Hmm, CGAL error only after F5/F6 sequence.
Sun, Nov 6, 2016 4:07 AM
This is a strange one. I'm trying to track down a CGAL error in 2016.10.05
(&.04) which doesn't happen in 2015.03-2.
However it appeared to be intermittent.
As you know GCAL error do not repeat as they are cached. So using
Design/Flush_Caches is needed to reproduce.
I happens after a clean start, then F5 then F6.
It only happens with a F6 AFTER an F5!
Noting that there is use of render() which does CGAL calls on F5, comment
out this and there is no error.
----------------------code-------------------
echo(version());
$fa=0.05;
$fs=1;
s=0.1;
s2=s*2;
!recessOrig(i=1);
rOD=40.25;
rID=36.3;
rThick=2.3;
rDeep=38;
rRoundOffset=6;
module recessOrig(i=0,logo=true) { // i inverted
cylinder(r=rID/2+rThick,h=rDeep); // main tube
translate([0,0,-s])
cylinder(r=rID/2,h=rDeep+rRoundOffset+s2); // hollow out tube
} // d
} // u
translate([rThick-0.5,0,0 ])
render(convexity=30)          //  <<== comment out
translate([rID/2-2.5,(i ? -1 : +1)*1.3,(i ? 17.5 : 17.5)])
rotate([90,(i ? 0 : 90),90])
scale(0.9)
linear_extrude(height=15, convexity=30)
text("MH",font="Rockwell",spacing=0.7,halign="center");
translate([0,0,-s])
} // d
} // recess
View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954.html
This is a strange one. I'm trying to track down a CGAL error in 2016.10.05 (&.04) which doesn't happen in 2015.03-2. However it appeared to be intermittent. As you know GCAL error do not repeat as they are cached. So using Design/Flush_Caches is needed to reproduce. I happens after a clean start, then F5 then F6. It only happens with a F6 AFTER an F5! Noting that there is use of render() which does CGAL calls on F5, comment out this and there is no error. ----------------------code------------------- echo(version()); $fa=0.05; $fs=1; s=0.1; s2=s*2; !recessOrig(i=1); rOD=40.25; rID=36.3; rThick=2.3; rDeep=38; rRoundOffset=6; module recessOrig(i=0,logo=true) { // i inverted difference() { union() { difference() { cylinder(r=rID/2+rThick,h=rDeep); // main tube // - translate([0,0,-s]) cylinder(r=rID/2,h=rDeep+rRoundOffset+s2); // hollow out tube } // d } // u // - translate([rThick-0.5,0,0 ]) render(convexity=30) // <<== comment out intersection() { translate([rID/2-2.5,(i ? -1 : +1)*1.3,(i ? 17.5 : 17.5)]) rotate([90,(i ? 0 : 90),90]) scale(0.9) { linear_extrude(height=15, convexity=30) text("MH",font="Rockwell",spacing=0.7,halign="center"); } difference(){ cylinder(r=rID/2+rThick,h=rDeep); translate([0,0,-s]) cylinder(r=rID/2,h=rDeep+rRoundOffset+s2); // hollow out tube } } } // d } // recess ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Nov 6, 2016 12:03 PM
Also doesn't happen in 2016.04.06
View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p18957.html
Also doesn't happen in 2016.04.06 -- View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p18957.html Sent from the OpenSCAD mailing list archive at Nabble.com.
JL
Jean-Paul Louis
Sun, Nov 6, 2016 7:42 PM
Doesn’t happen to me with the latest OS X build.
OpenSCAD version 2016.10.16 (git 5cb40a2)
Jean-Paul
N1JPL
echo(version());
$fa=0.05;
$fs=1;
s=0.1;
s2=s*2;
!recessOrig(i=1);
rOD=40.25;
rID=36.3;
rThick=2.3;
rDeep=38;
rRoundOffset=6;
translate([0,0,-s])
} // d
} // u
scale(0.9)
translate([0,0,-s])
} // d
} // recess
Doesn’t happen to me with the latest OS X build. OpenSCAD version 2016.10.16 (git 5cb40a2) Jean-Paul N1JPL > On Nov 6, 2016, at 12:07 AM, MichaelAtOz <oz.at.michael@gmail.com> wrote: > > This is a strange one. I'm trying to track down a CGAL error in 2016.10.05 > (&.04) which doesn't happen in 2015.03-2. > > However it appeared to be intermittent. > As you know GCAL error do not repeat as they are cached. So using > Design/Flush_Caches is needed to reproduce. > > I happens after a clean start, then F5 then F6. > > It only happens with a F6 AFTER an F5! > > Noting that there is use of render() which does CGAL calls on F5, comment > out this and there is no error. > > > ----------------------code------------------- > > echo(version()); > $fa=0.05; > $fs=1; > s=0.1; > s2=s*2; > > !recessOrig(i=1); > > rOD=40.25; > rID=36.3; > rThick=2.3; > rDeep=38; > rRoundOffset=6; > > module recessOrig(i=0,logo=true) { // i inverted > difference() { > union() { > difference() { > cylinder(r=rID/2+rThick,h=rDeep); // main tube > // - > translate([0,0,-s]) > cylinder(r=rID/2,h=rDeep+rRoundOffset+s2); // hollow out tube > } // d > } // u > // - > translate([rThick-0.5,0,0 ]) > render(convexity=30) // <<== comment out > intersection() { > translate([rID/2-2.5,(i ? -1 : +1)*1.3,(i ? 17.5 : 17.5)]) > rotate([90,(i ? 0 : 90),90]) > scale(0.9) > { > linear_extrude(height=15, convexity=30) > text("MH",font="Rockwell",spacing=0.7,halign="center"); > } > difference(){ > cylinder(r=rID/2+rThick,h=rDeep); > translate([0,0,-s]) > cylinder(r=rID/2,h=rDeep+rRoundOffset+s2); // hollow out tube > } > } > } // d > } // recess > > > > > ----- > Admin - PM me if you need anything, or if I've done something stupid... > > Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! > -- > View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Sun, Nov 6, 2016 10:19 PM
Could you describe the error, and how to reproduce it, in more detail?
I’ve tested this on various version (on Mac only so far) without managing to reproduce it..
> On Nov 6, 2016, at 00:07, MichaelAtOz <oz.at.michael@gmail.com> wrote: > > This is a strange one. I'm trying to track down a CGAL error in 2016.10.05 > (&.04) which doesn't happen in 2015.03-2. > Could you describe the error, and how to reproduce it, in more detail? I’ve tested this on various version (on Mac only so far) without managing to reproduce it.. -Marius
Sun, Nov 6, 2016 11:23 PM
At first I had trouble tracking down what I changed, in my .scad, to trigger
it.
I got to something I changed around the text("MH"... bit, I had moved it
around.
But reverting and adjusting wasn't consistent in generating the error.
Which is when I worked out it only happens for a F6 AFTER a F5.
I can reproduce, just by loading the code above, doing F5, then F6. F6 alone
does not error.
(load a fresh instance of the .exe, I had numerous occasions where, after
doing a few, design/flush_caches no-longer caused the message to occur, you
could tell by the F6 being instant, v's taking a bit of time to think before
error-ing)
View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p18973.html
At first I had trouble tracking down what I changed, in my .scad, to trigger it. I got to something I changed around the text("MH"... bit, I had moved it around. But reverting and adjusting wasn't consistent in generating the error. Which is when I worked out it only happens for a F6 AFTER a F5. I can reproduce, just by loading the code above, doing F5, then F6. F6 alone does not error. (load a fresh instance of the .exe, I had numerous occasions where, after doing a few, design/flush_caches no-longer caused the message to occur, you could tell by the F6 being instant, v's taking a bit of time to think before error-ing) ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p18973.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Nov 6, 2016 11:28 PM
Sorry, misunderstood, error is:
ECHO: [2016, 10, 4]
violation! Expr: pe_prev->is_border() ||
!internal::Plane_constructor::get_plane(pe_prev->facet(),pe_prev->facet()->plane()).is_degenerate()
File:
/opt/mxe/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h
Line: 251
Geometries in cache: 10
Geometry cache size in bytes: 151720
CGAL Polyhedrons in cache: 5
CGAL cache size in bytes: 2820112
Total rendering time: 0 hours, 0 minutes, 0 seconds
Simple:        yes
Vertices:      488
Halfedges:    1464
Edges:        732
Halffacets:    492
Facets:        246
Volumes:        2
Rendering finished.
Reproduced as mentioned above.
View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p18974.html
Sorry, misunderstood, error is: Compiling design (CSG Tree generation)... ECHO: [2016, 10, 4] Rendering Polygon Mesh using CGAL... ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion violation! Expr: pe_prev->is_border() || !internal::Plane_constructor::get_plane(pe_prev->facet(),pe_prev->facet()->plane()).is_degenerate() File: /opt/mxe/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h Line: 251 Geometries in cache: 10 Geometry cache size in bytes: 151720 CGAL Polyhedrons in cache: 5 CGAL cache size in bytes: 2820112 Total rendering time: 0 hours, 0 minutes, 0 seconds Top level object is a 3D object: Simple: yes Vertices: 488 Halfedges: 1464 Edges: 732 Halffacets: 492 Facets: 246 Volumes: 2 Rendering finished. Reproduced as mentioned above. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p18974.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Nov 6, 2016 11:56 PM
I suppose what I'm reporting here is the render() seems to be the cause of
the F5 first F6 error bit.
As just F6 does not error, and the 3d object is correct, I'm assuming the
exact CGAL error is spurious. ??
View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p18976.html
I suppose what I'm reporting here is the render() seems to be the cause of the F5 first F6 error bit. As just F6 does not error, and the 3d object is correct, I'm assuming the exact CGAL error is spurious. ?? ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p18976.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Nov 7, 2016 1:19 AM
This sort of stuff can happen:
o When doing F5 and we encounter geometry without any CSG ops (i.e. just geometry + transformations), we calculate and cache the transformed object by applying the transformation ourselves (i.e. without CGAL).
o When we subsequently do an F6, this cached object is used.
o However, if doing F6 from the start, CGAL is used all the way.
This is not optimal and we should probably manage that sort of caching in a better way.
I belive we have an issue for this somewhere but I cannot find it atm…
I’ll try to reproduce the problem under Windows..
> On Nov 6, 2016, at 18:56, MichaelAtOz <oz.at.michael@gmail.com> wrote: > > I suppose what I'm reporting here is the render() seems to be the cause of > the F5 first F6 error bit. > This sort of stuff can happen: o When doing F5 and we encounter geometry without any CSG ops (i.e. just geometry + transformations), we calculate and cache the transformed object by applying the transformation ourselves (i.e. without CGAL). o When we subsequently do an F6, this cached object is used. o However, if doing F6 from the start, CGAL is used all the way. This is not optimal and we should probably manage that sort of caching in a better way. I belive we have an issue for this somewhere but I cannot find it atm… I’ll try to reproduce the problem under Windows.. -Marius
JL
Jean-Paul Louis
Mon, Nov 7, 2016 2:46 AM
When I try the code, I get after F5:
Saved backup file: /Users/jean-paullouis/Documents/OpenSCAD/backups/unsaved-backup-xJL31134.scad
ECHO: [2016, 10, 16]
Geometries in cache: 9
Geometry cache size in bytes: 117552
CGAL Polyhedrons in cache: 2
CGAL cache size in bytes: 848032
Normalized CSG tree has 3 elements
Compile and preview finished.
Total rendering time: 0 hours, 0 minutes, 1 seconds
After F6, I get:
Geometry cache size in bytes: 137864
CGAL cache size in bytes: 3361744
Simple:        yes
Vertices:      660
Halfedges:    2080
Edges:        1040
Halffacets:    764
Facets:        382
Volumes:        2
Rendering finished.
No problem at all. Must be platform dependent.
Jean-Paul
N1JPL
echo(version());
$fa=0.05;
$fs=1;
s=0.1;
s2=s*2;
!recessOrig(i=1);
rOD=40.25;
rID=36.3;
rThick=2.3;
rDeep=38;
rRoundOffset=6;
translate([0,0,-s])
} // d
} // u
scale(0.9)
translate([0,0,-s])
} // d
} // recess
When I try the code, I get after F5: Saved backup file: /Users/jean-paullouis/Documents/OpenSCAD/backups/unsaved-backup-xJL31134.scad Compiling design (CSG Tree generation)... ECHO: [2016, 10, 16] Compiling design (CSG Products generation)... Geometries in cache: 9 Geometry cache size in bytes: 117552 CGAL Polyhedrons in cache: 2 CGAL cache size in bytes: 848032 Compiling design (CSG Products normalization)... Normalized CSG tree has 3 elements Compile and preview finished. Total rendering time: 0 hours, 0 minutes, 1 seconds After F6, I get: Saved backup file: /Users/jean-paullouis/Documents/OpenSCAD/backups/unsaved-backup-xJL31134.scad Compiling design (CSG Tree generation)... ECHO: [2016, 10, 16] Rendering Polygon Mesh using CGAL... Geometries in cache: 10 Geometry cache size in bytes: 137864 CGAL Polyhedrons in cache: 5 CGAL cache size in bytes: 3361744 Total rendering time: 0 hours, 0 minutes, 0 seconds Top level object is a 3D object: Simple: yes Vertices: 660 Halfedges: 2080 Edges: 1040 Halffacets: 764 Facets: 382 Volumes: 2 Rendering finished. No problem at all. Must be platform dependent. Jean-Paul N1JPL > On Nov 6, 2016, at 12:07 AM, MichaelAtOz <oz.at.michael@gmail.com> wrote: > > This is a strange one. I'm trying to track down a CGAL error in 2016.10.05 > (&.04) which doesn't happen in 2015.03-2. > > However it appeared to be intermittent. > As you know GCAL error do not repeat as they are cached. So using > Design/Flush_Caches is needed to reproduce. > > I happens after a clean start, then F5 then F6. > > It only happens with a F6 AFTER an F5! > > Noting that there is use of render() which does CGAL calls on F5, comment > out this and there is no error. > > > ----------------------code------------------- > > echo(version()); > $fa=0.05; > $fs=1; > s=0.1; > s2=s*2; > > !recessOrig(i=1); > > rOD=40.25; > rID=36.3; > rThick=2.3; > rDeep=38; > rRoundOffset=6; > > module recessOrig(i=0,logo=true) { // i inverted > difference() { > union() { > difference() { > cylinder(r=rID/2+rThick,h=rDeep); // main tube > // - > translate([0,0,-s]) > cylinder(r=rID/2,h=rDeep+rRoundOffset+s2); // hollow out tube > } // d > } // u > // - > translate([rThick-0.5,0,0 ]) > render(convexity=30) // <<== comment out > intersection() { > translate([rID/2-2.5,(i ? -1 : +1)*1.3,(i ? 17.5 : 17.5)]) > rotate([90,(i ? 0 : 90),90]) > scale(0.9) > { > linear_extrude(height=15, convexity=30) > text("MH",font="Rockwell",spacing=0.7,halign="center"); > } > difference(){ > cylinder(r=rID/2+rThick,h=rDeep); > translate([0,0,-s]) > cylinder(r=rID/2,h=rDeep+rRoundOffset+s2); // hollow out tube > } > } > } // d > } // recess > > > > > ----- > Admin - PM me if you need anything, or if I've done something stupid... > > Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! > -- > View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Tue, Nov 8, 2016 2:29 AM
I’ve tried to reproduce this without success on 32-bit Windows (I don’t have a 64-bit Windows lying around..)
I need some help - could someone:
  1. Verify that this issue only happens using the 64-bit Windows binaries?
  2. Post a Help->Library Info dump from a failing version of OpenSCAD?
I’ve tried to reproduce this without success on 32-bit Windows (I don’t have a 64-bit Windows lying around..) I need some help - could someone: 1) Verify that this issue only happens using the 64-bit Windows binaries? 2) Post a Help->Library Info dump from a failing version of OpenSCAD? -Marius
