Render failure - Marker Felt "j"
G
GaryMcIntyre
Sat, May 29, 2021 1:58 AM
I'm really new at Openscad, and am learning so much thanks to the wiki.
I'v encountered what I think is a bug, but I want to be sure.
When I F5 this code, it works fine, but when I F6, the "j" disappears. It
only seems to be happening with The Marker Felt font, but I've only tried 3
others.
If I remark out the cube, the "j" doesn't disappear.
Thanks!
font="Marker Felt:style=Thin";
fontsize=10;
letter="j";
width=11;
tileheight=1;
        cube ([14,14,1]);
    translate ([0,0,1])
     translate([7,7,5])
        rotate([0,180,0])
               linear_extrude(height=6)
                  translate([0,-4.2,0])text(letter,size=fontsize,
font=font);
I'm really new at Openscad, and am learning so much thanks to the wiki. I'v encountered what I think is a bug, but I want to be sure. When I F5 this code, it works fine, but when I F6, the "j" disappears. It only seems to be happening with The Marker Felt font, but I've only tried 3 others. If I remark out the cube, the "j" doesn't disappear. Thanks! font="Marker Felt:style=Thin"; fontsize=10; letter="j"; width=11; tileheight=1; { cube ([14,14,1]); translate ([0,0,1]) { translate([7,7,5]) rotate([0,180,0]) linear_extrude(height=6) translate([0,-4.2,0])text(letter,size=fontsize, font=font); } } -- Sent from: http://forum.openscad.org/
Gene Heskett
Sat, May 29, 2021 5:07 AM
wiki.
tried 3 others.
Thanks!
fontsize=10;
letter="j";
width=11;
tileheight=1;
         cube ([14,14,1]);
     translate ([0,0,1])
      translate([7,7,5])
         rotate([0,180,0])
font=font);
My best guess and thats all it is, is that you are hiding the j inside
the cube. Reducing the cubes size might make it appear?
Cheers, Gene Heskett
-Ed Howdershelt (Author)
On Friday 28 May 2021 21:58:06 GaryMcIntyre wrote: > I'm really new at Openscad, and am learning so much thanks to the > wiki. > > I'v encountered what I think is a bug, but I want to be sure. > > When I F5 this code, it works fine, but when I F6, the "j" disappears. > It only seems to be happening with The Marker Felt font, but I've only > tried 3 others. > If I remark out the cube, the "j" doesn't disappear. > > Thanks! > > > font="Marker Felt:style=Thin"; > fontsize=10; > letter="j"; > width=11; > tileheight=1; > > > { > cube ([14,14,1]); > translate ([0,0,1]) > { > translate([7,7,5]) > rotate([0,180,0]) > linear_extrude(height=6) > translate([0,-4.2,0])text(letter,size=fontsize, > font=font); > } > } > > My best guess and thats all it is, is that you are hiding the j inside the cube. Reducing the cubes size might make it appear? > > > -- > Sent from: http://forum.openscad.org/ Cheers, Gene Heskett -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Genes Web page <http://geneslinuxbox.net:6309/gene>
Sat, May 29, 2021 7:11 AM
Your code shows up the same with both R5 and F6 here.  What release of
OpenSCAD are you using?
tried 3 others.
Thanks!
fontsize=10;
letter="j";
width=11;
tileheight=1;
            cube ([14,14,1]);
        translate ([0,0,1])
         translate([7,7,5])
            rotate([0,180,0])
Your code shows up the same with both R5 and F6 here.  What release of OpenSCAD are you using? Jon On 5/28/2021 9:58 PM, GaryMcIntyre wrote: > I'm really new at Openscad, and am learning so much thanks to the wiki. > > I'v encountered what I think is a bug, but I want to be sure. > > When I F5 this code, it works fine, but when I F6, the "j" disappears. > It only seems to be happening with The Marker Felt font, but I've only > tried 3 others. > If I remark out the cube, the "j" doesn't disappear. > > Thanks! > > > font="Marker Felt:style=Thin"; > fontsize=10; > letter="j"; > width=11; > tileheight=1; > > >                 { >             cube ([14,14,1]); >         translate ([0,0,1]) >                     { >          translate([7,7,5]) >             rotate([0,180,0]) >                    linear_extrude(height=6) > translate([0,-4.2,0])text(letter,size=fontsize, font=font); >                     } >                 } > > > ------------------------------------------------------------------------ > Sent from the OpenSCAD mailing list archive > <http://forum.openscad.org/> at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Sat, May 29, 2021 7:53 AM
Have you got the same font though? Perhaps the J has a self intersection in
its boundary. If that is the case applying a very small expansion with
offset might fix it as Clipper will sort out 2D self intersections.
others.
Thanks!
fontsize=10;
letter="j";
width=11;
tileheight=1;
         cube ([14,14,1]);
     translate ([0,0,1])
      translate([7,7,5])
         rotate([0,180,0])
font=font);
at Nabble.com.
Have you got the same font though? Perhaps the J has a self intersection in its boundary. If that is the case applying a very small expansion with offset might fix it as Clipper will sort out 2D self intersections. On Sat, 29 May 2021 at 08:11, jon <jon@jonbondy.com> wrote: > Your code shows up the same with both R5 and F6 here. What release of > OpenSCAD are you using? > > Jon > On 5/28/2021 9:58 PM, GaryMcIntyre wrote: > > I'm really new at Openscad, and am learning so much thanks to the wiki. > > I'v encountered what I think is a bug, but I want to be sure. > > When I F5 this code, it works fine, but when I F6, the "j" disappears. It > only seems to be happening with The Marker Felt font, but I've only tried 3 > others. > If I remark out the cube, the "j" doesn't disappear. > > Thanks! > > > font="Marker Felt:style=Thin"; > fontsize=10; > letter="j"; > width=11; > tileheight=1; > > > { > cube ([14,14,1]); > translate ([0,0,1]) > { > translate([7,7,5]) > rotate([0,180,0]) > linear_extrude(height=6) > translate([0,-4.2,0])text(letter,size=fontsize, > font=font); > } > } > > > ------------------------------ > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Terrypin
Sat, May 29, 2021 1:35 PM
Also OK here in OpenSCAD version 2021.01 using Version 20H2 (OS Build
19042.985), and with the random half dozen other fonts I tried.
Also OK here in OpenSCAD version 2021.01 using Version 20H2 (OS Build 19042.985), and with the random half dozen other fonts I tried. -- Sent from: http://forum.openscad.org/
G
GaryMcIntyre
Sat, May 29, 2021 2:52 PM
wiki.
tried 3 others.
Thanks!
fontsize=10;
letter="j";
width=11;
tileheight=1;
         cube ([14,14,1]);
     translate ([0,0,1])
      translate([7,7,5])
         rotate([0,180,0])
font=font);
  • Louis D. Brandeis
discuss-leave@.openscad
Thanks, but I've tried moving the cube far away from the j and it still
disappears.
I haven't had any other letter do this.
Gene Heskett wrote > On Friday 28 May 2021 21:58:06 GaryMcIntyre wrote: > >> I'm really new at Openscad, and am learning so much thanks to the >> wiki. >> >> I'v encountered what I think is a bug, but I want to be sure. >> >> When I F5 this code, it works fine, but when I F6, the "j" disappears. >> It only seems to be happening with The Marker Felt font, but I've only >> tried 3 others. >> If I remark out the cube, the "j" doesn't disappear. >> >> Thanks! >> >> >> font="Marker Felt:style=Thin"; >> fontsize=10; >> letter="j"; >> width=11; >> tileheight=1; >> >> >> { >> cube ([14,14,1]); >> translate ([0,0,1]) >> { >> translate([7,7,5]) >> rotate([0,180,0]) >> linear_extrude(height=6) >> translate([0,-4.2,0])text(letter,size=fontsize, >> font=font); >> } >> } >> >> > My best guess and thats all it is, is that you are hiding the j inside > the cube. Reducing the cubes size might make it appear? >> >> >> -- >> Sent from: http://forum.openscad.org/ > > > Cheers, Gene Heskett > -- > "There are four boxes to be used in defense of liberty: > soap, ballot, jury, and ammo. Please use in that order." > -Ed Howdershelt (Author) > If we desire respect for the law, we must first make the law respectable. > - Louis D. Brandeis > Genes Web page &lt;http://geneslinuxbox.net:6309/gene&gt; > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to > discuss-leave@.openscad Thanks, but I've tried moving the cube far away from the j and it still disappears. I haven't had any other letter do this. -- Sent from: http://forum.openscad.org/
G
GaryMcIntyre
Sat, May 29, 2021 2:54 PM
in
jon@
3
others.
Thanks!
fontsize=10;
letter="j";
width=11;
tileheight=1;
         cube ([14,14,1]);
     translate ([0,0,1])
      translate([7,7,5])
         rotate([0,180,0])
font=font);
at Nabble.com.
That's a mouthful.
I wish I understood what you mean, as I'm willing to try anything.
nophead wrote > Have you got the same font though? Perhaps the J has a self intersection > in > its boundary. If that is the case applying a very small expansion with > offset might fix it as Clipper will sort out 2D self intersections. > > On Sat, 29 May 2021 at 08:11, jon &lt; > jon@ > &gt; wrote: > >> Your code shows up the same with both R5 and F6 here. What release of >> OpenSCAD are you using? >> >> Jon >> On 5/28/2021 9:58 PM, GaryMcIntyre wrote: >> >> I'm really new at Openscad, and am learning so much thanks to the wiki. >> >> I'v encountered what I think is a bug, but I want to be sure. >> >> When I F5 this code, it works fine, but when I F6, the "j" disappears. It >> only seems to be happening with The Marker Felt font, but I've only tried >> 3 >> others. >> If I remark out the cube, the "j" doesn't disappear. >> >> Thanks! >> >> >> font="Marker Felt:style=Thin"; >> fontsize=10; >> letter="j"; >> width=11; >> tileheight=1; >> >> >> { >> cube ([14,14,1]); >> translate ([0,0,1]) >> { >> translate([7,7,5]) >> rotate([0,180,0]) >> linear_extrude(height=6) >> translate([0,-4.2,0])text(letter,size=fontsize, >> font=font); >> } >> } >> >> >> ------------------------------ >> Sent from the OpenSCAD mailing list archive >> &lt;http://forum.openscad.org/&gt; >> at Nabble.com. >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to > discuss-leave@.openscad >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to > discuss-leave@.openscad >> > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to > discuss-leave@.openscad That's a mouthful. I wish I understood what you mean, as I'm willing to try anything. -- Sent from: http://forum.openscad.org/
G
GaryMcIntyre
Sat, May 29, 2021 2:55 PM
tried 3 others.
Thanks!
fontsize=10;
letter="j";
width=11;
tileheight=1;
            cube ([14,14,1]);
        translate ([0,0,1])
         translate([7,7,5])
            rotate([0,180,0])
jon_bondy wrote > Your code shows up the same with both R5 and F6 here.  What release of > OpenSCAD are you using? > > Jon > > On 5/28/2021 9:58 PM, GaryMcIntyre wrote: >> I'm really new at Openscad, and am learning so much thanks to the wiki. >> >> I'v encountered what I think is a bug, but I want to be sure. >> >> When I F5 this code, it works fine, but when I F6, the "j" disappears. >> It only seems to be happening with The Marker Felt font, but I've only >> tried 3 others. >> If I remark out the cube, the "j" doesn't disappear. >> >> Thanks! >> >> >> font="Marker Felt:style=Thin"; >> fontsize=10; >> letter="j"; >> width=11; >> tileheight=1; >> >> >>                 { >>             cube ([14,14,1]); >>         translate ([0,0,1]) >>                     { >>          translate([7,7,5]) >>             rotate([0,180,0]) >>                    linear_extrude(height=6) >> translate([0,-4.2,0])text(letter,size=fontsize, font=font); >>                     } >>                 } >> >> >> ------------------------------------------------------------------------ >> Sent from the OpenSCAD mailing list archive >> &lt;http://forum.openscad.org/&gt; at Nabble.com. >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to > discuss-leave@.openscad > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to > discuss-leave@.openscad <http://forum.openscad.org/file/t3237/Screen_Shot_2021-05-29_at_10.png> -- Sent from: http://forum.openscad.org/
Terrypin
Sat, May 29, 2021 3:16 PM
Perhaps it's exclusively a Mac issue? Hopefully another Mac user might be
along to check that guess.
BTW, I too am a novice and like you I don't understand what nophead meant
Terry
Perhaps it's exclusively a Mac issue? Hopefully another Mac user might be along to check that guess. BTW, I too am a novice and like you I don't understand what nophead meant ;-) Terry -- Sent from: http://forum.openscad.org/
Sat, May 29, 2021 3:33 PM
I meant try something like this:
offset (0.001)
If the J in the font has an outline that self intersects then offset() uses
the Clipper library and that is very good at fixing 2D self intersections.
Terry
at Nabble.com.
I meant try something like this: linear_extrude(height=6) translate([0,-4.2,0]) offset (0.001) text(letter,size=fontsize, font=font); If the J in the font has an outline that self intersects then offset() uses the Clipper library and that is very good at fixing 2D self intersections. On Sat, 29 May 2021 at 16:16, Terrypin <terrypingm@gmail.com> wrote: > Perhaps it's exclusively a Mac issue? Hopefully another Mac user might be > along to check that guess. > > BTW, I too am a novice and like you I don't understand what nophead meant > ;-) > > Terry > ------------------------------ > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
