Current range syntax:
[ i: j ]
[ i: j: k ]
Proposed additional syntax:
a) [ :j ] ---- i can be skipped if i==0
b) [ i: array ] ---- j can be an array or string . For example:
arr = ["a","b","c","d"];
[ for ( i=
[ :arr ]
) i ]; ==> [0,1,2,3]
[ for ( i=
[ :2:arr ]
) i ]; ==> [0,2]
c) ^ array (or some other syntax like [arr;] [ %arr ] etc ... )
to give both index and item:
[ for
( i,x = ^arr )
str( i,"=",x) ] ==> [ "0=a", "1=b", "2=c" ]
Compare the proposed
*for ( i=[:a] ) *
to the current usage
for ( i=[0:len(a)-1] )
it is much quicker and easier to write and read.
$ Runsun Pan, PhD
$ -- OpenScad_DocTest ( Thingiverse ), faces , Offliner
View this message in context: http://forum.openscad.org/Proposal-for-range-i-j-k-improvement-tp13184.html
Sounds like we could do with a foreach statement:
foreach (i in array)
doSomething();
View this message in context: http://forum.openscad.org/Proposal-for-range-i-j-k-improvement-tp13184p13185.html
doSomething();
We already have such a thing:
for (v = array)
doSomething ();
You can't use this when you actually need the array index though.
Kind regards,
Loong Jin
for (v = array)
doSomething ();
I did not know that! How long has this form been supported?
True. I can't resist the temptation to slip into programming good practice
at this point, despite (I know, I know!) the fact that OpenSCAD isn't a
programming language.
View this message in context: http://forum.openscad.org/Proposal-for-range-i-j-k-improvement-tp13184p13188.html
for (v = array)
doSomething ();
I dunno, I first started using OpenSCAD with 2014.04, and it already had that
feature.
Well, there are still some good practices to follow, such as not hardcoding
precalculated values everywhere.
Kind regards,
Loong Jin
we can get both:
Going back to @runsun proposal:
[ i: j ]
[ i: j: k ]
[ for ( i=[ :arr ] ) i ]; ==> [0,1,2,3]
[ for ( i=[ :2:arr ] ) i ]; ==> [0,2]
[ for ( i,x = ^arr ) str( i,"=",x) ] ==> [ "0=a", "1=b", "2=c" ]
... [show rest of quote]
Proposed to return just the array indices. Not the values.
current:
Proposed to return two values index and value. (i=index, x=value).
current (where the value is a new variable in this scope and not reused).
I note that in Python there is a special function "enumerate" that returns a
tuple of (index, value). Of course this works in Python because tuples are
consts of arrays and can be accessed in a loop like this:
which visually indicates that the enumerate will return two values and how
they will be mapped to i and x.
Personally I find Python's slicing, range, tuple, array, dictionary design
to be very clean, clear and well designed.
For OpenSCAD I liekd someone's proposal to use "in" to explicitly indicate
that the argument was an array.
E.g.
Maybe this variant coudl be used to differntiate between indices or values
from the array ?
View this message in context: http://forum.openscad.org/Proposal-for-range-i-j-k-improvement-tp13184p13194.html
a tuple of (index, value). Of course this works in Python because tuples
are consts of arrays and can be accessed in a loop like this:
Part of my idea is indeed inspired by Python. Another slicing feature of
python that I like is the reversed indexing:
IMHO It's one of the features that earn Python the reputation of "elegant".
It'd certainly be nice if we can adopt this, too.
E.g.
from the array ?
Wouldn't it be a little confusing, 'cos the index doesn't actually "in" the
arr ?
$ Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Proposal-for-range-i-j-k-improvement-tp13184p13196.html
Just lazy. ;)
for ( i=[:a] )
I don't mind that, where you still use 0:, so where 'a' is a string or
vector, its len()-1 is used.
for (i=[0:vector]) ...
View this message in context: http://forum.openscad.org/Proposal-for-range-i-j-k-improvement-tp13184p13204.html
*for ( i=[:a] ) *
I don't mind if an operation for returning the indices of an array is added
to OpenSCAD.
However, the syntax [:a] is pretty inscrutable, and I'm bit disturbed that
the array a is used in an integer context and interpreted as meaning
'len(a)-1'. That's weird.
How about an ordinary function instead?
In Perl, this is 'keys(a)'.
I can't remember seeing this operation in other languages.
However, 'indices(a)' or 'indexes(a)' would also make sense.
for( i = indices(a) ) ...
I'm not seeing the value of this. I think it's clearer to write
[ for ( i = arr ) str( i,"=",arr[i]) ]
In the case where 'arr' is a really long expression, you can do this:
[ let(a=arr) for(i=a) str(i,"=",a[i]) ]
Doug.
[ i: j ]
[ i: j: k ]
[ for ( i=
[ :arr ]
[ for ( i=
[ :2:arr ]
) i ]; ==> [0,2]
[ for
( i,x = ^arr )
*for ( i=[:a] ) *
*for ( i=[0:len(a)-1] )*
$ Runsun Pan, PhD
In fact, since we don't have this [:arr] yet, a function is exactly what
I do in my own lib. Here is the test output of my range(...) function:
range ( i,j,k,cycle,returnitems )=array ( tested:54 ) (mode:12)
| // 1 arg: starting from 0
| 0> range(5)= [0, 1, 2, 3, 4]
| 1> range(-5)= [0, -1, -2, -3, -4]
| 2> range(0)= []
| 3> range([])= []
| // 2 args:
| 4> range(2,5)= [2, 3, 4]
| 5> range(5,2)= [5, 4, 3]
| 6> range(-2,1)= [-2, -1, 0]
| 7> range(-5,-1)= [-5, -4, -3, -2]
| // Note these are the same:
| 8> range(3)= [0, 1, 2]
| 9> range(0,3)= [0, 1, 2]
| 10> range(-3)= [0, -1, -2]
| 11> range(0,-3)= [0, -1, -2]
| 12> range(1)= [0]
| 13> range(-1)= [0]
| // 3 args, the middle one is interval. Its sign has no effect
| 14> range(2,0.5,5)= [2, 2.5, 3, 3.5, 4, 4.5]
| 15> range(2,-0.5,5)= [2, 2.5, 3, 3.5, 4, 4.5]
| 16> range(5,-1,0)= [5, 4, 3, 2, 1]
| 17> range(5,1,2)= [5, 4, 3]
| 18> range(8,2,0)= [8, 6, 4, 2]
| 19> range(0,2,8)= [0, 2, 4, 6]
| 20> range(0,3,8)= [0, 3, 6]
| // Extreme cases:
| 21> range()= [] // Give nothing, get nothing
| 22> range(0)= [] // Count from 0 to 0 gets you nothing
| 23> range(2,2)= [] // 2 to 2 gets you nothing, either
| 24> range(2,0,4)= [] // No intv gets you nothing, too
| 25> range(0,1)= [0]
| 26> range(0,1,1)= [0]
| // When interval > range, count only the first:
| 27> range(2,5,4)= [2]
| 28> range(2,5,-1)= [2]
| 29> range(-2,5,-4)= [-2]
| 30> range(-2,5,1)= [-2]
| range( obj )
| // range( arr ) or range( str ) to return a range of an array
| // so you don"t have to do : range( len(arr) )
| > obj = [10, 11, 12, 13]
| 31> range(obj)= [0, 1, 2, 3]
| 32> range([3,4,5])= [0, 1, 2]
| 33> range("345")= [0, 1, 2]
| 34> range([])= []
| 35> range(")= []
| range( ... cycle= i,-i,true...)
| // New 2014.9.7:
| // cycle= +i: extend the index on the right by +i count
| // cycle= -i: extend the index on the right by -i count
| // cycle= true: same as cycle=1
| 36> range(4,cycle=1)= [0, 1, 2, 3, 0] // Add first to the right
| 37> range(4,cycle=-1)= [3, 0, 1, 2, 3] // Add last to the left
| 38> range(4,cycle=true)= [0, 1, 2, 3, 0] // true=1
| 39> range(2,5,cycle=1)= [2, 3, 4, 2] // Add first to the right
| 40> range(2,5,cycle=2)= [2, 3, 4, 2, 3] // Add 1st,2nd to the right
| 41> range(2,5,cycle=-1)= [4, 2, 3, 4] // Add last to the left
| 42> range(2,5,cycle=-2)= [3, 4, 2, 3, 4]
| 43> range(2,5,cycle=true)= [2, 3, 4, 2] // true=1
| 44> range(2,1.5,8,cycle=2)= [2, 3.5, 5, 6.5, 2, 3.5]
| 45> range(2,1.5,8,cycle=-2)= [5, 6.5, 2, 3.5, 5, 6.5]
| 46> range(2,1.5,8,cycle=true)= [2, 3.5, 5, 6.5, 2]
| range(obj,cycle=i,-1,[-1,1],true...)
| 47> range(obj,cycle=1)= [0, 1, 2, 3, 0]
| 48> range(obj,cycle=[-1,1])= [3, 0, 1, 2, 3, 0]
| 49> range(obj,cycle=2)= [0, 1, 2, 3, 0, 1]
| 50> range(obj,cycle=-1)= [3, 0, 1, 2, 3]
| 51> range(obj,cycle=-2)= [2, 3, 0, 1, 2, 3]
| range( obj, returnitems=true,false )
| // When using obj, can set returnitems=true to return items.
| 52> range([3,4,5],returnitems=true)= [3, 4, 5]
| 53> range(obj,cycle=[-1,1],returnitems=true)= [13, 10, 11, 12, 13, 10]
$ Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Proposal-for-range-i-j-k-improvement-tp13184p13212.html
