click >>>> here. >>>> NAML >>>> <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> >>>> >>> >>> >> > > ------------------------------ > View this message in context: Re: Access violation on starting OpenSCAD > (Win8) > <http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14222.html> > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
DB
don bright
Thu, Oct 29, 2015 12:03 AM
To make this easier to track I took the liberty of making a github issue
https://github.com/openscad/openscad/issues/1467
  don bright
  hmbright@fastmail.com
and the stack:
openscad.exe!0000000000ff7a04()Unknown
openscad.exe!0000000000ff867e()Unknown
openscad.exe!0000000000ff9087()Unknown
openscad.exe!0000000000fd3be3()Unknown
openscad.exe!0000000000fd5ad9()Unknown
openscad.exe!0000000000f9d6e5()Unknown
openscad.exe!0000000000f9d9fd()Unknown
openscad.exe!00000000004e8817()Unknown
openscad.exe!00000000004edec1()Unknown
openscad.exe!0000000000557eff()Unknown
openscad.exe!00000000004013e8()Unknown
openscad.exe!00000000004014eb()Unknown
Boost version: 1_53
Qt version: 4.8.5
GLEW version: 1.9.0
GL Vendor: Intel
Machine: 8664
Thanks,
Kit
On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] <[hidden email][3]> wrote:
If you reply to this email, your message will be added to the discussion below:
To unsubscribe from Access violation on starting OpenSCAD (Win8), click here.
NAML[4]
View this message in context: Re: Access violation on starting OpenSCAD (Win8)[5]
Sent from the OpenSCAD mailing list archive[6] at Nabble.com.
To make this easier to track I took the liberty of making a github issue https://github.com/openscad/openscad/issues/1467 --   don bright   hmbright@fastmail.com On Tue, Oct 27, 2015, at 04:46 AM, Kit Adams wrote: > Actually, that dis-assembly and stack is for the 2015.03-1 build. The 2015.10.17 version crashes in similar code at address 0000000000F903F4 :  mov         rax,qword ptr [rdx] . > > On Tue, Oct 27, 2015 at 8:38 PM, spinorkit <kit.adams@gmail.com> wrote: >> >> and the stack: >> >openscad.exe!0000000000ff7a04()Unknown >> openscad.exe!0000000000ff867e()Unknown >> openscad.exe!0000000000ff9087()Unknown >> openscad.exe!0000000000fd3be3()Unknown >> openscad.exe!0000000000fd5ad9()Unknown >> openscad.exe!0000000000f9d6e5()Unknown >> openscad.exe!0000000000f9d9fd()Unknown >> openscad.exe!00000000004e8817()Unknown >> openscad.exe!00000000004edec1()Unknown >> openscad.exe!0000000000557eff()Unknown >> openscad.exe!00000000004013e8()Unknown >> openscad.exe!00000000004014eb()Unknown >> >> >> >> On Tue, Oct 27, 2015 at 8:36 PM, Kit Adams <[hidden email][1]> wrote: >>> In case it helps, the disassembly around the crash is: >>> 0000000000FF79B5  call        0000000001001D10   >>> 0000000000FF79BA  mov         r12,rax   >>> 0000000000FF79BD  mov         rbp,qword ptr [rsi+30h]   >>> 0000000000FF79C1  test        rbp,rbp   >>> 0000000000FF79C4  je          0000000000FF7A60   >>> 0000000000FF79CA  cmp         byte ptr [rsi+0D5h],0   >>> 0000000000FF79D1  jne         0000000000FF7A60   >>> 0000000000FF79D7  test        r12,r12   >>> 0000000000FF79DA  jle         0000000000FF7B00   >>> 0000000000FF79E0  mov         rax,qword ptr [rsi+88h]   >>> 0000000000FF79E7  mov         rdx,qword ptr [rsi+30h]   >>> 0000000000FF79EB  lea         rbx,[rsp+30h]   >>> 0000000000FF79F0  lea         rcx,[rsi+38h]   >>> 0000000000FF79F4  mov         r9d,r12d   >>> 0000000000FF79F7  lea         r12,[rsi+88h]   >>> 0000000000FF79FE  mov         r8,rdi   >>> 0000000000FF7A01  mov         ebp,dword ptr [rax+4]   >>> Null deference [rdx] here ->0000000000FF7A04  mov         rax,qword ptr [rdx]   >>> 0000000000FF7A07  mov         qword ptr [rsp+20h],rcx   >>> 0000000000FF7A0C  mov         rcx,rbx   >>> 0000000000FF7A0F  call        qword ptr [rax+18h]   >>> 0000000000FF7A12  mov         rdx,rbx   >>> 0000000000FF7A15  mov         rcx,r12   >>> 0000000000FF7A18  call        00000000010440F0   >>> 0000000000FF7A1D  mov         rcx,qword ptr [rsp+30h]   >>> 0000000000FF7A22  mov         eax,dword ptr [rcx]   >>> 0000000000FF7A24  test        eax,eax   >>> 0000000000FF7A26  jne         0000000000FF7AC3   >>> 0000000000FF7A2C  mov         r8d,8   >>> 0000000000FF7A32  mov         edx,2   >>> 0000000000FF7A37  call        00000000010BE1A0   >>> 0000000000FF7A3C  test        r13b,r13b   >>> 0000000000FF7A3F  jne         0000000000FF7B90   >>> 0000000000FF7A45  mov         eax,1   >>> 0000000000FF7A4A  add         rsp,4048h   >>> 0000000000FF7A51  pop         rbx   >>> 0000000000FF7A52  pop         rsi   >>> 0000000000FF7A53  pop         rdi   >>> 0000000000FF7A54  pop         rbp   >>> 0000000000FF7A55  pop         r12   >>> 0000000000FF7A57  pop         r13   >>> 0000000000FF7A59  ret   >>> 0000000000FF7A5A  nop         word ptr [rax+rax]   >>> >>> >>> On Tue, Oct 27, 2015 at 8:26 PM, Kit Adams <[hidden email][2]> wrote: >>>> On my Win8.0 machine, the 2015.10.17 build returns after a few seconds with no output. The 2014 build on the same machine returns: >>>> >>>> C:\Program Files\OpenSCAD>openscad.exe --info >>>> >>>> C:\Program Files\OpenSCAD>openscad --info >>>> OpenSCAD Version: 2014.03 >>>> Compiler, build date: GCC "4.8.1", Mar  9 2014 >>>> Boost version: 1_53 >>>> Eigen version: 3.1.3 >>>> CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, Epeck >>>> OpenCSG version: OpenCSG 1.3.2 >>>> Qt version: 4.8.5 >>>> MingW build: MingW64 >>>> GLib version: 2.36.3 >>>> OPENSCADPATH: <not set> >>>> OpenSCAD library path: >>>> >>>> >>>> GLEW version: 1.9.0 >>>> OpenGL Version: 4.3.0 - Build 10.18.14.4264 >>>> GL Renderer: Intel(R) HD Graphics 4600 >>>> GL Vendor: Intel >>>> RGBA(8888), depth(24), stencil(8) >>>> GL_ARB_framebuffer_object: yes >>>> GL_EXT_framebuffer_object: yes >>>> GL_EXT_packed_depth_stencil: yes >>>> GL context creator: WGL >>>> PNG generator: lodepng >>>> OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x1eaec74 amd64 >>>> Machine: 8664 >>>> >>>> C:\Program Files\OpenSCAD> >>>> >>>> Running openscad.exe --info crashes without output. The access violation is : >>>> Unhandled exception at 0x0000000000FF7A04 in openscad.exe: 0xC0000005: Access violation reading location 0x0000000000000000. >>>> >>>> >>>> Thanks, >>>> Kit >>>> >>>> On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] <[hidden email][3]> wrote: >>>>> >>>>> My first question would be, can the user run "openscad --info" from the command line? >>>>> >>>>> >>>>> >>>>> If you reply to this email, your message will be added to the discussion below: >>>>> http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14219.html >>>>> To unsubscribe from Access violation on starting OpenSCAD (Win8), click here. >>>>> NAML[4] >>>> >>> >> >> >> View this message in context: Re: Access violation on starting OpenSCAD (Win8)[5] >> Sent from the OpenSCAD mailing list archive[6] at Nabble.com. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _________________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org Links: 1. http:///user/SendEmail.jtp?type=node&node=14222&i=0 2. http:///user/SendEmail.jtp?type=node&node=14222&i=1 3. http:///user/SendEmail.jtp?type=node&node=14222&i=2 4. http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml 5. http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14222.html 6. http://forum.openscad.org/
DB
don bright
Thu, Oct 29, 2015 11:43 AM
Hello
A .zip package of an alternative build, using the MSYS2 Build System,
has been uploaded here (note it is rather large, >50MB)::
http://files.openscad.org/snapshots/OpenSCAD-2015.10.28-x86-64.msys2.zip
Also this build has sprinkled openscad.cc with several debug print
statements.  Running this might help diagnose the problems...
  don bright
and the stack:
Boost version: 1_53
Qt version: 4.8.5
GLEW version: 1.9.0
GL Vendor: Intel
Machine: 8664
Thanks,
Kit
NAML[4]
Hello A .zip package of an alternative build, using the MSYS2 Build System, has been uploaded here (note it is rather large, >50MB):: http://files.openscad.org/snapshots/OpenSCAD-2015.10.28-x86-64.msys2.zip Also this build has sprinkled openscad.cc with several debug print statements. Running this might help diagnose the problems... --   don bright   hmbright@fastmail.com On Tue, Oct 27, 2015, at 04:46 AM, Kit Adams wrote: > Actually, that dis-assembly and stack is for the 2015.03-1 build. The 2015.10.17 version crashes in similar code at address 0000000000F903F4 :  mov         rax,qword ptr [rdx] . > > On Tue, Oct 27, 2015 at 8:38 PM, spinorkit <kit.adams@gmail.com> wrote: >> >> and the stack: >> >openscad.exe!0000000000ff7a04()Unknown >> openscad.exe!0000000000ff867e()Unknown >> openscad.exe!0000000000ff9087()Unknown >> openscad.exe!0000000000fd3be3()Unknown >> openscad.exe!0000000000fd5ad9()Unknown >> openscad.exe!0000000000f9d6e5()Unknown >> openscad.exe!0000000000f9d9fd()Unknown >> openscad.exe!00000000004e8817()Unknown >> openscad.exe!00000000004edec1()Unknown >> openscad.exe!0000000000557eff()Unknown >> openscad.exe!00000000004013e8()Unknown >> openscad.exe!00000000004014eb()Unknown >> >> >> >> On Tue, Oct 27, 2015 at 8:36 PM, Kit Adams <[hidden email][1]> wrote: >>> In case it helps, the disassembly around the crash is: >>> 0000000000FF79B5  call        0000000001001D10   >>> 0000000000FF79BA  mov         r12,rax   >>> 0000000000FF79BD  mov         rbp,qword ptr [rsi+30h]   >>> 0000000000FF79C1  test        rbp,rbp   >>> 0000000000FF79C4  je          0000000000FF7A60   >>> 0000000000FF79CA  cmp         byte ptr [rsi+0D5h],0   >>> 0000000000FF79D1  jne         0000000000FF7A60   >>> 0000000000FF79D7  test        r12,r12   >>> 0000000000FF79DA  jle         0000000000FF7B00   >>> 0000000000FF79E0  mov         rax,qword ptr [rsi+88h]   >>> 0000000000FF79E7  mov         rdx,qword ptr [rsi+30h]   >>> 0000000000FF79EB  lea         rbx,[rsp+30h]   >>> 0000000000FF79F0  lea         rcx,[rsi+38h]   >>> 0000000000FF79F4  mov         r9d,r12d   >>> 0000000000FF79F7  lea         r12,[rsi+88h]   >>> 0000000000FF79FE  mov         r8,rdi   >>> 0000000000FF7A01  mov         ebp,dword ptr [rax+4]   >>> Null deference [rdx] here ->0000000000FF7A04  mov         rax,qword ptr [rdx]   >>> 0000000000FF7A07  mov         qword ptr [rsp+20h],rcx   >>> 0000000000FF7A0C  mov         rcx,rbx   >>> 0000000000FF7A0F  call        qword ptr [rax+18h]   >>> 0000000000FF7A12  mov         rdx,rbx   >>> 0000000000FF7A15  mov         rcx,r12   >>> 0000000000FF7A18  call        00000000010440F0   >>> 0000000000FF7A1D  mov         rcx,qword ptr [rsp+30h]   >>> 0000000000FF7A22  mov         eax,dword ptr [rcx]   >>> 0000000000FF7A24  test        eax,eax   >>> 0000000000FF7A26  jne         0000000000FF7AC3   >>> 0000000000FF7A2C  mov         r8d,8   >>> 0000000000FF7A32  mov         edx,2   >>> 0000000000FF7A37  call        00000000010BE1A0   >>> 0000000000FF7A3C  test        r13b,r13b   >>> 0000000000FF7A3F  jne         0000000000FF7B90   >>> 0000000000FF7A45  mov         eax,1   >>> 0000000000FF7A4A  add         rsp,4048h   >>> 0000000000FF7A51  pop         rbx   >>> 0000000000FF7A52  pop         rsi   >>> 0000000000FF7A53  pop         rdi   >>> 0000000000FF7A54  pop         rbp   >>> 0000000000FF7A55  pop         r12   >>> 0000000000FF7A57  pop         r13   >>> 0000000000FF7A59  ret   >>> 0000000000FF7A5A  nop         word ptr [rax+rax]   >>> >>> >>> On Tue, Oct 27, 2015 at 8:26 PM, Kit Adams <[hidden email][2]> wrote: >>>> On my Win8.0 machine, the 2015.10.17 build returns after a few seconds with no output. The 2014 build on the same machine returns: >>>> >>>> C:\Program Files\OpenSCAD>openscad.exe --info >>>> >>>> C:\Program Files\OpenSCAD>openscad --info >>>> OpenSCAD Version: 2014.03 >>>> Compiler, build date: GCC "4.8.1", Mar  9 2014 >>>> Boost version: 1_53 >>>> Eigen version: 3.1.3 >>>> CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, Epeck >>>> OpenCSG version: OpenCSG 1.3.2 >>>> Qt version: 4.8.5 >>>> MingW build: MingW64 >>>> GLib version: 2.36.3 >>>> OPENSCADPATH: <not set> >>>> OpenSCAD library path: >>>> >>>> >>>> GLEW version: 1.9.0 >>>> OpenGL Version: 4.3.0 - Build 10.18.14.4264 >>>> GL Renderer: Intel(R) HD Graphics 4600 >>>> GL Vendor: Intel >>>> RGBA(8888), depth(24), stencil(8) >>>> GL_ARB_framebuffer_object: yes >>>> GL_EXT_framebuffer_object: yes >>>> GL_EXT_packed_depth_stencil: yes >>>> GL context creator: WGL >>>> PNG generator: lodepng >>>> OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x1eaec74 amd64 >>>> Machine: 8664 >>>> >>>> C:\Program Files\OpenSCAD> >>>> >>>> Running openscad.exe --info crashes without output. The access violation is : >>>> Unhandled exception at 0x0000000000FF7A04 in openscad.exe: 0xC0000005: Access violation reading location 0x0000000000000000. >>>> >>>> >>>> Thanks, >>>> Kit >>>> >>>> On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] <[hidden email][3]> wrote: >>>>> >>>>> My first question would be, can the user run "openscad --info" from the command line? >>>>> >>>>> >>>>> >>>>> If you reply to this email, your message will be added to the discussion below: >>>>> http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14219.html >>>>> To unsubscribe from Access violation on starting OpenSCAD (Win8), click here. >>>>> NAML[4] >>>> >>> >> >> >> View this message in context: Re: Access violation on starting OpenSCAD (Win8)[5] >> Sent from the OpenSCAD mailing list archive[6] at Nabble.com. >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _________________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org Links: 1. http:///user/SendEmail.jtp?type=node&node=14222&i=0 2. http:///user/SendEmail.jtp?type=node&node=14222&i=1 3. http:///user/SendEmail.jtp?type=node&node=14222&i=2 4. http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml 5. http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14222.html 6. http://forum.openscad.org/
S
spinorkit
Thu, Oct 29, 2015 10:01 PM
Thanks for the debug build.
It gets a bit further.
Running openscad results in the error message in the attached screen shot
before it terminates.
The openscad --info command now gives:
C:\Users\Kit\Downloads\OpenSCAD-2015.10.28-x86-64.msys2\openscad-2015.10.28>openscad
--info
debug pt 0
debug pt 1
debug pt 2
debug pt 3
debug pt 4
debug pt 5
debug pt 6
debug pt 7
debug pt 8
debug pt 9
debug pt 10
debug pt 11
debug pt 12
debug pt 13
debug pt 14
debug pt 15
debug pt 16
debug pt 17
debug pt 18
OpenSCAD Version: 2015.10.28
System information: Windows 8 (v6.2.0.0) 8 CPUs 15.88 GB RAM
Compiler: GCC "5.2.0" 64bit
Boost version: 1_57
Eigen version: 3.2.5
CGAL version, kernels: 4.6.1, Cartesian<Gmpq>, Extended_cartesian<Gmpq>,
Epeck
OpenCSG version: OpenCSG 1.4.0
Qt version: 5.5.0
QScintilla version: 2.9
GLib version: 2.44.1
Application Path:
C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28
Documents Path: E:\Users\Kit\Documents
Resource Path:
User Library Path: E:/Users/Kit/Documents/OpenSCAD/libraries
User Config Path: C:\Users\Kit\AppData\Local/OpenSCAD
Backup Path: E:/Users/Kit/Documents/OpenSCAD/backups
C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28\libraries
OPENSCAD_FONT_PATH: <not set>
OpenSCAD font path:
GLEW version: 1.12.0
GL Vendor: Intel
OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x23d0f4 amd64
Machine: 8664
On Fri, Oct 30, 2015 at 12:44 AM, donbright [via OpenSCAD] <
ml-node+s1091067n14244h9@n5.nabble.com> wrote:
Hello
don bright
[hidden email] http:///user/SendEmail.jtp?type=node&node=14244&i=0
On Tue, Oct 27, 2015 at 8:38 PM, spinorkit <[hidden email]
http:///user/SendEmail.jtp?type=node&node=14244&i=1> wrote:
and the stack:
[rdx]
Boost version: 1_53
Epeck
Qt version: 4.8.5
GLEW version: 1.9.0
GL Vendor: Intel
Machine: 8664
is :
Thanks,
Kit
command line?
below:
here.
NAML
(Win8)
at Nabble.com.
[hidden email] http:///user/SendEmail.jtp?type=node&node=14244&i=2
[hidden email] http:///user/SendEmail.jtp?type=node&node=14244&i=3
[hidden email] http:///user/SendEmail.jtp?type=node&node=14244&i=4
below:
http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14244.html
here
NAML
OpenSCAD.png (9K) http://forum.openscad.org/attachment/14246/0/OpenSCAD.png
View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14246.html
Thanks for the debug build. It gets a bit further. Running openscad results in the error message in the attached screen shot before it terminates. The openscad --info command now gives: C:\Users\Kit\Downloads\OpenSCAD-2015.10.28-x86-64.msys2\openscad-2015.10.28>openscad --info debug pt 0 debug pt 1 debug pt 2 debug pt 3 debug pt 4 debug pt 5 debug pt 6 debug pt 7 debug pt 8 debug pt 9 debug pt 10 debug pt 11 debug pt 12 debug pt 13 debug pt 14 debug pt 15 debug pt 16 debug pt 17 debug pt 18 OpenSCAD Version: 2015.10.28 System information: Windows 8 (v6.2.0.0) 8 CPUs 15.88 GB RAM Compiler: GCC "5.2.0" 64bit Boost version: 1_57 Eigen version: 3.2.5 CGAL version, kernels: 4.6.1, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, Epeck OpenCSG version: OpenCSG 1.4.0 Qt version: 5.5.0 QScintilla version: 2.9 MingW build: MingW64 GLib version: 2.44.1 Application Path: C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28 Documents Path: E:\Users\Kit\Documents Resource Path: C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28 User Library Path: E:/Users/Kit/Documents/OpenSCAD/libraries User Config Path: C:\Users\Kit\AppData\Local/OpenSCAD Backup Path: E:/Users/Kit/Documents/OpenSCAD/backups OPENSCADPATH: <not set> OpenSCAD library path: E:/Users/Kit/Documents/OpenSCAD/libraries C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28\libraries OPENSCAD_FONT_PATH: <not set> OpenSCAD font path: GLEW version: 1.12.0 OpenGL Version: 4.3.0 - Build 10.18.14.4264 GL Renderer: Intel(R) HD Graphics 4600 GL Vendor: Intel RGBA(8888), depth(24), stencil(8) GL_ARB_framebuffer_object: yes GL_EXT_framebuffer_object: yes GL_EXT_packed_depth_stencil: yes GL context creator: WGL PNG generator: lodepng OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x23d0f4 amd64 Machine: 8664 C:\Users\Kit\Downloads\OpenSCAD-2015.10.28-x86-64.msys2\openscad-2015.10.28> On Fri, Oct 30, 2015 at 12:44 AM, donbright [via OpenSCAD] < ml-node+s1091067n14244h9@n5.nabble.com> wrote: > Hello > > A .zip package of an alternative build, using the MSYS2 Build System, has > been uploaded here (note it is rather large, >50MB):: > > http://files.openscad.org/snapshots/OpenSCAD-2015.10.28-x86-64.msys2.zip > > Also this build has sprinkled openscad.cc with several debug print > statements. Running this might help diagnose the problems... > > -- > don bright > [hidden email] <http:///user/SendEmail.jtp?type=node&node=14244&i=0> > > On Tue, Oct 27, 2015, at 04:46 AM, Kit Adams wrote: > > Actually, that dis-assembly and stack is for the 2015.03-1 build. The > 2015.10.17 version crashes in similar code at address 0000000000F903F4 : > mov rax,qword ptr [rdx] . > > On Tue, Oct 27, 2015 at 8:38 PM, spinorkit <[hidden email] > <http:///user/SendEmail.jtp?type=node&node=14244&i=1>> wrote: > > > and the stack: > >openscad.exe!0000000000ff7a04()Unknown > openscad.exe!0000000000ff867e()Unknown > openscad.exe!0000000000ff9087()Unknown > openscad.exe!0000000000fd3be3()Unknown > openscad.exe!0000000000fd5ad9()Unknown > openscad.exe!0000000000f9d6e5()Unknown > openscad.exe!0000000000f9d9fd()Unknown > openscad.exe!00000000004e8817()Unknown > openscad.exe!00000000004edec1()Unknown > openscad.exe!0000000000557eff()Unknown > openscad.exe!00000000004013e8()Unknown > openscad.exe!00000000004014eb()Unknown > > > > On Tue, Oct 27, 2015 at 8:36 PM, Kit Adams <[hidden email] > <http:///user/SendEmail.jtp?type=node&node=14222&i=0>> wrote: > > In case it helps, the disassembly around the crash is: > 0000000000FF79B5 call 0000000001001D10 > 0000000000FF79BA mov r12,rax > 0000000000FF79BD mov rbp,qword ptr [rsi+30h] > 0000000000FF79C1 test rbp,rbp > 0000000000FF79C4 je 0000000000FF7A60 > 0000000000FF79CA cmp byte ptr [rsi+0D5h],0 > 0000000000FF79D1 jne 0000000000FF7A60 > 0000000000FF79D7 test r12,r12 > 0000000000FF79DA jle 0000000000FF7B00 > 0000000000FF79E0 mov rax,qword ptr [rsi+88h] > 0000000000FF79E7 mov rdx,qword ptr [rsi+30h] > 0000000000FF79EB lea rbx,[rsp+30h] > 0000000000FF79F0 lea rcx,[rsi+38h] > 0000000000FF79F4 mov r9d,r12d > 0000000000FF79F7 lea r12,[rsi+88h] > 0000000000FF79FE mov r8,rdi > 0000000000FF7A01 mov ebp,dword ptr [rax+4] > Null deference [rdx] here ->0000000000FF7A04 mov rax,qword ptr > [rdx] > 0000000000FF7A07 mov qword ptr [rsp+20h],rcx > 0000000000FF7A0C mov rcx,rbx > 0000000000FF7A0F call qword ptr [rax+18h] > 0000000000FF7A12 mov rdx,rbx > 0000000000FF7A15 mov rcx,r12 > 0000000000FF7A18 call 00000000010440F0 > 0000000000FF7A1D mov rcx,qword ptr [rsp+30h] > 0000000000FF7A22 mov eax,dword ptr [rcx] > 0000000000FF7A24 test eax,eax > 0000000000FF7A26 jne 0000000000FF7AC3 > 0000000000FF7A2C mov r8d,8 > 0000000000FF7A32 mov edx,2 > 0000000000FF7A37 call 00000000010BE1A0 > 0000000000FF7A3C test r13b,r13b > 0000000000FF7A3F jne 0000000000FF7B90 > 0000000000FF7A45 mov eax,1 > 0000000000FF7A4A add rsp,4048h > 0000000000FF7A51 pop rbx > 0000000000FF7A52 pop rsi > 0000000000FF7A53 pop rdi > 0000000000FF7A54 pop rbp > 0000000000FF7A55 pop r12 > 0000000000FF7A57 pop r13 > 0000000000FF7A59 ret > 0000000000FF7A5A nop word ptr [rax+rax] > > > On Tue, Oct 27, 2015 at 8:26 PM, Kit Adams <[hidden email] > <http:///user/SendEmail.jtp?type=node&node=14222&i=1>> wrote: > > On my Win8.0 machine, the 2015.10.17 build returns after a few seconds > with no output. The 2014 build on the same machine returns: > > C:\Program Files\OpenSCAD>openscad.exe --info > > C:\Program Files\OpenSCAD>openscad --info > OpenSCAD Version: 2014.03 > Compiler, build date: GCC "4.8.1", Mar 9 2014 > Boost version: 1_53 > Eigen version: 3.1.3 > CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, > Epeck > OpenCSG version: OpenCSG 1.3.2 > Qt version: 4.8.5 > MingW build: MingW64 > GLib version: 2.36.3 > OPENSCADPATH: <not set> > OpenSCAD library path: > > > GLEW version: 1.9.0 > OpenGL Version: 4.3.0 - Build 10.18.14.4264 > GL Renderer: Intel(R) HD Graphics 4600 > GL Vendor: Intel > RGBA(8888), depth(24), stencil(8) > GL_ARB_framebuffer_object: yes > GL_EXT_framebuffer_object: yes > GL_EXT_packed_depth_stencil: yes > GL context creator: WGL > PNG generator: lodepng > OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x1eaec74 amd64 > Machine: 8664 > > C:\Program Files\OpenSCAD> > > Running openscad.exe --info crashes without output. The access violation > is : > Unhandled exception at 0x0000000000FF7A04 in openscad.exe: 0xC0000005: > Access violation reading location 0x0000000000000000. > > > Thanks, > Kit > > On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] <[hidden email] > <http:///user/SendEmail.jtp?type=node&node=14222&i=2>> wrote: > > > My first question would be, can the user run "openscad --info" from the > command line? > > ------------------------------ > > > If you reply to this email, your message will be added to the discussion > below: > > http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14219.html > To unsubscribe from Access violation on starting OpenSCAD (Win8), click > here. > NAML > <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> > > > > > > > > ------------------------------ > View this message in context: Re: Access violation on starting OpenSCAD > (Win8) > <http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14222.html> > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > [hidden email] <http:///user/SendEmail.jtp?type=node&node=14244&i=2> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > *_______________________________________________* > OpenSCAD mailing list > [hidden email] <http:///user/SendEmail.jtp?type=node&node=14244&i=3> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > _______________________________________________ > OpenSCAD mailing list > [hidden email] <http:///user/SendEmail.jtp?type=node&node=14244&i=4> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > ------------------------------ > If you reply to this email, your message will be added to the discussion > below: > > http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14244.html > To unsubscribe from Access violation on starting OpenSCAD (Win8), click > here > <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=14201&code=a2l0LmFkYW1zQGdtYWlsLmNvbXwxNDIwMXwtMTM1NzI4MDMyMQ==> > . > NAML > <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> > OpenSCAD.png (9K) <http://forum.openscad.org/attachment/14246/0/OpenSCAD.png> -- View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14246.html Sent from the OpenSCAD mailing list archive at Nabble.com.
DB
don bright
Fri, Oct 30, 2015 3:05 AM
Thanks for testing the msys2 build. Sorry about the error, it's my first
time doing QT5 on Windows.
Here is a new test MSYS2 build off the Master branch. I have tested it
on Windows 7.
http://files.openscad.org/snapshots/OpenSCAD-2015.10.29-msys2-x86-64.zip
  don bright
debug pt 0
debug pt 1
debug pt 2
debug pt 3
debug pt 4
debug pt 5
debug pt 6
debug pt 7
debug pt 8
debug pt 9
debug pt 10
debug pt 11
debug pt 12
debug pt 13
debug pt 14
debug pt 15
debug pt 16
debug pt 17
debug pt 18
Boost version: 1_57
Qt version: 5.5.0
OpenSCAD font path:
GL Vendor: Intel
Machine: 8664
On Fri, Oct 30, 2015 at 12:44 AM, donbright [via OpenSCAD] <[hidden email]> wrote:
Hello
  don bright
[hidden email][1]
On Tue, Oct 27, 2015 at 8:38 PM, spinorkit <[hidden email][2]> wrote:
and the stack:
Boost version: 1_53
Qt version: 4.8.5
GLEW version: 1.9.0
GL Vendor: Intel
Machine: 8664
Thanks,
Kit
On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] <[hidden email][5]> wrote:
NAML[6]
View this message in context: Re: Access violation on starting OpenSCAD (Win8)[7]
Sent from the OpenSCAD mailing list archive[8] at Nabble.com.
[hidden email][9]
[hidden email][11]
NAML[12]
View this message in context: Re: Access violation on starting OpenSCAD (Win8)[14]
Sent from the OpenSCAD mailing list archive[15] at Nabble.com.
Links:
  1. http:///user/SendEmail.jtp?type=node&node=14244&i=0
  2. http:///user/SendEmail.jtp?type=node&node=14244&i=1
  3. http:///user/SendEmail.jtp?type=node&node=14222&i=0
  4. http:///user/SendEmail.jtp?type=node&node=14222&i=1
  5. http:///user/SendEmail.jtp?type=node&node=14222&i=2
  6. http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
  7. http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14222.html
  8. http://forum.openscad.org/
  9. http:///user/SendEmail.jtp?type=node&node=14244&i=2
  10. http:///user/SendEmail.jtp?type=node&node=14244&i=3
  11. http:///user/SendEmail.jtp?type=node&node=14244&i=4
  12. http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml
  13. http://forum.openscad.org/attachment/14246/0/OpenSCAD.png
  14. http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14246.html
  15. http://forum.openscad.org/
Thanks for testing the msys2 build. Sorry about the error, it's my first time doing QT5 on Windows. Here is a new test MSYS2 build off the Master branch. I have tested it on Windows 7. http://files.openscad.org/snapshots/OpenSCAD-2015.10.29-msys2-x86-64.zip --   don bright   hmbright@fastmail.com On Thu, Oct 29, 2015, at 05:01 PM, spinorkit wrote: > Thanks for the debug build. > It gets a bit further. > Running openscad results in the error message in the attached screen shot before it terminates. > > The openscad --info command now gives: > > C:\Users\Kit\Downloads\OpenSCAD-2015.10.28-x86-64.msys2\openscad-2015.10.28>openscad --info > debug pt 0 > debug pt 1 > debug pt 2 > debug pt 3 > debug pt 4 > debug pt 5 > debug pt 6 > debug pt 7 > debug pt 8 > debug pt 9 > debug pt 10 > debug pt 11 > debug pt 12 > debug pt 13 > debug pt 14 > debug pt 15 > debug pt 16 > debug pt 17 > debug pt 18 > OpenSCAD Version: 2015.10.28 > System information: Windows 8 (v6.2.0.0) 8 CPUs 15.88 GB RAM > Compiler: GCC "5.2.0" 64bit > Boost version: 1_57 > Eigen version: 3.2.5 > CGAL version, kernels: 4.6.1, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, Epeck > OpenCSG version: OpenCSG 1.4.0 > Qt version: 5.5.0 > QScintilla version: 2.9 > MingW build: MingW64 > GLib version: 2.44.1 > Application Path: C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28 > Documents Path: E:\Users\Kit\Documents > Resource Path: C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28 > User Library Path: E:/Users/Kit/Documents/OpenSCAD/libraries > User Config Path: C:\Users\Kit\AppData\Local/OpenSCAD > Backup Path: E:/Users/Kit/Documents/OpenSCAD/backups > OPENSCADPATH: <not set> > OpenSCAD library path: >   E:/Users/Kit/Documents/OpenSCAD/libraries >   C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28\libraries > > OPENSCAD_FONT_PATH: <not set> > OpenSCAD font path: > > > GLEW version: 1.12.0 > OpenGL Version: 4.3.0 - Build 10.18.14.4264 > GL Renderer: Intel(R) HD Graphics 4600 > GL Vendor: Intel > RGBA(8888), depth(24), stencil(8) > GL_ARB_framebuffer_object: yes > GL_EXT_framebuffer_object: yes > GL_EXT_packed_depth_stencil: yes > GL context creator: WGL > PNG generator: lodepng > OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x23d0f4 amd64 > Machine: 8664 > > C:\Users\Kit\Downloads\OpenSCAD-2015.10.28-x86-64.msys2\openscad-2015.10.28> > > > > On Fri, Oct 30, 2015 at 12:44 AM, donbright [via OpenSCAD] <[hidden email]> wrote: >> >> Hello >> >> A .zip package of an alternative build, using the MSYS2 Build System, has been uploaded here (note it is rather large, >50MB):: >> >> http://files.openscad.org/snapshots/OpenSCAD-2015.10.28-x86-64.msys2.zip >> >> Also this build has sprinkled openscad.cc with several debug print statements. Running this might help diagnose the problems... >> >> >> -- >>   don bright >> [hidden email][1] >> >> >> On Tue, Oct 27, 2015, at 04:46 AM, Kit Adams wrote: >> >>> >>> Actually, that dis-assembly and stack is for the 2015.03-1 build. The 2015.10.17 version crashes in similar code at address 0000000000F903F4 :  mov         rax,qword ptr [rdx] . >>> >>> >>> >>> On Tue, Oct 27, 2015 at 8:38 PM, spinorkit <[hidden email][2]> wrote: >>> >>>> >>>> >>>> and the stack: >>>> >openscad.exe!0000000000ff7a04()Unknown >>>> openscad.exe!0000000000ff867e()Unknown >>>> openscad.exe!0000000000ff9087()Unknown >>>> openscad.exe!0000000000fd3be3()Unknown >>>> openscad.exe!0000000000fd5ad9()Unknown >>>> openscad.exe!0000000000f9d6e5()Unknown >>>> openscad.exe!0000000000f9d9fd()Unknown >>>> openscad.exe!00000000004e8817()Unknown >>>> openscad.exe!00000000004edec1()Unknown >>>> openscad.exe!0000000000557eff()Unknown >>>> openscad.exe!00000000004013e8()Unknown >>>> openscad.exe!00000000004014eb()Unknown >>>> >>>> >>>> >>>> >>>> On Tue, Oct 27, 2015 at 8:36 PM, Kit Adams <[hidden email][3]> wrote: >>>>> In case it helps, the disassembly around the crash is: >>>>> 0000000000FF79B5  call        0000000001001D10   >>>>> 0000000000FF79BA  mov         r12,rax   >>>>> 0000000000FF79BD  mov         rbp,qword ptr [rsi+30h]   >>>>> 0000000000FF79C1  test        rbp,rbp   >>>>> 0000000000FF79C4  je          0000000000FF7A60   >>>>> 0000000000FF79CA  cmp         byte ptr [rsi+0D5h],0   >>>>> 0000000000FF79D1  jne         0000000000FF7A60   >>>>> 0000000000FF79D7  test        r12,r12   >>>>> 0000000000FF79DA  jle         0000000000FF7B00   >>>>> 0000000000FF79E0  mov         rax,qword ptr [rsi+88h]   >>>>> 0000000000FF79E7  mov         rdx,qword ptr [rsi+30h]   >>>>> 0000000000FF79EB  lea         rbx,[rsp+30h]   >>>>> 0000000000FF79F0  lea         rcx,[rsi+38h]   >>>>> 0000000000FF79F4  mov         r9d,r12d   >>>>> 0000000000FF79F7  lea         r12,[rsi+88h]   >>>>> 0000000000FF79FE  mov         r8,rdi   >>>>> 0000000000FF7A01  mov         ebp,dword ptr [rax+4]   >>>>> Null deference [rdx] here ->0000000000FF7A04  mov         rax,qword ptr [rdx]   >>>>> 0000000000FF7A07  mov         qword ptr [rsp+20h],rcx   >>>>> 0000000000FF7A0C  mov         rcx,rbx   >>>>> 0000000000FF7A0F  call        qword ptr [rax+18h]   >>>>> 0000000000FF7A12  mov         rdx,rbx   >>>>> 0000000000FF7A15  mov         rcx,r12   >>>>> 0000000000FF7A18  call        00000000010440F0   >>>>> 0000000000FF7A1D  mov         rcx,qword ptr [rsp+30h]   >>>>> 0000000000FF7A22  mov         eax,dword ptr [rcx]   >>>>> 0000000000FF7A24  test        eax,eax   >>>>> 0000000000FF7A26  jne         0000000000FF7AC3   >>>>> 0000000000FF7A2C  mov         r8d,8   >>>>> 0000000000FF7A32  mov         edx,2   >>>>> 0000000000FF7A37  call        00000000010BE1A0   >>>>> 0000000000FF7A3C  test        r13b,r13b   >>>>> 0000000000FF7A3F  jne         0000000000FF7B90   >>>>> 0000000000FF7A45  mov         eax,1   >>>>> 0000000000FF7A4A  add         rsp,4048h   >>>>> 0000000000FF7A51  pop         rbx   >>>>> 0000000000FF7A52  pop         rsi   >>>>> 0000000000FF7A53  pop         rdi   >>>>> 0000000000FF7A54  pop         rbp   >>>>> 0000000000FF7A55  pop         r12   >>>>> 0000000000FF7A57  pop         r13   >>>>> 0000000000FF7A59  ret   >>>>> 0000000000FF7A5A  nop         word ptr [rax+rax]   >>>>> >>>>> >>>>> On Tue, Oct 27, 2015 at 8:26 PM, Kit Adams <[hidden email][4]> wrote: >>>>>> On my Win8.0 machine, the 2015.10.17 build returns after a few seconds with no output. The 2014 build on the same machine returns: >>>>>> >>>>>> C:\Program Files\OpenSCAD>openscad.exe --info >>>>>> >>>>>> C:\Program Files\OpenSCAD>openscad --info >>>>>> OpenSCAD Version: 2014.03 >>>>>> Compiler, build date: GCC "4.8.1", Mar  9 2014 >>>>>> Boost version: 1_53 >>>>>> Eigen version: 3.1.3 >>>>>> CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, Epeck >>>>>> OpenCSG version: OpenCSG 1.3.2 >>>>>> Qt version: 4.8.5 >>>>>> MingW build: MingW64 >>>>>> GLib version: 2.36.3 >>>>>> OPENSCADPATH: <not set> >>>>>> OpenSCAD library path: >>>>>> >>>>>> >>>>>> GLEW version: 1.9.0 >>>>>> OpenGL Version: 4.3.0 - Build 10.18.14.4264 >>>>>> GL Renderer: Intel(R) HD Graphics 4600 >>>>>> GL Vendor: Intel >>>>>> RGBA(8888), depth(24), stencil(8) >>>>>> GL_ARB_framebuffer_object: yes >>>>>> GL_EXT_framebuffer_object: yes >>>>>> GL_EXT_packed_depth_stencil: yes >>>>>> GL context creator: WGL >>>>>> PNG generator: lodepng >>>>>> OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x1eaec74 amd64 >>>>>> Machine: 8664 >>>>>> >>>>>> C:\Program Files\OpenSCAD> >>>>>> >>>>>> Running openscad.exe --info crashes without output. The access violation is : >>>>>> Unhandled exception at 0x0000000000FF7A04 in openscad.exe: 0xC0000005: Access violation reading location 0x0000000000000000. >>>>>> >>>>>> >>>>>> Thanks, >>>>>> Kit >>>>>> >>>>>> On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] <[hidden email][5]> wrote: >>>>>>> >>>>>>> My first question would be, can the user run "openscad --info" from the command line? >>>>>>> >>>>>>> >>>>>>> >>>>>>> If you reply to this email, your message will be added to the discussion below: >>>>>>> http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14219.html >>>>>>> To unsubscribe from Access violation on starting OpenSCAD (Win8), click here. >>>>>>> NAML[6] >>>>>> >>>>> >>>> >>>> >>>> View this message in context: Re: Access violation on starting OpenSCAD (Win8)[7] >>>> Sent from the OpenSCAD mailing list archive[8] at Nabble.com. >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> [hidden email][9] >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>> _________________________________________________ >>> OpenSCAD mailing list >>> [hidden email][10] >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >> _______________________________________________ >> >> OpenSCAD mailing list >> >> [hidden email][11] >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >> >> >> If you reply to this email, your message will be added to the discussion below: >> http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14244.html >> To unsubscribe from Access violation on starting OpenSCAD (Win8), click here. >> NAML[12] > > > *OpenSCAD.png* (9K) Download Attachment[13] > > View this message in context: Re: Access violation on starting OpenSCAD (Win8)[14] > Sent from the OpenSCAD mailing list archive[15] at Nabble.com. > _________________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org Links: 1. http:///user/SendEmail.jtp?type=node&node=14244&i=0 2. http:///user/SendEmail.jtp?type=node&node=14244&i=1 3. http:///user/SendEmail.jtp?type=node&node=14222&i=0 4. http:///user/SendEmail.jtp?type=node&node=14222&i=1 5. http:///user/SendEmail.jtp?type=node&node=14222&i=2 6. http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml 7. http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14222.html 8. http://forum.openscad.org/ 9. http:///user/SendEmail.jtp?type=node&node=14244&i=2 10. http:///user/SendEmail.jtp?type=node&node=14244&i=3 11. http:///user/SendEmail.jtp?type=node&node=14244&i=4 12. http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml 13. http://forum.openscad.org/attachment/14246/0/OpenSCAD.png 14. http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14246.html 15. http://forum.openscad.org/
S
spinorkit
Fri, Oct 30, 2015 9:12 AM
This latest version runs fine.
I just had to check "Force Goldfeather" for the Preview to render correctly.
Many thanks,
Kit
On Fri, Oct 30, 2015 at 4:07 PM, donbright [via OpenSCAD] <
Windows 7.
don bright
[hidden email] http:///user/SendEmail.jtp?type=node&node=14247&i=0
--info
debug pt 0
debug pt 1
debug pt 2
debug pt 3
debug pt 4
debug pt 5
debug pt 6
debug pt 7
debug pt 8
debug pt 9
debug pt 10
debug pt 11
debug pt 12
debug pt 13
debug pt 14
debug pt 15
debug pt 16
debug pt 17
debug pt 18
Boost version: 1_57
Epeck
Qt version: 5.5.0
Application Path:
Resource Path:
OpenSCAD font path:
GL Vendor: Intel
Machine: 8664
Hello
don bright
and the stack:
[rdx]
Boost version: 1_53
Epeck
Qt version: 4.8.5
GLEW version: 1.9.0
GL Vendor: Intel
Machine: 8664
is :
Thanks,
Kit
command line?
below:
here.
NAML
(Win8)
at Nabble.com.
below:
here.
NAML
(Win8)
at Nabble.com.
[hidden email] http:///user/SendEmail.jtp?type=node&node=14247&i=1
[hidden email] http:///user/SendEmail.jtp?type=node&node=14247&i=2
below:
http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14247.html
here
NAML
View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14250.html
This latest version runs fine. I just had to check "Force Goldfeather" for the Preview to render correctly. Many thanks, Kit On Fri, Oct 30, 2015 at 4:07 PM, donbright [via OpenSCAD] < ml-node+s1091067n14247h2@n5.nabble.com> wrote: > > Thanks for testing the msys2 build. Sorry about the error, it's my first > time doing QT5 on Windows. > > Here is a new test MSYS2 build off the Master branch. I have tested it on > Windows 7. > > http://files.openscad.org/snapshots/OpenSCAD-2015.10.29-msys2-x86-64.zip > > -- > don bright > [hidden email] <http:///user/SendEmail.jtp?type=node&node=14247&i=0> > > > On Thu, Oct 29, 2015, at 05:01 PM, spinorkit wrote: > > Thanks for the debug build. > It gets a bit further. > Running openscad results in the error message in the attached screen shot > before it terminates. > > The openscad --info command now gives: > > C:\Users\Kit\Downloads\OpenSCAD-2015.10.28-x86-64.msys2\openscad-2015.10.28>openscad > --info > debug pt 0 > debug pt 1 > debug pt 2 > debug pt 3 > debug pt 4 > debug pt 5 > debug pt 6 > debug pt 7 > debug pt 8 > debug pt 9 > debug pt 10 > debug pt 11 > debug pt 12 > debug pt 13 > debug pt 14 > debug pt 15 > debug pt 16 > debug pt 17 > debug pt 18 > OpenSCAD Version: 2015.10.28 > System information: Windows 8 (v6.2.0.0) 8 CPUs 15.88 GB RAM > Compiler: GCC "5.2.0" 64bit > Boost version: 1_57 > Eigen version: 3.2.5 > CGAL version, kernels: 4.6.1, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, > Epeck > OpenCSG version: OpenCSG 1.4.0 > Qt version: 5.5.0 > QScintilla version: 2.9 > MingW build: MingW64 > GLib version: 2.44.1 > Application Path: > C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28 > Documents Path: E:\Users\Kit\Documents > Resource Path: > C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28 > User Library Path: E:/Users/Kit/Documents/OpenSCAD/libraries > User Config Path: C:\Users\Kit\AppData\Local/OpenSCAD > Backup Path: E:/Users/Kit/Documents/OpenSCAD/backups > OPENSCADPATH: <not set> > OpenSCAD library path: > E:/Users/Kit/Documents/OpenSCAD/libraries > > C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28\libraries > > OPENSCAD_FONT_PATH: <not set> > OpenSCAD font path: > > > GLEW version: 1.12.0 > OpenGL Version: 4.3.0 - Build 10.18.14.4264 > GL Renderer: Intel(R) HD Graphics 4600 > GL Vendor: Intel > RGBA(8888), depth(24), stencil(8) > GL_ARB_framebuffer_object: yes > GL_EXT_framebuffer_object: yes > GL_EXT_packed_depth_stencil: yes > GL context creator: WGL > PNG generator: lodepng > OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x23d0f4 amd64 > Machine: 8664 > > > C:\Users\Kit\Downloads\OpenSCAD-2015.10.28-x86-64.msys2\openscad-2015.10.28> > > > > On Fri, Oct 30, 2015 at 12:44 AM, donbright [via OpenSCAD] <[hidden email] > > wrote: > > > Hello > > A .zip package of an alternative build, using the MSYS2 Build System, has > been uploaded here (note it is rather large, >50MB):: > > http://files.openscad.org/snapshots/OpenSCAD-2015.10.28-x86-64.msys2.zip > > Also this build has sprinkled openscad.cc with several debug print > statements. Running this might help diagnose the problems... > > > -- > don bright > [hidden email] <http:///user/SendEmail.jtp?type=node&node=14244&i=0> > > > On Tue, Oct 27, 2015, at 04:46 AM, Kit Adams wrote: > > > > Actually, that dis-assembly and stack is for the 2015.03-1 build. The > 2015.10.17 version crashes in similar code at address 0000000000F903F4 : > mov rax,qword ptr [rdx] . > > > > On Tue, Oct 27, 2015 at 8:38 PM, spinorkit <[hidden email] > <http:///user/SendEmail.jtp?type=node&node=14244&i=1>> wrote: > > > > > and the stack: > >openscad.exe!0000000000ff7a04()Unknown > openscad.exe!0000000000ff867e()Unknown > openscad.exe!0000000000ff9087()Unknown > openscad.exe!0000000000fd3be3()Unknown > openscad.exe!0000000000fd5ad9()Unknown > openscad.exe!0000000000f9d6e5()Unknown > openscad.exe!0000000000f9d9fd()Unknown > openscad.exe!00000000004e8817()Unknown > openscad.exe!00000000004edec1()Unknown > openscad.exe!0000000000557eff()Unknown > openscad.exe!00000000004013e8()Unknown > openscad.exe!00000000004014eb()Unknown > > > > > On Tue, Oct 27, 2015 at 8:36 PM, Kit Adams <[hidden email] > <http:///user/SendEmail.jtp?type=node&node=14222&i=0>> wrote: > > In case it helps, the disassembly around the crash is: > 0000000000FF79B5 call 0000000001001D10 > 0000000000FF79BA mov r12,rax > 0000000000FF79BD mov rbp,qword ptr [rsi+30h] > 0000000000FF79C1 test rbp,rbp > 0000000000FF79C4 je 0000000000FF7A60 > 0000000000FF79CA cmp byte ptr [rsi+0D5h],0 > 0000000000FF79D1 jne 0000000000FF7A60 > 0000000000FF79D7 test r12,r12 > 0000000000FF79DA jle 0000000000FF7B00 > 0000000000FF79E0 mov rax,qword ptr [rsi+88h] > 0000000000FF79E7 mov rdx,qword ptr [rsi+30h] > 0000000000FF79EB lea rbx,[rsp+30h] > 0000000000FF79F0 lea rcx,[rsi+38h] > 0000000000FF79F4 mov r9d,r12d > 0000000000FF79F7 lea r12,[rsi+88h] > 0000000000FF79FE mov r8,rdi > 0000000000FF7A01 mov ebp,dword ptr [rax+4] > Null deference [rdx] here ->0000000000FF7A04 mov rax,qword ptr > [rdx] > 0000000000FF7A07 mov qword ptr [rsp+20h],rcx > 0000000000FF7A0C mov rcx,rbx > 0000000000FF7A0F call qword ptr [rax+18h] > 0000000000FF7A12 mov rdx,rbx > 0000000000FF7A15 mov rcx,r12 > 0000000000FF7A18 call 00000000010440F0 > 0000000000FF7A1D mov rcx,qword ptr [rsp+30h] > 0000000000FF7A22 mov eax,dword ptr [rcx] > 0000000000FF7A24 test eax,eax > 0000000000FF7A26 jne 0000000000FF7AC3 > 0000000000FF7A2C mov r8d,8 > 0000000000FF7A32 mov edx,2 > 0000000000FF7A37 call 00000000010BE1A0 > 0000000000FF7A3C test r13b,r13b > 0000000000FF7A3F jne 0000000000FF7B90 > 0000000000FF7A45 mov eax,1 > 0000000000FF7A4A add rsp,4048h > 0000000000FF7A51 pop rbx > 0000000000FF7A52 pop rsi > 0000000000FF7A53 pop rdi > 0000000000FF7A54 pop rbp > 0000000000FF7A55 pop r12 > 0000000000FF7A57 pop r13 > 0000000000FF7A59 ret > 0000000000FF7A5A nop word ptr [rax+rax] > > > On Tue, Oct 27, 2015 at 8:26 PM, Kit Adams <[hidden email] > <http:///user/SendEmail.jtp?type=node&node=14222&i=1>> wrote: > > On my Win8.0 machine, the 2015.10.17 build returns after a few seconds > with no output. The 2014 build on the same machine returns: > > C:\Program Files\OpenSCAD>openscad.exe --info > > C:\Program Files\OpenSCAD>openscad --info > OpenSCAD Version: 2014.03 > Compiler, build date: GCC "4.8.1", Mar 9 2014 > Boost version: 1_53 > Eigen version: 3.1.3 > CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, > Epeck > OpenCSG version: OpenCSG 1.3.2 > Qt version: 4.8.5 > MingW build: MingW64 > GLib version: 2.36.3 > OPENSCADPATH: <not set> > OpenSCAD library path: > > > GLEW version: 1.9.0 > OpenGL Version: 4.3.0 - Build 10.18.14.4264 > GL Renderer: Intel(R) HD Graphics 4600 > GL Vendor: Intel > RGBA(8888), depth(24), stencil(8) > GL_ARB_framebuffer_object: yes > GL_EXT_framebuffer_object: yes > GL_EXT_packed_depth_stencil: yes > GL context creator: WGL > PNG generator: lodepng > OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x1eaec74 amd64 > Machine: 8664 > > C:\Program Files\OpenSCAD> > > Running openscad.exe --info crashes without output. The access violation > is : > Unhandled exception at 0x0000000000FF7A04 in openscad.exe: 0xC0000005: > Access violation reading location 0x0000000000000000. > > > Thanks, > Kit > > On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] <[hidden email] > <http:///user/SendEmail.jtp?type=node&node=14222&i=2>> wrote: > > > My first question would be, can the user run "openscad --info" from the > command line? > > ------------------------------ > > > If you reply to this email, your message will be added to the discussion > below: > > http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14219.html > To unsubscribe from Access violation on starting OpenSCAD (Win8), click > here. > NAML > <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> > > > > > > > > ------------------------------ > View this message in context: Re: Access violation on starting OpenSCAD > (Win8) > <http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14222.html> > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > [hidden email] <http:///user/SendEmail.jtp?type=node&node=14244&i=2> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > *_______________________________________________* > OpenSCAD mailing list > [hidden email] <http:///user/SendEmail.jtp?type=node&node=14244&i=3> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > _______________________________________________ > OpenSCAD mailing list > [hidden email] <http:///user/SendEmail.jtp?type=node&node=14244&i=4> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > ------------------------------ > > > If you reply to this email, your message will be added to the discussion > below: > > http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14244.html > To unsubscribe from Access violation on starting OpenSCAD (Win8), click > here. > NAML > <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> > > > > *OpenSCAD.png* (9K) Download Attachment > <http://forum.openscad.org/attachment/14246/0/OpenSCAD.png> > > ------------------------------ > View this message in context: Re: Access violation on starting OpenSCAD > (Win8) > <http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14246.html> > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > *_______________________________________________* > OpenSCAD mailing list > [hidden email] <http:///user/SendEmail.jtp?type=node&node=14247&i=1> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > _______________________________________________ > OpenSCAD mailing list > [hidden email] <http:///user/SendEmail.jtp?type=node&node=14247&i=2> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > ------------------------------ > If you reply to this email, your message will be added to the discussion > below: > > http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14247.html > To unsubscribe from Access violation on starting OpenSCAD (Win8), click > here > <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=14201&code=a2l0LmFkYW1zQGdtYWlsLmNvbXwxNDIwMXwtMTM1NzI4MDMyMQ==> > . > NAML > <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> > -- View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14250.html Sent from the OpenSCAD mailing list archive at Nabble.com.
