Sun, Aug 24, 2025 11:08 PM
Cory did quote links to the code.
Your analysis assumes you can do regular arithmetic on epsilon, which I
think is suspect if epsilon is machine precision, since every computational
step has the potential to introduce error on the order of epsilon---in
either direction. In fact it appears that only by subtracting epsilon at
the end do you guarantee that you're not subject to subsequent rounding
error that makes the value too large.
In the helix() function in fact angle can be arbitrarily large, as the
helix may have many turns.
On Sun, Aug 24, 2025 at 6:46 PM Cory Cross openscad@corycross.org wrote:
On 8/22/25 3:28 PM, Adrian Mariano via Discuss wrote:
Why would it matter if n>360? I don't see that it makes a difference if
you subtract epsilon from angle or from the whole expression. I did the
latter because it was simpler.
So the error is in angle, and it's multiplied by n/360. We're assuming
the error is as much as epsilon, so subtracting at the end:
n*(angle+epsilon)/360 - epsilon
nangle/360 + epsilonn/360 - epsilon
so if n=720 we're still epsilon too much, and if (n*angle/360) is an
integer, the final result will round up to the next higher integer.
versus subtracting at angle:
n*(angle+epsilon-epsilon)/360
n*angle/360
independent of n when error==epsilon (which we're assuming). If it's
actually less than epsilon:
nangle/360 - epsilonn/360
That will only cause a different result if n*angle/360 was slightly more
than a whole number, which will never (for any sane measurements) be the
case when you are choosing some fraction of $fn arc, and only arose in
freak coincidences in existing code.
On Fri, Aug 22, 2025 at 4:38 PM Cory Cross via Discuss <
Representability as a double is not sufficient. You have to also compute
that representation. Since arccos is involved this is not guaranteed. I
see issues with n of 5, 6 and 8 which have integer angles of 72, 60 and
45. It works for n of 3 and 12.
Oops, I inverted the equation. (n * arc_angle / 360) of course. Okay, so
a trigonometric function is calculating the angle and returning 72+epsilon
(or more!? hope not), so just subtracting epsilon from the whole equation
won't always work when n>360, so it should be taken from the angle.
Subtracting epsilon before the ceil seems ok and of course does fix it.
On Thu, Aug 21, 2025 at 13:30 Cory Cross via Discuss <
I think the cause is when either angle or 360/(n*arc_angle) isn't
perfectly representable by a double.
I think the best solution is to subtract epsilon before calling ceil. I
haven't thought of any situation this is worse, especially given n is
In C++, OpenSCAD converts n to int first before doing the arc angle
calculation. That may introduce a tiny difference, as if you do the
calculation in OpenSCAD, it’s kept as double all the way. Not sure if
that’s the root cause though..
If I'm remembering my numerical methods lessons correctly, I don't
that's the reason, as the code correctly multiplies n*arc_angle first,
which will always be less than the maximum representable integer in a
double (for any reasonable n), so it will exact if the angle is
representable as a double.
On Aug 21, 2025, at 10:22, Adrian Mariano via Discuss <
Thanks. The possibility of rounding error exists in the
Someone observed in BOSL2 that offset behaved irregularly. The
calculation does not match openscad but even with it fixed if I offset
regular n gon with $fn = n I get rounding errors and sometimes the ceil
rounds up giving an extra facet. Openscad seems to avoid this somehow
consistently produces just a single facet.
On Thu, Aug 21, 2025 at 09:43 Cory Cross via Discuss <
At least in DxfData:
n = static_cast<int>(ceil(n * arc_angle / 360));
where n comes from
int n = Calc::get_fragments_from_r(radius, fn, fs, fa);
which returns $fn so long as it's at least 3: <
Sorry for non-permalinks.
On August 21, 2025 8:18:44 AM EDT, Adrian Mariano via Discuss <
Does anybody know the calculation openscad uses for the number of
segments on an arc of angle theta as a function of $fn? Exactly what
> So the error is in `angle`, and it's multiplied by n/360. We're assuming
> n*angle/360 + epsilon*n/360 - epsilon
> n*angle/360
> n*angle/360 - epsilon*n/360
> - Cory Cross
> discuss@lists.openscad.org> wrote:
>> On August 21, 2025 2:02:00 PM EDT, Adrian Mariano via Discuss <
>> - Cory
>> never
>> >> less than 3.
>> >> On August 21, 2025 10:45:52 AM EDT, Marius Kintel via Discuss <
>> same
>> think
>> >> - Cory Cross
>> >> > -Marius
>> computation.
>> existing
>> a
>> and
>> >> >>> where n comes from
>> https://github.com/openscad/openscad/blob/master/src%2Futils%2Fcalc.cc#L47
>> https://github.com/openscad/openscad/blob/master/src%2Fio%2FDxfData.cc#L205
>> kind
>> >> of rounding is used?
>> >> >>> _______________________________________________
>> >> >>> OpenSCAD mailing list
>> >> >>> To unsubscribe send an email to discuss-leave@lists.openscad.org
>> >> <mailto:discuss-leave@lists.openscad.org
CC
Cory Cross
Mon, Aug 25, 2025 12:03 AM
I think is suspect if epsilon is machine precision, since every
computational step has the potential to introduce error on the order
of epsilon---in either direction. In fact it appears that only by
subtracting epsilon at the end do you guarantee that you're not
subject to subsequent rounding error that makes the value too large.
Okay, let's assume we're exactly one epsilon too large, see if my Python
is correct. Some lines truncated
... print("n=%d\t%s", n, format(720+1/2**n,'.17f'))
n=%d %s 43 720.00000000000011369
n=%d %s 44 720.00000000000000000
math.log2(1/math.ulp(720))
... print("n=%d\t%s" % (n, format((720+1/2**43)*n,'.17f')))
n=2 1440.00000000000022737
n=3 2160.00000000000045475
n=6 4320.00000000000090949
n=12 8640.00000000000181899
n=23 16560.00000000000363798
n=24 17280.00000000000363798
n=25 18000.00000000000363798
for n in range(2,36000,10000):
... postresult=n*(720+math.ulp(720))/360
... postresult-=math.ulp(postresult)
... angresult=n*(720+math.ulp(720)-math.ulp(720))/360
... print("n=%d\t%s\t%s" % (n, format(postresult,'.17f'),
format(angresult,'.17f')))
n=2 4.00000000000000000 4.00000000000000000
n=10002 20004.00000000000000000 20004.00000000000000000
n=20002 40004.00000000000000000 40004.00000000000000000
n=30002 60004.00000000000000000 60004.00000000000000000
Okay, as long as you're calculating epsilon it looks correct either way.
(if you use the "machine epsilon" or epsilon of the angle, it gives
wrong answers)
difference if you subtract epsilon from angle or from the whole
expression. I did the latter because it was simpler.
assuming the error is as much as epsilon, so subtracting at the end:
an integer, the final result will round up to the next higher integer.
n*angle/360
it's actually less than epsilon:
slightly more than a whole number, which will never (for any sane
measurements) be the case when you are choosing some fraction of
$fn arc, and only arose in freak coincidences in existing code.
- Cory Cross
course. Okay, so a trigonometric function is calculating the
angle and returning 72+epsilon (or more!? hope not), so just
subtracting epsilon from the whole equation won't always work
- Cory
less than 3.
irregularly. The existing
where n comes from
>>> for n in range(40,60):
43.0
>>> for n in range(2,30):
wrong answers)
- Cory
> n*angle/360
> - Cory Cross
>> also compute
>> guaranteed. I
>> 72, 60 and
>> - Cory
>> does fix it.
>> calling ceil. I
>> given n is never
>> >> less than 3.
>> Discuss <
>> arc angle
>> you do the same
>> Not sure if
>> I don't think
>> n*arc_angle first,
>> integer in a
>> angle is
>> >> - Cory Cross
>> >> > -Marius
>> the computation.
>> if I offset a
>> sometimes the ceil
>> this somehow and
>> >> >>> where n comes from
>> fn, fs, fa);
>> Discuss <
>> the number of
>> Exactly what kind
>> To unsubscribe send an email todiscuss-leave@lists.openscad.org
Mon, Aug 25, 2025 7:05 AM
kind of rounding is used?
I don't think anybody ever directly quoted the source:
My apologies. I read more into Adrian's question than was there; the
only case that came to mind that processes arcs was rotate_extrude and
so that's what I thought he was talking about.
Part of the true answer is that there is no true answer. There is a
central function for doing the r/fn/fs/fa calculation for the number of
segments in a circle, but no corresponding central function for
calculating the number of segments in an arc. Each component that needs
it does the calculation on its own.
For the particular case of offset(), which is what Adrian is looking
at, it's here:
https://github.com/openscad/openscad/blob/4c9d585cffd9d1e787366eb3023d9f9d3c5084fa/src/geometry/GeometryEvaluator.cc#L599
... which only partially answers the question:
// ClipperLib documentation: The formula for the number of steps in a full
// circular arc is ... Pi / acos(1 - arc_tolerance / abs(delta))
double n = Calc::get_fragments_from_r(std::abs(node.delta), node.fn, node.fs, node.fa);
double arc_tolerance = std::abs(node.delta) * (1 - cos_degrees(180 / n));
geom = ClipperUtils::applyOffset(*polygon, node.delta, node.join_type, node.miter_limit,
arc_tolerance);
so it's considerably uglier than rotate_extrude.
For the particular case of offset(), which *is* what Adrian is looking
at, it's here:
arc_tolerance);
Mon, Aug 25, 2025 8:31 PM
I can't tell what's going on in that clipperlib code fragment. Does
node.delta hold the r value for the offset?
On Mon, Aug 25, 2025 at 3:06 AM Jordan Brown via Discuss <
Does anybody know the calculation openscad uses for the number of segments
on an arc of angle theta as a function of $fn? Exactly what kind of
rounding is used?
My apologies. I read more into Adrian's question than was there; the only
case that came to mind that processes arcs was rotate_extrude and so that's
segments in a circle, but no corresponding central function for calculating
the number of segments in an arc. Each component that needs it does the
For the particular case of offset(), which is what Adrian is looking at,
it's here:
arc_tolerance);
> rounding is used?
> For the particular case of offset(), which *is* what Adrian is looking at,
> it's here:
> arc_tolerance);
Mon, Aug 25, 2025 9:17 PM
of segments on an arc of angle theta as a function of $fn?
Exactly what kind of rounding is used?
the only case that came to mind that processes arcs was
rotate_extrude and so that's what I thought he was talking about.
a central function for doing the r/fn/fs/fa calculation for the
number of segments in a circle, but no corresponding central
function for calculating the number of segments in an arc. Each
component that needs it does the calculation on its own.
looking at, it's here:
arc_tolerance);
node.delta gets "r" if it's set, else gets "delta" if it's set, else is 1.
https://github.com/openscad/openscad/blob/4c9d585cffd9d1e787366eb3023d9f9d3c5084fa/src/core/OffsetNode.cc#L55
> arc_tolerance);
