On Fri, 17 Jul 2015 11:24:48 -0700 (MST)
runsun runsun@gmail.com wrote:
doug.moen wrote
How about an ordinary function instead?
In Perl, this is 'keys(a)'.
I can't remember seeing this operation in other languages.
However, 'indices(a)' or 'indexes(a)' would also make sense.
for( i = indices(a) ) ...
In fact, since we don't have this [:arr] yet, a function is exactly
what I do in my own lib. Here is the test output of my range(...)
function:
I like range(arr) better than [:arr].
range ( i,j,k,cycle,returnitems )=array ( tested:54 ) (mode:12)
| // 1 arg: starting from 0
| 0> range(5)= [0, 1, 2, 3, 4]
| 1> range(-5)= [0, -1, -2, -3, -4]
| 2> range(0)= []
| 3> range([])= []
| // 2 args:
| 4> range(2,5)= [2, 3, 4]
| 5> range(5,2)= [5, 4, 3]
| 6> range(-2,1)= [-2, -1, 0]
| 7> range(-5,-1)= [-5, -4, -3, -2]
| // Note these are the same:
| 8> range(3)= [0, 1, 2]
| 9> range(0,3)= [0, 1, 2]
| 10> range(-3)= [0, -1, -2]
| 11> range(0,-3)= [0, -1, -2]
| 12> range(1)= [0]
| 13> range(-1)= [0]
| // 3 args, the middle one is interval. Its sign has no effect
| 14> range(2,0.5,5)= [2, 2.5, 3, 3.5, 4, 4.5]
| 15> range(2,-0.5,5)= [2, 2.5, 3, 3.5, 4, 4.5]
| 16> range(5,-1,0)= [5, 4, 3, 2, 1]
| 17> range(5,1,2)= [5, 4, 3]
| 18> range(8,2,0)= [8, 6, 4, 2]
| 19> range(0,2,8)= [0, 2, 4, 6]
| 20> range(0,3,8)= [0, 3, 6]
| // Extreme cases:
| 21> range()= [] // Give nothing, get nothing
| 22> range(0)= [] // Count from 0 to 0 gets you nothing
| 23> range(2,2)= [] // 2 to 2 gets you nothing, either
| 24> range(2,0,4)= [] // No intv gets you nothing, too
| 25> range(0,1)= [0]
| 26> range(0,1,1)= [0]
| // When interval > range, count only the first:
| 27> range(2,5,4)= [2]
| 28> range(2,5,-1)= [2]
| 29> range(-2,5,-4)= [-2]
| 30> range(-2,5,1)= [-2]
| range( obj )
| // range( arr ) or range( str ) to return a range of an array
| // so you don"t have to do : range( len(arr) )
| > obj = [10, 11, 12, 13]
| 31> range(obj)= [0, 1, 2, 3]
| 32> range([3,4,5])= [0, 1, 2]
| 33> range("345")= [0, 1, 2]
| 34> range([])= []
| 35> range(")= []
| range( ... cycle= i,-i,true...)
| // New 2014.9.7:
| // cycle= +i: extend the index on the right by +i count
| // cycle= -i: extend the index on the right by -i count
| // cycle= true: same as cycle=1
| 36> range(4,cycle=1)= [0, 1, 2, 3, 0] // Add first to the right
| 37> range(4,cycle=-1)= [3, 0, 1, 2, 3] // Add last to the left
| 38> range(4,cycle=true)= [0, 1, 2, 3, 0] // true=1
| 39> range(2,5,cycle=1)= [2, 3, 4, 2] // Add first to the right
| 40> range(2,5,cycle=2)= [2, 3, 4, 2, 3] // Add 1st,2nd to the
right | 41> range(2,5,cycle=-1)= [4, 2, 3, 4] // Add last to the
left | 42> range(2,5,cycle=-2)= [3, 4, 2, 3, 4]
| 43> range(2,5,cycle=true)= [2, 3, 4, 2] // true=1
| 44> range(2,1.5,8,cycle=2)= [2, 3.5, 5, 6.5, 2, 3.5]
| 45> range(2,1.5,8,cycle=-2)= [5, 6.5, 2, 3.5, 5, 6.5]
| 46> range(2,1.5,8,cycle=true)= [2, 3.5, 5, 6.5, 2]
| range(obj,cycle=i,-1,[-1,1],true...)
| 47> range(obj,cycle=1)= [0, 1, 2, 3, 0]
| 48> range(obj,cycle=[-1,1])= [3, 0, 1, 2, 3, 0]
| 49> range(obj,cycle=2)= [0, 1, 2, 3, 0, 1]
| 50> range(obj,cycle=-1)= [3, 0, 1, 2, 3]
| 51> range(obj,cycle=-2)= [2, 3, 0, 1, 2, 3]
| range( obj, returnitems=true,false )
| // When using obj, can set returnitems=true to return items.
| 52> range([3,4,5],returnitems=true)= [3, 4, 5]
| 53> range(obj,cycle=[-1,1],returnitems=true)= [13, 10, 11, 12,
13, 10]
$ Runsun Pan, PhD
$ -- OpenScad_DocTest ( Thingiverse ), faces , Offliner
$ -- Linux Mint 17.1 Rebecca x64 + OpenSCAD
2015.03.15/2015.04.01.nightly
View this message in context:
http://forum.openscad.org/Proposal-for-range-i-j-k-improvement-tp13184p13212.html
Do unto others 20% better than you would expect them to do unto you, to
correct for subjective error. -- Linus Pauling
in python you can access a dictionaries items, values, and keys like so:
arr = {1: 11, 2:22, 3:33}
arr.items() returns [(1, 11), (2, 22), (3, 33)]
arr.values() returns [11, 22, 33]
arr.keys() returns [1, 2, 3]
View this message in context: http://forum.openscad.org/Proposal-for-range-i-j-k-improvement-tp13184p13223.html
