$fn and arcs
Thu, Aug 21, 2025 12:18 PM
Does anybody know the calculation openscad uses for the number of segments
on an arc of angle theta as a function of $fn?  Exactly what kind of
rounding is used?
Does anybody know the calculation openscad uses for the number of segments on an arc of angle theta as a function of $fn? Exactly what kind of rounding is used?
CC
Cory Cross
Thu, Aug 21, 2025 1:42 PM
At least in DxfData:
      n = static_cast<int>(ceil(n * arc_angle / 360));
where n comes from
      int n = Calc::get_fragments_from_r(radius, fn, fs, fa);
which returns $fn so long as it's at least 3: https://github.com/openscad/openscad/blob/master/src%2Futils%2Fcalc.cc#L47
https://github.com/openscad/openscad/blob/master/src%2Fio%2FDxfData.cc#L205
Sorry for non-permalinks.
On August 21, 2025 8:18:44 AM EDT, Adrian Mariano via Discuss discuss@lists.openscad.org wrote:
rounding is used?
At least in DxfData: n = static_cast<int>(ceil(n * arc_angle / 360)); where n comes from int n = Calc::get_fragments_from_r(radius, fn, fs, fa); which returns $fn so long as it's at least 3: <https://github.com/openscad/openscad/blob/master/src%2Futils%2Fcalc.cc#L47> <https://github.com/openscad/openscad/blob/master/src%2Fio%2FDxfData.cc#L205> Sorry for non-permalinks. On August 21, 2025 8:18:44 AM EDT, Adrian Mariano via Discuss <discuss@lists.openscad.org> wrote: >Does anybody know the calculation openscad uses for the number of segments >on an arc of angle theta as a function of $fn? Exactly what kind of >rounding is used?
Thu, Aug 21, 2025 2:22 PM
Thanks.  The possibility of rounding error exists in the computation.
Someone observed in BOSL2 that offset behaved irregularly.  The existing
calculation does not match openscad but even with it fixed if I offset a
regular n gon with $fn = n I get rounding errors and sometimes the ceil
rounds up giving an extra facet. Openscad seems to avoid this somehow and
consistently produces just a single facet.
On Thu, Aug 21, 2025 at 09:43 Cory Cross via Discuss <
where n comes from
Thanks. The possibility of rounding error exists in the computation. Someone observed in BOSL2 that offset behaved irregularly. The existing calculation does not match openscad but even with it fixed if I offset a regular n gon with $fn = n I get rounding errors and sometimes the ceil rounds up giving an extra facet. Openscad seems to avoid this somehow and consistently produces just a single facet. On Thu, Aug 21, 2025 at 09:43 Cory Cross via Discuss < discuss@lists.openscad.org> wrote: > At least in DxfData: > > n = static_cast<int>(ceil(n * arc_angle / 360)); > > where n comes from > > int n = Calc::get_fragments_from_r(radius, fn, fs, fa); > > which returns $fn so long as it's at least 3: < > https://github.com/openscad/openscad/blob/master/src%2Futils%2Fcalc.cc#L47 > > > > < > https://github.com/openscad/openscad/blob/master/src%2Fio%2FDxfData.cc#L205 > > > > Sorry for non-permalinks. > > > On August 21, 2025 8:18:44 AM EDT, Adrian Mariano via Discuss < > discuss@lists.openscad.org> wrote: > >> Does anybody know the calculation openscad uses for the number of >> segments on an arc of angle theta as a function of $fn? Exactly what kind >> of rounding is used? >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Thu, Aug 21, 2025 2:45 PM
In C++, OpenSCAD converts n to int first before doing the arc angle calculation. That may introduce a tiny difference, as if you do the same calculation in OpenSCAD, it’s kept as double all the way. Not sure if that’s the root cause though..
On Aug 21, 2025, at 10:22, Adrian Mariano via Discuss discuss@lists.openscad.org wrote:
On Thu, Aug 21, 2025 at 09:43 Cory Cross via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
where n comes from
On August 21, 2025 8:18:44 AM EDT, Adrian Mariano via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org> wrote:
To unsubscribe send an email to discuss-leave@lists.openscad.org mailto:discuss-leave@lists.openscad.org_______________________________________________
In C++, OpenSCAD converts n to int first before doing the arc angle calculation. That may introduce a tiny difference, as if you do the same calculation in OpenSCAD, it’s kept as double all the way. Not sure if that’s the root cause though.. -Marius > On Aug 21, 2025, at 10:22, Adrian Mariano via Discuss <discuss@lists.openscad.org> wrote: > > Thanks. The possibility of rounding error exists in the computation. Someone observed in BOSL2 that offset behaved irregularly. The existing calculation does not match openscad but even with it fixed if I offset a regular n gon with $fn = n I get rounding errors and sometimes the ceil rounds up giving an extra facet. Openscad seems to avoid this somehow and consistently produces just a single facet. > > On Thu, Aug 21, 2025 at 09:43 Cory Cross via Discuss <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: >> At least in DxfData: >> >> n = static_cast<int>(ceil(n * arc_angle / 360)); >> >> where n comes from >> >> int n = Calc::get_fragments_from_r(radius, fn, fs, fa); >> >> which returns $fn so long as it's at least 3: <https://github.com/openscad/openscad/blob/master/src%2Futils%2Fcalc.cc#L47> >> >> <https://github.com/openscad/openscad/blob/master/src%2Fio%2FDxfData.cc#L205> >> >> Sorry for non-permalinks. >> >> >> On August 21, 2025 8:18:44 AM EDT, Adrian Mariano via Discuss <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: >>> Does anybody know the calculation openscad uses for the number of segments on an arc of angle theta as a function of $fn? Exactly what kind of rounding is used? >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org>_______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
CC
Cory Cross
Thu, Aug 21, 2025 5:29 PM
I think the cause is when either angle or 360/(n*arc_angle) isn't perfectly representable by a double.
I think the best solution is to subtract epsilon before calling ceil. I haven't thought of any situation this is worse, especially given n is never less than 3.
On August 21, 2025 10:45:52 AM EDT, Marius Kintel via Discuss discuss@lists.openscad.org wrote:
If I'm remembering my numerical methods lessons correctly, I don't think that's the reason, as the code correctly multiplies n*arc_angle first, which will always be less than the maximum representable integer in a double (for any reasonable n), so it will exact if the angle is representable as a double.
  • Cory Cross
where n comes from
I think the cause is when either angle or 360/(n*arc_angle) isn't perfectly representable by a double. I think the best solution is to subtract epsilon before calling ceil. I haven't thought of any situation this is worse, especially given n is never less than 3. On August 21, 2025 10:45:52 AM EDT, Marius Kintel via Discuss <discuss@lists.openscad.org> wrote: >In C++, OpenSCAD converts n to int first before doing the arc angle calculation. That may introduce a tiny difference, as if you do the same calculation in OpenSCAD, it’s kept as double all the way. Not sure if that’s the root cause though.. If I'm remembering my numerical methods lessons correctly, I don't think that's the reason, as the code correctly multiplies n*arc_angle first, which will always be less than the maximum representable integer in a double (for any reasonable n), so it will exact if the angle is representable as a double. - Cory Cross > > -Marius > >> On Aug 21, 2025, at 10:22, Adrian Mariano via Discuss <discuss@lists.openscad.org> wrote: >> >> Thanks. The possibility of rounding error exists in the computation. Someone observed in BOSL2 that offset behaved irregularly. The existing calculation does not match openscad but even with it fixed if I offset a regular n gon with $fn = n I get rounding errors and sometimes the ceil rounds up giving an extra facet. Openscad seems to avoid this somehow and consistently produces just a single facet. >> >> On Thu, Aug 21, 2025 at 09:43 Cory Cross via Discuss <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: >>> At least in DxfData: >>> >>> n = static_cast<int>(ceil(n * arc_angle / 360)); >>> >>> where n comes from >>> >>> int n = Calc::get_fragments_from_r(radius, fn, fs, fa); >>> >>> which returns $fn so long as it's at least 3: <https://github.com/openscad/openscad/blob/master/src%2Futils%2Fcalc.cc#L47> >>> >>> <https://github.com/openscad/openscad/blob/master/src%2Fio%2FDxfData.cc#L205> >>> >>> Sorry for non-permalinks. >>> >>> >>> On August 21, 2025 8:18:44 AM EDT, Adrian Mariano via Discuss <discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: >>>> Does anybody know the calculation openscad uses for the number of segments on an arc of angle theta as a function of $fn? Exactly what kind of rounding is used? >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org>_______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >
Thu, Aug 21, 2025 6:02 PM
Representability as a double is not sufficient. You have to also compute
that representation. Since arccos is involved this is not guaranteed.  I
see issues with n of 5, 6 and 8 which have integer angles of 72, 60 and
45.  It works for n of 3 and 12.
Subtracting epsilon before the ceil seems ok and of course does fix it.
On Thu, Aug 21, 2025 at 13:30 Cory Cross via Discuss <
less than 3.
  • Cory Cross
where n comes from
Representability as a double is not sufficient. You have to also compute that representation. Since arccos is involved this is not guaranteed. I see issues with n of 5, 6 and 8 which have integer angles of 72, 60 and 45. It works for n of 3 and 12. Subtracting epsilon before the ceil seems ok and of course does fix it. On Thu, Aug 21, 2025 at 13:30 Cory Cross via Discuss < discuss@lists.openscad.org> wrote: > I think the cause is when either angle or 360/(n*arc_angle) isn't > perfectly representable by a double. > > I think the best solution is to subtract epsilon before calling ceil. I > haven't thought of any situation this is worse, especially given n is never > less than 3. > > > > On August 21, 2025 10:45:52 AM EDT, Marius Kintel via Discuss < > discuss@lists.openscad.org> wrote: > >In C++, OpenSCAD converts n to int first before doing the arc angle > calculation. That may introduce a tiny difference, as if you do the same > calculation in OpenSCAD, it’s kept as double all the way. Not sure if > that’s the root cause though.. > > If I'm remembering my numerical methods lessons correctly, I don't think > that's the reason, as the code correctly multiplies n*arc_angle first, > which will always be less than the maximum representable integer in a > double (for any reasonable n), so it will exact if the angle is > representable as a double. > > - Cory Cross > > > > > > > > -Marius > > > >> On Aug 21, 2025, at 10:22, Adrian Mariano via Discuss < > discuss@lists.openscad.org> wrote: > >> > >> Thanks. The possibility of rounding error exists in the computation. > Someone observed in BOSL2 that offset behaved irregularly. The existing > calculation does not match openscad but even with it fixed if I offset a > regular n gon with $fn = n I get rounding errors and sometimes the ceil > rounds up giving an extra facet. Openscad seems to avoid this somehow and > consistently produces just a single facet. > >> > >> On Thu, Aug 21, 2025 at 09:43 Cory Cross via Discuss < > discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: > >>> At least in DxfData: > >>> > >>> n = static_cast<int>(ceil(n * arc_angle / 360)); > >>> > >>> where n comes from > >>> > >>> int n = Calc::get_fragments_from_r(radius, fn, fs, fa); > >>> > >>> which returns $fn so long as it's at least 3: < > https://github.com/openscad/openscad/blob/master/src%2Futils%2Fcalc.cc#L47 > > > >>> > >>> < > https://github.com/openscad/openscad/blob/master/src%2Fio%2FDxfData.cc#L205 > > > >>> > >>> Sorry for non-permalinks. > >>> > >>> > >>> On August 21, 2025 8:18:44 AM EDT, Adrian Mariano via Discuss < > discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: > >>>> Does anybody know the calculation openscad uses for the number of > segments on an arc of angle theta as a function of $fn? Exactly what kind > of rounding is used? > >>> _______________________________________________ > >>> OpenSCAD mailing list > >>> To unsubscribe send an email to discuss-leave@lists.openscad.org > <mailto:discuss-leave@lists.openscad.org > >_______________________________________________ > >> OpenSCAD mailing list > >> To unsubscribe send an email to discuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
CC
Cory Cross
Fri, Aug 22, 2025 8:37 PM
On August 21, 2025 2:02:00 PM EDT, Adrian Mariano via Discuss discuss@lists.openscad.org wrote:
Oops, I inverted the equation. (n * arc_angle / 360) of course. Okay, so a trigonometric function is calculating the angle and returning 72+epsilon (or more!? hope not), so just subtracting epsilon from the whole equation won't always work when n>360, so it should be taken from the angle.
  • Cory
less than 3.
  • Cory Cross
where n comes from
On August 21, 2025 2:02:00 PM EDT, Adrian Mariano via Discuss <discuss@lists.openscad.org> wrote: >Representability as a double is not sufficient. You have to also compute >that representation. Since arccos is involved this is not guaranteed. I >see issues with n of 5, 6 and 8 which have integer angles of 72, 60 and >45. It works for n of 3 and 12. Oops, I inverted the equation. (n * arc_angle / 360) of course. Okay, so a trigonometric function is calculating the angle and returning 72+epsilon (or more!? hope not), so just subtracting epsilon from the whole equation won't always work when n>360, so it should be taken from the angle. - Cory > >Subtracting epsilon before the ceil seems ok and of course does fix it. > >On Thu, Aug 21, 2025 at 13:30 Cory Cross via Discuss < >discuss@lists.openscad.org> wrote: > >> I think the cause is when either angle or 360/(n*arc_angle) isn't >> perfectly representable by a double. >> >> I think the best solution is to subtract epsilon before calling ceil. I >> haven't thought of any situation this is worse, especially given n is never >> less than 3. >> >> >> >> On August 21, 2025 10:45:52 AM EDT, Marius Kintel via Discuss < >> discuss@lists.openscad.org> wrote: >> >In C++, OpenSCAD converts n to int first before doing the arc angle >> calculation. That may introduce a tiny difference, as if you do the same >> calculation in OpenSCAD, it’s kept as double all the way. Not sure if >> that’s the root cause though.. >> >> If I'm remembering my numerical methods lessons correctly, I don't think >> that's the reason, as the code correctly multiplies n*arc_angle first, >> which will always be less than the maximum representable integer in a >> double (for any reasonable n), so it will exact if the angle is >> representable as a double. >> >> - Cory Cross >> >> >> >> >> > >> > -Marius >> > >> >> On Aug 21, 2025, at 10:22, Adrian Mariano via Discuss < >> discuss@lists.openscad.org> wrote: >> >> >> >> Thanks. The possibility of rounding error exists in the computation. >> Someone observed in BOSL2 that offset behaved irregularly. The existing >> calculation does not match openscad but even with it fixed if I offset a >> regular n gon with $fn = n I get rounding errors and sometimes the ceil >> rounds up giving an extra facet. Openscad seems to avoid this somehow and >> consistently produces just a single facet. >> >> >> >> On Thu, Aug 21, 2025 at 09:43 Cory Cross via Discuss < >> discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: >> >>> At least in DxfData: >> >>> >> >>> n = static_cast<int>(ceil(n * arc_angle / 360)); >> >>> >> >>> where n comes from >> >>> >> >>> int n = Calc::get_fragments_from_r(radius, fn, fs, fa); >> >>> >> >>> which returns $fn so long as it's at least 3: < >> https://github.com/openscad/openscad/blob/master/src%2Futils%2Fcalc.cc#L47 >> > >> >>> >> >>> < >> https://github.com/openscad/openscad/blob/master/src%2Fio%2FDxfData.cc#L205 >> > >> >>> >> >>> Sorry for non-permalinks. >> >>> >> >>> >> >>> On August 21, 2025 8:18:44 AM EDT, Adrian Mariano via Discuss < >> discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: >> >>>> Does anybody know the calculation openscad uses for the number of >> segments on an arc of angle theta as a function of $fn? Exactly what kind >> of rounding is used? >> >>> _______________________________________________ >> >>> OpenSCAD mailing list >> >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >> <mailto:discuss-leave@lists.openscad.org >> >_______________________________________________ >> >> OpenSCAD mailing list >> >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org
Fri, Aug 22, 2025 10:28 PM
Why would it matter if n>360?  I don't see that it makes a difference if
you subtract epsilon from angle or from the whole expression.  I did the
latter because it was simpler.
On Fri, Aug 22, 2025 at 4:38 PM Cory Cross via Discuss <
  • Cory
never
less than 3.
  • Cory Cross
and
where n comes from
kind
Why would it matter if n>360? I don't see that it makes a difference if you subtract epsilon from angle or from the whole expression. I did the latter because it was simpler. On Fri, Aug 22, 2025 at 4:38 PM Cory Cross via Discuss < discuss@lists.openscad.org> wrote: > > > On August 21, 2025 2:02:00 PM EDT, Adrian Mariano via Discuss < > discuss@lists.openscad.org> wrote: > >Representability as a double is not sufficient. You have to also compute > >that representation. Since arccos is involved this is not guaranteed. I > >see issues with n of 5, 6 and 8 which have integer angles of 72, 60 and > >45. It works for n of 3 and 12. > > Oops, I inverted the equation. (n * arc_angle / 360) of course. Okay, so a > trigonometric function is calculating the angle and returning 72+epsilon > (or more!? hope not), so just subtracting epsilon from the whole equation > won't always work when n>360, so it should be taken from the angle. > > - Cory > > > > > >Subtracting epsilon before the ceil seems ok and of course does fix it. > > > >On Thu, Aug 21, 2025 at 13:30 Cory Cross via Discuss < > >discuss@lists.openscad.org> wrote: > > > >> I think the cause is when either angle or 360/(n*arc_angle) isn't > >> perfectly representable by a double. > >> > >> I think the best solution is to subtract epsilon before calling ceil. I > >> haven't thought of any situation this is worse, especially given n is > never > >> less than 3. > >> > >> > >> > >> On August 21, 2025 10:45:52 AM EDT, Marius Kintel via Discuss < > >> discuss@lists.openscad.org> wrote: > >> >In C++, OpenSCAD converts n to int first before doing the arc angle > >> calculation. That may introduce a tiny difference, as if you do the same > >> calculation in OpenSCAD, it’s kept as double all the way. Not sure if > >> that’s the root cause though.. > >> > >> If I'm remembering my numerical methods lessons correctly, I don't think > >> that's the reason, as the code correctly multiplies n*arc_angle first, > >> which will always be less than the maximum representable integer in a > >> double (for any reasonable n), so it will exact if the angle is > >> representable as a double. > >> > >> - Cory Cross > >> > >> > >> > >> > >> > > >> > -Marius > >> > > >> >> On Aug 21, 2025, at 10:22, Adrian Mariano via Discuss < > >> discuss@lists.openscad.org> wrote: > >> >> > >> >> Thanks. The possibility of rounding error exists in the computation. > >> Someone observed in BOSL2 that offset behaved irregularly. The existing > >> calculation does not match openscad but even with it fixed if I offset a > >> regular n gon with $fn = n I get rounding errors and sometimes the ceil > >> rounds up giving an extra facet. Openscad seems to avoid this somehow > and > >> consistently produces just a single facet. > >> >> > >> >> On Thu, Aug 21, 2025 at 09:43 Cory Cross via Discuss < > >> discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: > >> >>> At least in DxfData: > >> >>> > >> >>> n = static_cast<int>(ceil(n * arc_angle / 360)); > >> >>> > >> >>> where n comes from > >> >>> > >> >>> int n = Calc::get_fragments_from_r(radius, fn, fs, fa); > >> >>> > >> >>> which returns $fn so long as it's at least 3: < > >> > https://github.com/openscad/openscad/blob/master/src%2Futils%2Fcalc.cc#L47 > >> > > >> >>> > >> >>> < > >> > https://github.com/openscad/openscad/blob/master/src%2Fio%2FDxfData.cc#L205 > >> > > >> >>> > >> >>> Sorry for non-permalinks. > >> >>> > >> >>> > >> >>> On August 21, 2025 8:18:44 AM EDT, Adrian Mariano via Discuss < > >> discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> wrote: > >> >>>> Does anybody know the calculation openscad uses for the number of > >> segments on an arc of angle theta as a function of $fn? Exactly what > kind > >> of rounding is used? > >> >>> _______________________________________________ > >> >>> OpenSCAD mailing list > >> >>> To unsubscribe send an email to discuss-leave@lists.openscad.org > >> <mailto:discuss-leave@lists.openscad.org > >> >_______________________________________________ > >> >> OpenSCAD mailing list > >> >> To unsubscribe send an email to discuss-leave@lists.openscad.org > >> > > >> _______________________________________________ > >> OpenSCAD mailing list > >> To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Sun, Aug 24, 2025 9:57 PM
I don't think anybody ever directly quoted the source:
https://github.com/openscad/openscad/blob/7cf1c641e4dba4bac4ffe247b7a900029b8ae148/src/geometry/rotate_extrude.cc#L103
  const auto num_sections = (unsigned int)std::ceil(fmax(
    Calc::get_fragments_from_r(max_x - min_x, node.fn, node.fs, node.fa) * std::abs(node.angle) / 360,
    1));
Calc:get_fragments_from_r() is the $fn/$fa/$fs/r calculation, which
returns $fn if it is set and reasonable.
On 8/21/2025 2:18 PM, Adrian Mariano via Discuss wrote: > Does anybody know the calculation openscad uses for the number of > segments on an arc of angle theta as a function of $fn?  Exactly what > kind of rounding is used? I don't think anybody ever directly quoted the source: https://github.com/openscad/openscad/blob/7cf1c641e4dba4bac4ffe247b7a900029b8ae148/src/geometry/rotate_extrude.cc#L103   const auto num_sections = (unsigned int)std::ceil(fmax(     Calc::get_fragments_from_r(max_x - min_x, node.fn, node.fs, node.fa) * std::abs(node.angle) / 360,     1)); Calc:get_fragments_from_r() is the $fn/$fa/$fs/r calculation, which returns $fn if it is set and reasonable.
CC
Cory Cross
Sun, Aug 24, 2025 10:46 PM
So the error is in angle, and it's multiplied by n/360. We're assuming
the error is as much as epsilon, so subtracting at the end:
n*(angle+epsilon)/360 - epsilon
nangle/360 + epsilonn/360 - epsilon
so if n=720 we're still epsilon too much, and if (n*angle/360) is an
integer, the final result will round up to the next higher integer.
versus subtracting at angle:
n*(angle+epsilon-epsilon)/360
n*angle/360
independent of n when error==epsilon (which we're assuming). If it's
actually less than epsilon:
nangle/360 - epsilonn/360
That will only cause a different result if n*angle/360 was slightly more
than a whole number, which will never (for any sane measurements) be the
case when you are choosing some fraction of $fn arc, and only arose in
freak coincidences in existing code.
  • Cory Cross
 compute
 guaranteed.  I
 60 and
 - Cory
 fix it.
 ceil. I
 given n is never
less than 3.
 angle
 the same
 sure if
 don't think
 first,
 integer in a
  • Cory Cross
 computation.
 existing
 offset a
 the ceil
 somehow and
where n comes from
 fs, fa);
 number of
 Exactly what kind
On 8/22/25 3:28 PM, Adrian Mariano via Discuss wrote: > Why would it matter if n>360?  I don't see that it makes a difference > if you subtract epsilon from angle or from the whole expression.  I > did the latter because it was simpler. So the error is in `angle`, and it's multiplied by n/360. We're assuming the error is as much as epsilon, so subtracting at the end: n*(angle+epsilon)/360 - epsilon n*angle/360 + epsilon*n/360 - epsilon so if n=720 we're still epsilon too much, and if (n*angle/360) is an integer, the final result will round up to the next higher integer. versus subtracting at angle: n*(angle+epsilon-epsilon)/360 n*angle/360 independent of n when error==epsilon (which we're assuming). If it's actually less than epsilon: n*angle/360 - epsilon*n/360 That will only cause a different result if n*angle/360 was slightly more than a whole number, which will never (for any sane measurements) be the case when you are choosing some fraction of $fn arc, and only arose in freak coincidences in existing code. - Cory Cross > > On Fri, Aug 22, 2025 at 4:38 PM Cory Cross via Discuss > <discuss@lists.openscad.org> wrote: > > > > On August 21, 2025 2:02:00 PM EDT, Adrian Mariano via Discuss > <discuss@lists.openscad.org> wrote: > >Representability as a double is not sufficient. You have to also > compute > >that representation. Since arccos is involved this is not > guaranteed.  I > >see issues with n of 5, 6 and 8 which have integer angles of 72, > 60 and > >45.  It works for n of 3 and 12. > > Oops, I inverted the equation. (n * arc_angle / 360) of course. > Okay, so a trigonometric function is calculating the angle and > returning 72+epsilon (or more!? hope not), so just subtracting > epsilon from the whole equation won't always work when n>360, so > it should be taken from the angle. > > - Cory > > > > > >Subtracting epsilon before the ceil seems ok and of course does > fix it. > > > >On Thu, Aug 21, 2025 at 13:30 Cory Cross via Discuss < > >discuss@lists.openscad.org> wrote: > > > >> I think the cause is when either angle or 360/(n*arc_angle) isn't > >> perfectly representable by a double. > >> > >> I think the best solution is to subtract epsilon before calling > ceil. I > >> haven't thought of any situation this is worse, especially > given n is never > >> less than 3. > >> > >> > >> > >> On August 21, 2025 10:45:52 AM EDT, Marius Kintel via Discuss < > >> discuss@lists.openscad.org> wrote: > >> >In C++, OpenSCAD converts n to int first before doing the arc > angle > >> calculation. That may introduce a tiny difference, as if you do > the same > >> calculation in OpenSCAD, it’s kept as double all the way. Not > sure if > >> that’s the root cause though.. > >> > >> If I'm remembering my numerical methods lessons correctly, I > don't think > >> that's the reason, as the code correctly multiplies n*arc_angle > first, > >> which will always be less than the maximum representable > integer in a > >> double (for any reasonable n), so it will exact if the angle is > >> representable as a double. > >> > >> - Cory Cross > >> > >> > >> > >> > >> > > >> > -Marius > >> > > >> >> On Aug 21, 2025, at 10:22, Adrian Mariano via Discuss < > >> discuss@lists.openscad.org> wrote: > >> >> > >> >> Thanks.  The possibility of rounding error exists in the > computation. > >> Someone observed in BOSL2 that offset behaved irregularly.  The > existing > >> calculation does not match openscad but even with it fixed if I > offset a > >> regular n gon with $fn = n I get rounding errors and sometimes > the ceil > >> rounds up giving an extra facet. Openscad seems to avoid this > somehow and > >> consistently produces just a single facet. > >> >> > >> >> On Thu, Aug 21, 2025 at 09:43 Cory Cross via Discuss < > >> discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> > wrote: > >> >>> At least in DxfData: > >> >>> > >> >>>           n = static_cast<int>(ceil(n * arc_angle / 360)); > >> >>> > >> >>> where n comes from > >> >>> > >> >>>           int n = Calc::get_fragments_from_r(radius, fn, > fs, fa); > >> >>> > >> >>> which returns $fn so long as it's at least 3: < > >> > https://github.com/openscad/openscad/blob/master/src%2Futils%2Fcalc.cc#L47 > >> > > >> >>> > >> >>> < > >> > https://github.com/openscad/openscad/blob/master/src%2Fio%2FDxfData.cc#L205 > >> > > >> >>> > >> >>> Sorry for non-permalinks. > >> >>> > >> >>> > >> >>> On August 21, 2025 8:18:44 AM EDT, Adrian Mariano via Discuss < > >> discuss@lists.openscad.org <mailto:discuss@lists.openscad.org>> > wrote: > >> >>>> Does anybody know the calculation openscad uses for the > number of > >> segments on an arc of angle theta as a function of $fn?  > Exactly what kind > >> of rounding is used? > >> >>> _______________________________________________ > >> >>> OpenSCAD mailing list > >> >>> To unsubscribe send an email to > discuss-leave@lists.openscad.org > >> <mailto:discuss-leave@lists.openscad.org > >> >_______________________________________________ > >> >> OpenSCAD mailing list > >> >> To unsubscribe send an email to discuss-leave@lists.openscad.org > >> > > >> _______________________________________________ > >> OpenSCAD mailing list > >> To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
