The problem with many copies of an object is that union is slow. Even when
the objects are disjoint, finding that they are disjoint takes a long time
(consider checking all pairs of 100 objects). If you are trying to make a
model of hundreds of these things and they are actually not intersecting (a
model with hundreds of distinct parts) then using lazy union could make it
much faster. (That's an experimental feature in the dev version.) It will
output copies of the parts without checking whether they intersect.
When you make copies of one object the information is cached---OpenSCAD
isn't generating the object anew each time. So importing the part from an
STL will not help. The only thing I can think of that would help would be
constructing your model to be a smaller number of polyhedra. But I can't
comment on how that might be done without more information on your full
model.
sasa wrote
Folks,
Thanks so much for your help.
I've implemented both the hull() and the sweep() methods and both work but
sweep is fastest. I'd never seen this library before but it does
<exactly>
what I wanted.
One final question: my final model has many (100s) repeats of this simple
shape and, even with the sweep() method the final render is very slow (how
slow I don't know yet but the memory requirements seem sane).
At the moment I'm saving my shape to .stl and then tiling this .stl file.
Perhaps with the sweep() function I should skip this step? Clearly I need
to
benchmark both approaches but while I wait for the final render would
anyone
care to guess which would be faster?
Thanks!
discuss-leave@.openscad
I'm sure that willmake things much faster...
What do you mean "make copies" I'm just generating (or loading) 300 identical
versions of the same object...
If you have 300 non-intersecting copies of the same object then lazy union
should work for you. It might also work to make one polyhedron with all 300
objects in it instead of 300 polyhedra. (I haven't tried this.) You still
didn't actually reveal your end goal.
If you're trying to make hair on a sphere or something it's not so easy,
because everything actually intersects.
When I say make copies I mean just what I said: you have the same object in
your model multiple times. Unless the time to compute your model for a
single object is very long, you're not going to gain anything by saving it
to stl and reloading it because the object is only actually calculated or
loaded one time, and then the copying is the same no matter whether you
calculated it or loaded it. (It's also a very ugly method, so I'd say it
better deliver a big advantage if you are going to do it.)
it
will
an
identical
union
300
There are at least two different notions of "lazy union":
One is that OpenSCAD will omit to calculate a union in certain situations
and used to be an experimental feature in the dev snapshots dating back to
2019 or so. I think you can't activate it in the release versions.
The other one was discussed in this forum several times in the last years
and aimed on stuffing the point lists and triangles of a number of objects
known to be non-intersecting into the same polyhedron call. This technique
even allows to bypass a CGAL rendering before STL export, given
a) there are no Boolean operations in the code
b) the whole thing is really a proper manifold - i.e. watertight, no
intersecting edges, no common vertices
My Naca_sweep libary (following Ronaldo's ideas who maintains a similar
library) covers the second case and does a fantastic job in constructing
hundreds of objects within a single polyhedron() call. It has a sweeps()
function that combines the dataset for N ordinary sweep operations into a
single dataset to be stuffed into a single polyhedron call.
As a test case for the problem of the TS I quickly composed a lazy union of
100 objects (curved hairs) built of 180 circles each comprising 30 vertices,
as shown in the picture attached. The run time on my system for F5 was 37s,
for F6 only 34s and the export was a 64MB STL file, containing a proper
manifold (that e.g. can be imported to kisslicer).
If anybody is interested please let me know, as I didn't show the details in
favor of compactness.
http://forum.openscad.org/file/t887/multiobj.png
Here the main library part, which shows a quite simple interface
Yes, the method of making one polyhedron with all the objects in it is easy
enough to execute. I tried it two ways in BOSL2. I can sweep a "region"
which is a shape defined by many polygons, or I can joint together
polyhedron data from multiple polyhedra. If I use sweep directly it is slow
because sweep is not lazy enough---it checks the swept multi-polygon shape
for intersections. But if I sweep the shape and then just make copies and
gather them into one polyhedron, it is snappy: I can make 100 hairs in 3s.
It looks like in your test you didn't use the original point list, but a
different larger list of points. I tried also making the hairs 180 circles
long and my run time stretches to 20s. Render was 21s. Full code with all
details included below.
My presumption is that this isn't what the original poster is actually
trying to do...that his hairs are connected to something, which makes the
problem more difficult.
include<BOSL2/std.scad>
$fn=30;
pts = [
[0.000000,0,10.593750],
[0.000000,0,10.406250],
[-0.003906,0,10.199219],
[-0.011719,0,9.972656],
[-0.023438,0,9.726562],
[-0.039062,0,9.460938],
[-0.058594,0,9.175781],
[-0.082031,0,8.871094],
[-0.109375,0,8.546875],
[-0.140625,0,8.203125],
[-0.175781,0,7.839844],
[-0.214844,0,7.457031],
[-0.257812,0,7.054688],
[-0.304688,0,6.632812],
[-0.355469,0,6.191406],
[-0.410156,0,5.730469],
[-0.468750,0,5.250000],
[-0.531250,0,4.750000],
[-0.582031,0,4.273438],
[-0.621094,0,3.820312],
[-0.648438,0,3.390625],
[-0.664062,0,2.984375],
[-0.667969,0,2.601562],
[-0.660156,0,2.242188],
[-0.640625,0,1.906250],
[-0.609375,0,1.593750],
[-0.566406,0,1.304688],
[-0.511719,0,1.039062],
[-0.445312,0,0.796875],
[-0.367188,0,0.578125],
[-0.277344,0,0.382812],
[-0.175781,0,0.210938],
[-0.062500,0,0.062500],
//pts = [for(i=[1:180]) [sin(i),0,i/18]];
// This method works, but is slow (~2 minutes)
//many_circles = [for(x=[0:9], y=[0:9]) move([x,y],circle(r=.2))];
//path_sweep(many_circles, pts);
// This approach is faster 3.7s
one_hair = path_sweep(circle(r=.2),pts);
many_hairs = vnf_merge([for(x=[0:9], y=[0:9]) move([x,y],one_hair)]);
vnf_polyhedron(many_hairs);
Parkinbot wrote
union
300
technique
of
vertices,
37s,
in
<http://forum.openscad.org/file/t887/multiobj.png>
Well, I didn't want to spend the time to gether the full information about
the hair object from all the posts to be able to show a more adopted
solution, as the TS was a bit vague about how the objects will be situated
in 3D space. And, I don't know, whether the method I showed works out of the
box with BOSL2, since I don't use this lib. But I don't think so.
The method just combines the data of N not necessarily similar skin (or
sweep) operations into a single polyhedron call that is all - no secrets.
When I use your pts-Array (33 vertices) instead of circle() (30 vertices) to
construct the "hair", F5 time is again 37s - no wonder, because the
complexity is about the same. With 200 objects F5 time grows to 1:11
However, to fit into my code setup I had to rotate the "hair" given in pts
function obj() =
let (ci = Rx(90, pts))
[for (i = [0:180])
Tz(i, Tx(40*sin(i), ci))
I attached my lib if you wanna check yourselves or have a look into the
code.
Naca_sweep.scad http://forum.openscad.org/file/t887/Naca_sweep.scad
