FH
Father Horton
Sat, Jul 3, 2021 1:03 AM
If what you're after is an arbitrary eight-sided polygon, then you're stuck
with doing a lot of messy trig. If there are regularities in it (e.g., the
figure remains symmetric), there's still trig, but less of it.
Sat, Jul 3, 2021 1:24 AM
Terry,
The Mailing-list Archive is not a Forum, I presume you are referring to it.
To save confusion, call it Empathy. (THE Forum is not dead yet, it's Schrodinger)
I did mention posting via Empathy had limitations. Gmail via web is probably your better option
(with your previously mentioned considerations).
Note that the format of the Empathy post/email is actually stored correctly for posterity,
it is just badly displayed.
But as I've said, things are not likely to get fixed in a hurry,
so for now it is probably not worth noting such things, unless they are critical.
Michael
Sent: Sat, 3 Jul 2021 05:36
Cc: Terry (GMail)
Subject: [OpenSCAD] Re: New and a question
It's odd that my post is accessible in the forum but I haven't yet
received it as an email. Anyway, in the forum somehow the pasted code
has been corrupted (as you see from the accompanying screenshot.
Hopefully the email will be correct.
Terry,
Michael
> -----Original Message-----
> From: Terry [mailto:terrypingm@gmail.com]
> To: OpenSCAD general discussion
> Cc: Terry (GMail)
Sat, Jul 3, 2021 1:33 AM
Well, as the Admin, I suffer for you all and actually get three copies of all your prose,
via different avenues to make sure things are working. (Plus three versions of Digests...)
So if you want to see your Gmail posts, subscribe another email address (#2) and set up
some email rules, either just throw away all the gmails, or remove all #2's emails except your gmails.
Sent: Sat, 3 Jul 2021 06:37
To: Hans L via Discuss
It’s because you use Gmail.
Gmail has a policy that it will never show you an email that it can tell was sent by
yourself.
Makes me crazy when testing groups.
I guess they think it would insult your memory?
David Gustavson
dbg@SCIzzL.com
Hopefully the email will be correct. Here's another paste:
function cartesian(radius,angle)=
[radiuscos(angle),radiussin(angle)];
module triangle(p1,p2,p3) {
polygon([p1,p2,p3]);
module regular_polygon(poly_edges,poly_radius) {
for(n=[0:poly_edges-1]) {
p1 = cartesian(poly_radius,n*360/poly_edges);
p2 = cartesian(poly_radius,(n+1)*360/poly_edges);
triangle([0,0],p1,p2);
// Octagon example
poly_edges = 8;
poly_radius = 20;
poly_height = 3;
linear_extrude(poly_height)
regular_polygon(poly_edges,poly_radius);
> From: David Gustavson [mailto:dbg@SCIzzL.com]
> yourself.
> David Gustavson
> dbg@SCIzzL.com
> > [radius*cos(angle),radius*sin(angle)];
> > // Octagon example
> > poly_edges = 8;
> > poly_radius = 20;
> > poly_height = 3;
> > OpenSCAD mailing list
Sat, Jul 3, 2021 3:28 AM
On Fri, 2021-07-02 at 20:26 +0100, Terry wrote:
I want to make an octagonal shape (8 sides) where I could change
the angle of each corner, so the lengths of the "lines" between
them is not equivalent. How could I do this?
// Octagon example
poly_edges = 8;
poly_radius = 20;
poly_height = 3;
Apart from that not having unequal sides and angles, There is a FAR
easier way to draw a polygonal figure as a regular polygon.
Give this a try:
cylinder(h=3,d=40,$fn=8);
> // Octagon example
> poly_edges = 8;
> poly_radius = 20;
> poly_height = 3;
Give this a try:
Ray West
Sat, Jul 3, 2021 10:08 AM
Sorry, not a clear enough description. Is it a simple or complex
polygon, is concave acceptable? How will you refer to the specific
corners? How will you ensure that all the angles are valid, or are you
just changing one or two, and hoping the rest will sort themselves out,
and whatever the result is, it doesn't matter?. Any 7 random x,y
coordinates can generate an 8 sided polygon. What have you tried? Is a
Mk 1 eyeball good enough, or are you looking for precision, involving
doing some sums? https://www.mathsisfun.com/geometry/octagon.html
On 02/07/2021 15:26, disruptivesolutionsnl@gmail.com wrote:
Hello,
I am new to his forum/mailing list, so thank you for having me!
I want to make an octagonal shape (8 sides) where I could change the
angle of each corner, so the lengths of the “lines” between them is
I hope my question is clear enough without presenting an example picture.
With kind regards,
Ben
> Hello,
> With kind regards,
> Ben
Terry
Sat, Jul 3, 2021 10:14 AM
Hardly 'critical' but the corruption of code in Empathy was serious
enough to get a warning mention IMO.
I see it occurs again in Revar's post. Empathy clearly doesn't like the
asterisk symbol. Sometimes treating it as a signal to switch on italics.
Who knows what other symbols are wrongly handled?
Original:
let(ang=a+bsmall_ang)
r[cos(ang), sin(ang)]
Empathy corruption:
So using its impressively large archive to search and use helpful code
from years before I became a subscriber is no longer sensible.
Terry
On Sat, 3 Jul 2021 11:24:40 +1000, you wrote:
Terry,
Michael
Cc: Terry (GMail)
Original:
let(ang=a+b*small_ang)
r*[cos(ang), sin(ang)]
Empathy corruption:
Terry
>Terry,
>Michael
>> Cc: Terry (GMail)
Terry
Sat, Jul 3, 2021 10:37 AM
That particular book was John Craig's "OpenSCAD Cookbook".
I didn't interpret Ben's "... where I could change the angle of each
corner, so the lengths of the 'lines' between them is not equivalent,"
as you seem to have done. I assumed the lines between the corners could
vary in length, as Ben said, but not the RADII too. But until we hear
back from Ben, I guess we won't know. ;-)
In my post I was also careful to add: "Although it's not a close match,
with a revised function it might be a start."
Terry
On Sat, 3 Jul 2021 10:49:09 +1000, you wrote:
Sent: Sat, 3 Jul 2021 05:26
I'm newish here too, and an OS novice, but one of the books I've bought
has some examples
Terry,
Firstly we do not use OS as an abbreviation for OpenSCAD it gets confused for Operating System,
which is a more common term. What version of the OS are you running?
So what books??
BTW, people have missed the subtlety of the original request; different angles/lengths.
I want to make an octagonal shape (8 sides) where I could change the angle
of each corner, so the lengths of the "lines" between them is not
Terry
>> has some examples
>Terry,
>So what books??
Terry
Sat, Jul 3, 2021 2:10 PM
I posted a reply at 11:14 and it promptly appeared in Empathy. (Actually
an hour before, according to the time stamp!) But nearly five hours
later I've still have not received it in my mail (nor another reply
posted at 11:37).
I'll try again. Here's a copy/paste from my Sent folder
Original:
Empathy corruption:
Terry
Terry,
Michael
Cc: Terry (GMail)
posted at 11:37).
Original:
Empathy corruption:
Terry
>Terry,
>Michael
>> Cc: Terry (GMail)
Sat, Jul 3, 2021 2:21 PM
I received your previous email "From: Terry terrypingm@gmail.com"
As previously explained gmail does not send emails from you to you.
Please do not report anything further re Empathy.
It is no longer supported. It is available for people to use as a convenience.
Sent: Sun, 4 Jul 2021 00:11
posted at 11:37).
Original:
Empathy corruption:
Terry
Terry,
Michael
Cc: Terry (GMail)
I received your previous email "From: Terry <terrypingm@gmail.com>"
> posted at 11:37).
> Original:
> Empathy corruption:
> Terry
> >Terry,
> option
> posterity,
> >Michael
> >> Cc: Terry (GMail)
Terry
Sat, Jul 3, 2021 2:29 PM
Posted this at 11:37, promptly appeared in Empathy (at 10:37!) but five
hours later still not received the email. This is not an initiating
first post, but a reply, so not subject to the Gmail 'feature' already
discussed. I DID get the 'Discuss post acknowledgment'. I am getting
other emails to my gmail ID. So most likely culprit appears to be some
setting or filter in my email client (Forte's Agent). I'll focus on that
but would welcome any other ideas.
Anyway, I'll try again, but not optimistic.
Terry
has some examples
Terry,
So what books??
Terry
>> has some examples
>Terry,
>So what books??
