Hi Maurizio,
This sounds great!!!
For stupid/busy people - how do I install your patch to try it in Linux
and/or Windows please?
Cheers
Alex
-------- Original Message --------
Subject: [OpenSCAD] Abbreviations
Date: Wed, June 08, 2016 9:18 am
I often use the Scite editor, based on the same Scintilla component as
OpenSCAD. As such I am really missing a very good Scite feature:
abbreviations. I implemented (in a rather crude way) abbreviation expansion
for common OpenSCAD constructs. This should allow for really fast coding.
As a bonus I added folding toggle as a keyboard shortcut (CTRL+*, also
added to the edit menu as "Toggle current fold").
*How this works:
Type a single character abbreviation in the editor, for example "c". Then
hit CTRL+B. The typed character has been replaced by "cube([]);". The
cursor is now positioned after the open square bracket for you to enter the
cube's dimensions.
*Full list of abreviations (the | character is not included but shows where
the caret will be positioned):
c cube([|]);
d difference() {\n\t|\n}
f for (i=[|]) {\n\t\n}
i intersection() {\n\t|\n}
m module |() {\n\t\n}
r rotate([|]);
s sphere(r=|);
t translate([|])
u union() {\n\t|\n}
x ,center=true|
y cylinder(r=|,h=);<hr>_______________________________________________
I'm not the best one to reply to this question but I'll do my best.
Basically you should download the source, apply the patch i submitted (via
the patch command) and the compile everything.
The steps for compiling can be found in OpenSCAD README.md file.
Although building for Linux is feasible it is still quite a lengthy process.
The Windows build is quite a nightmare though.
Though, since this little mod seems to have spread some interest you'd
better wait for it to be integrated and the binary be available in the
development snapshots.
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17588.html
The Linux nightly builds are always based on the master branch, so
it would pick it up only when officially included.
I can try to kick off a special Windows build though.
http://files.openscad.org/snapshots/OpenSCAD-2016.06.08-x86-32_abbrev-patch-Installer.exe
http://files.openscad.org/snapshots/OpenSCAD-2016.06.08-x86-32_abbrev-patch.zip
http://files.openscad.org/snapshots/OpenSCAD-2016.06.08-x86-64_abbrev-patch-Installer.exe
http://files.openscad.org/snapshots/OpenSCAD-2016.06.08-x86-64_abbrev-patch.zip
Wooooooooo Hoooooooooooooo!
Thanks!!
Il 08/giu/2016 21:13, "tp3 [via OpenSCAD]" <
[hidden email] http:///user/SendEmail.jtp?type=node&node=17602&i=0
-- Torsten
below:
http://forum.openscad.org/Abbreviations-tp17583p17602.html
To unsubscribe from Abbreviations, click here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=17583&code=bWF1cml6aW8uYnV0dGlAZ21haWwuY29tfDE3NTgzfDE4OTg0NTUyNTk=
NAML
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17603.html
...aaaaaand for completeness, that's the version with the
AutoComplete/CallTip and Template implementation based on
the QScintilla features.
http://files.openscad.org/snapshots/OpenSCAD-2016.06.08-x86-32_issue905-Installer.exe
http://files.openscad.org/snapshots/OpenSCAD-2016.06.08-x86-32_issue905.zip
http://files.openscad.org/snapshots/OpenSCAD-2016.06.08-x86-64_issue905-Installer.exe
http://files.openscad.org/snapshots/OpenSCAD-2016.06.08-x86-64_issue905.zip
The template popup should be triggered by CTRL+Enter
Interesting approach. But I think you should check what's on the left of
the cursor to restrict choices. For example: if there's a 'c' the choices
should only be 'cube' and 'cylinder'; if you find 'cy' you just complete to
'cylinder' with no menu appearing. Most IDEs I've seen work that way.
Scintilla has a very nice 'wordlist completion' based on whatever is in the
document you're editing. That means you can easily complete long
identifiers hitting CTRL+ENTER. I'm thinking about trying to add this
functionality, it might be straightforward but I'm not sure.
On Wed, Jun 8, 2016 at 11:27 PM, tp3 [via OpenSCAD] <
[hidden email] http:///user/SendEmail.jtp?type=node&node=17607&i=0
-- Torsten
below:
http://forum.openscad.org/Abbreviations-tp17583p17607.html
NAML
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17610.html
http://www.thingiverse.com/thing:15363
http://www.thingiverse.com/thing:26537
http://www.thingiverse.com/thing:26853
http://www.thingiverse.com/thing:29505
http://www.thingiverse.com/thing:167899
http://www.thingiverse.com/thing:280319
http://www.thingiverse.com/thing:681028
May relate.
+1 to tp's config file, there are many personal preferences to how to do
this. Personally I like np++'s style.
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17612.html
If you specify
qsci->setAutoCompletionShowSingle(true);
the dropdown menu is not shown when there is a single choice available
On Thu, Jun 9, 2016 at 8:42 AM, maurizio butti maurizio.butti@gmail.com
the document you're editing. That means you can easily complete long
-- Torsten
below:
NAML
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17614.html
I added the "document autocomplete" feature. Basically CTRL+Return triggers
an autocompletion based on the list of words in the document you're editing.
Beware that Return means the key on the alphabetic portion of your
keyboard, not in the numeric keypad.
I'm thinking about moving the abbreviation list to an external file. Can
someone point me in the right direction for choosing a format and location
for the file? I was thinking about a per-user JSON file.
The format might be something like this:
"t" : {
"l" : "translate([",
"r" : "])"
where l and r stand for left and right of cursor
Is it too complicated? Should I stick to the very same format
https://sourceforge.net/p/scintilla/scite/ci/default/tree/src/abbrev.properties
SciTE uses ?
On Thu, Jun 9, 2016 at 1:39 PM, maurizio butti maurizio.butti@gmail.com
If you specify
-- Torsten
below:
NAML
editor-improvement2.patch (4K) http://forum.openscad.org/attachment/17616/0/editor-improvement2.patch
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17616.html
