On Thu, Apr 23, 2015 at 08:16:08AM -0700, Yvette S. Hirth, CCP, CDP wrote:
hi all,
i'm trying to "cut" threads in openSCAD. i'm using the threads.scad module
i found on thingiverse, like so:
use <threads.scad>;
english_thread(diameter=(632ScrewRadius*2),
threads_per_inch=32,
length=(coverDepth+coverThickness),
internal=true,
$fn=30);
gosh, is it slow! i played a game of freecell and the progress meter
hasn't budged from "just started". and now i've finished typing this email
and still no progress.
i put cylinders in the code to check for positioning and depth; once i got
those right, i commented out ONLY the first cylinder and inserted just the
code for the one thread above. my res time (F6) was 45sec; now it could be
hours. from one thread - and i have four to gen before slicing.
i'm sure the lack of progress is due to threads.scad creating a bazillion
polygons. i'm not trying to complain; i'm just trying to get my stuff
printed.
is there any alternative to threads.scad?
Use OpenSCAD 2015.03 and threads.scad from MCAD's dev branch. It's an updated
version of the threads.scad you're using. Uses list comprehension, and sweep()
for generalized extrusion of the threads, and is much faster than the
implementation you're using.
Kind regards,
Loong Jin
hi all,
use <threads.scad>;
internal=true,
$fn=30);
printed.
Oh, it also obeys $fs, $fa and $fn, so you'll have to tweak those values for
higher faceting resolution on small diameters. OpenSCAD's default $fs, $fa and
$fn parameters are unfortunately pretty coarse.
Kind regards,
Loong Jin
As OpenSCAD tends to generate a lot of tiny polygons
Really, I thought it just generated the polygons implied by the source code
with $fn, etc. Does it make some extra ones up?
On 24 April 2015 at 03:59, Andrew Plumb andrew@plumb.org wrote:
On Apr 23, 2015, at 10:00 PM, Marius Kintel marius@kintel.net wrote:
On Apr 23, 2015, at 21:00 PM, stonysmith stonysmith@gmail.com wrote:
[...] The polygon
reduction they apply has the effect of smoothing the model a bit too much
for my tastes. It may well be within the resolution of the printer, but to
me the detail produced looks terrible.
That's good feedback.
Perhaps a much better solution would be for OpenSCAD to perform said
polygon reduction on the original design. As OpenSCAD tends to generate a
lot of tiny polygons, we could probably reduce typical designs
significantly before it having a large visual impact.
CGAL does document some mesh reduction approaches:
http://doc.cgal.org/latest/Surface_mesh_simplification/
Andrew.
Really, I thought it just generated the polygons implied by the source code with $fn, etc. Does it make some extra ones up?
During CSG operations, tiny polygons tend to be introduced by CGAL, partially due to their infinite precision. Some of these polygons could easily be reduced to nothing by employing a topology-preserving optimization mechanism.
