DC
David Coneff
Wed, Mar 8, 2017 7:47 PM
I am attempting to figure out how to do operations with "large" sets
(>10,000 elements), which presents a couple problems in OpenSCAD that I
believe there is a solution to, but I can't quite figure it out. I posted
earlier about issues with for() being limited to an iteration range of
10,000, looking back this seems like a reasonable limitation since it
points out that you're probably doing something inefficient that should
otherwise be done with list comprehensions or something that is not
stack-intensive.
Example code:
function generate_random_polar(n=5001, r=1)=[for (i=[0:1:n-1]) [r, rands(0,
360,1)[0]]];
function polar_to_xy(r_theta=[1,0]) = [r_theta[0]*cos(r_theta[1]),r_theta[0
]*sin(r_theta[1])];
list1 = concat(generate_random_polar(),generate_random_polar());
list2 = [for (x = list1) polar_to_xy(x)];
Problem 1: Algorithmic generation of a list with greater than 10,000
elements
The only way I've figured out how to do this is simple concatenation of two
more or more smaller lists that are generated by a function call with
<10,000 iterations in the for() loop. For lists of random points, no big
deal. If I was trying to generate a set of ordered points with certain
spaces in a certain canonical order, this could get more complicated to
have to "batch" the function calls. Is there a better way?
Problem 2: Performing actions that require access to the inside of a list
element (e.g., a coordinate pair)
Say I have a list of coordinates (x,y), and that list is greater than
10,000 elements. How would I loop over the entire list and perform an
action such as plotting a cube at that point?, e.g.:
cube_size = 0.01;
for(i = [0:1:len(list2)-1]) {translate([list2[i][0],list2[i][1],0]) cube
(cube_size);}
List comprehensions in OpenSCAD are, from what I understand, limited to
taking a list as input, performing an operation on the individual elements
(and even doing the operation may be conditional depending on the contents
of the element), and returning a list. "Actions" can't be performed such as
translate(); and cube();, but I can perform math on the elements and return
a list of modified elements (e.g., convert from polar to cartesian
coordinates).
List comprehensions seem to be implemented in such a way that they are not
limited to 10,000 element lists (I don't see any errors when I input lists
bigger than that in this example code), so it must have been written in the
back-end to not create a huge stack I assume. I don't mind switching to
this syntax for operations on lists - it is no doubt more efficient - but
on the end of a) creating, and b) doing something with lists that large
after the math is done, there doesn't seem to be a way to do that, since
both would require "action" syntax that I can only get to work in a normal
for() loop. Is there a way around this with a better use of OpenSCAD's
language features that I just don't understand well enough yet, or am I
stuck with batching the for() loop calls to sets with less than 10,000
elements?
Thanks,
David
stack-intensive.
Example code:
360,1)[0]]];
]*sin(r_theta[1])];
elements
cube_size = 0.01;
(cube_size);}
coordinates).
elements?
Thanks,
David
Wed, Mar 8, 2017 9:50 PM
The for loop limit is not really anything to do with stack use, that would
be a recursion limit. I think it is just an arbitrary limit to catch
infinite loops or massive trees of objects that will cause CGAL to explode
in time and or memory use. A list on the other hand is a much smaller data
structure than a CGAL object.
If you have a practical use for such massive trees of objects then perhaps
the limit can be increased. How many do you need and are you going to need
to F6 the result? F5 might be OK but F6 with 10000 objects doesn't seem
practical.
stack-intensive.
Example code:
,360,1)[0]]];
0]*sin(r_theta[1])];
elements
two more or more smaller lists that are generated by a function call with
cube_size = 0.01;
(cube_size);}
coordinates).
elements?
Thanks,
David
practical.
> stack-intensive.
> Example code:
> ,360,1)[0]]];
> elements
> cube_size = 0.01;
> (cube_size);}
> coordinates).
> elements?
> Thanks,
> David
Wed, Mar 8, 2017 10:00 PM
Why not make the limit configurable, with a default of 10,000?
would be a recursion limit. I think it is just an arbitrary limit to
catch infinite loops or massive trees of objects that will cause CGAL
to explode in time and or memory use. A list on the other hand is a
much smaller data structure than a CGAL object.
perhaps the limit can be increased. How many do you need and are you
going to need to F6 the result? F5 might be OK but F6 with 10000
objects doesn't seem practical.
Wed, Mar 8, 2017 10:04 PM
Only any point if there is a practical use for 10000+ objects.
would be a recursion limit. I think it is just an arbitrary limit to catch
perhaps the limit can be increased. How many do you need and are you going
to need to F6 the result? F5 might be OK but F6 with 10000 objects doesn't
seem practical.
> Jon
>> seem practical.
DC
David Coneff
Wed, Mar 8, 2017 10:05 PM
For cases where you have a lot of objects overlapping each other (say you
generate 1000s of cubes lying on the same unit circle), CGAL will sieze up
trying to render maybe the first 1000 objects. In the case of, say, 10000
cubes lying on a unit sphere evenly-spaced grid, CGAL doesn't have as much
of a problem although it does take a while to render. The main issue where
I see things start to lag is when you try to render objects that overlap in
a lot of areas and it has to compute the end result inner surface or
combined outer surface of many objects. So if you are careful about how
much intersection happens (e.g., by creating a wire-frame grid where there
are regular intersections only at the ends of the wires), CGAL can
potentially render a lot more than 10000 objects in one call.
practical.
stack-intensive.
Example code:
0,360,1)[0]]];
]),r_theta[0]*sin(r_theta[1])];
elements
cube_size = 0.01;
(cube_size);}
coordinates).
not limited to 10,000 element lists (I don't see any errors when I input
lists bigger than that in this example code), so it must have been written
in the back-end to not create a huge stack I assume. I don't mind switching
to this syntax for operations on lists - it is no doubt more efficient -
but on the end of a) creating, and b) doing something with lists that large
elements?
Thanks,
David
> practical.
>> stack-intensive.
>> Example code:
>> 0,360,1)[0]]];
>> elements
>> cube_size = 0.01;
>> (cube_size);}
>> coordinates).
>> elements?
>> Thanks,
>> David
Wed, Mar 8, 2017 10:19 PM
The trouble is OpenSCAD doesn't know which scenerio it is. 10000 might be
far too many overlapping objects, or not enough when they don't overlap.
It seems like too blunt a tool, so perhaps the limit should simply go and
the user gets what they deserve.
seem practical.
stack-intensive.
Example code:
(0,360,1)[0]]];
elements
list element (e.g., a coordinate pair)
cube_size = 0.01;
(cube_size);}
coordinates).
elements?
Thanks,
David
>> seem practical.
>>> stack-intensive.
>>> Example code:
>>> (0,360,1)[0]]];
>>> elements
>>> cube_size = 0.01;
>>> (cube_size);}
>>> coordinates).
>>> elements?
>>> Thanks,
>>> David
Wed, Mar 8, 2017 10:54 PM
David,
The main aspect to understand is that there is a for limit just for ranges.
If you don't use range in a for, there is no limit.
p = rands(0,1,1000000); // p is a list of 1000000 elements
for(pi=p){ // there is no range here
if(pi<1e-6) echo(pi=pi);
Or if all your ranges have less than 10000 elements, you will not get an
error message.
// a very long for with ranges
for(i=[0:999], j=[0:999], k=1000*i+j){
if(k<10 || k> 999990) echo(k=k);
The same happens with for in list comprehension:
// short lists filtered from a long lists
q = [for(pi=p) if(pi<1e-6) pi];
s = [for(i=[0:999], j=[0:999], k=1000*i+j) if(k<len(p)-1 && p[k]<1e-6 )
p[k] ];
echo(q=q);
echo(s=s);
David,
error message.
p[k] ];
echo(q=q);
echo(s=s);
Ronaldo
Wed, Mar 8, 2017 11:02 PM
Are you sure of that? As far as I know neither OpenSCAD nor CGAL use
bounding boxes.
View this message in context: http://forum.openscad.org/for-loop-iteration-limitation-list-comprehensions-tp20806p20813.html
Wed, Mar 8, 2017 11:36 PM
for(x = [0:99], y = [0:99])
translate([x * 10, y * 10, 0])
sphere(1);
Takes 1 hour 18 minutes on my system and uses 2.6GB of memory. So perhaps
10K is a bit low, but not much before it would bring my system to its knees
as Windows doesn't handle running out of memory very well.
sphere(1);
> much
> bounding boxes.
DC
David Coneff
Wed, Mar 8, 2017 11:41 PM
Ronaldo,
Thanks for that example, it's exactly what I was looking for. I hadn't seen
that syntax case used in the for() argument before, it looks like that just
knows to go over the entire list in canonical order without having to
specify a range and iteration interval. The more common (0:1:len(list)-1)
is what I see in most other people's code, but this is a really cumbersome
way to do it, and introduces that range limitation on a for() loop
unnecessarily.
As for the unit sphere example, I have some code that can produce that type
of list. From what I have observed in test-case code I've written, it has
nothing to do with bounding box calculations - the CSG rendering does a
quick and dirty render that doesn't complain about intersecting surfaces
because it is also not trying to be precise. CGAL seems to have awareness
of when primitives intersect and tries to produce one solid geometry that
is a simplification of all the intersecting volumes, so if you create
something like the thread of a screw using progressively rotated and
translated rectangular cubes (someone else's library that I played with a
little), then the result is a very slow render because it has to figure out
how many of the vertices of the intersecting volumes are inside the
end-result shape in order to discard them.
I found that creating a thread by first starting with a 2D primitive and
going through a linear_extrusion(rotation) operation was much more
efficient both in CSG and CGAL since it is generating the end-result
vertices in the first place rather than having to do loads of extra 3D
math. I would assume that if you also just limit the number of objects that
intersect in a given region to a small number, the math is probably much
simpler for CGAL as well. I won't know until I have a fully fleshed out
test-framework, I'm fairly close to being there.
Ronaldo,
unnecessarily.
> much
> bounding boxes.
