Troberg
Mon, Feb 4, 2019 1:58 PM
I'm trying to design a box with dividers, to be lasercut, with tabs to fit
things together.
My plan is to put tabs on one of the parts which mesh, then then put them
together and difference(). to put the corresponding tabs/slots in the other
part.
Tre problem is that to do this, I woill need to put all the parts together,
and do most of the parts twice (one positive, one for the difference(). Once
I've done all the parts, due to the way OpenSCAD works, they'll be "lost". I
can't move them about to break it apart and get a template to cut. I need to
put them together, but once I do put it all together, I can't take it apart.
Is there a smart way to work this?
things together.
part.
WA
William Adams
Mon, Feb 4, 2019 2:11 PM
I worked up similar code for a CNC machine at:
http://community.carbide3d.com/t/cnc-finger-joint-box/8880 and wound up
extracting the parameters for the box from the JSON file and then working
up a LuaLaTeX / METAPOST file which creates an SVG.
I'm now experimenting with doing something similar using tplang instead of
lualatex/mp
You should be able to use my code to work out how to have an arrangement
where the box is flattened out and arranged for cutting on the laser.
I'm trying to get all this put together as a Kickstarter --- drop me a line
at willadams@aol.com and I'll see what I can work out which might help you.
things together.
part.
Once
I
to
apart.
lualatex/mp
> things together.
> part.
> Once
> I
> to
> apart.
FV
Frank van der Hulst
Mon, Feb 4, 2019 5:16 PM
Typically, people use a variable to control the final position of the
parts; if it's set to true, translate & rotate into the correct position
for lasercutting, else if it's false leave the parts in their assembled
positions.
things together.
other
part.
together,
Once
"lost". I
to
apart.
positions.
>> things together.
>> other
>> part.
>> together,
>> Once
>> "lost". I
>> to
>> apart.
Mon, Feb 4, 2019 5:46 PM
positions.
That's the way I normally work too. Although I've switched from a
boolean to a "small integer". That way I can select any of a bunch of
configurations.
For another project I've made a module that will instantiate one of
the children and then subtract (difference) all of the following
children.
The children then need to start out in "assembled" locations. For the
lasercutting locations I rotate them back to planar in the "laser"
module.
if (show == 1) {
assembled ();
if (show == 2) {
alternative_assembly ();
if (show == 3) {
laser ();
if (show == 4) {
projection (cut=true) translate ([0,0,-mt/2]) laser ();
Actually, Openscad is much faster working with 3D objects. The
projection is really slow. So for viewing and adjusting the laser
configuration I use show=3, and then for exporting to DXF I use the
show=4. mt is material thickness.
things together.
other
part.
together,
Once
"lost". I
to
apart.
> positions.
configurations.
children.
module.
if (show == 1) {
assembled ();
if (show == 2) {
if (show == 3) {
laser ();
if (show == 4) {
> >> things together.
> >> other
> >> part.
> >> together,
> >> Once
> >> "lost". I
> >> to
> >> apart.
JG
Juliean Galak
Mon, Feb 4, 2019 6:01 PM
You can also write a module that generates the positive part, and call it
twice - once for the positive, once for the subtractive element for the
negative.
things together.
part.
Once
I
to
apart.
negative.
> things together.
> part.
> Once
> I
> to
> apart.
Juliean Galak
jgalak@gmail.com
JF
Joe Francis
Mon, Feb 4, 2019 6:08 PM
On 2/4/19 11:46 AM, Rogier Wolff wrote:
<snip>
For building up laser-cut parts, it can also be useful to draw all the
components as 2d modules. Then you can arrange them in 2d space for
laser cutting and avoid the projection altogether, but still extrude
them out for the as-assembled view.
things together.
other
part.
together,
Once
"lost". I
to
apart.
> <snip>
> Roger.
>>>> things together.
>>>> other
>>>> part.
>>>> together,
>>>> Once
>>>> "lost". I
>>>> to
>>>> apart.
EN
Ed Nisley
Mon, Feb 4, 2019 8:25 PM
On 2/4/19 12:46 PM, Rogier Wolff wrote:
switched from a boolean to a "small integer"
I use strings tucked into Customizer variable:
Layout = "Show"; // [Show,Fit,Build]
Part = "Shell"; //
[Cradle,Shell,Clamp,ShellSections,M20,Interposer,Battery,Buttons]
… then near the bottom of the file …
if (Layout == "Show")
if (Part == "Battery")
BatteryShape();
else if (Part == "Buttons")
Buttons();
else if (Part == "Interposer")
InterposerShape(Embiggen = false);
else if etc etc etc
if (Layout == "Build")
if (Part == "Cradle")
Cradle();
else if (Part == "Clamp") {
translate([0,0.7ClampOA.y,0])
translate([0,0,-Kerf/2])
Clamp(Support = true);
translate([0,0,-ClampOA.z])
cube(2ClampOA,center=true);
translate([0,-0.7ClampOA.y,-0])
rotate([0,180,0])
else if etc etc etc
The "Show" layouts present each part, pretty much as-designed, with the
intent of letting me build each one in isolation.
The "Build" layouts consist of totally ad-hoc translates & rotates
arranging the pieces as needed on the printer platform.
The "Fit" layout tediously assembles everything more-or-less as it
should fit together in space, so as to see whether it does. The
motivation for a completely different chunk of code is a cross-check on
the dimensions, as debugging the Fit layout generally reveals a screwup
in a "Show" design. [sigh]
Suffices for my simple needs, anyhow.
Ed
https://softsolder.com
Part = "Shell"; //
BatteryShape();
Buttons();
else if etc etc etc
Cradle();
translate([0,0.7*ClampOA.y,0])
cube(2*ClampOA,center=true);
translate([0,-0.7*ClampOA.y,-0])
rotate([0,180,0])
else if etc etc etc
Ed
Mon, Feb 4, 2019 8:42 PM
I figure out the following scheme:
module assemble(miss=-1)
if(miss<0 || miss>=nparts)
for( i=[0:nparts-1] )
rotate(rot[i])
translate(pos[i])
part(i) ;
else {
for(i=[0:1:miss-1]) linear_extrude(thick) bPart[i];
for(i=[miss+1:1:nparts-1]) linear_extrude(thick) bPart[i];
module part(i)
translate(-pos[i])
rotate(-rot[i]) // transform back to xy plane
rotate(rot[i])
translate(pos[i]) // transformed to assembly position
linear_extrude(thick) bPart(i);
assemble(i);
module bPart(part) {
if(part==0)
<basic definition of part 0 on xy plane> ;
else if(part==1)
pos = [ pos0, pos1, pos2, ...];
rot = [ rot0, rot1, rot2, ...];
The module assemble() is able to assemble the full model (as default) or
with one part missing whose index is its argument. The full assembly uses
the parts cut using the assembly of basic parts.
The module part(i) computes the difference between the i-th basic part and
the others basic parts in the assembly. That part is brought back to xy
plane after cut by the other parts.
The module bPart(i) generates the 2D shape of the part i . That basic part
definitions should have the extra material to be cut by the other basic
The vectors pos and rot store the translation vector and rotation vector to
bring the linear_extrude() of the basic parts from the xy plane to their
assembly positions.
I have not tried this scheme so ...
rotate(rot[i])
translate(pos[i])
part(i) ;
else {
module part(i)
translate(-pos[i])
rotate(rot[i])
assemble(i);
if(part==0)
else if(part==1)
assembly positions.
Tue, Feb 5, 2019 1:22 AM
configurations.
I'm not sure whether it's valuable or just for fun, but I've had cases
where I made it an animation, where it would animate back and forth
between the assembled view and the as-printed view. (Linear
interpolation between the two translations and the two rotations, with
small "pause" periods at each end.)
// Given a value and a table of value/position pairs, interpolate a
// position for that value.
// It seems like lookup() should do this sort of vector interpolation
// on its own, but it doesn't seem to.
function xyzinterp(v, table) =
let (x= [for (i=[0:len(table)-1]) [table[i][0], table[i][1][0]]])
let (y= [for (i=[0:len(table)-1]) [table[i][0], table[i][1][1]]])
let (z= [for (i=[0:len(table)-1]) [table[i][0], table[i][1][2]]])
[lookup(v, x), lookup(v, y), lookup(v,z)];
// Given a table of animation time values (from zero to one) and
// positions for each of those time values, translate the children
// to the appropriate position.
module atranslate(table) {
translate(xyzinterp($t, table)) children();
// rotations for each of those time values, rotate the children
module arotate(table) {
rotate(xyzinterp($t, table)) children();
// Given a start point and an end point, translate the children
// from the start to the end and back in each animation cycle.
// Pause briefly at the start and end.
module a2translate(p1, p2) {
atranslate([[0.05, p1], [0.45, p2], [0.55, p2], [0.95, p1]]) children();
// Given a start rotation and an end rotation, rotate the children
module a2rotate(p1, p2) {
arotate([[0.05, p1], [0.45, p2], [0.55, p2], [0.95, p1]]) children();
Thus, given a couple of modules and positions and rotations for each view:
a2translate([0,0,0], [0,0,d]) a2rotate([0,0,0], [-90,0,0])
color("SandyBrown") body();
a2translate([0,0,0], [w+5,0,door_t]) a2rotate([0,0,0], [-90,0,0])
color("SandyBrown") doors();
(As it happens, the modules are positioned to "as assembled" at t=0 and
"as printed" at t=0.5, but it could be the other way 'round.)
> configurations.
Troberg
Tue, Feb 5, 2019 9:39 AM
I use that a lot in other cases, such as when I want to make "exploded views"
showing disassembly.
The problem here, is that the placement of a part is part of making other
parts. I place a part to "poke holes" in other parts using difference(), to
ensure a correct fit. Now, say that this part pokes holes in three other
parts, I can't now move them, because they aren't available as objects
anymore.
Sure, I could do the math, calculate every position of every tab so that it
lines up, but it's a lot more work, and it makes for a much more error prone
process, likely to waste expensive material.
anymore.
