AC
A. Craig West
Fri, Apr 9, 2021 12:13 PM
I should note that it might be more efficient to build this as a
polyhedron, but the hull solution works pretty well in this example
On Fri, Apr 9, 2021 at 8:10 AM A. Craig West acraigwest@gmail.com wrote:
Try this, it is more likely to get the results you need (all of those
spheres and cylinders of matching radius and position are far too likely to
cause degenerate polygons of various types)
// sm=0.000000
$fn=30;
pts = [
[0.000000,0,10.593750],
[0.000000,0,10.406250],
[-0.003906,0,10.199219],
[-0.011719,0,9.972656],
[-0.023438,0,9.726562],
[-0.039062,0,9.460938],
[-0.058594,0,9.175781],
[-0.082031,0,8.871094],
[-0.109375,0,8.546875],
[-0.140625,0,8.203125],
[-0.175781,0,7.839844],
[-0.214844,0,7.457031],
[-0.257812,0,7.054688],
[-0.304688,0,6.632812],
[-0.355469,0,6.191406],
[-0.410156,0,5.730469],
[-0.468750,0,5.250000],
[-0.531250,0,4.750000],
[-0.582031,0,4.273438],
[-0.621094,0,3.820312],
[-0.648438,0,3.390625],
[-0.664062,0,2.984375],
[-0.667969,0,2.601562],
[-0.660156,0,2.242188],
[-0.640625,0,1.906250],
[-0.609375,0,1.593750],
[-0.566406,0,1.304688],
[-0.511719,0,1.039062],
[-0.445312,0,0.796875],
[-0.367188,0,0.578125],
[-0.277344,0,0.382812],
[-0.175781,0,0.210938],
[-0.062500,0,0.062500],
[0, 0, 0]
angles = [
[0,180.000000,0],
[0,181.080924,0],
[0,181.974934,0],
[0,182.726311,0],
[0,183.366461,0],
[0,183.918249,0],
[0,184.398705,0],
[0,184.820766,0],
[0,185.194429,0],
[0,185.527540,0],
[0,185.826342,0],
[0,186.095862,0],
[0,186.340192,0],
[0,186.562699,0],
[0,186.766175,0],
[0,186.952957,0],
[0,187.125016,0],
[0,186.082337,0],
[0,184.927110,0],
[0,183.641185,0],
[0,182.202598,0],
[0,180.584631,0],
[0,178.754636,0],
[0,176.672596,0],
[0,174.289407,0],
[0,171.544972,0],
[0,168.366366,0],
[0,164.666715,0],
[0,160.346176,0],
[0,155.297570,0],
[0,149.420773,0],
[0,142.650651,0],
[0,135.000000,0],
[0,135.000000,0]
module section(pts, angles, i, r, t) {
hull() {
translate(pts[i])
rotate(angles[i])
cylinder(r = r, h = t, center = true);
translate(pts[i + 1])
rotate(angles[i + 1])
for (i = [0 : len(pts) - 2])
section(pts, angles, i, 0.2, 0.01);
> // sm=0.000000
> $fn=30;
> pts = [
> [0, 0, 0]
> angles = [
> [0,180.000000,0],
> [0,181.080924,0],
> [0,181.974934,0],
> [0,182.726311,0],
> [0,183.366461,0],
> [0,183.918249,0],
> [0,184.398705,0],
> [0,184.820766,0],
> [0,185.194429,0],
> [0,185.527540,0],
> [0,185.826342,0],
> [0,186.095862,0],
> [0,186.340192,0],
> [0,186.562699,0],
> [0,186.766175,0],
> [0,186.952957,0],
> [0,187.125016,0],
> [0,186.082337,0],
> [0,184.927110,0],
> [0,183.641185,0],
> [0,182.202598,0],
> [0,180.584631,0],
> [0,178.754636,0],
> [0,176.672596,0],
> [0,174.289407,0],
> [0,171.544972,0],
> [0,168.366366,0],
> [0,164.666715,0],
> [0,160.346176,0],
> [0,155.297570,0],
> [0,149.420773,0],
> [0,142.650651,0],
> [0,135.000000,0],
> [0,135.000000,0]
> hull() {
> translate(pts[i])
> rotate(angles[i])
> On Fri, Apr 9, 2021 at 7:21 AM <superaorta@gmail.com> wrote:
>> Scaling the model doesn't appear to fix anything
>> OpenSCAD mailing list
S
Fri, Apr 9, 2021 12:24 PM
That is an extremely nice solution (and also very fast). I'd tried the
opposite using minkowski sum of an extremely thin path and a sphere but that
was horribly slow.
I can also see this will be intrinsically immune to the problems I've had so
far.
Thanks you! that is much appreciated!
// sm=0.000000
$fn=30;
pts = [
[0, 0, 0]
angles = [
[0,180.000000,0],
[0,181.080924,0],
[0,181.974934,0],
[0,182.726311,0],
[0,183.366461,0],
[0,183.918249,0],
[0,184.398705,0],
[0,184.820766,0],
[0,185.194429,0],
[0,185.527540,0],
[0,185.826342,0],
[0,186.095862,0],
[0,186.340192,0],
[0,186.562699,0],
[0,186.766175,0],
[0,186.952957,0],
[0,187.125016,0],
[0,186.082337,0],
[0,184.927110,0],
[0,183.641185,0],
[0,182.202598,0],
[0,180.584631,0],
[0,178.754636,0],
[0,176.672596,0],
[0,174.289407,0],
[0,171.544972,0],
[0,168.366366,0],
[0,164.666715,0],
[0,160.346176,0],
[0,155.297570,0],
[0,149.420773,0],
[0,142.650651,0],
[0,135.000000,0],
[0,135.000000,0]
hull() {
translate(pts[i])
rotate(angles[i])
was horribly slow.
far.
> // sm=0.000000
> $fn=30;
> pts = [
> [0, 0, 0]
> angles = [
> [0,180.000000,0],
> [0,181.080924,0],
> [0,181.974934,0],
> [0,182.726311,0],
> [0,183.366461,0],
> [0,183.918249,0],
> [0,184.398705,0],
> [0,184.820766,0],
> [0,185.194429,0],
> [0,185.527540,0],
> [0,185.826342,0],
> [0,186.095862,0],
> [0,186.340192,0],
> [0,186.562699,0],
> [0,186.766175,0],
> [0,186.952957,0],
> [0,187.125016,0],
> [0,186.082337,0],
> [0,184.927110,0],
> [0,183.641185,0],
> [0,182.202598,0],
> [0,180.584631,0],
> [0,178.754636,0],
> [0,176.672596,0],
> [0,174.289407,0],
> [0,171.544972,0],
> [0,168.366366,0],
> [0,164.666715,0],
> [0,160.346176,0],
> [0,155.297570,0],
> [0,149.420773,0],
> [0,142.650651,0],
> [0,135.000000,0],
> [0,135.000000,0]
> hull() {
> translate(pts[i])
> rotate(angles[i])
AC
A. Craig West
Fri, Apr 9, 2021 12:32 PM
The biggest problem with using this for more general shapes is that it only
works for convex shapes. Luckily yours is a circle, which is as convex as
it gets. If you do need concave shapes, you can usually decompose it into
multiple convex shapes with difference and union
that
was horribly slow.
so
far.
// sm=0.000000
$fn=30;
pts = [
[0, 0, 0]
angles = [
[0,180.000000,0],
[0,181.080924,0],
[0,181.974934,0],
[0,182.726311,0],
[0,183.366461,0],
[0,183.918249,0],
[0,184.398705,0],
[0,184.820766,0],
[0,185.194429,0],
[0,185.527540,0],
[0,185.826342,0],
[0,186.095862,0],
[0,186.340192,0],
[0,186.562699,0],
[0,186.766175,0],
[0,186.952957,0],
[0,187.125016,0],
[0,186.082337,0],
[0,184.927110,0],
[0,183.641185,0],
[0,182.202598,0],
[0,180.584631,0],
[0,178.754636,0],
[0,176.672596,0],
[0,174.289407,0],
[0,171.544972,0],
[0,168.366366,0],
[0,164.666715,0],
[0,160.346176,0],
[0,155.297570,0],
[0,149.420773,0],
[0,142.650651,0],
[0,135.000000,0],
[0,135.000000,0]
hull() {
translate(pts[i])
rotate(angles[i])
> that
> was horribly slow.
> so
> far.
> to
> > // sm=0.000000
> > $fn=30;
> > pts = [
> > [0, 0, 0]
> > angles = [
> > [0,180.000000,0],
> > [0,181.080924,0],
> > [0,181.974934,0],
> > [0,182.726311,0],
> > [0,183.366461,0],
> > [0,183.918249,0],
> > [0,184.398705,0],
> > [0,184.820766,0],
> > [0,185.194429,0],
> > [0,185.527540,0],
> > [0,185.826342,0],
> > [0,186.095862,0],
> > [0,186.340192,0],
> > [0,186.562699,0],
> > [0,186.766175,0],
> > [0,186.952957,0],
> > [0,187.125016,0],
> > [0,186.082337,0],
> > [0,184.927110,0],
> > [0,183.641185,0],
> > [0,182.202598,0],
> > [0,180.584631,0],
> > [0,178.754636,0],
> > [0,176.672596,0],
> > [0,174.289407,0],
> > [0,171.544972,0],
> > [0,168.366366,0],
> > [0,164.666715,0],
> > [0,160.346176,0],
> > [0,155.297570,0],
> > [0,149.420773,0],
> > [0,142.650651,0],
> > [0,135.000000,0],
> > [0,135.000000,0]
> > hull() {
> > translate(pts[i])
> > rotate(angles[i])
Fri, Apr 9, 2021 12:45 PM
I tried the polyhedron approach and 1 copy of the object rendered instantly
and 3 copies of the object rendered in 7s. With the approach below, it took
30s to render one copy of the object and 43s to render 3 copies. Probably
lazy union would help the performance of the hull approach significantly.
The easiest way to use the polyhedron approach is to use a sweep function to
make your polyhedron. The one I used is from the BOSL2 library.
https://github.com/revarbat/BOSL2/wiki/skin.scad#functionmodule-path_sweep
Other libraries such as dotSCAD also supply this capability.
include<BOSL2/std.scad>
$fn=30;
pts = [
path_sweep(circle(r=.2), pts);
to
// sm=0.000000
$fn=30;
pts = [
[0, 0, 0]
angles = [
[0,180.000000,0],
[0,181.080924,0],
[0,181.974934,0],
[0,182.726311,0],
[0,183.366461,0],
[0,183.918249,0],
[0,184.398705,0],
[0,184.820766,0],
[0,185.194429,0],
[0,185.527540,0],
[0,185.826342,0],
[0,186.095862,0],
[0,186.340192,0],
[0,186.562699,0],
[0,186.766175,0],
[0,186.952957,0],
[0,187.125016,0],
[0,186.082337,0],
[0,184.927110,0],
[0,183.641185,0],
[0,182.202598,0],
[0,180.584631,0],
[0,178.754636,0],
[0,176.672596,0],
[0,174.289407,0],
[0,171.544972,0],
[0,168.366366,0],
[0,164.666715,0],
[0,160.346176,0],
[0,155.297570,0],
[0,149.420773,0],
[0,142.650651,0],
[0,135.000000,0],
[0,135.000000,0]
hull() {
translate(pts[i])
rotate(angles[i])
$fn=30;
pts = [
> acraigwest@
>> to
>> // sm=0.000000
>> $fn=30;
>> pts = [
>> [0, 0, 0]
>> angles = [
>> [0,180.000000,0],
>> [0,181.080924,0],
>> [0,181.974934,0],
>> [0,182.726311,0],
>> [0,183.366461,0],
>> [0,183.918249,0],
>> [0,184.398705,0],
>> [0,184.820766,0],
>> [0,185.194429,0],
>> [0,185.527540,0],
>> [0,185.826342,0],
>> [0,186.095862,0],
>> [0,186.340192,0],
>> [0,186.562699,0],
>> [0,186.766175,0],
>> [0,186.952957,0],
>> [0,187.125016,0],
>> [0,186.082337,0],
>> [0,184.927110,0],
>> [0,183.641185,0],
>> [0,182.202598,0],
>> [0,180.584631,0],
>> [0,178.754636,0],
>> [0,176.672596,0],
>> [0,174.289407,0],
>> [0,171.544972,0],
>> [0,168.366366,0],
>> [0,164.666715,0],
>> [0,160.346176,0],
>> [0,155.297570,0],
>> [0,149.420773,0],
>> [0,142.650651,0],
>> [0,135.000000,0],
>> [0,135.000000,0]
>> hull() {
>> translate(pts[i])
>> rotate(angles[i])
> superaorta@
> discuss-leave@.openscad
AC
A. Craig West
Fri, Apr 9, 2021 12:53 PM
I was pretty sure that was the case. I wrote my own functions to do sweep
style functionality based on beziers, for generating the cooling ducts for
Hero Me in recent versions. At the time I had not found BOSL 2, and my
libraries are rather extensive now. I need to look at what is there, and
perhaps add any functionality I have that is not in BOSL2 yet.
It is amazing how difficult it was to properly implement triangularisation
of arbitrary polygons in 2d, I'm pretty sure I could have saved myself a
lot of work. On the other hand, I quite enjoyed it 😁
instantly and 3 copies of the object rendered in 7s. With the approach
below, it took 30s to render one copy of the object and 43s to render 3
copies. Probably lazy union would help the performance of the hull
to make your polyhedron. The one I used is from the BOSL2 library.
$fn=30;
pts = [
On Fri, Apr 9, 2021 at 8:10 AM A. Craig West <[hidden email]
// sm=0.000000
$fn=30;
pts = [
[0, 0, 0]
angles = [
[0,180.000000,0],
[0,181.080924,0],
[0,181.974934,0],
[0,182.726311,0],
[0,183.366461,0],
[0,183.918249,0],
[0,184.398705,0],
[0,184.820766,0],
[0,185.194429,0],
[0,185.527540,0],
[0,185.826342,0],
[0,186.095862,0],
[0,186.340192,0],
[0,186.562699,0],
[0,186.766175,0],
[0,186.952957,0],
[0,187.125016,0],
[0,186.082337,0],
[0,184.927110,0],
[0,183.641185,0],
[0,182.202598,0],
[0,180.584631,0],
[0,178.754636,0],
[0,176.672596,0],
[0,174.289407,0],
[0,171.544972,0],
[0,168.366366,0],
[0,164.666715,0],
[0,160.346176,0],
[0,155.297570,0],
[0,149.420773,0],
[0,142.650651,0],
[0,135.000000,0],
[0,135.000000,0]
hull() {
translate(pts[i])
rotate(angles[i])
On Fri, Apr 9, 2021 at 7:21 AM <[hidden email]
> $fn=30;
> pts = [
> to
> > // sm=0.000000
> > $fn=30;
> > pts = [
> > [0, 0, 0]
> > angles = [
> > [0,180.000000,0],
> > [0,181.080924,0],
> > [0,181.974934,0],
> > [0,182.726311,0],
> > [0,183.366461,0],
> > [0,183.918249,0],
> > [0,184.398705,0],
> > [0,184.820766,0],
> > [0,185.194429,0],
> > [0,185.527540,0],
> > [0,185.826342,0],
> > [0,186.095862,0],
> > [0,186.340192,0],
> > [0,186.562699,0],
> > [0,186.766175,0],
> > [0,186.952957,0],
> > [0,187.125016,0],
> > [0,186.082337,0],
> > [0,184.927110,0],
> > [0,183.641185,0],
> > [0,182.202598,0],
> > [0,180.584631,0],
> > [0,178.754636,0],
> > [0,176.672596,0],
> > [0,174.289407,0],
> > [0,171.544972,0],
> > [0,168.366366,0],
> > [0,164.666715,0],
> > [0,160.346176,0],
> > [0,155.297570,0],
> > [0,149.420773,0],
> > [0,142.650651,0],
> > [0,135.000000,0],
> > [0,135.000000,0]
> > hull() {
> > translate(pts[i])
> > rotate(angles[i])
> <http:///user/SendEmail.jtp?type=email&email=discuss-leave%40.openscad>
> at Nabble.com.
CA
Fri, Apr 9, 2021 1:20 PM
STL enclosed and these highlight the problem:
// preview and render OK
translate([0,10,0])rotate([0,0,90])import("test.stl");
//translate([0,-10,0])rotate([0,0,90])import("test.stl");
//translate([0,0,-20])cylinder(r=12.5,h=10,$fn=120);
// preview OK and render fail
I should also mention I'm using V2019.05
Thanks!
Each of the 3 examples seem to work fine processing the .scad file in
AngelCAD, using the provided test.stl file.
In this process, the STL is automatically repaired using 'polyfix'. It
removes a large number of zero area faces and other issues. It still has
issues after repair, but the import works.
> Thanks!
CA
Fri, Apr 9, 2021 2:04 PM
function to make your polyhedron. The one I used is from the BOSL2
library.
Agreed, sweep is almost always the cleanest and most proper approach for
something like this. Sweep avoids the issues of mismatching sections and
performing a lot of unions, so it is much faster. And as a bonus you
don't have the issues resulting from the unions of slightly mismatching
sections.
https://gist.github.com/arnholm/87ccd342abc8b8bef712791f648b5021
This approach completes in 0.2s
> library.
sections.
S
Fri, Apr 9, 2021 2:12 PM
Folks,
Thanks so much for your help.
I've implemented both the hull() and the sweep() methods and both work but the
sweep is fastest. I'd never seen this library before but it does <exactly>
what I wanted.
One final question: my final model has many (100s) repeats of this simple
shape and, even with the sweep() method the final render is very slow (how
slow I don't know yet but the memory requirements seem sane).
At the moment I'm saving my shape to .stl and then tiling this .stl file.
Perhaps with the sweep() function I should skip this step? Clearly I need to
benchmark both approaches but while I wait for the final render would anyone
care to guess which would be faster?
Thanks!
Folks,
what I wanted.
Thanks!
Fri, Apr 9, 2021 2:31 PM
My guess would be both methods would be about the same because the time is
taken unioning the items together.
On Fri, 9 Apr 2021 at 15:12, superaorta@gmail.com wrote:
Folks,
<exactly>
what I wanted.
to
anyone
Thanks!
On Fri, 9 Apr 2021 at 15:12, <superaorta@gmail.com> wrote:
> Folks,
> the
> <exactly>
> what I wanted.
> to
> anyone
> Thanks!
Fri, Apr 9, 2021 4:03 PM
I can render the one part quickly but rendering the many copies is
proving impossible.
I'm looking for simple ways to divide and conquer the problem.
My approach is to generate the basic part and save to stl (easily
doable and takes a few seconds) and then I generate my array using
import("part.stl").
Somebody who knows more about the geometry processing than I do can
correct me if I'm wrong, but I don't think this approach can help with
the rendering time, even if you get past the CGAL issues.
You say that rendering one of your object is fast, but that rendering
more than one is slow.
The slowness comes from the boolean operations required. Exporting to
STL and importing the STL only saves the time to render the original
object; it doesn't save the time required to do the boolean operations.
Put differently: if it takes insignificant time to render the
individual objects... then they aren't the problem. Once they're
rendered to STL and you re-import the STL, you're in exactly the same
place you would have been, doing expensive boolean operations on pretty
much the same objects.
(Not quite exactly the same objects. STL converts to triangles. That
might actually make it worse, because you can have several times as many
of them as you had facets in the original objects.)
Theoretically you might get something of a win by exporting to STL and
then doing the boolean operations in parallel with multiple invocations
of OpenSCAD. However, because the last boolean operation, which can't
be in parallel, tends to be the most expensive, the win will not be as
big as you'd like.
But I agree with Craig and Adrian: trying to do this by connecting
cylinders and spheres will lead to pain, because you can't get the
facets on the spheres to precisely align with the facets on the
cylinders. A sweep is a better answer.
> proving impossible.
> import("part.stl").
big as you'd like.
