Hmm, CGAL error only after F5/F6 sequence.
Tue, Nov 8, 2016 8:49 AM
I have 64 bit Win 7. I don't get the error with the version I am using at
the moment: 2015.05.16 (git e673fff). What version do you want me to test?
On 8 November 2016 at 02:29, Marius Kintel marius@kintel.net wrote:
I’ve tried to reproduce this without success on 32-bit Windows (I don’t
have a 64-bit Windows lying around..)
I need some help - could someone:
  1. Verify that this issue only happens using the 64-bit Windows binaries?
  2. Post a Help->Library Info dump from a failing version of OpenSCAD?
I have 64 bit Win 7. I don't get the error with the version I am using at the moment: 2015.05.16 (git e673fff). What version do you want me to test? On 8 November 2016 at 02:29, Marius Kintel <marius@kintel.net> wrote: > I’ve tried to reproduce this without success on 32-bit Windows (I don’t > have a 64-bit Windows lying around..) > I need some help - could someone: > > 1) Verify that this issue only happens using the 64-bit Windows binaries? > 2) Post a Help->Library Info dump from a failing version of OpenSCAD? > > -Marius > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Tue, Nov 8, 2016 10:33 AM
  1. standby
OpenSCAD Version: 2016.10.04 (git 7e0935d)
System information: Windows 7 SP1 (v6.1.1.0) 2 CPUs 3.75 GB RAM
Compiler: GCC "4.9.4" 64bit
Boost version: 1_60
Eigen version: 3.2.5
CGAL version, kernels: 4.6.3, Cartesian, Extended_cartesian, Epeck
OpenCSG version: OpenCSG 1.4.2
Qt version: 5.7.0
QScintilla version: 2.8.4
MingW build: MingW64
GLib version: 2.44.1
Application Path: C:/Program Files/openscad-2016.10.04
Documents Path: C:\Users\MeB\Documents
Resource Path: C:/Program Files/openscad-2016.10.04
User Library Path: C:/Users/MeB/Documents/OpenSCAD/libraries
User Config Path: C:\Users\MeB\AppData\Local/OpenSCAD
Backup Path: C:/Users/MeB/Documents/OpenSCAD/backups
OPENSCADPATH: C:\Users\MeB\Documents\3D-REPRAP\OpenSCAD\OpenSCAD
Libraries;C:\Users;C:\test;C:\test2
OpenSCAD library path:
C:\Users\MeB\Documents\3D-REPRAP\OpenSCAD\OpenSCAD Libraries
C:\Users
C:\test
C:\test2
C:/Program Files/openscad-2016.10.04\libraries
OPENSCAD_FONT_PATH:
OpenSCAD font path:
C:/Windows/fonts
C:/Users/MeB/.local/share/fonts
C:/Users/MeB/.fonts
GLEW version: 1.12.0
OpenGL Version: 3.3.0
GL Renderer: ION/integrated/SSE2
GL Vendor: NVIDIA Corporation
RGBA(8888), depth(24), stencil(8)
GL_ARB_framebuffer_object: yes
GL_EXT_framebuffer_object: yes
GL_EXT_packed_depth_stencil: yes
Qt graphics widget: QGLWidgetGL Extensions:
GL_ARB_ES2_compatibility
GL_ARB_ES3_compatibility
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_clear_buffer_object
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_instanced
GL_ARB_enhanced_layouts
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_bind
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_robust_buffer_access_behavior
GL_ARB_robustness
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_separate_shader_objects
GL_ARB_shader_bit_encoding
GL_ARB_shader_objects
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_include
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_mirror_clamp_to_edge
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_stencil8
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_10f_11f_11f_rev
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXTX_framebuffer_mixed_formats
GL_EXT_Cg_shader
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_multisample_blit_scaled
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_import_sync_object
GL_EXT_multi_draw_arrays
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_shader_objects
GL_EXT_separate_specular_color
GL_EXT_shader_integer_mix
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shared_exponent
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_transform_feedback2
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KHR_debug
GL_KTX_buffer_region
GL_NVX_conditional_render
GL_NVX_gpu_memory_info
GL_NV_ES1_1_compatibility
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_depth_buffer_float
GL_NV_depth_clamp
GL_NV_explicit_multisample
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_fragment_program
GL_NV_fragment_program2
GL_NV_fragment_program_option
GL_NV_framebuffer_multisample_coverage
GL_NV_geometry_shader4
GL_NV_gpu_program4
GL_NV_half_float
GL_NV_light_max_exponent
GL_NV_multisample_coverage
GL_NV_multisample_filter_hint
GL_NV_occlusion_query
GL_NV_packed_depth_stencil
GL_NV_parameter_buffer_object
GL_NV_parameter_buffer_object2
GL_NV_path_rendering
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_primitive_restart
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_shader_buffer_load
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4
GL_NV_texture_expand_normal
GL_NV_texture_multisample
GL_NV_texture_rectangle
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_transform_feedback
GL_NV_transform_feedback2
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_buffer_unified_memory
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_NV_vertex_program2
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_S3_s3tc
GL_SGIS_generate_mipmap
GL_SGIS_texture_lod
GL_SGIX_depth_texture
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_EXT_swap_control
View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19000.html
kintel wrote > 1) Verify that this issue only happens using the 64-bit Windows binaries? > 2) Post a Help->Library Info dump from a failing version of OpenSCAD? 1) standby 2) OpenSCAD Version: 2016.10.04 (git 7e0935d) System information: Windows 7 SP1 (v6.1.1.0) 2 CPUs 3.75 GB RAM Compiler: GCC "4.9.4" 64bit Boost version: 1_60 Eigen version: 3.2.5 CGAL version, kernels: 4.6.3, Cartesian, Extended_cartesian, Epeck OpenCSG version: OpenCSG 1.4.2 Qt version: 5.7.0 QScintilla version: 2.8.4 MingW build: MingW64 GLib version: 2.44.1 Application Path: C:/Program Files/openscad-2016.10.04 Documents Path: C:\Users\MeB\Documents Resource Path: C:/Program Files/openscad-2016.10.04 User Library Path: C:/Users/MeB/Documents/OpenSCAD/libraries User Config Path: C:\Users\MeB\AppData\Local/OpenSCAD Backup Path: C:/Users/MeB/Documents/OpenSCAD/backups OPENSCADPATH: C:\Users\MeB\Documents\3D-REPRAP\OpenSCAD\OpenSCAD Libraries;C:\Users;C:\test;C:\test2 OpenSCAD library path: C:\Users\MeB\Documents\3D-REPRAP\OpenSCAD\OpenSCAD Libraries C:\Users C:\test C:\test2 C:/Users/MeB/Documents/OpenSCAD/libraries C:/Program Files/openscad-2016.10.04\libraries OPENSCAD_FONT_PATH: OpenSCAD font path: C:/Windows/fonts C:/Users/MeB/.local/share/fonts C:/Users/MeB/.fonts GLEW version: 1.12.0 OpenGL Version: 3.3.0 GL Renderer: ION/integrated/SSE2 GL Vendor: NVIDIA Corporation RGBA(8888), depth(24), stencil(8) GL_ARB_framebuffer_object: yes GL_EXT_framebuffer_object: yes GL_EXT_packed_depth_stencil: yes Qt graphics widget: QGLWidgetGL Extensions: GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXTX_framebuffer_mixed_formats GL_EXT_Cg_shader GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_import_sync_object GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NV_ES1_1_compatibility GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program2 GL_NV_fragment_program_option GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_S3_s3tc GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19000.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Nov 8, 2016 10:56 AM
Error with 32 bit 2016.10.04 (F6 after F5)
System information: Windows 7 SP1 (v6.1.1.0) 2 CPUs WOW64 3.75 GB RAM
Compiler: GCC "4.9.4" 32bit
Boost version: 1_60
Qt version: 5.7.0
MingW build: MingW32
Application Path: C:/Program Files (x86)/openscad-2016.10.04-32
Resource Path: C:/Program Files (x86)/openscad-2016.10.04-32
C:\Users
C:\test
C:\test2
C:/Program Files (x86)/openscad-2016.10.04-32\libraries
OPENSCAD_FONT_PATH:
OpenSCAD font path:
C:/Windows/fonts
C:/Users/MeB/.fonts
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_clamp
GL_ARB_draw_buffers
GL_ARB_imaging
GL_ARB_multi_bind
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_point_sprite
GL_ARB_robustness
GL_ARB_shadow
GL_ARB_sync
GL_ARB_texture_rg
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_EXT_Cg_shader
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_minmax
GL_EXT_fog_coord
GL_EXT_gpu_shader4
GL_EXT_packed_float
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_lod
GL_EXT_texture_sRGB
GL_EXT_timer_query
GL_EXT_vertex_array
GL_KHR_debug
GL_NV_blend_square
GL_NV_copy_image
GL_NV_depth_clamp
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_gpu_program4
GL_NV_half_float
GL_NV_point_sprite
GL_S3_s3tc
GL_SGIS_texture_lod
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
http://forum.openscad.org/file/n19001/error_32_bit.jpg
View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19001.html
kintel wrote > 1) Verify that this issue only happens using the 64-bit Windows binaries? Error with 32 bit 2016.10.04 (F6 after F5) OpenSCAD Version: 2016.10.04 (git 7e0935d) System information: Windows 7 SP1 (v6.1.1.0) 2 CPUs WOW64 3.75 GB RAM Compiler: GCC "4.9.4" 32bit Boost version: 1_60 Eigen version: 3.2.5 CGAL version, kernels: 4.6.3, Cartesian, Extended_cartesian, Epeck OpenCSG version: OpenCSG 1.4.2 Qt version: 5.7.0 QScintilla version: 2.8.4 MingW build: MingW32 GLib version: 2.44.1 Application Path: C:/Program Files (x86)/openscad-2016.10.04-32 Documents Path: C:\Users\MeB\Documents Resource Path: C:/Program Files (x86)/openscad-2016.10.04-32 User Library Path: C:/Users/MeB/Documents/OpenSCAD/libraries User Config Path: C:\Users\MeB\AppData\Local/OpenSCAD Backup Path: C:/Users/MeB/Documents/OpenSCAD/backups OPENSCADPATH: C:\Users\MeB\Documents\3D-REPRAP\OpenSCAD\OpenSCAD Libraries;C:\Users;C:\test;C:\test2 OpenSCAD library path: C:\Users\MeB\Documents\3D-REPRAP\OpenSCAD\OpenSCAD Libraries C:\Users C:\test C:\test2 C:/Users/MeB/Documents/OpenSCAD/libraries C:/Program Files (x86)/openscad-2016.10.04-32\libraries OPENSCAD_FONT_PATH: OpenSCAD font path: C:/Windows/fonts C:/Users/MeB/.local/share/fonts C:/Users/MeB/.fonts GLEW version: 1.12.0 OpenGL Version: 3.3.0 GL Renderer: ION/integrated/SSE2 GL Vendor: NVIDIA Corporation RGBA(8888), depth(24), stencil(8) GL_ARB_framebuffer_object: yes GL_EXT_framebuffer_object: yes GL_EXT_packed_depth_stencil: yes Qt graphics widget: QGLWidgetGL Extensions: GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXTX_framebuffer_mixed_formats GL_EXT_Cg_shader GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_import_sync_object GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NV_ES1_1_compatibility GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program2 GL_NV_fragment_program_option GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_S3_s3tc GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control <http://forum.openscad.org/file/n19001/error_32_bit.jpg> ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19001.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Nov 8, 2016 11:54 AM
I don't get it with 2015.08.02, try latest snapshot, 2016.10.04.
View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19002.html
I don't get it with 2015.08.02, try latest snapshot, 2016.10.04. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19002.html Sent from the OpenSCAD mailing list archive at Nabble.com.
N
nophead
Tue, Nov 8, 2016 12:11 PM
Works fine for me.
System information: Windows 7 SP1 (v6.1.1.0) 4 CPUs 7.90 GB RAM
Boost version: 1_60
Qt version: 5.7.0
Application Path:
C:/Users/ChrisP/Downloads/OpenSCAD-2016.10.04-x86-64/openscad-2016.10.04
Documents Path: C:\Users\ChrisP\Documents
Resource Path:
User Library Path: C:/Users/ChrisP/Documents/OpenSCAD/libraries
User Config Path: C:\Users\ChrisP\AppData\Local/OpenSCAD
Backup Path: C:/Users/ChrisP/Documents/OpenSCAD/backups
OPENSCADPATH: D:\chris\projects\repraptor\OpenScadLibs
C:/Users/ChrisP/Downloads/OpenSCAD-2016.10.04-x86-64/openscad-2016.10.04\libraries
OPENSCAD_FONT_PATH:
OpenSCAD font path:
C:/Windows/fonts
C:/Users/ChrisP/.local/share/fonts
C:/Users/ChrisP/.fonts
OpenGL Version: 4.0.0 - Build 9.17.10.2875
GL Renderer: Intel(R) HD Graphics 4000
GL Vendor: Intel
GL_3DFX_texture_compression_FXT1
GL_ARB_copy_buffer
GL_ARB_depth_clamp
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_indirect
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_point_sprite
GL_ARB_sample_shading
GL_ARB_shader_subroutine
GL_ARB_shadow
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_cube_map_array
GL_ARB_texture_gather
GL_ARB_texture_query_lod
GL_ARB_texture_rg
GL_ARB_timer_query
GL_ARB_transform_feedback3
GL_ARB_window_pos
GL_ATI_separate_stencil
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_minmax
GL_EXT_clip_volume_hint
GL_EXT_fog_coord
GL_EXT_packed_float
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_rectangle
GL_EXT_texture_sRGB
GL_EXT_texture_snorm
GL_INTEL_map_texture
GL_INTEL_performance_queries
GL_NV_blend_square
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
GL_SUN_multi_draw_arrays
GL_WIN_swap_hint
WGL_ARB_buffer_region
WGL_ARB_create_context
WGL_ARB_create_context_profile
WGL_ARB_extensions_string
WGL_ARB_framebuffer_sRGB
WGL_ARB_make_current_read
WGL_ARB_multisample
WGL_ARB_pbuffer
WGL_ARB_pixel_format
WGL_ARB_pixel_format_float
WGL_EXT_create_context_es2_profile
WGL_EXT_depth_float
WGL_EXT_extensions_string
WGL_EXT_pixel_format_packed_float
WGL_EXT_swap_control_tear
View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19003.html
Works fine for me. OpenSCAD Version: 2016.10.04 (git 7e0935d) System information: Windows 7 SP1 (v6.1.1.0) 4 CPUs 7.90 GB RAM Compiler: GCC "4.9.4" 64bit Boost version: 1_60 Eigen version: 3.2.5 CGAL version, kernels: 4.6.3, Cartesian, Extended_cartesian, Epeck OpenCSG version: OpenCSG 1.4.2 Qt version: 5.7.0 QScintilla version: 2.8.4 MingW build: MingW64 GLib version: 2.44.1 Application Path: C:/Users/ChrisP/Downloads/OpenSCAD-2016.10.04-x86-64/openscad-2016.10.04 Documents Path: C:\Users\ChrisP\Documents Resource Path: C:/Users/ChrisP/Downloads/OpenSCAD-2016.10.04-x86-64/openscad-2016.10.04 User Library Path: C:/Users/ChrisP/Documents/OpenSCAD/libraries User Config Path: C:\Users\ChrisP\AppData\Local/OpenSCAD Backup Path: C:/Users/ChrisP/Documents/OpenSCAD/backups OPENSCADPATH: D:\chris\projects\repraptor\OpenScadLibs OpenSCAD library path: D:\chris\projects\repraptor\OpenScadLibs C:/Users/ChrisP/Documents/OpenSCAD/libraries C:/Users/ChrisP/Downloads/OpenSCAD-2016.10.04-x86-64/openscad-2016.10.04\libraries OPENSCAD_FONT_PATH: OpenSCAD font path: C:/Windows/fonts C:/Users/ChrisP/.local/share/fonts C:/Users/ChrisP/.fonts GLEW version: 1.12.0 OpenGL Version: 4.0.0 - Build 9.17.10.2875 GL Renderer: Intel(R) HD Graphics 4000 GL Vendor: Intel RGBA(8888), depth(24), stencil(8) GL_ARB_framebuffer_object: yes GL_EXT_framebuffer_object: yes GL_EXT_packed_depth_stencil: yes Qt graphics widget: QGLWidgetGL Extensions: GL_3DFX_texture_compression_FXT1 GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_subroutine GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_window_pos GL_ATI_separate_stencil GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_compression_s3tc GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_transform_feedback GL_IBM_texture_mirrored_repeat GL_INTEL_map_texture GL_INTEL_performance_queries GL_NV_blend_square GL_NV_conditional_render GL_NV_primitive_restart GL_NV_texgen_reflection GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_ARB_buffer_region WGL_ARB_create_context WGL_ARB_create_context_profile WGL_ARB_extensions_string WGL_ARB_framebuffer_sRGB WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_EXT_create_context_es2_profile WGL_EXT_depth_float WGL_EXT_extensions_string WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_EXT_swap_control_tear -- View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19003.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Nov 8, 2016 9:28 PM
nophead wrote
Works fine for me.
You did an F5 then F6, with the code from the OP?
View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19006.html
nophead wrote > Works fine for me. You did an F5 then F6, with the code from the OP? ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19006.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Nov 8, 2016 9:41 PM
Yes, did it twice from a cold start to be sure.
On 8 November 2016 at 21:28, MichaelAtOz oz.at.michael@gmail.com wrote:
nophead wrote
Works fine for me.
Yes, did it twice from a cold start to be sure. On 8 November 2016 at 21:28, MichaelAtOz <oz.at.michael@gmail.com> wrote: > nophead wrote > > Works fine for me. > > You did an F5 then F6, with the code from the OP? > > > > ----- > Admin - PM me if you need anything, or if I've done something stupid... > > Unless specifically shown otherwise above, my contribution is in the > Public Domain; to the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. Obviously > inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ time is running out! > -- > View this message in context: http://forum.openscad.org/Hmm- > CGAL-error-only-after-F5-F6-sequence-tp18954p19006.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Tue, Nov 8, 2016 9:54 PM
kintel wrote
This sort of stuff can happen:
o When doing F5 and we encounter geometry without any CSG ops (i.e. just
geometry + transformations), we calculate and cache the transformed object
by applying the transformation ourselves (i.e. without CGAL).
o When we subsequently do an F6, this cached object is used.
o However, if doing F6 from the start, CGAL is used all the way.
BTW
From the above I thought the 'ourselves' geometry was conflicting in
resolution with the CGAL geometry, so looking at the code the two
difference()'d cylinder pairs are identical, one is outside the render().
First I changed them to a module, called twice, no difference.
Added a render to the above new module, no difference.
Moved render() [the orig one not the above one] just after module
recessOrig(), error no longer occurs. Thus the same 'ourselves' geometry is
used for both, no conflict.
View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19009.html
kintel wrote > This sort of stuff can happen: > o When doing F5 and we encounter geometry without any CSG ops (i.e. just > geometry + transformations), we calculate and cache the transformed object > by applying the transformation ourselves (i.e. without CGAL). > o When we subsequently do an F6, this cached object is used. > o However, if doing F6 from the start, CGAL is used all the way. BTW >From the above I thought the 'ourselves' geometry was conflicting in resolution with the CGAL geometry, so looking at the code the two difference()'d cylinder pairs are identical, one is outside the render(). First I changed them to a module, called twice, no difference. Added a render to the above new module, no difference. Moved render() [the orig one not the above one] just after module recessOrig(), error no longer occurs. Thus the same 'ourselves' geometry is used for both, no conflict. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19009.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Jan 4, 2017 2:13 AM
Another case of this. Code I was trying from another post:
module MyShape() { translate([0,0,30]) sphere(20); translate([0,15,20])
sphere(20); }
minkowski() {
MyShape();
translate([0,0,-100]) cylinder(d=0.001,h=100);
translate([0,0,50]) cube([100,100,100],center=true);
With 2015.03-2 F5 then F6 work.
(Tho there is a display issue with F5, do I recall problems reported about
intersection() preview issues?)
With 2016.11.11 (& .10.04) F6 alone renders OK.
Flush cache, then F5, then F6 gets CGAL error:
violation! Expr: e->incident_sface() != SFace_const_handle() File:
/opt/mxe/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_S2/SM_const_decorator.h
Line: 326
Noting that with the OP error others could not reproduce.
Something changed since 2015.  I feel there are more geometry issues in
OpenSCAD generated STLs (not using imported STLs) with the snapshots.
we calculate and cache the transformed object by applying the
Perhaps that should be a preference option, for those who prefer accuracy
over speed?
View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19909.html
Another case of this. Code I was trying from another post: module MyShape() { translate([0,0,30]) sphere(20); translate([0,15,20]) sphere(20); } intersection() { minkowski() { MyShape(); translate([0,0,-100]) cylinder(d=0.001,h=100); } translate([0,0,50]) cube([100,100,100],center=true); With 2015.03-2 F5 then F6 work. (Tho there is a display issue with F5, do I recall problems reported about intersection() preview issues?) With 2016.11.11 (& .10.04) F6 alone renders OK. Flush cache, then F5, then F6 gets CGAL error: ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion violation! Expr: e->incident_sface() != SFace_const_handle() File: /opt/mxe/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_S2/SM_const_decorator.h Line: 326 Noting that with the OP error others could not reproduce. kintel wrote > This sort of stuff can happen: > o When doing F5 and we encounter geometry without any CSG ops (i.e. just > geometry + transformations), we calculate and cache the transformed object > by applying the transformation ourselves (i.e. without CGAL). > o When we subsequently do an F6, this cached object is used. > o However, if doing F6 from the start, CGAL is used all the way. Something changed since 2015. I feel there are more geometry issues in OpenSCAD generated STLs (*not* using imported STLs) with the snapshots. > we calculate and cache the transformed object by applying the > transformation ourselves (i.e. without CGAL). Perhaps that should be a preference option, for those who prefer accuracy over speed? ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Hmm-CGAL-error-only-after-F5-F6-sequence-tp18954p19909.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Jan 4, 2017 8:25 AM
I can reproduce this one with version 2016.10.04 (git 7e0935d)
sphere(20); }
minkowski() {
MyShape();
Line: 326
object
over speed?
I can reproduce this one with version 2016.10.04 (git 7e0935d) On 4 January 2017 at 02:13, MichaelAtOz <oz.at.michael@gmail.com> wrote: > Another case of this. Code I was trying from another post: > > module MyShape() { translate([0,0,30]) sphere(20); translate([0,15,20]) > sphere(20); } > > intersection() { > minkowski() { > MyShape(); > translate([0,0,-100]) cylinder(d=0.001,h=100); > } > translate([0,0,50]) cube([100,100,100],center=true); > > With 2015.03-2 F5 then F6 work. > (Tho there is a display issue with F5, do I recall problems reported about > intersection() preview issues?) > > With 2016.11.11 (& .10.04) F6 alone renders OK. > Flush cache, then F5, then F6 gets CGAL error: > ERROR: CGAL error in CGAL_Nef_polyhedron3(): CGAL ERROR: assertion > violation! Expr: e->incident_sface() != SFace_const_handle() File: > /opt/mxe/usr/x86_64-w64-mingw32.static/include/CGAL/ > Nef_S2/SM_const_decorator.h > Line: 326 > > Noting that with the OP error others could not reproduce. > > > kintel wrote > > This sort of stuff can happen: > > o When doing F5 and we encounter geometry without any CSG ops (i.e. just > > geometry + transformations), we calculate and cache the transformed > object > > by applying the transformation ourselves (i.e. without CGAL). > > o When we subsequently do an F6, this cached object is used. > > o However, if doing F6 from the start, CGAL is used all the way. > > Something changed since 2015. I feel there are more geometry issues in > OpenSCAD generated STLs (*not* using imported STLs) with the snapshots. > > > we calculate and cache the transformed object by applying the > > transformation ourselves (i.e. without CGAL). > > Perhaps that should be a preference option, for those who prefer accuracy > over speed? > > > > ----- > Admin - PM me if you need anything, or if I've done something stupid... > > Unless specifically shown otherwise above, my contribution is in the > Public Domain; to the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. Obviously > inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ time is running out! > -- > View this message in context: http://forum.openscad.org/Hmm- > CGAL-error-only-after-F5-F6-sequence-tp18954p19909.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
