DC
David Coneff
Wed, Mar 8, 2017 11:47 PM
I have 16 GB of RAM, a 1 TB SSD, and a quad-core i7 in my laptop. The
unfortunate thing about most software is that it is written to keep
programs in check for lower spec systems, but frequently doesn't have the
option to disable those limits or up them when you do have better hardware.
I think it is perfectly reasonable to have a default limit of 10,000 since
not everyone has the setup I do, it'd just be nice to have an option to
change it if I want to do something dumb on purpose :).
On Wed, Mar 8, 2017 at 4:36 PM, nop head nop.head@gmail.com wrote:
for(x = [0:99], y = [0:99])
translate([x * 10, y * 10, 0])
sphere(1);
Takes 1 hour 18 minutes on my system and uses 2.6GB of memory. So perhaps
10K is a bit low, but not much before it would bring my system to its knees
as Windows doesn't handle running out of memory very well.
On 8 March 2017 at 23:02, Ronaldo rcmpersiano@gmail.com wrote:
In the case of, say, 10000
cubes lying on a unit sphere evenly-spaced grid, CGAL doesn't have as
of a problem although it does take a while to render.
> sphere(1);
>> much
>> Are you sure of that? As far as I know neither OpenSCAD nor CGAL use
>> bounding boxes.
>> View this message in context: http://forum.openscad.org/for-
>> loop-iteration-limitation-list-comprehensions-tp20806p20813.html
>> Sent from the OpenSCAD mailing list archive at Nabble.com.
>> Discuss@lists.openscad.org
>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
DC
David Coneff
Wed, Mar 8, 2017 11:48 PM
Actually, just realized 24 GB of RAM. 16 GB is available after I have a
bunch of programs running and a few different OpenSCAD instances.
sphere(1);
>> sphere(1);
>>> much
>>> bounding boxes.
Wed, Mar 8, 2017 11:54 PM
CGAL is extremely slow when there are a large number of non overlapping
facets. It gets even slower if they do overlap but it certainly doesn't
skip the easy cases.
sphere(1);
>> sphere(1);
>>> much
>>> bounding boxes.
DC
David Coneff
Thu, Mar 9, 2017 1:31 AM
I agree it does get slow. Just that it won't necessarily seize up or throw
an error simply because there are a bunch. But that's to be expected for
any model of sufficient complexity.
sphere(1);
perhaps 10K is a bit low, but not much before it would bring my system to
its knees as Windows doesn't handle running out of memory very well.
>>> sphere(1);
>>>> much
>>>> bounding boxes.
Thu, Mar 9, 2017 1:44 AM
I've had some things which rendered in 24+ hours.
(slowed by Windows swapping to SSD)
If someone wants to make some normally unreasonable thing, it is their time
they are potentially wasting.
I think a limit should be an advanced option, AND, it should probably apply
to the other cases Ronald highlighted too.
View this message in context: http://forum.openscad.org/for-loop-iteration-limitation-list-comprehensions-tp20806p20820.html
Thu, Mar 9, 2017 3:01 AM
I see the limit of ranges, lists, whatever as a constraint. It may seem
reasonable to avoid a long unwanted run by a beginner. But it may be a
bottleneck for many serious work. So, David proposal that the limit may be
extended by the user is a sensible one.
It may seem reasonable to extend the guardianship to lists. But a
bi-dimensional matrix of 100x100 has 10000 elements. Should it be
prohibited? I have implemented some f-rep modelling methods in OpenSCAD.
Often that system build tri-dimensional matrices greater than 100x100x100
and build lists of triangles with more than 20000 elements. Any organic
model will have this sort of size. Should all this be forbidden because
this is not the intended application?
OpenSCAD is a powerful tool and should not be restricted to the beginner
that builds models with a handful of cubes. Or it will be no more than a
hammer, and worst, a hammer toy.
DC
David Coneff
Thu, Mar 9, 2017 3:22 AM
That's my general feeling Ronaldo, I started playing with OpenSCAD because
it is open-source and free, has a wide user base in the 3D printing
community, and readily translates models on a computer to valid STL files
that can be printed without much fuss if the appropriate level of detail is
applied to the CGAL render. There's no reason it can't be used for serious
work, it just has a less developed UI than the average piece of commercial
software. For my purposes that is fine since the work I'm doing with is
generative/algorithmic and not stuff that could be done by hand with a
cursor in a well-developed GUI. It's just the minor limitations that I run
into that are occasionally annoying, like this 10,000 element limitation.
It's reasonable to prevent beginners from blowing up the program and
thinking it is unstable on their mediocre computers (it's remarkably solid
for open-source!), and to nudge you in the direction of using more
sophisticated language features where appropriate (e.g., list
comprehensions for purely mathematical stuff), but there are plenty of
situations where that hard-coded limit is just an unnecessary obstacle.
Sometimes you need to be able to use an inefficient script, see if the
concept works, and refactor later.
On Wed, Mar 8, 2017 at 8:01 PM, Ronaldo Persiano rcmpersiano@gmail.com
On Wed, Mar 8, 2017 at 8:01 PM, Ronaldo Persiano <rcmpersiano@gmail.com>
Thu, Mar 9, 2017 3:49 AM
I agree that there are valid workflows outside our hardcoded limits.
Does anyone want to take a shot at refactoring the limit system?
I’d see a few relatively isolated steps:
o Make it configurable (using our config file)
o Make it adjustable using GUI/Preferences
o Detect limit situations and offer helpful dialogs offering users to cancel / ignore limit once / Never ask me again
The primary challenge is that once we start certain operations, we cannot cancel. When we run our own code, this is fixable, but if we hit a non-cancellable entry point to a 3rd party library it gets trickier (e.g. CGAL).
DC
David Coneff
Thu, Mar 9, 2017 4:41 AM
Ronaldo,
Since you knew the for() syntax that bypasses the 10,000 element
limitation, I was wondering if you might also know the solution to this:
Say I have a list of the form:
[[x,y,z],[x2,y2,z2],....]
How would I make a for() loop that performs an action using the (i)-th and
(i+1)th elements? Normally I would use the iterator variable, but the
syntax that bypasses the 10,000 range limit doesn't have "access" to an
iterator variable.
simple example of what I would normally do:
points = [[1,1,1],[2,2,2],[3,3,3]]
for(i = [0:1:len(points-2)]){
translate([points[i][0],points[i+1][1],0])cube(1);
On Wed, Mar 8, 2017 at 3:54 PM, Ronaldo Persiano rcmpersiano@gmail.com
David,
The main aspect to understand is that there is a for limit just for ranges.
If you don't use range in a for, there is no limit.
p = rands(0,1,1000000); // p is a list of 1000000 elements
for(pi=p){ // there is no range here
if(pi<1e-6) echo(pi=pi);
Or if all your ranges have less than 10000 elements, you will not get an
error message.
// a very long for with ranges
for(i=[0:999], j=[0:999], k=1000*i+j){
if(k<10 || k> 999990) echo(k=k);
The same happens with for in list comprehension:
// short lists filtered from a long lists
q = [for(pi=p) if(pi<1e-6) pi];
s = [for(i=[0:999], j=[0:999], k=1000*i+j) if(k<len(p)-1 && p[k]<1e-6 )
p[k] ];
echo(q=q);
echo(s=s);
Ronaldo,
iterator variable.
On Wed, Mar 8, 2017 at 3:54 PM, Ronaldo Persiano <rcmpersiano@gmail.com>
> David,
> error message.
> p[k] ];
> echo(q=q);
> echo(s=s);
Thu, Mar 9, 2017 10:17 AM
I think this a work around that will allow a for loop of 10,000,000
module for_n(n) {
thousands = floor(n / 1000);
remainder = n % 1000;
if(thousands)
for(a = [0 : thousands - 1], b = [0 : 999], $i = a * 1000 + b)
if(remainder)
for(a = [0 : remainder - 1], $i = thousands * 1000 + a)
for_n(1002)
echo($i);
Note that it counts from 0 to n-1
On 9 March 2017 at 04:41, David Coneff david.coneff@gmail.com wrote:
Ronaldo,
iterator variable.
David,
ranges.
error message.
p[k] ];
echo(q=q);
echo(s=s);
module for_n(n) {
if(thousands)
if(remainder)
for_n(1002)
echo($i);
On 9 March 2017 at 04:41, David Coneff <david.coneff@gmail.com> wrote:
> Ronaldo,
> iterator variable.
> wrote:
>> David,
>> ranges.
>> error message.
>> p[k] ];
>> echo(q=q);
>> echo(s=s);
