Is it possible in the world of Windows to install the RC alongside an earlier
version? I'm not usually an early adopter, but reading that there are tabs
involved has me on the edge.
I have the latest release and the latest snapshot both installed in
Windows without a problem: just put them in different folders under the
Program Files directory tree
You can download the zip version. Unzip it anywhere you want and execute it
from there.
On Mon, 7 Dec 2020 at 14:10, fred_dot_u via Discuss <
earlier
thanks for the confidence boost. I'll have to give it a shot.
Yay for optimizations! I have a couple questions, though:
-Revar
On Dec 7, 2020, at 1:58 AM, Hans L thehans@gmail.com wrote:
Generic tail recursion https://github.com/openscad/openscad/pull/3020 was an improvement to the Tail Call Optimization https://en.wikipedia.org/wiki/Tail_call (see also here https://en.wikibooks.org/w/index.php?title=OpenSCAD_User_Manual/User-Defined_Functions_and_Modules#Recursive_functions) so that it applies to many more forms of function definitions than previously (for example using "let" was not an option before and now it is), which in general means faster recursion and less chance of stack overflow.
Unrelated to that change, but relevant to one of the complaints in the recent OpenSCAD Python discussion:
On Thu, Nov 26, 2020 at 12:29 PM adrianv <avm4@cornell.edu mailto:avm4@cornell.edu> wrote:
Algorithms in the literature may be O(N*log(N)) but that
assumes you have actual data structures. In OpenSCAD it may turn out to be
O(N^3) instead. In many cases it just doesn't seem practical to implement
efficient algorithms.
I think it should also be mentioned that this release contains changes to make array concatenation complexity O(1) instead of O(n), which should be a major improvement (up to 10,000x https://github.com/openscad/openscad/issues/3380 has been seen in one extreme case) for many data-heavy algorithms/scripts.
Hans
Just tested it with some complex projects, and so far, it seems very nice!
Assuming there are no showstoppers, when dare we hope for the real final
release?
Yes, list-comprehension each is optimized in the same way as concat.
comprehensions with ‘if’s etc.?
and for appending a long list?
If it uses concat or each, it should benefit from this optimization in all
cases, regardless of how complex the overall expression is.
However, there is one caveat: the first "random access" (aka any use of
subscript operator: vector[i] ) after any number of such concat/each
operations, will force a "flattening" of the vector internally, which has a
one-time cost of O(n) time.
Once flattened, subsequent random access reads will be O(1) as usual.
For more details about the implementation of this and how it came about,
you can read the PR discussion starting with the last paragraph of the
comment here:
https://github.com/openscad/openscad/pull/3102#issuecomment-652579183
I've also tried to document the feature and data structure details in
source code comments here:
https://github.com/openscad/openscad/blob/6768ed7df36b83b277d0aec903c84c3078a5ac8a/src/value.h#L338-L360
More importantly, if you have any existing scripts which were slow from
constructing large vectors, just try the new RC and see how it goes. I
think the majority of such cases will see significant improvements.
Cheers,
Hans
Just noticed the informative syntax error messages. Saves me lots of time
when I do stupid mistakes!
Just noticed a massive slowdown when rendering a complex model in preview. On
the previous version it's a 15-20 second render, in the RC, it's a five
minute render.
It's a too complicated design to easily nail down where the difference is,
but something isn't as it should be.
If you can't provide an example to reproduce it then there's not a lot of
hope in fixing it.
Before troubleshooting further, are you sure you didn't run out of RAM and
hit swap space when the RC was run? That could certainly cause such a
slowdown.
If you ran the previous release first(assuming it used a significant
portion of your RAM) and left it open while testing the RC, I could see
that possibly happening.
If that's not the cause, then I would recommend trying to single out which
part(s) of the design are taking much longer on RC, by systematically using
disable modifiers * and/or a root modifier ! on different places in the
script.
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Modifier_Characters#Disable_Modifier
To speed up the process, you can try reducing $fn (or increasing $fs and
$fa) wherever used.
Also if there are loops of geometries involved, try reducing their loop
count significantly.
If it's possible to reduce overall complexity until the previous release
takes say 1 second to preview, then if the RC is really still 15x-20x
slower in this case, at least you should only have to wait 15-20 seconds,
not 5 minutes, in between trying out disable modifiers etc.
Hans
On
minute render.
