Von: buttim maurizio.butti@gmail.com
I'm thinking about moving the abbreviation list to an external
file. Can someone point me in the right direction for choosing
a format and location for the file? I was thinking about a
per-user JSON file.
I guess it would be best to follow the logic that already exists
for render and editor color schemes, e.g.:
https://github.com/openscad/openscad/blob/master/src/scintillaeditor.cpp#L400
This allows to read the configuration from an application folder
location as well as overwrite from the user directory.
The format might be something like this:
"t" : {
"l" : "translate([",
"r" : "])"
Using JSON makes sense as the other configs are using this format
too and there's a simple file parser in Boost to read those files.
The l/r looks a bit strange, but it does not really matter much.
How would that handle multi-line cases / indentation? I think JSON
supports escaping like \t and \n, but I did not try that yet.
I think it would be good to merge the features from both solutions
as they do complete each other (like the CallTips are probably
quite useful for people getting started).
Yes, the l/r thing is a bit weird. But the alternatives I see are even
weirder:
Regarding the special characters I'm pretty confident JSON will handle them.
I'll study the code related to the color schemes handling.
Thanks for your help
On Thu, Jun 9, 2016 at 5:37 PM, tp3 [via OpenSCAD] <
ml-node+s1091067n17618h33@n5.nabble.com> wrote:
Von: buttim <[hidden email]
http:///user/SendEmail.jtp?type=node&node=17618&i=0>
per-user JSON file.
"t" : {
"r" : "])"
[hidden email] http:///user/SendEmail.jtp?type=node&node=17618&i=1
-- Torsten
below:
http://forum.openscad.org/Abbreviations-tp17583p17618.html
To unsubscribe from Abbreviations, click here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=17583&code=bWF1cml6aW8uYnV0dGlAZ21haWwuY29tfDE3NTgzfDE4OTg0NTUyNTk=
NAML
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17620.html
Thanks buttim for sharing, thanks Torsten for the release. This is very
handy, i like it.
With CTRL+Alt instead of CTRL+B would be even better. Nevertheless it is
good enough.
I prefer this solution to the pop-up menu. I don't like automatic pop-ups.
jpmendes
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17627.html
I have no clue of how something like CRTL+ALT or a simple TAB should be
handled in code. And everybody seems to have a personal preference on the
ideal shortcut. So I'll stick to CTRL+B, LOL.
Thanks for the encouragement, I hope more editor improvement will come soon.
On Thu, Jun 9, 2016 at 10:32 PM, jpmendes [via OpenSCAD] <
handy, i like it.
good enough.
jpmendes
below:
NAML
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17628.html
I implemented the configurable abbreviation list.
Together with the patch I'm sending you an example file (equivalent to what
was previously hard coded).
The file location follows the same logic as the color schemes cfgs.
The two other features are still present:
CTRL+* to toggle current folding
CTRL+Return to complete the word preceding the cursor
per-user JSON file.
"t" : {
"r" : "])"
-- Torsten
below:
NAML
editor-improvement3.patch (5K) http://forum.openscad.org/attachment/17630/0/editor-improvement3.patch
abbrev.json (640 bytes) http://forum.openscad.org/attachment/17630/1/abbrev.json
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17630.html
Torsten, would you mind sharing the code you used for call tips?
I'm trying to implement them myself but I'm stuck
On Wed, Jun 8, 2016 at 11:27 PM, tp3 [via OpenSCAD] <
ml-node+s1091067n17607h92@n5.nabble.com> wrote:
On 06/08/2016 02:47 PM, Torsten Paul wrote:
I can try to kick off a special Windows build though.
...aaaaaand for completeness, that's the version with the
AutoComplete/CallTip and Template implementation based on
the QScintilla features.
http://files.openscad.org/snapshots/OpenSCAD-2016.06.08-x86-32_issue905-Installer.exe
http://files.openscad.org/snapshots/OpenSCAD-2016.06.08-x86-32_issue905.zip
http://files.openscad.org/snapshots/OpenSCAD-2016.06.08-x86-64_issue905-Installer.exe
http://files.openscad.org/snapshots/OpenSCAD-2016.06.08-x86-64_issue905.zip
The template popup should be triggered by CTRL+Enter
[hidden email] http:///user/SendEmail.jtp?type=node&node=17607&i=0
-- Torsten
below:
http://forum.openscad.org/Abbreviations-tp17583p17607.html
NAML
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17633.html
Sure, this is the autocomplete-2 branch:
https://github.com/openscad/openscad/tree/autocomplete-2
Is that (Ctrl+) the numeric keypad ''? Presumably not Ctrl-Shift-8.
Many keybords today don't have the numeric keypad. But if it will be
configurable then it doesn't matter.
Note, keyboard usage is documented here
https://github.com/openscad/openscad/wiki/Keyboard-Shortcuts
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17641.html
You can use both *. I choose this shortcut because SciTE already uses it
and OpenSCAD has CTRL++ and CTRL+- so it should not sound too exotic to
OpenSCAD users.
It's just a menu shortcut so it won't be configurable (unless the whole
menu system becomes confgurable one day)
On Sat, Jun 11, 2016 at 2:28 AM, MichaelAtOz [via OpenSCAD] <
*Admin - PM me if you need anything, *
or if I've done something stupid...
copyright and related or neighbouring rights to this work.
Obviously inclusion of works of previous authors is not included in the
above.
http://www.ourfairdeal.org/ time is running out!
below:
NAML
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17645.html
Thanks to careful examination of your code I managed to get the call tips
functionality working.
My approach is quite different and leads to a much more compact code (but I
might be missing some features of your version). Basically I used the
already available QsciAPIs class instead of defining my own inherited from
QsciAbstractAPIs.
A good thing about my code is that the templates are configurable (file
scad.api, usual locations).
Another small goodie is the (automatical) highlighting of the current
parameter.
I added a new menu entry (and shortcut) for toggling all folds in the
document, once more SciTE-style.
On Fri, Jun 10, 2016 at 6:47 PM, tp3 [via OpenSCAD] <
[hidden email] http:///user/SendEmail.jtp?type=node&node=17635&i=0
-- Torsten
below:
http://forum.openscad.org/Abbreviations-tp17583p17635.html
NAML
editor-improvement4.patch (7K) http://forum.openscad.org/attachment/17656/0/editor-improvement4.patch
scad.api (168 bytes) http://forum.openscad.org/attachment/17656/1/scad.api
View this message in context: http://forum.openscad.org/Abbreviations-tp17583p17656.html
