So there's not much surprises for people who already
used the snapshot builds.
This activates the following 2 experimental features
for the release mode:
News post:
https://www.openscad.org/news.html#20201206
Download (Windows & Linux only for now):
https://www.openscad.org/downloads.html#rc
I have a vague recollection that OpenSCAD now will import OFF files, but
that does not seem to work. Is my memory bad, or do I need to enable a
feature? I do not get an error message: the imported OFF file is just
empty.
Thanks.
News post:
import OFF files, but that does not seem to work.
Is my memory bad, or do I need to enable a feature?
is just empty.
As far as I can tell, that's an ancient feature (it's
mentioned in the 2011.12 release notes) and it seems
to works with a couple of test files I grabbed from
http://www.holmes3d.net/graphics/offfiles/
I confirmed that lazy union is supported by the RC.
Seems like lazy union and the new undef handling ought to be mentioned as
pretty major changes on the news page.
News post:
Discuss@.openscad
to be mentioned as pretty major changes on the news page.
If lazy union can be enabled, that's a bug that needs
to be fixed before the release.
Not "can be enabled". It just is enabled. I didn't do anything to any
settings, and I did a union test and got a different result in the RC than
in 2019.05.
Discuss@.openscad
I agree that OFF files work in some cases. In one complex case, the STL
works, but the corresponding OFF does not.
Not sure how important this is
is just empty.
I also noticed that the news page says "generic tail recursion" is added.
What exactly does this do?
empty.
Thanks.
News post:
Discuss@.openscad
Discuss@.openscad
Generic tail recursion https://github.com/openscad/openscad/pull/3020 was
an improvement to the Tail Call Optimization
https://en.wikipedia.org/wiki/Tail_call (see also here
https://en.wikibooks.org/w/index.php?title=OpenSCAD_User_Manual/User-Defined_Functions_and_Modules#Recursive_functions)
so that it applies to many more forms of function definitions than
previously (for example using "let" was not an option before and now
it is), which in general means faster recursion and less chance of stack
overflow.
Unrelated to that change, but relevant to one of the complaints in the
recent OpenSCAD Python discussion:
On Thu, Nov 26, 2020 at 12:29 PM adrianv avm4@cornell.edu wrote:
Algorithms in the literature may be O(N*log(N)) but that
assumes you have actual data structures. In OpenSCAD it may turn out to be
O(N^3) instead. In many cases it just doesn't seem practical to implement
efficient algorithms.
I think it should also be mentioned that this release contains changes to
make array concatenation complexity O(1) instead of O(n), which should be a
major improvement (up to 10,000x
https://github.com/openscad/openscad/issues/3380 has been seen in one
extreme case) for many data-heavy algorithms/scripts.
Hans
empty.
Thanks.
News post:
Discuss@.openscad
Discuss@.openscad
Just upgraded to this and love it - the speed increase when rendering in
particular.
The multiple tabs are very useful too.
Would it be possible to have an option to force "single instance of program"
?? I often select 2 or 3 scad files and use "open with" and it would be
very useful if this resulted in a single program with the file open in
separate "tabs".
I use the Windoze 7 x64 variant.
Best regards,
Dave
