Hi Don,
I am curious, did you fix an issue, or was it using the MSYS2 build process
that solved the problem, or was it the debug build that prevented the
crash, or was it already fixed in the master?
Thanks,
Kit
On Fri, Oct 30, 2015 at 10:12 PM, spinorkit kit.adams@gmail.com wrote:
This latest version runs fine.
I just had to check "Force Goldfeather" for the Preview to render
correctly.
Many thanks,
Kit
On Fri, Oct 30, 2015 at 4:07 PM, donbright [via OpenSCAD] <[hidden email]
http:///user/SendEmail.jtp?type=node&node=14250&i=0> wrote:
Thanks for testing the msys2 build. Sorry about the error, it's my first
time doing QT5 on Windows.
Here is a new test MSYS2 build off the Master branch. I have tested it on
Windows 7.
http://files.openscad.org/snapshots/OpenSCAD-2015.10.29-msys2-x86-64.zip
don bright
[hidden email] http:///user/SendEmail.jtp?type=node&node=14247&i=0
On Thu, Oct 29, 2015, at 05:01 PM, spinorkit wrote:
Thanks for the debug build.
It gets a bit further.
Running openscad results in the error message in the attached screen shot
before it terminates.
The openscad --info command now gives:
C:\Users\Kit\Downloads\OpenSCAD-2015.10.28-x86-64.msys2\openscad-2015.10.28>openscad
--info
debug pt 0
debug pt 1
debug pt 2
debug pt 3
debug pt 4
debug pt 5
debug pt 6
debug pt 7
debug pt 8
debug pt 9
debug pt 10
debug pt 11
debug pt 12
debug pt 13
debug pt 14
debug pt 15
debug pt 16
debug pt 17
debug pt 18
OpenSCAD Version: 2015.10.28
System information: Windows 8 (v6.2.0.0) 8 CPUs 15.88 GB RAM
Compiler: GCC "5.2.0" 64bit
Boost version: 1_57
Eigen version: 3.2.5
CGAL version, kernels: 4.6.1, Cartesian<Gmpq>, Extended_cartesian<Gmpq>,
Epeck
OpenCSG version: OpenCSG 1.4.0
Qt version: 5.5.0
QScintilla version: 2.9
MingW build: MingW64
GLib version: 2.44.1
Application Path:
C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28
Documents Path: E:\Users\Kit\Documents
Resource Path:
User Library Path: E:/Users/Kit/Documents/OpenSCAD/libraries
User Config Path: C:\Users\Kit\AppData\Local/OpenSCAD
Backup Path: E:/Users/Kit/Documents/OpenSCAD/backups
OPENSCADPATH: <not set>
OpenSCAD library path:
C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28\libraries
OPENSCAD_FONT_PATH: <not set>
OpenSCAD font path:
GLEW version: 1.12.0
OpenGL Version: 4.3.0 - Build 10.18.14.4264
GL Renderer: Intel(R) HD Graphics 4600
GL Vendor: Intel
RGBA(8888), depth(24), stencil(8)
GL_ARB_framebuffer_object: yes
GL_EXT_framebuffer_object: yes
GL_EXT_packed_depth_stencil: yes
GL context creator: WGL
PNG generator: lodepng
OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x23d0f4 amd64
Machine: 8664
On Fri, Oct 30, 2015 at 12:44 AM, donbright [via OpenSCAD] <[hidden
email]> wrote:
Hello
A .zip package of an alternative build, using the MSYS2 Build System, has
been uploaded here (note it is rather large, >50MB)::
http://files.openscad.org/snapshots/OpenSCAD-2015.10.28-x86-64.msys2.zip
Also this build has sprinkled openscad.cc with several debug print
statements. Running this might help diagnose the problems...
don bright
[hidden email] http:///user/SendEmail.jtp?type=node&node=14244&i=0
On Tue, Oct 27, 2015, at 04:46 AM, Kit Adams wrote:
Actually, that dis-assembly and stack is for the 2015.03-1 build. The
2015.10.17 version crashes in similar code at address 0000000000F903F4 :
mov rax,qword ptr [rdx] .
On Tue, Oct 27, 2015 at 8:38 PM, spinorkit <[hidden email]
http:///user/SendEmail.jtp?type=node&node=14244&i=1> wrote:
and the stack:
openscad.exe!0000000000ff7a04()Unknown
openscad.exe!0000000000ff867e()Unknown
openscad.exe!0000000000ff9087()Unknown
openscad.exe!0000000000fd3be3()Unknown
openscad.exe!0000000000fd5ad9()Unknown
openscad.exe!0000000000f9d6e5()Unknown
openscad.exe!0000000000f9d9fd()Unknown
openscad.exe!00000000004e8817()Unknown
openscad.exe!00000000004edec1()Unknown
openscad.exe!0000000000557eff()Unknown
openscad.exe!00000000004013e8()Unknown
openscad.exe!00000000004014eb()Unknown
On Tue, Oct 27, 2015 at 8:36 PM, Kit Adams <[hidden email]
http:///user/SendEmail.jtp?type=node&node=14222&i=0> wrote:
In case it helps, the disassembly around the crash is:
0000000000FF79B5 call 0000000001001D10
0000000000FF79BA mov r12,rax
0000000000FF79BD mov rbp,qword ptr [rsi+30h]
0000000000FF79C1 test rbp,rbp
0000000000FF79C4 je 0000000000FF7A60
0000000000FF79CA cmp byte ptr [rsi+0D5h],0
0000000000FF79D1 jne 0000000000FF7A60
0000000000FF79D7 test r12,r12
0000000000FF79DA jle 0000000000FF7B00
0000000000FF79E0 mov rax,qword ptr [rsi+88h]
0000000000FF79E7 mov rdx,qword ptr [rsi+30h]
0000000000FF79EB lea rbx,[rsp+30h]
0000000000FF79F0 lea rcx,[rsi+38h]
0000000000FF79F4 mov r9d,r12d
0000000000FF79F7 lea r12,[rsi+88h]
0000000000FF79FE mov r8,rdi
0000000000FF7A01 mov ebp,dword ptr [rax+4]
Null deference [rdx] here ->0000000000FF7A04 mov rax,qword ptr
[rdx]
0000000000FF7A07 mov qword ptr [rsp+20h],rcx
0000000000FF7A0C mov rcx,rbx
0000000000FF7A0F call qword ptr [rax+18h]
0000000000FF7A12 mov rdx,rbx
0000000000FF7A15 mov rcx,r12
0000000000FF7A18 call 00000000010440F0
0000000000FF7A1D mov rcx,qword ptr [rsp+30h]
0000000000FF7A22 mov eax,dword ptr [rcx]
0000000000FF7A24 test eax,eax
0000000000FF7A26 jne 0000000000FF7AC3
0000000000FF7A2C mov r8d,8
0000000000FF7A32 mov edx,2
0000000000FF7A37 call 00000000010BE1A0
0000000000FF7A3C test r13b,r13b
0000000000FF7A3F jne 0000000000FF7B90
0000000000FF7A45 mov eax,1
0000000000FF7A4A add rsp,4048h
0000000000FF7A51 pop rbx
0000000000FF7A52 pop rsi
0000000000FF7A53 pop rdi
0000000000FF7A54 pop rbp
0000000000FF7A55 pop r12
0000000000FF7A57 pop r13
0000000000FF7A59 ret
0000000000FF7A5A nop word ptr [rax+rax]
On Tue, Oct 27, 2015 at 8:26 PM, Kit Adams <[hidden email]
http:///user/SendEmail.jtp?type=node&node=14222&i=1> wrote:
On my Win8.0 machine, the 2015.10.17 build returns after a few seconds
with no output. The 2014 build on the same machine returns:
C:\Program Files\OpenSCAD>openscad.exe --info
C:\Program Files\OpenSCAD>openscad --info
OpenSCAD Version: 2014.03
Compiler, build date: GCC "4.8.1", Mar 9 2014
Boost version: 1_53
Eigen version: 3.1.3
CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>,
Epeck
OpenCSG version: OpenCSG 1.3.2
Qt version: 4.8.5
GLib version: 2.36.3
GLEW version: 1.9.0
GL Vendor: Intel
OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x1eaec74 amd64
Machine: 8664
Running openscad.exe --info crashes without output. The access violation
is :
Unhandled exception at 0x0000000000FF7A04 in openscad.exe: 0xC0000005:
Access violation reading location 0x0000000000000000.
Thanks,
Kit
On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] <[hidden
email] http:///user/SendEmail.jtp?type=node&node=14222&i=2> wrote:
My first question would be, can the user run "openscad --info" from the
command line?
below:
http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14219.html
To unsubscribe from Access violation on starting OpenSCAD (Win8), click
here.
NAML
View this message in context: Re: Access violation on starting OpenSCAD
(Win8)
http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14222.html
at Nabble.com.
[hidden email] http:///user/SendEmail.jtp?type=node&node=14244&i=2
[hidden email] http:///user/SendEmail.jtp?type=node&node=14244&i=3
[hidden email] http:///user/SendEmail.jtp?type=node&node=14244&i=4
below:
http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14244.html
here.
NAML
http://forum.openscad.org/attachment/14246/0/OpenSCAD.png
(Win8)
http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14246.html
at Nabble.com.
[hidden email] http:///user/SendEmail.jtp?type=node&node=14247&i=1
[hidden email] http:///user/SendEmail.jtp?type=node&node=14247&i=2
below:
http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14247.html
here.
NAML
(Win8)
http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14250.html
at Nabble.com.
Thanks for testing it out, that is good news.
The MSYS2 build and link process is the only real difference between the
versions. This is not a good permanent solution, for example the MSYS2
build required some nasty kludging of MSYS2 windeployqt which is why
there are two identical 25 megabyte ICU .dll files with only a slightly
different name in the download package.
don bright
hmbright@fastmail.com
On Fri, Oct 30, 2015, at 04:52 PM, Kit Adams wrote:
Hi Don,
I am curious, did you fix an issue, or was it using the MSYS2 build process that solved the problem, or was it the debug build that prevented the crash, or was it already fixed in the master?
Thanks,
Kit
I just had to check "Force Goldfeather" for the Preview to render correctly.
Many thanks,
Kit
On Fri, Oct 30, 2015 at 4:07 PM, donbright [via OpenSCAD] <[hidden email][1]> wrote:
Thanks for testing the msys2 build. Sorry about the error, it's my first time doing QT5 on Windows.
Here is a new test MSYS2 build off the Master branch. I have tested it on Windows 7.
don bright
[hidden email][2]
Running openscad results in the error message in the attached screen shot before it terminates.
C:\Users\Kit\Downloads\OpenSCAD-2015.10.28-x86-64.msys2\openscad-2015.10.28>openscad --info
debug pt 0
debug pt 1
debug pt 2
debug pt 3
debug pt 4
debug pt 5
debug pt 6
debug pt 7
debug pt 8
debug pt 9
debug pt 10
debug pt 11
debug pt 12
debug pt 13
debug pt 14
debug pt 15
debug pt 16
debug pt 17
debug pt 18
Boost version: 1_57
CGAL version, kernels: 4.6.1, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, Epeck
Qt version: 5.5.0
Application Path: C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28
Resource Path: C:/Users/Kit/Downloads/OpenSCAD-2015.10.28-x86-64.msys2/openscad-2015.10.28
OpenSCAD font path:
GL Vendor: Intel
Machine: 8664
On Fri, Oct 30, 2015 at 12:44 AM, donbright [via OpenSCAD] <[hidden email]> wrote:
Hello
A .zip package of an alternative build, using the MSYS2 Build System, has been uploaded here (note it is rather large, >50MB)::
Also this build has sprinkled openscad.cc with several debug print statements. Running this might help diagnose the problems...
don bright
[hidden email][3]
Actually, that dis-assembly and stack is for the 2015.03-1 build. The 2015.10.17 version crashes in similar code at address 0000000000F903F4 : mov rax,qword ptr [rdx] .
On Tue, Oct 27, 2015 at 8:38 PM, spinorkit <[hidden email][4]> wrote:
and the stack:
Null deference [rdx] here ->0000000000FF7A04 mov rax,qword ptr [rdx]
On Tue, Oct 27, 2015 at 8:26 PM, Kit Adams <[hidden email][6]> wrote:
On my Win8.0 machine, the 2015.10.17 build returns after a few seconds with no output. The 2014 build on the same machine returns:
Boost version: 1_53
CGAL version, kernels: 4.0.2, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, Epeck
Qt version: 4.8.5
GLEW version: 1.9.0
GL Vendor: Intel
Machine: 8664
Running openscad.exe --info crashes without output. The access violation is :
Unhandled exception at 0x0000000000FF7A04 in openscad.exe: 0xC0000005: Access violation reading location 0x0000000000000000.
Thanks,
Kit
On Tue, Oct 27, 2015 at 12:41 PM, donbright [via OpenSCAD] <[hidden email][7]> wrote:
My first question would be, can the user run "openscad --info" from the command line?
If you reply to this email, your message will be added to the discussion below:
To unsubscribe from Access violation on starting OpenSCAD (Win8), click here.
NAML[8]
View this message in context: Re: Access violation on starting OpenSCAD (Win8)[9]
Sent from the OpenSCAD mailing list archive[10] at Nabble.com.
[hidden email][11]
[hidden email][12]
[hidden email][13]
NAML[14]
View this message in context: Re: Access violation on starting OpenSCAD (Win8)[16]
Sent from the OpenSCAD mailing list archive[17] at Nabble.com.
[hidden email][18]
[hidden email][19]
NAML[20]
View this message in context: Re: Access violation on starting OpenSCAD (Win8)[21]
Sent from the OpenSCAD mailing list archive[22] at Nabble.com.
Links:
Hello
There are some new test builds uploaded (listed below) using a very recent
checkout of the MXE MingW cross build system.
It would be extremely helpful if anyone with a Windows machine that crashed
on OpenSCAD 2015 would be able to take a few minutes and test both a shared
build and a static build, just enough to see if they still crash before
bootup, and if not to see whether they will do a simple preview of a cube or
whatever.
http://files.openscad.org/snapshots/OpenSCAD-2015.11.11-MingW-x86-32-shared.zip
http://files.openscad.org/snapshots/OpenSCAD-2015.11.11-MingW-x86-32-static.zip
http://files.openscad.org/snapshots/OpenSCAD-2015.11.11-MingW-x86-64-shared.zip
http://files.openscad.org/snapshots/OpenSCAD-2015.11.11-MingW-x86-64-static.zip
Basically the theory being tested is whether or not the crash is caused by
Static Linking vs Shared Linking... or whether it is just MXE / MingW in
general that is causing the crash.
Thanks!!!!
don bright
View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14392.html
Hi, have tested OpenScad 2015-11-11 and it seems to work in my Win 10. I
will continue to test.
Regards
Kent Ahlberg
Den 151211 06:37 skrev Discuss on behalf of donbright
<discuss-bounces@lists.openscad.org on behalf of hmbright@fastmail.com>:
Hello
crashed
shared
or
whatever.
d.zip
c.zip
d.zip
c.zip
Thanks!!!!
don bright
01p14392.html
Hi Don,
Both these static and shared builds run and display fine on my main Windows
8.0 machine where the 2015.03 build still crashes.
Thanks,
Kit
On Thu, Nov 12, 2015 at 6:37 PM, donbright [via OpenSCAD] <
ml-node+s1091067n14392h97@n5.nabble.com> wrote:
Hello
crashed on OpenSCAD 2015 would be able to take a few minutes and test both
a shared build and a static build, just enough to see if they still crash
before bootup, and if not to see whether they will do a simple preview of a
cube or whatever.
Thanks!!!!
don bright
below:
here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=14201&code=a2l0LmFkYW1zQGdtYWlsLmNvbXwxNDIwMXwtMTM1NzI4MDMyMQ==
NAML
View this message in context: http://forum.openscad.org/Access-violation-on-starting-OpenSCAD-Win8-tp14201p14402.html
Thanks to all testers.....
hate to ask another favor but there is one last test... this build is
off the 2015.03 branch
http://files.openscad.org/snapshots/OpenSCAD-2015.11.13-x86-64.zip
http://files.openscad.org/snapshots/OpenSCAD-2015.11.13-x86-32.zip
The theory being tested here is to see if the build machine itself,
including the version of gcc, libraries, linker, assembler, mxe, etc, is
somehow causing the crash. (this build machine for the links above is a
fresh debian linux 8 box with mxe updated a week or two ago).
don bright
On Thu, Nov 12, 2015, at 05:36 AM, spinorkit wrote:
Hi Don,
Both these static and shared builds run and display fine on my main Windows 8.0 machine where the 2015.03 build still crashes.
Thanks,
Kit
On Thu, Nov 12, 2015 at 6:37 PM, donbright [via OpenSCAD] <[hidden email]> wrote:
Hello
There are some new test builds uploaded (listed below) using a very recent checkout of the MXE MingW cross build system.
It would be extremely helpful if anyone with a Windows machine that crashed on OpenSCAD 2015 would be able to take a few minutes and test both a shared build and a static build, just enough to see if they still crash before bootup, and if not to see whether they will do a simple preview of a cube or whatever.
Basically the theory being tested is whether or not the crash is caused by Static Linking vs Shared Linking... or whether it is just MXE / MingW in general that is causing the crash.
Thanks!!!!
don bright
NAML[1]
View this message in context: Re: Access violation on starting OpenSCAD (Win8)[2]
Sent from the OpenSCAD mailing list archive[3] at Nabble.com.
Links:
Hi Don,
Both these builds also run and display fine for me, unlike the original
2015.03.
Thanks,
Kit
hate to ask another favor but there is one last test... this build is off
the 2015.03 branch
don bright
Hi Don,
Thanks,
Kit
Hello
cube or whatever.
Thanks!!!!
don bright
below:
here.
NAML
(Win8)
at Nabble.com.
