Voxel file format
I
Ivo
Thu, Apr 23, 2015 12:36 PM
Shapeways has a an upper limit of 1000000 polygons per model.
A format that does not seem to have this limitation us the SVX format :
http://www.shapeways.com/blog/archives/17972-shapeways-launches-svx-voxel-file-format-for-3d-printing.html
described in : http://abfab3d.com/svx-format/
Sculpteo is less specific ; "tiny details in large files with excessive
numbers of polygons will not be rendered"
How hard would it be be to build an exporter for this format ?
SVX seems to be very poorly supported.
View this message in context: http://forum.openscad.org/Voxel-file-format-tp12468.html
Shapeways has a an upper limit of 1000000 polygons per model. A format that does not seem to have this limitation us the SVX format : http://www.shapeways.com/blog/archives/17972-shapeways-launches-svx-voxel-file-format-for-3d-printing.html described in : http://abfab3d.com/svx-format/ Sculpteo is less specific ; "tiny details in large files with excessive numbers of polygons will not be rendered" How hard would it be be to build an exporter for this format ? SVX seems to be very poorly supported. -- View this message in context: http://forum.openscad.org/Voxel-file-format-tp12468.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Q
QuackingPlums
Thu, Apr 23, 2015 1:33 PM
I can't speak for Shapeways but my RepRap is unlikely to have sufficient
resolution to print 1,000,000 faces on an object the size of my print bed
(and for those faces to be distinguishable).
A better approach might be to work out the limitations of your print format
and output the correct resolution to match. There will be no discernible
different and file sizes will be smaller.
View this message in context: http://forum.openscad.org/Voxel-file-format-tp12468p12469.html
I can't speak for Shapeways but my RepRap is unlikely to have sufficient resolution to print 1,000,000 faces on an object the size of my print bed (and for those faces to be distinguishable). A better approach might be to work out the limitations of your print format and output the correct resolution to match. There will be no discernible different and file sizes will be smaller. -- View this message in context: http://forum.openscad.org/Voxel-file-format-tp12468p12469.html Sent from the OpenSCAD mailing list archive at Nabble.com.
YS
Yvette S. Hirth, CCP, CDP
Thu, Apr 23, 2015 3:16 PM
hi all,
i'm trying to "cut" threads in openSCAD.  i'm using the threads.scad
module i found on thingiverse, like so:
use <threads.scad>;
english_thread(diameter=(632ScrewRadius*2),
threads_per_inch=32,
length=(coverDepth+coverThickness),
internal=true,
$fn=30);
gosh, is it slow!  i played a game of freecell and the progress meter
hasn't budged from "just started".  and now i've finished typing this
email and still no progress.
i put cylinders in the code to check for positioning and depth; once i
got those right, i commented out ONLY the first cylinder and inserted
just the code for the one thread above.  my res time (F6) was 45sec; now
it could be hours.  from one thread - and i have four to gen before
slicing.
i'm sure the lack of progress is due to threads.scad creating a
bazillion polygons.  i'm not trying to complain; i'm just trying to get
my stuff printed.
is there any alternative to threads.scad?
thanks!
yvette
hi all, i'm trying to "cut" threads in openSCAD. i'm using the threads.scad module i found on thingiverse, like so: use <threads.scad>; ... english_thread(diameter=(632ScrewRadius*2), threads_per_inch=32, length=(coverDepth+coverThickness), internal=true, $fn=30); gosh, is it *slow*! i played a game of freecell and the progress meter hasn't budged from "just started". and now i've finished typing this email and still no progress. i put cylinders in the code to check for positioning and depth; once i got those right, i commented out ONLY the first cylinder and inserted just the code for the one thread above. my res time (F6) was 45sec; now it could be hours. from *one* thread - and i have four to gen before slicing. i'm sure the lack of progress is due to threads.scad creating a bazillion polygons. i'm not trying to complain; i'm just trying to get my stuff printed. is there any alternative to threads.scad? thanks! yvette
I
Ivo
Thu, Apr 23, 2015 7:19 PM
QuackingPlums wrote > I can't speak for Shapeways but my RepRap is unlikely to have sufficient > resolution to print 1,000,000 faces on an object the size of my print bed > (and for those faces to be distinguishable). Models like https://www.shapeways.com/product/KPZ4NZLQH/twisty-cube?li=search-results-5&optionId=42490374 https://www.shapeways.com/product/TCAXXR9BJ/woven-purse?li=search-results-30&optionId=42445606 Will get to a million faces. -- View this message in context: http://forum.openscad.org/Voxel-file-format-tp12468p12471.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Apr 23, 2015 7:35 PM
On Apr 23, 2015, at 08:36 AM, Ivo ivo.knutsel@gmail.com wrote:
Do shapeways have a limitation on the size of SVX files?
Such voxel files will easily reach a GB of raw data..
On Apr 23, 2015, at 08:36 AM, Ivo <ivo.knutsel@gmail.com> wrote: > http://www.shapeways.com/blog/archives/17972-shapeways-launches-svx-voxel-file-format-for-3d-printing.html > described in : http://abfab3d.com/svx-format/ > Do shapeways have a limitation on the size of SVX files? Such voxel files will easily reach a GB of raw data.. -Marius
I
Ivo
Thu, Apr 23, 2015 8:08 PM
ivo.knutsel@
With the existing png export it almost seems like something that can be
scripted together in a sunday afternoon.
View this message in context: http://forum.openscad.org/Voxel-file-format-tp12468p12473.html
kintel wrote > On Apr 23, 2015, at 08:36 AM, Ivo &lt; > ivo.knutsel@ > &gt; wrote: > >> http://www.shapeways.com/blog/archives/17972-shapeways-launches-svx-voxel-file-format-for-3d-printing.html >> described in : http://abfab3d.com/svx-format/ >> > Do shapeways have a limitation on the size of SVX files? > Such voxel files will easily reach a GB of raw data.. > > -Marius With the existing png export it almost seems like something that can be scripted together in a sunday afternoon. -- View this message in context: http://forum.openscad.org/Voxel-file-format-tp12468p12473.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Apr 23, 2015 8:23 PM
Might take more than an afternoon to run though as you would need to slice
with projection() and that isn't quick.
On 23 April 2015 at 21:08, Ivo ivo.knutsel@gmail.com wrote:
ivo.knutsel@
Might take more than an afternoon to run though as you would need to slice with projection() and that isn't quick. On 23 April 2015 at 21:08, Ivo <ivo.knutsel@gmail.com> wrote: > kintel wrote > > On Apr 23, 2015, at 08:36 AM, Ivo &lt; > > > ivo.knutsel@ > > > &gt; wrote: > > > >> > http://www.shapeways.com/blog/archives/17972-shapeways-launches-svx-voxel-file-format-for-3d-printing.html > >> described in : http://abfab3d.com/svx-format/ > >> > > Do shapeways have a limitation on the size of SVX files? > > Such voxel files will easily reach a GB of raw data.. > > > > -Marius > > With the existing png export it almost seems like something that can be > scripted together in a sunday afternoon. > > > > -- > View this message in context: > http://forum.openscad.org/Voxel-file-format-tp12468p12473.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
S
stonysmith
Fri, Apr 24, 2015 1:00 AM
First, it's 1million TRIANGLES, not 1m polygons.  If you upload a file made
out of polygons, it will first be triangulated, and then fail in the upload
process for having more than the limit of triangles.
Second, I believe that, rather silently, they upped it to TWO million
triangles many months ago. (or, at least some number more than 1m)
Third, the Shapeways file size limit is still 64mb.  But, SVX must be
zipped, so the compression will help you out on the size.
Forth, I'm not real happy with the SVX implementation, the model is uploaded
as voxels (cubes), but they render them out to polygons, and then apply a
polygon reduction operation to the outer shell of the model.  The polygon
reduction they apply has the effect of smoothing the model a bit too much
for my tastes.  It may well be within the resolution of the printer, but to
me the detail produced looks terrible.
View this message in context: http://forum.openscad.org/Voxel-file-format-tp12468p12476.html
First, it's 1million TRIANGLES, not 1m polygons. If you upload a file made out of polygons, it will first be triangulated, and then fail in the upload process for having more than the limit of triangles. Second, I believe that, rather silently, they upped it to TWO million triangles many months ago. (or, at least some number more than 1m) Third, the Shapeways file size limit is still 64mb. But, SVX must be zipped, so the compression will help you out on the size. Forth, I'm not real happy with the SVX implementation, the model is uploaded as voxels (cubes), but they render them out to polygons, and then apply a polygon reduction operation to the outer shell of the model. The polygon reduction they apply has the effect of smoothing the model a bit too much for my tastes. It may well be within the resolution of the printer, but to me the detail produced looks terrible. -- View this message in context: http://forum.openscad.org/Voxel-file-format-tp12468p12476.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Fri, Apr 24, 2015 2:00 AM
On Apr 23, 2015, at 21:00 PM, stonysmith stonysmith@gmail.com wrote:
[…] The polygon
That’s good feedback.
Perhaps a much better solution would be for OpenSCAD to perform said polygon reduction on the original design. As OpenSCAD tends to generate a lot of tiny polygons, we could probably reduce typical designs significantly before it having a large visual impact.
On Apr 23, 2015, at 21:00 PM, stonysmith <stonysmith@gmail.com> wrote: > […] The polygon > reduction they apply has the effect of smoothing the model a bit too much > for my tastes. It may well be within the resolution of the printer, but to > me the detail produced looks terrible. > That’s good feedback. Perhaps a much better solution would be for OpenSCAD to perform said polygon reduction on the original design. As OpenSCAD tends to generate a lot of tiny polygons, we could probably reduce typical designs significantly before it having a large visual impact. -Marius
AP
Andrew Plumb
Fri, Apr 24, 2015 2:59 AM
[…] The polygon
> On Apr 23, 2015, at 10:00 PM, Marius Kintel <marius@kintel.net> wrote: > > On Apr 23, 2015, at 21:00 PM, stonysmith <stonysmith@gmail.com> wrote: > >> […] The polygon >> reduction they apply has the effect of smoothing the model a bit too much >> for my tastes. It may well be within the resolution of the printer, but to >> me the detail produced looks terrible. >> > That’s good feedback. > Perhaps a much better solution would be for OpenSCAD to perform said polygon reduction on the original design. As OpenSCAD tends to generate a lot of tiny polygons, we could probably reduce typical designs significantly before it having a large visual impact. CGAL does document some mesh reduction approaches: http://doc.cgal.org/latest/Surface_mesh_simplification/ <http://doc.cgal.org/latest/Surface_mesh_simplification/> Andrew.
